BOINC 6.4.7 erschienen
- Ersteller KIDH
KIDH
- Pogotopia
- Folding@Home
- Abit AV8 3rd Eye
- Thermaltake Silent Boost K8
- GeForce 6800 GT
- DVD-ROM / DVD-Brenner
- Creative Audigy
- noname
- Enermax Liberty 400W Dual
- Win98SE / WinXP SP3
Am 03.03.09 wurde die Version 6.4.7 des BOINC Clients freigegeben, nachdem BOINC 6.4.6 kurz nach Erscheinen wieder zurückgezogen wurde.
Download: http://boinc.berkeley.edu/download_all.php
Changelog Version 6.4.7
* SS: Fix new screensaver coordinator to work properly on Windows
* client: add SCHEDULER_OP::rpc_failed(); this gets called when the op fails, either at initialization or later on; it clears the project's sched_rpc_pending flag if needed. This fixes a bug that caused user-requested RPCs to retry every 10 seconds when the network is down.
* client: if debt-adjust period is too long, reset accounting. Otherwise we'll get this infinitely.
* API: all optional alpha argument to TEXTURE_DESC::draw()
* client: if master file doesn't have URLs, clear RPC request
* client: show proxy info correctly on startup
* client: fix minor bug that produced spurious adjust debt interval too long messages when zero projects
* SS: Fix new screensaver coordinator sandbox permissions.
* ss_app: Replace temporary icon with standard BOINC icon.
* ss_app: Fix compiler warning.
* lib: add time stamps to BOINCTRACE on non-Windows systems
* client: change the formula for debt update so that largest debt among eligible projects tends towards zero
* client: change definition of "overworked"; debt must be < 1 day
* client: change garbage collection so that an app version is deleted only if there's another version *of the same plan class* with a higher version number
* client and API: eliminate dynamically-allocated parts of GLOBAL_PREFS. This fixes a double-free bug in the API
* boinc_zip: put null arg at end of argv. Fixes crashing bug. From Michael Tyka.
* MGR: Check to see if the app version pointer is legit before attempting to use it
* lib: implement APP_INIT_DATA::copy() with assignments instead of memcpy(). This protects against any future double-free bugs
* MGR: Remove remaining UI thread calls to setlocale which could confuse the parsing system or vise versa
* client, API: populate APP_INIT_DATA::hostid. Remove userid and teamid fields, since the client doesn't know these
* SS: Graphics executables need a Mac icon only if they can be run in a window, to allow the user to bring it to the front or control it. Since the new boincscr app runs only as a screensaver, the Dock is not visible when it is running so there is no reason to have an icon. So restore the previous permissions settings (non-writable).
* ss_app: Remove code which adds a Mac icon.
* ss_app: Change Windows build executable file name to boincscr.exe
* SS: Continue refining screensaver coordinator logic.
* client: debt_eligible() was returning false if the backoff was max. This can lead to a situation where a project never gets work. Remove that clause.
* client, web: add preference for not using GPU while computer busy
* client: bug fix for GPU pref
* ss_app: Under sandbox security, set boincscr permissions the same as for BOINC Manager: setgid to boinc_master but do not setuid; this allows the screensaver coordinator to kill boincscr but still gives boincscr access to GUI RPC password file and so to all GUI RPCs.
* SS: On Windows, add code to get paths to BOINC data and executable directories from Windows registry; expects boincscr in BOINC executable directory and ss-config.xml in BOINC data directory
* GUI RPC: "get prefs" RPC was messed up by yesterdays's checkin; also, change all bools to <foo>0|1</foo> rather than <foo/>
* Manager: add GPU preference to advanced prefs dialog
ICEMAN
- AMD Ryzen 3 2200G
- HP 255 G8
- AMD Ryzen 5 5600G
- MSI B450 Gaming Plus
- Noctua NH-U9F
- AMD Radeon Vega 8
- 1TB Samsung HD103SJ
- DVD-Brenner
- Windows 10 64bit Prof.
▼250
Guggst du hier -> http://www.planet3dnow.de/vbulletin/showthread.php?p=3876670
KIDH
- Pogotopia
- Folding@Home
- Abit AV8 3rd Eye
- GeForce 6800 GT
- Creative Audigy
- noname
Wenn du damit meinst, daß es schon da war...mein Post ist älter.
Oder meinst wegen changelog?
KIDH
KIDH
ICEMAN
- AMD Ryzen 3 2200G
- HP 255 G8
- AMD Ryzen 5 5600G
- Noctua NH-U9F
- AMD Radeon Vega 8
- DVD-Brenner
▼250
DeswegenOder meinst wegen changelog?
KIDH
KIDH
- Pogotopia
- Folding@Home
- Abit AV8 3rd Eye
- GeForce 6800 GT
- Creative Audigy
- noname
Ah...gut!
DanysAhne
- Erfurt
- Einstein, Rosetta, Collatz, LHC
- POEM
- Ryzen 7 1700,i5-2500,i7-5600U,i7-4790,ATI 6850,ATI 380
- Acer TimelineX 5820TG-484G16Mnks
- AMD Ryzen 7 1700
- Asus Prime X370-Pro
- AMD Wraith Spire
- 16 GB DDR4 Corsair Vengeance 2666
- SAPPHIRE PULSE RX 5500XT 8GB
- 28", Samsung U28E590D, 4K
- 250 GB EVO 960, 1TB EVO 850, 512GB Crucial m4
- Thermaltake Berlin 630W
- Windows 10 Pro 64bit
Die 6.4.6 wurde anscheinend wieder zurück gezogen. Dabei hab ich sie daheim erst gestern installiert.
Die letzte Stable Version ist jetzt wieder die 6.4.5.
KIDH
- Pogotopia
- Folding@Home
- Abit AV8 3rd Eye
- GeForce 6800 GT
- Creative Audigy
- noname
Hm komisch...das gab's schonmal. Da hab ich hier nen Thread erstellt und aufeinmal war die alte Version wieder da.
KIDH
- Pogotopia
- Folding@Home
- Abit AV8 3rd Eye
- GeForce 6800 GT
- Creative Audigy
- noname
Nachdem BOINC 6.4.6 wieder zurückgezogen wurde, ist heute BOINC 6.4.7 erschienen! Ein Changelog ist leider wieder nicht verfügbar, wird aber sicher noch nachgereicht.
TAL9000
- nähe Giessen
- OnBoard
- VERTI WM25
▼50 MBit
▲10 MBit
hmm, werde erstmal warten mit der Install. Hoffe das die Spoofing Lücke jetzt dicht ist.
TAL9000
TAL9000
KIDH
- Pogotopia
- Folding@Home
- Abit AV8 3rd Eye
- GeForce 6800 GT
- Creative Audigy
- noname
Changelog hinzugefügt
