A new SSD controller designer is coming out of stealth mode today. Innogrit was founded in 2016 by storage industry veterans with the goal of developing storage technology to support AI and big data applications. We spoke with co-founder Dr. Zining Wu (formerly Marvell's CTO) about the company's planned product lineup, and he will be presenting more information next week in a keynote speech at Flash Memory Summit.
Innogrit's long term goal is to go after the enterprise storage market, but they are starting small with a DRAMless client SSD controller, the IG5208 "Shasta". This is already in mass production with full turnkey reference SSD designs available. It will be followed up incrementally larger controllers with more advanced feature sets: Shasta+, Rainier and Tacoma. With each iteration, Innogrit is increasing performance, adding more features and improving their LDPC error correction engine.
Innogrit NVMe SSD Controller Roadmap
Controller
Shasta
Shasta+
Rainier
Tacoma
Model Number
IG5208
IG5216
IG5236
IG5668
Host Interface
PCIe 3 x2
PCIe 3 x4
PCIe 4 x4
PCIe 4 x4
Protocol
NVMe 1.3
NVMe 1.4
NAND Channels
4
4
8
16
Max Capacity
2 TB
2 TB
16 TB
32 TB
DRAM Support
No (HMB Supported)
DDR3/4, LPDDR3/4
32/16-bit bus
DDR3/4, LPDDR3/4,
72-bit bus
Manufacturing Process
28nm
"16/12nm"
BGA Package Size
10x9mm,
7x10mm
7x11mm,
10x10mm
15x15mm
17x17mm
Sequential Read
1750 MB/s
3.2 GB/s
7 GB/s
7 GB/s
Sequential Write
1500 MB/s
2.5 GB/s
6.1 GB/s
6.1 GB/s
4KB Random Read
250k IOPS
500k IOPS
1M IOPS
1.5M IOPS
4KB Random Write
200k IOPS
350k IOPS
800k IOPS
1M IOPS
Market Segment
Client
Client
High-end Client,
Datacenter
Datacenter, Enterprise
The Shasta and Shasta+ controllers are both primarily targeting the client SSD market, and they are designed as low-cost mainstream solutions. Shasta has just two PCIe 3 lanes while Shasta+ has four lanes and consequently higher performance, but otherwise they are quite similar. Both are 28nm designs and use the NVMe Host Memory Buffer feature rather than including DRAM controllers. Both controllers are small enough to be packaged inside single-chip BGA SSDs, and Innogrit's reference designs for Shasta-based SSDs include the standard 11.5x13mm and 16x20mm BGA SSD footprints and a CFX card design. The improved ECC capabilities of Shasta+ will make it a better choice for QLC-based SSDs, but both controllers support the full range of SLC through QLC from multiple manufacturers.
Because Shasta and Shasta+ are stepping stones toward the enterprise and datacenter markets, they include support for some features not commonly found on client SSDs, such as an Open-Channel SSD operating mode. End-to-end data path protection is included, with ECC on all the controller's SRAM buffers and on data stored in the Host Memory Buffer. Power management appropriate for client and embedded use is supported, with Shasta peaking at 0.9W and supporting idle states at 55mW and less than 1mW, while Shasta+ will peak at about 1.35W. The NVMe Boot Partition feature is also supported for embedded systems that don't include a separate boot ROM device.
Innogrit's Rainier controller is a significant generational advance over the Shasta family, moving up to the high-end client and entry-level datacenter markets. Rainier switches to one of TSMC's 16/12nm FinFET processes, which Innogrit (and most other controller designers) sees as necessary for PCIe gen4 support with reasonable power consumption. Rainier has 8 NAND channels that can run at up to 1200MT/s, fast enough for any currently-available NAND. This allows for sequential read and write speeds of up to 7GB/s and 6.1GB/s respectively, more or less saturating the PCIe 4 x4 interface. Rainier adds enterprise-oriented features like multiple namespace support and SR-IOV virtualization, but client-oriented power management is still supported, with idle states for 50mW and less than 2mW.
The most powerful controller on Innogrit's roadmap is Tacoma, which builds on Rainier by doubling the NAND channel count to 16 (bringing the maximum supported capacity up to 32TB), widening the DRAM interface to 72 bits (64b with ECC), and adding more high-end enterprise features. Sequential IO performance will be roughly the same as for Rainier but random IO gets a boost from the extra parallelism. The virtualization capabilities have been enhanced relative to Rainier and the NVMe Controller Memory Buffer feature is supported, which comes in handy for NVMe over Fabrics deployments. A special low-latency mode is introduced, which Innogrit will be demonstrating with Toshiba's XL-FLASH (their answer to Samsung's Z-NAND). Perhaps the most important feature of Tacoma is the addition of in-storage compute with a deep learning accelerator; more information about this will be shared next week during Innogrit's keynote presentation at Flash Memory Summit.
Innogrit's business model will be similar to most other independent SSD controller vendors, offering SSD vendors a range of options from a basic SDK for custom firmware up to full turnkey SSD designs. They have several design wins with the Shasta family controllers and are already sampling the Rainier and Tacoma controllers.
