Aprilscherz bei Steam
- Ersteller TeleTubby666
TeleTubby666
Gerade beim Starten von Steam gelesen:
Friday, April 1 2005
An update is available for Counter-Strike: Source. The update will be applied automatically when your Steam client is restarted. This update addresses requests for more realism in Counter-Strike: Source. The changes are as follows:
Features/Additions
Doubled player speed when jumping. The effect to cumulative, so the more you jump, the faster you go.
Cut price of AWP by 50%.
Added akimbo Riot Shield to buy menu.
Removed de_dust from mapcycle.
Realism Enhancements:
Knives:
Between rounds, it is suggested that you unsheath the weapon and repeatedly press the attack key to air it out as the leather now collects moisture and creates pits on the blade, making it less effective in the next round.
Shotguns:
1. Firing the shotgun without ammo loaded will now cause it to jam.
2. When the shotgun jams, press F2 to fill out form DA-1823-00/A12-H8.
3. You should then hear a scribbling sound. When it stops, press F3 to send the request to LIDM.
4. Failure to do paperwork before pressing F3 will result in the immediate return of the unrepaired shotgun.
5. The repairs can take 1-2 rounds for completion. During that time, you cannot purchase a replacement firearm and may only use your sidearm or knife.
Player Models:
Several models now feature eyewear. This is a completely cosmetic enhancement with the following exceptions:
Part EP-7829-292-2 must be purchased and worn correctly at all times in order to see during the round.
In between rounds, you may purchase and use part EC-2231-833-H34 to clean your EP-7829-292-2. Note: that this does not clean the eyewear itself!
To clean the eyewear, you need to purchase and use the designated cleaner, EC-2231-233-H34, EC-2231-523-H34, or EC-2231-239-H34a respectively depending on your model's eyewear. You can determine the part # of the correct cleaner by asking someone.
Machine and submachine guns:
At least once every five rounds, press F1 to inspect the weapon:
A musical cue indicates that the inspection has started. Now press F1 again repeatedly to clean and lubricate the weapon.
Your Preventative Maintenance Status (either "cleaning" or "lubricating") is determined by the speed with which you press the F1 key and will be displayed above your head.
To accurately simulate real life maintenance mistakes, pressing F1 too quickly will lubricate either the bolt face or the trunnion block. Pressing F1 too slowly sprays lubricant directly into the buffer tube. All mistakes render the gun inoperable, though this may not become immediately apparent.
Experiment with keypress timing to avoid (and discover!) other common maintenance errors.
In order to balance the improved stopping power of a well-maintained weapon, the reloading process has been made much less reliable.
When reloading, you should listen for two or three distinct clicks over a period of several seconds.
If you hear one click or no clicks or more than two clicks, you've bent the link ejector chute and the gun will most likely explode on the next attempt to fire it, though it may not.
© Valve Corporation. All rights reserved. Valve, Half-Life, and Counter-Strike are trademarks
and/or registered trademarks of Valve Corporation.
Features/Additions
Knives:
Shotguns:
Player Models:
DCTH
- Am Neckar
- Q9550
- Gigabyte P35-DS4 (Rev 1.0)
- nen recht großer Scythe
- 8GB
- GTX 560ti
- HP w2207
- 250gb
- vorhanden
- X-Fi Music
- schwarz
- Bequiet Dark Power Pro 430Watt
- Win7prof 64bit
.... wenn doch Steam selbst doch auch nur ein Scherz wäre....
sniper.de
Ping
- Göttingen
- Dell Vostro 1310 :D
- AMD Phenom II 1090T
- GIGABYTE GA-870A-UD3
- Boxed
- 4 x 4 GB TeamGroup Elite
- AMD Radeon HD 6950
- Samsung 226BW
- Crucial M500 256 GB
- Toshiba DT01ACA 2 TB
- LiteOn iHOS104 + NEC 3500AG
- ASUS Xonar DX
- Chieftec BH-02B-B-B
- be quiet! straight power 580W
- Windows 7 Professional 64 bit
Immer wieder das Gleiche, wo ist denn euer Problem im Moment mit Steam?
DCTH
- Am Neckar
- Q9550
- 8GB
- GTX 560ti
- HP w2207
- 250gb
- vorhanden
- X-Fi Music
- schwarz
- Win7prof 64bit
Benutze halt mal die Suchfunktion....
Exr
Ich habe kein Problem mit Steam. Half-Life 2 war Dreck.
Aber den April-Gag fand ich wirklich gut! Besonders die Art und die Rückmeldungen beim Reinigen der Waffen! Hihihi. Ich habe gelacht, und damit hats bei mir den Zweck erfüllt.
Anscheinend verhält es sich mit Steam wie oft mit WoW: Sobald irgendwo was gepostet wird, was damit zu tun hat, kommen ein paar Poster daher und nörgeln rum. Ganz egal um was es geht, solange Steam bzw WoW (o.a.) auch nur periphär erwähnt werden, wird einfach mal wieder eine Dosis Nörgel-Matsch abgeladen. Ist von diesen Leuten noch keiner auf die Idee gekommen dass das OT und für die meisten Leser total uninteressant ist?
so long,
exr
so long,
exr
Steam generell im Zusammenhang mit CS-Source zu kritisieren ist echt ziemlich daneben. Denn ich finde es wirklich ein sauberes (Hilfs)programm.
Steam in Zusammenhang mit dem Single Player Spiel Half Life 2 ist eine ganz andere Geschichte...
Greetings!
Nmx
Greetings!
Nmx
DCTH
- Am Neckar
- Q9550
- 8GB
- GTX 560ti
- HP w2207
- 250gb
- vorhanden
- X-Fi Music
- schwarz
- Win7prof 64bit
Wenn man nicht gerade über eine DSL-Verbindung oder wenigstens eine ISDN-Verbindung verfügt, so hindert Steam einen ziemlich effektiv daran, HL² zu spielen.... Und Patches sind kann man meist gleich ganz vergessen. Während bei andren Spielen diese noch auf diversen Heft-CDs zu finden sind, so ist man bei HL² durch Steam dazu gnötigt diese übers Inet zu saugen.
Die Art von Steam find ich ja auch in Ordnung, nur die Umsetzung ist Mist!
-> Also ich kritisiere Steam im Zusammenhang mit Half-Life²
The_Indeed
Greetings!
Nmx
Dem kann ich leider ned voll zustimmen, denn für Leute ohne DSL is STEAM echt hart.
Da es kaum richtige Flatrates für ISDN & Analog User mehr gibt schaut man doch schon genau auf die Uhr wenn man mal so eben lockere 2,5 Stunden wartet nur um sein CS:S wieder auf den aktuellen Stand zu bringen.
Das Patchmanagement war finde ich früher besser mit Downloadservern für die Leute mit schnellen Verbindungen und Heft-CD´s für die Leute die nicht so lange warten wollten bis der Download fertig war.
my 2 cents
godless.prayer
- Nürnberg
- Intel Core i5 2500K
- ASUS P8Z68-V Pro Gen 3
- Scythe Mugen 3
- 4x 4048 MB DDR3 PC3-10700H CL9 Corsair Vengeance
- Sapphire R9 290 Tri-X OC
- 22" LCD, HP w2207h | 24" Iiyama PLE2407HDS 1920x1080
- Samsung 840 PRO 128GB; Samsung 850 EVO 500GB
- WDC WD5000KS 500GB, WDC WD5002AALX 500GB
- Plextor PX-B300SA (BD-ROM, DVD Multinorm Brenner)
- Soundblaster Recon 3D
- Lian Li PC-7FN
- Cooler Master Real Power M 700W
- Google Chrome
jedesmal wenn ein neuer Patch rauskommt nehm ich meinen Barebone mit auf die Arbeit (DSL2000) und zieh mir den da.
Daheim mit ISDN isses net grad schön, vor allem weil mein Bruder die dann ja auch noch braucht.
Aber an sich find ich Steam bisher einwandfrei. Am Anfang hats gehakt, als die Server einfach mal total überlastet waren. Seitdem hatte ich nie wieder Probleme damit.
godless.prayer
- Nürnberg
- Scythe Mugen 3
- Lian Li PC-7FN
- Google Chrome
Is doch nurn Barebone
Kabel ab, untern Arm klemmen, auf der Arbeit schnell dran und fertig.
Ich hab mit meinem ISDN Zugang besseres zu tun, als mir die Steam Updates zu saugen.
Aber im August kommt ja endlich DSL
