OCZ Vertex 2 / Agility 2 / Vertex LE Firmware 1.33
- Ersteller Nero24
Am 19. April hat OCZ eine neue Firmware 1.33 für die SSDs mit Sandforce SF-1200 Controller herausgebracht. Folgende Fixes:
Download: http://www.ocztechnology.com/files/ssd_tools/OCZToolbox_v2.36.zipIssues resolved since version 1.32
- Further enhanced robustness of data loss protection due to power interruption
- Fixed a rare issue with multiple 320GB or larger capacity drives in a LSI 9211 RAID0 configuration that would cause the drive to drop out from the RAID under heavy workload
Issues resolved since version 1.29
- Improved the time required to wake up from sleep & standby
- Further Improved NAND flash end of life behavior
- Fixed a rare condition that could cause the drive to reset and clear the data
- Fixed a rare condition in which a drive could hang if repeatedly rebooted without sufficient time to recover between cycles
- Reduced the drive boot time when it was shutdown improperly
- Improved FW efficiency for performance improvements of up to 5%
- Improved the File System block error handling process
Issues resolved since version 1.28
- Fixed rare corner case that could cause the drive to reset and clear user data
LostHero
- Osnabrück
- Medion Akoya P6630
- Intel Core i7 3770k (3,5Ghz)
- ASUS P8Z77-V Deluxe
- Prolimatech Genesis
- 2x8GB Corsair Vengeance (1866 Mhz @1,5V mit 9-10-9-27-2)
- Gigabyte NVIDIA Geforce GTX 680 (2GB)
- 27" ASUS VG278-X 120 Hz 3D Monitor
- SSD1: Samsung 840 Pro Series (512GB), SSD2: Intel X25 Postville (160GB), HDD1: 3TB, HDD2: 3TB
- LG BH10LS (Blue-Ray Combo Brenner)
- Creative X-Fi Titanium HD
- BitFenix ShinobiXL Big-Tower (gedämmt)
- Enermax Modu87+ (600 Watt)
- Windows 7 Professional SP1 (64 Bit)
- Puh zu viel...
Hm ich bin noch mit Fireware 1.11 unterwegs, denke es wäre mal an der Zeit für n Upgrade, wie isn das mit Datenreset beim Flashen? Bleiben die normalerweise erhalten oder muss ich danach ein Backup einspielen? (wären ~60 GB zu schreiben die natürlich direkt auf die Lebenserwartung gehen ^^)
Bugfixer
Bleiben normalerweise erhalten. Sind es bei mir auch geblieben.
LostHero
- Osnabrück
- Puh zu viel...
hmm weiß ja nich was ich davon halten soll:
Links mit 1.11 Firmware (fast schon antik
), rechts mit neuester 1.33er Firmware
.die Unterschiede sind gravierend!
Kann das jemand bestätigen?
SpaceMan
- Schweiz
- i7 2600k
- ASUS P8P67
- Noctua NH-U12P SE2 / 2x Noctua NF-P12 Gehäuselüfter
- 4x4GB Corsair Vengeance, DDR3-1600
- ASUS HD6950 2GB @6970 + Scythe Setsugen 2
- 27" Acer S273HL @1080p
- OCZ SSD Vertex 2 240GB
- Lian Li PC-8NB Midi-Tower
- Antec TP-650
- Windows 7 x64
- Logitech MX Revolution, Logitech Wireless Solar Keyboard K750
wenn du mir sagst mit welchem tool du das getestet hast, kann ich das heute abend mal anschauen. ich hab firmware 1.29 drauf.
ich habe jedoch die 240GB version, keine ahnung, ob das einen unterschied macht.
Bei mir (von 1.27 auf 1.33) ist der Wert ca. 10 Punkte gestiegen - und so sollte es laut Changelog auch sein. Insofern alles in Ordnung (bei mir).
Hast Du die Messungen unmittelbar hintereinander gemacht? Also Wert mit 1.11 kurz vor dem Flashen und Wert mit 1.33 kurz danach? Ansonsten kannst Du die Werte für einen Vergleich vergessen.
SpaceMan
- Schweiz
- i7 2600k
- ASUS P8P67
- Antec TP-650
- Windows 7 x64
kann man das update eigentlich jetzt normal im windows machen ohne was umzuhängen oder am system zu ändern? sonst habe ich nämlich keine lust dazu
LostHero
- Osnabrück
- Puh zu viel...
AS SSD Benchmark.
Und ja, die SSD Kapazität hat meistens (immer?) direkte auswirkungen auf die Performance.
Aber wäre dennoch interessant zu sehen, ob sich bei dir vorher/nacher was ändert, das würde dann dafür sprechen, dass es an der 1.33er liegt. Da ich ja noch die aller erste FW drauf hatte mit der die ersten SSDs von dem Typ ausgeliefert wurden kann es natürlich auch gut sein, dass bereits mit dem ersten Update der "leistungseinbruch" kam, etc.
@Nero24:
Ja, bzw quasi. Liegen 2 oder 3 tage zwischen, hatte in den 2 oder 3 Tagen aber auf der SSD nix datenmäßig geändert (ist meine "Games" partition und da tut sich nur alle paar monate was, wenn ich n neuen Titel installiere oder nen alten lösche. Die Savegames landen alle auf ner anderen System-SSD in den eigenen Dokumenten).
Auch andere Systemkomponenten wie Treiber, Biossettings, etc sind unverändert.
@Spaceman:
Ja. Wenns die System Disk ist fordert er am ende zwar nen (doppelten) reboot, zumindest unter W7, aber die Toolbox funktioniert problemlos.
SpaceMan
- Schweiz
- i7 2600k
- ASUS P8P67
- Antec TP-650
- Windows 7 x64
hi
ich hab jetzt mal die tests mit firmware 1.29 gemacht. partition c sieht ja eigentlich normal aus. die 2te partition hat aber bei 4K enorme einbrüche. was kann das denn sein?? es ist ja dieselbe SSD nur eine andere (grössere) partition. liegt das an der clustergrösse oder so?!?
Anhang anzeigen 22688 Anhang anzeigen 22689
EDIT: ich hab auf Partition D eine Clustergrösse von 1KB und auf C 4KB. Daran liegts wohl
. Ich ändere das jetzt mal...
SpaceMan
- Schweiz
- i7 2600k
- ASUS P8P67
- Antec TP-650
- Windows 7 x64
so, firmware 1.33 ist drauf.
ich habe beim schreiben auch viel tiefere werte! beim lesen ein wenig besser.
ob das so sein muss?!?
1.29:
1.33:
1.29:
1.33:
LostHero
- Osnabrück
- Puh zu viel...
Interessant, danke!
Bei dir sind die Werte insgesamt mit der 1.33er aber besser geworden als mit der 1.29er, bis auf das sequentielle Schreiben, da haste auch nen deutlichen Einbruch, bei mir fallen ja quasi sämtliche Werte deutlich ab hmhmhm.
SpaceMan
- Schweiz
- i7 2600k
- ASUS P8P67
- Antec TP-650
- Windows 7 x64
ich habe jetzt die 2te partition neu formatiert (mit 4KB cluster) und nochmals leer getestet:
jetzt sind die werte beim schreiben wieder besser
ich teste es dann nochmals, wenn wieder dieselbe datenmenge drauf ist... EDIT: Werte sind noch gleich. auch die Partition C hat jetzt beim seq. schreiben 70MB/s und nicht mehr 50, komisch.
Naja, hauptsache alles ist im Rahmen..
HelixUltra
Ich sollte auch mal meine kleine 60Gb Vertex2 updaten, aber ich habe noch keine Lust auf Datensichern und flashen über einen anderen Rechner, auch wenn dieser verfügbar wäre. Ich sag mal, "never change a runnig system"
Bin ich normalerweise voll bei Dir!Ich sag mal, "never change a runnig system"![]()
SpaceMan
- Schweiz
- i7 2600k
- ASUS P8P67
- Antec TP-650
- Windows 7 x64
Ich sollte auch mal meine kleine 60Gb Vertex2 updaten, aber ich habe noch keine Lust auf Datensichern und flashen über einen anderen Rechner, auch wenn dieser verfügbar wäre. Ich sag mal, "never change a runnig system"![]()
flashen geht ohne datenverlust und ohne umstöpseln am pc, hatte es gestern ja erst gemacht. natürlich kann immer mal was passieren, aber ist wohl eher die ausnahme. eine sicherung ist trotzdem eine tolle sache
LostHero
- Osnabrück
- Puh zu viel...
jo kann da SpaceMan nur zustimmen. War ja anfangs auch meine Sorge, aber das Flashen lief (bei mir) reibungslos direkt in Windows 7 über die OCZToolbox.
Warum W7 daraufhin ZWEI neustarts verlange ist mir zwar n rätsel aber gut, kann ich mit leben
Das Flashen ging auch unerwartet schnell, kannte bis Dato nur die Flashprozeduren beim Mainboard BIOS, das hat keine 2 Sekunden gedauert.
Und je nach dem was für ein Netzteil du verwendest dürfte sogar der Risikofaktor Stromausfall in diesem Fall unbedenklich sein (mein Enermax NT schafft 10-30 Sekunden "Notstrom" bei einem Stromausfall, je nach dem wieviel Last gerade auf dem System ist, allerdings braucht mein Rechner beim Anschalten auch erstmal gut 5 Sekunden ehe sich was tut da der Kondensator laden muss
