* mainfrm.java
* Created on 15. Oktober 2008, 21:16
* @author Marc
import java.awt.MediaTracker;
import javax.swing.Icon;
import javax.swing.ImageIcon;
import javax.swing.JFrame;
import javax.swing.JLabel;
import javax.swing.JPanel;
import java.net.*;
import java.io.*;
import java.util.*;
import java.lang.*;
import java.awt.*;
import java.awt.event.*;
import javax.swing.*;
import javax.swing.event.*;
import javax.swing.text.html.*;
public class mainfrm extends javax.swing.JFrame {
/** Creates new form mainfrm */
public mainfrm() {
initComponents();
/** This method is called from within the constructor to
* initialize the form.
* WARNING: Do NOT modify this code. The content of this method is
* always regenerated by the Form Editor.
// <editor-fold defaultstate="collapsed" desc=" Generated Code ">
private void initComponents() {
jLabel1 = new javax.swing.JLabel();
jTextField1 = new javax.swing.JTextField();
jButton1 = new javax.swing.JButton();
setDefaultCloseOperation(javax.swing.WindowConstants.EXIT_ON_CLOSE);
jLabel1.setHorizontalAlignment(javax.swing.SwingConstants.CENTER);
jLabel1.setLabelFor(jLabel1);
jLabel1.setPreferredSize(new java.awt.Dimension(1024, 768));
jTextField1.setText("XXXX://"); // Wegen Spamschutz geändert
jButton1.setText("Suchen");
jButton1.addMouseListener(new java.awt.event.MouseAdapter() {
public void mouseClicked(java.awt.event.MouseEvent evt) {
jButton1MouseClicked(evt);
org.jdesktop.layout.GroupLayout layout = new org.jdesktop.layout.GroupLayout(getContentPane());
getContentPane().setLayout(layout);
layout.setHorizontalGroup(
layout.createParallelGroup(org.jdesktop.layout.GroupLayout.LEADING)
.add(layout.createSequentialGroup()
.addContainerGap()
.add(layout.createParallelGroup(org.jdesktop.layout.GroupLayout.LEADING)
.add(jTextField1, org.jdesktop.layout.GroupLayout.PREFERRED_SIZE, 392, org.jdesktop.layout.GroupLayout.PREFERRED_SIZE)
.addPreferredGap(org.jdesktop.layout.LayoutStyle.RELATED)
.add(jButton1))
.add(jLabel1, org.jdesktop.layout.GroupLayout.PREFERRED_SIZE, org.jdesktop.layout.GroupLayout.DEFAULT_SIZE, org.jdesktop.layout.GroupLayout.PREFERRED_SIZE))
.addContainerGap(22, Short.MAX_VALUE))
layout.setVerticalGroup(
.add(19, 19, 19)
.add(layout.createParallelGroup(org.jdesktop.layout.GroupLayout.BASELINE)
.add(jTextField1, org.jdesktop.layout.GroupLayout.PREFERRED_SIZE, org.jdesktop.layout.GroupLayout.DEFAULT_SIZE, org.jdesktop.layout.GroupLayout.PREFERRED_SIZE)
.add(jButton1))
.add(14, 14, 14)
.addContainerGap(org.jdesktop.layout.GroupLayout.DEFAULT_SIZE, Short.MAX_VALUE))
pack();
}// </editor-fold>
private void jButton1MouseClicked(java.awt.event.MouseEvent evt) {
String text;
text = jTextField1.getText();
String base64;
base64 = Base64.base64Encode(text); // Erstellt die eingegebene URL als Base64
zeigebild(base64); // Ruft die Funktion zeigebild auf
public static void zeigebild(String url) {
try {
ImageIcon i = null;
String newURL;
String b64;
b64 = url; // Speichert den Inhalt aus url in b64
newURL = "XXXX://xxx.thumbmaker.net/thumb/"+b64+"/pic.png"; // Generiert die URL (musste ich wegen dem Spamschutz ändern!
URL ImgURL;
ImgURL = new URL(newURL);
//JOptionPane.showMessageDialog(null, ImgURL);
i = new ImageIcon(ImgURL);
while ( i.getImageLoadStatus() == MediaTracker.LOADING );
i.setImageObserver(jLabel1);
jLabel1.setIcon(i);
catch (Exception e)
* @param args the command line arguments
public static void main(String args[]) throws Exception {
java.awt.EventQueue.invokeLater(new Runnable() {
public void run() {
new mainfrm().setVisible(true);
// Variables declaration - do not modify
private javax.swing.JButton jButton1;
private static javax.swing.JLabel jLabel1;
private static javax.swing.JTextField jTextField1;
// End of variables declaration
