AMD kündigt stromsparende Opteron Prozessoren an
- Ersteller Mighty
Mighty
Senior Moderator
Auf der Embedded Systems Conference hat <a href="http://www.amd.com" TARGET="b">AMD</a> heute für die erste Hälfte des Jahres 2004 für die Opteron Serien 100, 200 und 800 neue Prozessoren mit einem Stromverbrauch von 30 bzw. 55 Watt angekündigt, welche speziell in den Bereichen Blade- und Storage-Servern zum Einsatz kommen sollen.
<ul><i>BOSTON -- September 16, 2003 --At the Embedded Systems Conference, AMD today announced that it plans to offer customers mid- and low-power AMD Opteron™ processors in the first half of 2004. The mid- and low-power AMD Opteron processors, to be available at 55 watts and 30 watts, are designed to provide customers with a wide variety of solutions, extending into the AMD Opteron 100-, 200-, and 800- series product lines.
“AMD is once again entering new markets and offering additional choice to our customers,” said Marty Seyer, vice president and general manager of AMD’s Microprocessor Business Unit. “AMD is already a leader in providing low power, high performance processors to the market. With mid- and low-power AMD Opteron processors, AMD will now enable an enterprise to employ a common infrastructure based on AMD64 technology at all levels of it's computing environment - from high-performance clusters to blade servers.”
Enterprise computing systems that require power conservation, such as blade servers and storage devices, are gaining in popularity due to their scalability, ease of management and cost efficiency. In addition, mid- and low-power processors are a requirement for many server systems housed in large computing centers where power consumption and heat affects operating costs. The AMD Opteron processor’s high memory throughput and I/O bandwidth are ideal for products that must quickly move and manipulate large datasets, while consuming minimum power.
"The blade server market is expected to experience tremendous growth in the next few years," said Mark Melenovsky, Director, Server Research with IDC. "The benefits to be recognized by enterprise IT departments in terms of lower total cost of ownership and ease of management will mean more and more companies will turn to blade servers for their data center solutions."
This growing customer base will now be able to recognize the new level of computing available with AMD64 technology.</ul></i>
Knife
Ist wohl ein wenig eine Antwort auf Intels Stromspar Itanic
Links:
http://www.heise.de/newsticker/data/ciw-08.09.03-000/
H.a.n.d.
Knife
Links:
H.a.n.d.
Knife
Mari
Moderator
- BB
- Ryzen 7 5800X3D
- ASUS B550 F Gaming
- ENERMAX ETS-50/Alpenföhn Wings Boost 3
- 32 GB G.SKILL Trident 3600
- ASUS TUF RX6800XT
- Gigabyte 34"
- ADATA SX 8200XT
- diverse
- NZXT H6 Flow
- Enermax DFX 1050W
- Cherry
- Roccat Kone
- Win 11 Home
- MS Edge
- ▼1000 ▲50
Vielleicht wird es in naher Zukunft auch Opteron Laptops geben.
Knife
Ich glaub eher nicht Wenn es Mobile Hammers gibt, dann werden die sicher von den Athlon64 abgeleitet: ergo -> Athlon64MOriginal geschrieben von Mari
und Opteron PDAs oder gar Handys wird es wohl auch definitiv nicht geben SCNR
H.a.n.d.
Knife
AMD_Feuerspucker
Mehr als 55 W braucht der 244 angeblich ja gar net....
AMD_Feuerspucker
wahrscheinlich eh nur Marketing...
darkangel12
Original geschrieben von nv0
Eigentlich traurig, dass heutzutage 55W schon als stromsparend bezeichnet werden...
ja dann kauf dir doch neh epia
kein strom verbrauch 30 w das ganze baord aber dafür keine leistung
aber da sagt dann wieder jeder stromsparend ist er ja und klein ist itx auch aber keine leistung kann nicht mal divx ruckelfrei abspielen
für linux + vdr drauf sind die epia's aber bestens geeignet , schön leise perfekt für's wohnzimmer.
hab selber einen ...
Knife
Nun, ich habe auch so ein epia-V5000 board mit dem Eden 533MHz als kleiner Linugs 8) File- und Mailserver. Der Lüfter des Gehäusenetzteils ist aber nicht gerade leise. Ich habe dann eine kleine Modifikation vorgenommen und den Lüfter statt auf der 12V Schiene, auf die 5V Schiene gelegt. So wurde es angenehm leise (Hoffentlich überhitzt es dann aber nicht -> habe das Netzteil noch nicht eingebaut )
Links:
http://www.digitec.ch/cgi-bin/mitte_produktedetail.php?AI=GEH104695
H.a.l.o.f.a.h.a.n.d.
Knife
