Allg. AbiWord 2.6.3 Final erschienen
  • Ersteller Ersteller gast0815
  • Erstellt am Erstellt am
gast0815
Changelog:
Core
  • Bug 11328: AbiWord crashes when inserting an equation (Dominic Lachowicz)
  • Bug 11553: Hide formatting marks when printing or print previewing (sum1)
  • Optimize string comparison functions (Dominic Lachowicz)
  • Prevent a crash that occurred when inserting a text box in a document with columns (sum1)
  • Prevent a crash that occurred when visually dragging endnotes and footnotes (sum1)
  • Prevent a crash with invalid headers and footers (sum1)
  • Prevent a few caret-related crashes (Dominic Lachowicz)
  • Prevent a few crashes with invalid footnotes and endnotes (sum1)
  • Prevent a text box layout crash (sum1)
  • Simplify an internal string function (Dominic Lachowicz)
GUI
Cross-platform
  • Bug 11568: Show collaboration connection status in the UI (Marc Maurer)
  • Add status bar messages for the presentation and key bindings plug-ins (sum1)
  • Prevent a crash that could occur when closing a window with the word count dialog open (sum1)
  • Prevent a few crashes that could occur when quickly using separate menu items in the spelling context menu (sum1)
  • Prevent the display of uninitialized strings in the history dialog (sum1)
Windows
  • Bug 11130: Text labels are misaligned in the TCP dialog (sum1)
  • Bug 11509: Crash when using the language dialog in localized environments (Dominic Lachowicz)
  • Allow the entry of long address strings in the TCP dialog (sum1)
Import/Export
General
  • Bug 11541: AbiWord crashes when saving to a device with no space left (Dominic Lachowicz)
Applix
  • Improve file recognition so AbiWord can import Applix files it exports (sum1)
HTML
  • Add a method for exporting stylesheets as strings (Dominic Lachowicz)
  • Add a missing return statement in the code that handles title elements (sum1)
  • Escape style names in stylesheets (sum1)
  • Improve the handling of heading IDs in documents that do not contain a table of contents (Dominic Lachowicz)
Microsoft Word
  • Bug 6432: Background colors are not imported (sum1)
  • Bug 11159: Prevent a table-related crash with the attached document (sum1)
  • Bug 11219: Prevent a table-related crash with the attached document (sum1)
Microsoft WriteOpenDocument
  • Clean up compiler warnings (Hubert Figuiere)
  • Fix a crash that occurred when exporting invalid footnotes and endnotes (sum1)
  • Fix a crash that occurred when importing files with missing text:level attributes (sum1)
  • Improve support for large tables with customized widths (sum1)
  • Simplify the code that exports underline and strike formatting (sum1)
OpenOffice.org (sxw)
  • Import the no proofing language code (sum1)
RTF
  • Fix the export of transparent colors (sum1)
  • Handle large list labels (sum1)
StarOffice
  • Bug 9632: Memory leak with invalid documents (Hubert Figuiere)
WordPerfect
  • Prevent a crash that occurred when a footnote was opened before a section (sum1)
  • Prevent a layout hang caused by empty sections (sum1)
Internationalization
  • Fix an incorrect language code in the de-CH template (sum1)
Development
  • Bug 11483: AbiWord fails to compile when libxml2 is built without legacy support (Dominic Lachowicz)
  • Disable a few verbose debug messages (Marc Maurer)
  • Fix a build error in the key bindings plug-in (sum1)
  • Fix a comment typo (sum1)
  • Fix a large number of compiler warnings (Hubert Figuiere)
  • Fix a typo in the AbiCollab regression script (sum1)
  • Fix some misspelled function parameters in the AbiWidget code (Marc Maurer)
  • Maintain and release 2.6.3 (Marc Maurer)
Download:
Windows: http://www.abisource.com/downloads/abiword/2.6.3/Windows/abiword-setup-2.6.3.exe
Source: http://www.abisource.com/downloads/abiword/2.6.3/source/
sehr geiles programm, gehört schon für mich zum standard und wird bei bekannten und freunden auch immer installiert. :)
