Extra-Low Latency 433 MHz Registered Module von Corsair
Ghanja
01.07.2000
1.121
3
Big Cedar Lake
Corsair gab heute die Verfügbarkeit ihrer neuen TwinX1024RE-3500LLPT Module (2 x 512 MB) bekannt. Diese Registered Module (mit ECC-Korrektur) sollen gerade Besitzen von Athlon 64 FX System zugute kommen. Corsair garantiert für diesen Speicher scharfe Settings von 2-3-2-6. Hier die vollständige Pressemitteilung.<ul><i>Fremont, CA, January 27, 2003 &#8211; Corsair Memory, Inc. today announced a new XMS3500 speed grade of their registered XMS series that is intended for Athlon 64 FX users.
The new TwinX1024RE-3500LLPT is the world&#8217;s first 433 MHz registered module kit. This matched pair of 512 MByte modules was developed expressly to give Athlon 64 FX power users greater headroom for overclocking. Until now the memory bus in Athlon 64 FX based systems has been limited to 400 MHz.
These modules are tested and certified to operate at extremely aggressive latency settings (2-3-2-6) to offer optimum performance. These parts all feature Plug-n-Frag&#8482; SPD&#8217;s so the modules boot at the advanced 2-3-2-6 settings with no tweaking. They also come equipped with error correction (ECC) for ultimate reliability and platinum colored heatspreaders for efficient heat dissipation. They are available today through Corsair resellers worldwide.
&#8220;Corsair is already an established leader in both registered memory for the server market and extreme performance unbuffered modules for enthusiasts&#8221;, said Corsair Marketing Director Joe James. &#8220;This product will offer gaming enthusiasts a path to reach new performance peaks with the Athlon 64 FX processor, without the need to tweak latency settings.&#8221;</i></ul>Weitere Information findet man bei <a href="http://www.corsairmemory.com" TARGET="b">Corsair</a>.
Noch kann man offensichtlich DDR1 weitertreiben aber die Riegel dürften schon unter Schmerzen leiden.
Respekt vor der Leistung und Mut, PC3200 wird wohl dennoch das Ende der offiziellen Fahnenstange bleiben.
Freaks und Mutanten hatten sowieso nie Angst sich aussserhalb der Spezifikationen sich aufzuhalten. Da dürfte dieser Speicherriegel wie Manna für OC sein.
MFG Bokill
Hmm ich habe heute gerade die TwinX1024RE-3200LL bestellt, sollen ja auch mit 2-3-2-6 laufen, also sind die neuen also dann für overclocker oder wie, weil normalerweise würde ja auch die von mir bestellten reichen.
Wer's braucht ....
Früher hatten die Leuts einen Fuchsschwanz am Manta und heute überteuerten Ultra High Speed Low Latency Speicher im Rechner und wahrscheinlich auch noch eine solchen Aufkleber auf'm Gehäuse ....
