Download Process Lasso v12.4.7.20
- Ersteller pipin
- Je nach Gusto
- AMD Ryzen 9 5900X
- ASRock B550
- 2x 16 GB DDR4 3200
- GeForce GTX 1650
- 27 Zoll Acer + 24 Zoll DELL
- Samsung 980 Pro 256 GB
- diverse
- Fractal Design R5
- Logitech Cordless Desktop
- Logitech G502
- Firefox, Vivaldi
- ▼250 MBit ▲40 MBit
pipin hat Process Lasso mit einem neuen Updateeintrag aktualisiert:
Process Lasso v12.0.0.24
Lies den Rest der Aktualisierung…
v12.0.0.24 – Nov 15 2022 – Release Announcement
(1) GUI.WatchdogDialog: Remove warning about overly broad rules
- Support for Power Modes (overlays)
- Switch to CPU Utility %
- Support 3995WX CPU topology
- Other fixes and enhancements
(1) Core: Add log entry type for error restarting process or service by Watchdog
(3) GUI: Add option to disable graph tooltips
(5)...
- Je nach Gusto
- AMD Ryzen 9 5900X
- ASRock B550
- GeForce GTX 1650
- diverse
- Fractal Design R5
- Logitech G502
- Firefox, Vivaldi
Process Lasso v12.0.1.6
v12.0.1.6 – Nov 23 2022
(5) GUI: Fix graph tooltip was vertically clipped with some system font scalings
(3) GUI: Fix tray icon wouldn't properly reflect CPU Utility % values exceeding 100%
(1) GUI: Add product version to user-agent string
- Je nach Gusto
- AMD Ryzen 9 5900X
- ASRock B550
- GeForce GTX 1650
- diverse
- Fractal Design R5
- Logitech G502
- Firefox, Vivaldi
Process Lasso v12.0.2.18
v12.0.2.18 – Jan 3 2023
(1) GUI: Improve control alignment in IdleSaver config dialog
- Minor fixes and enhancements
(3) GUI: Suppress INI parsing error messageboxes from Governor when running as a service
(3) GUI: Show precise error message if Workstation key used on Server Edition
(7) Build: Minor maintenance to build scripts
(7) GUI: Add /activateonly command line parameter to ProcessLasso.exe to perform any deferred license activation from installer, then exit
(7)...
- Je nach Gusto
- AMD Ryzen 9 5900X
- ASRock B550
- GeForce GTX 1650
- diverse
- Fractal Design R5
- Logitech G502
- Firefox, Vivaldi
Process Lasso v12.0.3.16
v12.0.3.16 – Feb 3 2023
(1) Installer: Improve EULA formatting
(1) GUI: Improve German splash screen text
(1) GUI: Show notification when Process Lasso starts with Keep Awake Indefinite still active
(1) GUI/Core: Allow Keep Awake Indefinite setting to persist across reboots
(1) GUI: Add registry option to disable Keep Awake Indefinite from persisting across reboots, HKLM\Software\ProcessLasso:KeepAwakeResetOnReboot (dword bool)
(7) GUI...
- Je nach Gusto
- AMD Ryzen 9 5900X
- ASRock B550
- GeForce GTX 1650
- diverse
- Fractal Design R5
- Logitech G502
- Firefox, Vivaldi
Process Lasso v12.0.4.4
(1) GUI: Fix an issue in shell32.ExtractAssociatedIcon call that could cause a crash when processes are running from remote paths
(1) GUI: Translation updates
(1) All: Renewed code signing certificate
- Je nach Gusto
- AMD Ryzen 9 5900X
- ASRock B550
- GeForce GTX 1650
- diverse
- Fractal Design R5
- Logitech G502
- Firefox, Vivaldi
Process Lasso v12.1.0 BETA
v12.1.0 BETA - March 2, 2023
(7) GUI: [beta2beta] Refinement of prior
(5) GUI: Fix an issue in Watchdog dialog where added rules could disappear under certain scenarios
(1) GUI: Prohibit automated update (if enabled) when device is in fullscreen mode, fallback to notification
- Je nach Gusto
- AMD Ryzen 9 5900X
- ASRock B550
- GeForce GTX 1650
- diverse
- Fractal Design R5
- Logitech G502
- Firefox, Vivaldi
Process Lasso v12.1.0.26
v12.1.0.26 – Apr 3 2023
(1) GUI: Prohibit automated update when device is in fullscreen mode, and fallback to notification
- Add new copy-to-clipboard process context menu actions
(9) GUI: Make CPU Sets feature free in beta builds
(15) GUI.ProcessContextMenu: Change case of 'Select CPU Affinity'
(15) GUI.ProcessContextMenu: Reorder 'More'...
- Je nach Gusto
- AMD Ryzen 9 5900X
- ASRock B550
- GeForce GTX 1650
- diverse
- Fractal Design R5
- Logitech G502
- Firefox, Vivaldi
Process Lasso v12.1.1 BETA
(11) GUI.SysTimerRes: [beta2beta] Temporarily disable then repopulate the resolution edit control after 'Default' button pressed, to give Governor time to undo any previous persisted change
(9) GUI.SysTimerRes: [beta2beta] Enforce persisted timer resolution in Governor, emit log entry
(9) GUI.SysTimerRes: [beta2beta] Move persisted timer resolution setting to INI file
(9) GUI.SysTimerRes: [beta2beta] Make 'Default' button behavior more consistent
(9) GUI.SysTimerRes: [beta2beta] Set value...
- Je nach Gusto
- AMD Ryzen 9 5900X
- ASRock B550
- GeForce GTX 1650
- diverse
- Fractal Design R5
- Logitech G502
- Firefox, Vivaldi
Process Lasso v12.2.0.16
v12.2.0.16 – May 23 2023
(3) GUI: Add tool to set and persist System Timer Resolution up to 0.5ms, at 'Tools / System Timer Resolution'
- Add tool to change and persist System Timer Resolution
(13) GUI: When IdleSaver default timeout filled in config dialog, use minutes if evenly divisible
(13) GUI: When IdleSaver enabled for the first time via tray menu, inducing the config dialog, don't enable if dialog is aborted
(13) GUI: When...
- Je nach Gusto
- AMD Ryzen 9 5900X
- ASRock B550
- GeForce GTX 1650
- diverse
- Fractal Design R5
- Logitech G502
- Firefox, Vivaldi
Process Lasso v12.3.0 BETA
Process Lasso v12.3.0 BETA:
+ Add Efficiency Mode rules (persisted per-process Efficiency Mode)
(9) GUI: [beta2beta] Fix to 'Options / Power / Start with...' submenu
(9) GUI: Functional improvements to ProBalance advanced options dialog regarding dynamically enabled/disabled suboptions
(9) GUI: [beta2beta] Finish addition of 'Use Efficiency Mode' to ProBalance advanced options dialog
(9) GUI: [beta2beta] Disable EFficiency Mode menu items on unsupported platforms (less than Win11)
(7)...
- Je nach Gusto
- AMD Ryzen 9 5900X
- ASRock B550
- GeForce GTX 1650
- diverse
- Fractal Design R5
- Logitech G502
- Firefox, Vivaldi
Process Lasso v12.3.1 BETA
(1) GUI: Add new variable to Watchdog launch action, %5 for session ID (or use %sessionid%)
P3D-Bot
Bot von P3D
P3D-Bot hat Process Lasso mit einem neuen Updateeintrag aktualisiert:
Process Lasso v12.3.1.20
(3) GUI: Rename process context menu item 'Application Power Profile' to 'Power Profile'
(5) Installer: On new install, ensure config file is initialized prior to Governor start, eliminating an inconsequential load error log entry
(7) GUI: If Governor service is disabled, reenable it automatically when user tries to start it
(9) Insights: Fix sort...
P3D-Bot
Bot von P3D
Process Lasso v12.3.2.20
v12.3.2.20 – Sept 1 2023
(1) GUI: Fix manual power profile switch while using a 'start with' (base) power profile proceeds despite message that it can't
- Tie idle priority class to Efficiency Mode to match Task Manager’s behavior
- Fix an issue where cores could incorrectly show as parked on Intel 12th+
(also impacts Task Manager and Resource Monitor)- Minor fixes and enhancements
(1) Core: Remove special handling of audiodg.exe when 'Ignore problematic...
P3D-Bot
Bot von P3D
Process Lasso v12.4.0 Beta
(15) GUI/Core: [beta2beta] Move CPU affinity delay setting to per-rule instead of global
(13) GUI/Core: Add CPU affinity rules setting to delay enforcement, for games that have trouble at startup with custom affinities
(13) GUI.InstanceBalancer: Add confirmation if dialog dismissed via OK button with unadded rule in controls
(11) ThreadRacer: Add 'invert selection' and 'clear' buttons
(11) ThreadRacer: Disable checkboxes while started
(11) ThreadRacer: Add message if start attempted with no...
P3D-Bot
Bot von P3D
Process Lasso v12.4.0.44
(1) GUI.CoreGraphs: Owner draw on light themes too (changes appearance)
- E-core distinction in graphs
- Delayed CPU affinity rules
- ‘Remove all rules’ process action
(1) GUI.CoreGraphs: Append 'Efficiency' to tooltip when E-core
(1) GUI.CoreGraphs: Overlay leaf icon on Efficiency cores
(7) GUI: Fix issue where rules column wouldn't immediately refresh after automated config profile switch
(9) GUI: Add ProBalance option to not change CPU...
P3D-Bot
Bot von P3D
Process Lasso v12.4.1.10
(1) Build: Remove redundant digital signature on some modules
(3) Core: Move IdleSaver recovery info for improper termination to registry
(3) Core: Adjust cleanup order when exiting with app power plan, performance mode and/or IdleSaver active
(5) Core: Fix an issue where Efficiency Mode OFF rules were enforcing a normal priority class, overriding any other priority rules on the process
(5) GUI: When turning Efficiency Mode OFF, only reset the...
P3D-Bot
Bot von P3D
Process Lasso v12.4.2.44
v12.4.2.44 – Nov 11, 2023
(1) GUI: Add 'Stagger', 'P-Cores' and 'E-Cores' buttons to CPU Affinity selection
(11) GUI: Add System Timer Resolution option to apply the change globally
(29) GUI/Core: Support embedded commas in Disallowed Processes rules
(35) GUI/Core: Extend RegEx to I/O, memory priority, and disallowed process rules
(39) GUI/Core: Decouple SmartTrim's Standby List and File Cache purge operations
P3D-Bot
Bot von P3D
Process Lasso v12.4.3 BETA
(5) GUI: Show paused icon over graph when paused
(3) GUI: Add new option 'Pause on Right-Click', defaulting to true. This keeps the process lists from updating while in the context menu.
P3D-Bot
Bot von P3D
Process Lasso v12.4.3.14
v12.4.3.14 – Nov 29, 2023
(3) GUI: Add new option 'Pause on Right-Click', defaulting to true. This pauses the list and graph when the process context menu is open.
- Add option ‘Pause on Right-Click’
(5) GUI: Show paused icon on graph when paused
P3D-Bot
Bot von P3D
Process Lasso v12.4.4.22
(1) GUI.AffinitiesDialog: Add 'Show Advanced' link and hide delay edit control by default
(1) GUI/Core: Allow wildcards in Performance Mode basename matches (previously only full paths)
(5) GUI: Add IdleSaver exclusion list management to its config dialog
(11) GUI: Disable automatic game detection for Performance Mode by default for new installs
(11) GUI: Change order of 'Options / Power' submenu and move Bitsum Highest Performance options from...
P3D-Bot
Bot von P3D
Process Lasso v12.4.5.8
v12.4.5.8 – Dec 28, 2023
(1) GUI: Improve action confirmation flow on terminate and restart of critical system processes (e.g. explorer)
(7) GUI: Fix reset config action didn't clear overrides of hard-coded ProBalance exclusions
(7) GUI: Fix to ThreadRacer control ordering
(9) GUI/Core: Revert previous change to 'Automatic Game Detection' default value, now ON again. Only new installs or users who reset their config were affected by...
P3D-Bot
Bot von P3D
Process Lasso v12.4.6.10
(1) GUI: Fix suspended process state not always indicated in status column
(3) GUI: Add P/E core count to CPU topology string for About dialog and status bar
(5) GUI: Change copyright to 2024
(5) GUI: Fix issue where eco leaf icons weren't painted on core graphs under certain conditions
(7) GUI: When there is insufficient width for eco leaf icons draw circles instead
(7) GUI/Core: Add Epic Games to automatic game detection
(9) GUI: Support...
P3D-Bot
Bot von P3D
(1) GUI: Fix an issue changing existing I/O and memory priority rules from the context menu
(5) GUI: Improvements to translation tools
(9) GUI: Change default sort order of Insights to descending by restraint count
(11) GUI: Remove 'critical' I/O priority level since it cannot be enforced
(13) GUI/Core: Add common game platform launchers to stock ProBalance exclusions
(15) GUI: Large updates to Finnish and German translations
(15) GUI: Fix an...
