Projektnews Asteroids@home : New AVX512 application released
P3D-Bot
Bot von P3D
09.04.2006
73.733
229
Das Boot 3.0
We are very proud to announce our new set of optimized applications that will utilize AVX512 instruction set capable engines or to be precise those, which support AVX512dq instructions!
These applications are built to support both Linux and Windows 64bit architecture OS. The development of this version was possible thanks to the great help provided by ahorek's team!
Unfortunately it turns out that BOINC client applications for Windows still do not report all processor options to the server correctly. It is because of a known bug and even after a lot of discussions in BOINC's channels it's still there. The good news is that thanks to ahorek's team a bugfix was already accepted and merged into the BOINC's repository and the fix will be applied when client version 7.26.0 is released. Till then in order to run the AVX512 application you might need to switch to the Anonymous platform.
We'd like to remind you that while the Boinc server is capable of finding the best performing application for every particular system taking into account multiple factors, after a while it will start sending the right one for every particular system. Which means that even if your CPU supports AVX512dq instructions it still might receive FMA or AVX tasks and there is nothing to be concerned about. In such a case you might want to give a try to the so-called Anonymous platform where your client will explicitly request the AVX512 application.
Happy crunching and thank you for your support!
Asteroids@home's team
Lese weiter im Asteroids@home Forum ....
Wir sind sehr stolz, unsere neuen optimierten Anwendungen bekannt zu geben, die AVX512-Befehlssatz-fähige Engines verwenden werden, oder genauer gesagt solche, die AVX512dq-Anweisungen unterstützen!
Diese Anwendungen sind so konzipiert, dass sie sowohl Linux- als auch Windows-Betriebssysteme mit 64-Bit-Architektur unterstützen. Die Entwicklung dieser Version war dank der großartigen Hilfe des ahorek-Teams möglich!
Leider stellt sich heraus, dass BOINC-Clientanwendungen für Windows immer noch nicht alle Prozessoroptionen korrekt an den Server melden. Es liegt an einem bekannten Fehler und selbst nach vielen Diskussionen in den BOINC-Kanälen ist er immer noch da. Die gute Nachricht ist, dass dank des Teams von ahorek bereits ein Bugfix akzeptiert und in das BOINC-Repository integriert wurde und der Fix angewendet wird, wenn die Client-Version 7.26.0 veröffentlicht wird. Bis dahin müssen Sie zum Ausführen der AVX512-Anwendung möglicherweise zur Anonymous-Plattform wechseln.
Wir möchten Sie daran erinnern, dass der Boinc-Server zwar in der Lage ist, unter Berücksichtigung mehrerer Faktoren die leistungsstärkste Anwendung für jedes bestimmte System zu finden, nach einer Weile jedoch beginnt, für jedes bestimmte System die richtige Anwendung zu senden. Das bedeutet, dass Ihre CPU, selbst wenn sie AVX512dq-Anweisungen unterstützt, möglicherweise dennoch FMA- oder AVX-Aufgaben empfängt und kein Grund zur Sorge besteht. In einem solchen Fall möchten Sie vielleicht die sogenannte Anonymous-Plattform ausprobieren, bei der Ihr Kunde explizit die AVX512-Anwendung anfordert.
Viel Spaß beim Knuspern und vielen Dank für eure Unterstützung!
Das Team von Asteroids@home
Translated by google
