Download Kodi v18.6 (Leia) Media Center ist verfügbar.
- Ersteller eratte
User-News
Von eratte
Hinweis: Diese "User-News" wurde nicht von der Planet 3DNow! Redaktion veröffentlicht, sondern vom oben genannten Leser, der persönlich für den hier veröffentlichten Inhalt haftet.Homepage
Download
Kodi v18 (Leia) changelog
Forum
Kodi (formerly known as XBMC) is an award-winning free and open source (GPL) software media player and entertainment hub that can be installed on Linux, OSX, Windows, iOS and Android, featuring a 10-foot user interface for use with televisions and remote controls.
Download
Forum
Update auf 18.1 ist raus:
Download
Speed up Player and Playlists operations with JSON-RPC
Define a senseful default value for advanced settings "updateemptytagsinterval"
Revert edge case crash fix that caused DVDs to be not recognised on Mac OS
Remove "dxvaallowhqscaling" advanced setting to prepare for DXVA improvements in v18.2 for Windows
Linux X11: fix usage of required configuration values
Add date to the log records
Don't react on DPI change event on Win10 >= FCU
Fix Android MediaCodec freeze on early disposal of a stream
Flush streamplayers if abort is requested which solves waiting too long (on skipping DVD intros, for example)
Fix ListitemAbsolute and ListItemPosition in GUI engine
Ignore very first "server not reachable" notification for PVR servers
Use extended result codes for SQLite
Fix invalid PTS decoder value which should inprove MPEG2 playback on Android devices
update SSL CA trust store
Handle empty vertex buffers in GUIFontTTFGL which caused a hard crash
Reintroduce setting "Close channel OSD after switching channels" for PVR
Fix thread logging on Android which causes e.g. frozen DVD/Bluray playback
Avoid attempt to load music info for smartplaylists
Fix Top 100 Albums regression
RenderCapture: Only query Occlusion if GL lower 1.5
Check current mode if whitelist doesn't match and take correct action
Check if app intent is valid on Android. This fixes a hard crash when trying to open Kodi again
Fix PVR input stream creation for pvr file items only containing a path and no recording/channel tag.
Fix playing VP9 streams using inputstream addon. It failed because codec extradata is non-existent for this stream codec.
Catch an exception while reading or writing a file
Fix logical "or" operation in GUI engine
Check the system capabilities to support sleep states S1/S2/S3/S4 before reporting them as available
Fix crash in PCSX ReARMed with BIOS
Several Estuary cosmetic fixes
Download
Update auf 18.2 ist raus,
Update auf 18.3 ist raus.
However, since Kodi 18.3 is a bugfix release, we have a boatload of erm... fixes. In fact, too many to mention. Below is a non-exhaustive list of (mostly) usability fixes.
Estuary
Fixed favourites widget not scrolling properly on 16:10 displays
Fixed API button was not reachable with a mouse on Settings window
Fixed Skin Settings window scrollbar focus
Fixed order of TV Show title and Episode title in Video Info dialog
Added Search button to the side menu in the Video and Music windows
Fixed Wall and Infowall views scroll to bottom on certain aspect-ratios
Fixed broken side menu navigation in the Addon Browser window
PVR
Fixed a Group Manager crash when adding a new group
Fixed EPG UI corruption and/or EPG data not showing with newly added channels
Fixed PVR guide window channel data being overwritten
Music
Added support for DTS-HD audio tracks
Fixed wrong album or artist thumb art being picked from scraper results
The remaining fixes are under the hood and range from addressing nasty memory leaks to DVD playback from HTTPS sources, with a couple of crash and burn events in between. A special thanks to all the users that found a bug, took the time to report it and, in some cases, provided a fix.
The full v18.3 changelog can be found in our GitHub milestone. If you want to read back on what was actually changed in v18 itself, you can find the corresponding articles in the blog posts - Kodi 18, Kodi 18.1 and Kodi 18.2.
As usual, Kodi 18.3 availability on Google Play and Microsoft Store may take a few more days. Stay tuned.
Update auf 18.4 ist raus.
Update auf 18.5 ist raus.
Update auf 18.6 ist raus.
And.... here we are again. The latest Kodi release in the 18.x "Leia" cycle, with more (count them!) and better (measure them!) bug fixes for your various delight, delectation, and delirious... discussion?
18.6 is here. More nasty (and not-so-nasty) problems fixed, more bugs squashed, more happiness and love for all. This release is all about backports: where practical, we've brought bug fixes forwards from the forthcoming 19.x release, so you get the benefit sooner rather than later.
As usual, you can find full details of closed pull requests on GitHub, so explore that if you want the details, but the summary would be...
Audio
Fixes around visualisations
Fixes around pause/resume
Fixes around TrueHD crashes
Workaround firmware bug (AMLogic v23) (sidenote: there are many more Android audio fixes that can't be merged into 18.x "Leia" because of old AMLogic workarounds)
Fix to correctly resume audio-only MPEG-TS streams
Correct headphone enumeration (Android)
Build System
Updates for missing includes
Updates for Cmake (Windows)
Updates for device handling and packaging (macOS)
Games
Fixes for launching disc images and .zip files
Fixes for black screen for RGB emulators (Rpi)
Interface/Look-and-feel
Fixes around TextureCache
Fixes for windowing, refresh rate, mode change and others (Android)
Fixes for floating/split keyboard (iOS)
Fix for artist slideshow (Estuary)
Fix media view from addon given content
Playback/Display
Fixed race condition for OnPlaybackStarted
Fixes for MIME type (Android)
Support for DolbyVision streams via addons
Fixes for maximum width and height/vertical-shift (Android)
Fix for scanning in sub-directories
Fix size of EAGL layer on external screen (iOS)
Fix for glTexImage3D (Linux)
Fix for seeking issues
Reset playlist on new file playback
PVR
Fix for multiline episode names
Other/General
Fixed incorrectly formatted region time
Pass JSON serialised path settings to python scrapers
Fix file access on auto-mounted sources
Fix seeking with FileCache lockup
Fix passthrough on USB devices (Android)
Fix crash if profile.xml gets broken
Fix cache forward size on EOF
