Allg. [Vorstellung] foobar2000 v2.2 Preview 2024-04-27 wurde veröffentlicht
foobar2000 1.6.7 beta 13 wurde veröffentlicht.
Version 1.6.7 beta change log (Thread im offiziellen Forum):
Beta 2:
  • Exclusive mode fixes.
Beta 3:
Beta 4:
  • Workaround for tag update errors if the the tags contain a malformed attached picture.
Beta 5:
  • Made Output preferences reflect output device changes made by output picker toolbar.
Beta 6:
  • Allowed per-track REM COMMENT in cuesheets.
  • Fixed crashing on failed paste operations in Properties dialog.
  • Fixed incorrect handling of UTF-8 file names inside ZIP archives.
  • HLS radio bug fixes.
  • Added a Monty Python easter egg.
Beta 7:
  • Rewritten exclusive-mode WASAPI output from scratch.
  • Removed 8-bit output option.
  • Fixed inaccurate preamp decibel formatting in Converter setup dialog.
Beta 8:
  • Exclusive-mode output fixes.
Beta 9:
  • Exclusive-mode output fixes; fixed "unsupported format" error regression.
Beta 10:
  • Exclusive-mode output fixes; fixed high CPU usage when paused regression.
Beta 11:
  • Fixed a beta 7 regression causing glitched audio after a change of parameters (such as sample rate or channel count).
  • Re-enabled 32-bit floating-point output with exclusive mode, some devices seem to accept it.
Beta 12:
  • Fixed beta 11 regression which caused errors with some 24-bit devices.
Beta 13:
  • Prevented popup of Preferences page prompting for a valid output device if the audio device was unplugged with foobar2000 in background.
  • Re-added Advanced Preferences setting to override exclusive-mode hardware buffer length.
  • Added a special fix for FOSTEX cards that do not work with system-default buffer length.
  • Fixed missing remapping of 5.1 vs 5.1-side channel configurations with exclusive mode.
Changelog v1.6.7:
  • Built-in WASAPI exclusive output.
  • Rewritten entirely in beta 7, old beta1-6 bugs should be gone.
  • Added 'smart stop' option in Advanced Preferences; press stop key once to stop-after-current, twice to stop now.
  • Fixed WavPack lossy not working regression from 1.6.6.
  • Made Output preferences reflect output device changes made by output picker toolbar. (beta 5)
  • Allowed per-track REM COMMENT in cuesheets. (beta 6)
  • HLS radio bug fixes. (beta 6)
  • Fixed crashing on failed paste operations in Properties dialog. (beta 6)
  • Fixed incorrect handling of UTF-8 file names inside ZIP archives. (beta 6)
  • Removed 8-bit output option. (beta 7)
  • Fixed inaccurate preamp decibel formatting in Converter setup dialog. (beta 7)
  • Prevented popup of Preferences page prompting for a valid output device if the audio device was unplugged with foobar2000 in background. (beta 13)
Download foobar2000 1.6.7 beta 13
foobar2000 for Mac 2.2.24 wurde veröffentlicht.
Changelog v2.2.24:
  • Fixed zip archive reading bugs.
  • Added Speex decoder.
  • HLS radio playback fixes.
Download foobar2000 for Mac 2.2.24
foobar2000 1.6.7 beta 14 wurde veröffentlicht.
Beta 2:
Beta 3:
Beta 4:
Beta 5:
Beta 6:
Beta 7:
Beta 8:
Beta 9:
Beta 10:
Beta 11:
Beta 12:
Beta 13:
Beta 14:
  • Worked around glitched playback after a buffer underrun.
Changelog v1.6.7:
Download foobar2000 1.6.7 beta 14
foobar2000 1.6.7 beta 15 wurde veröffentlicht.
Beta 2:
Beta 3:
Beta 4:
Beta 5:
Beta 6:
Beta 7:
Beta 8:
Beta 9:
Beta 10:
Beta 11:
Beta 12:
Beta 13:
Beta 14:
Beta 15:
  • Added .weba (WebM audio) to recognized formats.
  • Attempted WASAPI exclusive compatibility fixes (timed polling instead of event, 50ms default hardware buffer).
    When reporting exclusive mode issues, please compare vs beta 13 (download link).
Changelog v1.6.7:
  • Added .weba (WebM audio) to recognied extensions. (beta 15)
Download foobar2000 1.6.7 beta 15
foobar2000 for Mac 2.2.25 wurde veröffentlicht.
Changelog v2.2.25:
  • Fixed MP4 DASH regressions.
  • Added .weba (WebM Audio) to recognized Matroska/WebM file extensions.
Download foobar2000 for Mac 2.2.25
foobar2000 1.2.25 für Android wurde veröffentlicht.
Changelog v1.2.25:
  • Fixed a crash when seeking in specific audio files.
Download foobar2000 1.2.25 für Android
Bei Problemen mit Google Play: Standalone Android APK downloads
foobar2000 1.2.25 für iOS wurde veröffentlicht.
Changelog v1.2.25:
Changelog v1.2.23:
  • Regression fix.
Download foobar2000 1.2.25 für iOS
foobar2000 1.6.7 beta 16 wurde veröffentlicht.
Beta 2:
Beta 3:
Beta 4:
Beta 5:
Beta 6:
Beta 7:
Beta 8:
Beta 9:
Beta 10:
Beta 11:
Beta 12:
Beta 13:
Beta 14:
Beta 15:
Beta 16:
  • WASAPI compatibility fixes. Defaults are equivalent to well-behaved beta 13 (event instead of polling). You can override if your device doesn't agree.
Changelog v1.6.7:
Download foobar2000 1.6.7 beta 16
foobar2000 1.6.7 beta 17 wurde veröffentlicht.
Beta 2:
Beta 3:
Beta 4:
Beta 5:
Beta 6:
Beta 7:
Beta 8:
Beta 9:
Beta 10:
Beta 11:
Beta 12:
Beta 13:
Beta 14:
Beta 15:
Beta 16:
Beta 17:
  • Refactored exclusive mode overrides in Advanced Preferences.
  • Added a specific workaround for Intel SST Audio, so exclusive mode works without manual tweaks.
  • Prevented foobar2000 from starting up with foo_dsp_std.dll missing, or else normal playback fails. Note that this can only happen as a result of tampering with the installation, as foo_dsp_std.dll is always installed.
Changelog v1.6.7:
Download foobar2000 1.6.7 beta 17
foobar2000 1.6.7 Final wurde veröffentlicht.
Beta 2:
Beta 3:
Beta 4:
Beta 5:
Beta 6:
Beta 7:
Beta 8:
Beta 9:
Beta 10:
Beta 11:
Beta 12:
Beta 13:
Beta 14:
Beta 15:
Beta 16:
Beta 17:
Final:
  • Removed startup popups about old WASAPI component being outdated.
  • Improved exclusive mode compatibility with audio drivers that incorrectly report supported format list.
Changelog v1.6.7:
  • Fixed issues with playing certain streamed M4A files. (beta 16)
Download foobar2000 1.6.7 Final
foobar2000 for Mac 2.2.26 wurde veröffentlicht.
Changelog v2.2.26:
  • Updated Binary Comparator tool to the latest code.
Download foobar2000 for Mac 2.2.26
foobar2000 1.2.27 für Android wurde veröffentlicht.
Changelog v1.2.27:
  • Implemented add-to-playlist menu commands for various item groups & folder objects.
Download foobar2000 1.2.27 für Android
foobar2000 1.2.27 für iOS wurde veröffentlicht.
Changelog v1.2.27:
Download foobar2000 1.2.27 für iOS
foobar2000 1.2.28 für Android wurde veröffentlicht.
Changelog v1.2.28:
  • Improved FTP compatibility.
  • Fixed modern folder picker not being shown on Android 11.
Download foobar2000 1.2.28 für Android
foobar2000 1.2.29 für iOS wurde veröffentlicht.
Changelog v1.2.29:
  • Fixed FTP server bugs.
  • Visual tweaks in FTP server and TuneFUSION pages.
Changelog v1.2.28:
  • Fixed crashing with animated transitrions off.
Download foobar2000 1.2.29 für iOS
foobar2000 for Mac 2.2.30 wurde veröffentlicht.
Changelog v2.2.30:
  • Added dock icon progress bar for various operations.
  • Fixed various module (MOD/S3M/XM/IT) handling bugs.
Download foobar2000 for Mac 2.2.30
foobar2000 1.2.30 für Android wurde veröffentlicht.
Changelog v1.2.30:
Download foobar2000 1.2.30 für Android
foobar2000 1.2.30 für iOS wurde veröffentlicht.
Changelog v1.2.30:
Download foobar2000 1.2.30 für iOS
foobar2000 1.6.8 beta 1 wurde veröffentlicht.
Changelog v1.6.8:
  • Fixed visual glitches when scrolling lists horizontally with mouse wheel through Logitech software.
  • Improved output format negotiation with exclusive output.
  • Fixed failure to install components from store-mode (uncompressed) zip archives.
  • Improved handling of malformed FLAC files, prevented crash from too many cuesheet entries.
  • Correct reporting of AC3 channel count in MP4 files even without AC3 component installed (before it would incorrectly report stereo).
  • Allowed UTF-8 cuesheets without UTF-8 header.
  • Fixed htmlspecialchars misuse in component update list / component page link.
  • Mapped MP4 @mvn field to "movement name".
  • Prevented the same folder from being added more than once to the Media Library.
  • Properties dialog: deferred logging of user-entered field names for the dropdown list until the tags are saved, effectively preventing typos from being remembered.
  • Fixed a bug causing alt+f4 (and possibly other keyboard events) to be disregarded if mouse pointer is above specific interactive portion of a window (list controls, buttons in editboxes).
  • Improved handling of files with malformed APE tags - some files were entirely unplayable.
  • More thorough 'remove tags' for Vorbis, Opus and Musepack.
  • Fixed text truncation in ReplayGain Scanner preferences page.
Download foobar2000 1.6.8 beta 1
foobar2000 1.6.8 beta 2 wurde veröffentlicht.
Changelog v1.6.8:
Download foobar2000 1.6.8 beta 2
foobar2000 1.6.8 beta 3 wurde veröffentlicht.
Changelog v1.6.8:
  • Made possible to add attached pictures by drag and drop to relevant Properties dialgo page. (beta 3)
Download foobar2000 1.6.8 beta 3
foobar2000 1.6.8 beta 4 wurde veröffentlicht.
Version 1.6.8 beta change log (Thread im offiziellen Forum):
Beta 2:
  • Fixed Properties crash regression from beta 1
Beta 3:
  • Made possible to add attached pictures by drag and drop to relevant Properties dialog page.
Beta 4:
Changelog v1.6.8:
Download foobar2000 1.6.8 beta 4
foobar2000 1.6.8 beta 5 wurde veröffentlicht.
Beta 2:
Beta 3:
Beta 4:
Beta 5:
Changelog v1.6.8:
Download foobar2000 1.6.8 beta 5
foobar2000 1.6.8 beta 6 wurde veröffentlicht.
Beta 2:
Beta 3:
Beta 4:
Beta 5:
Beta 6:
Changelog v1.6.8:
Download foobar2000 1.6.8 beta 6
foobar2000 1.6.8 Final wurde veröffentlicht.
For Windows XP users, a bug-fix update of 1.5 series is available in old versions page.
Changelog v1.6.8:
Download foobar2000 1.6.8 Final
foobar2000 1.6.9 beta 1 wurde veröffentlicht.
Changelog v1.6.9:
  • Fixed Properties dialog glitches when scrolling content horizontally.
  • Fixed Converter setup dialog crash when using mouse forward/back buttons to navigate pages.
  • Fixed truncated text in Converter at 125% text size.
  • Fixed bad behavior of stricmp_utf8() function in shared.dll causing incorrect behavior of some components.
  • Fixed incorrect rendering of some Preferences page elements with Windows 7 classic theme.
  • Fixed a bug preventing some large folders from being added to playlist correctly.
  • Worked around apparent incorrect playback of audio tracks beginning with early drum hits with default output settings.
  • Updated middle-click-scroll marker.
  • Cleaned up various leftovers from old versions.
Download foobar2000 1.6.9 beta 1
foobar2000 1.6.9 beta 2 wurde veröffentlicht.
Changelog v1.6.9:
  • Fixed blank Properties content after some (but not all) of tag writes failed. (beta 2)
Download foobar2000 1.6.9 beta 2
foobar2000 for Mac 2.2.32 wurde veröffentlicht.
foobar2000 for Mac version 2.2.32 has been released, problems playing xHE-AAC on macOS Monterey have been fixed.
iOS counterpart with the same bug fix will be available shortly.
Changelog v2.2.32:
  • Fixed xHE-AAC failing to play on Mac OS Monterey.
Download foobar2000 for Mac 2.2.32
foobar2000 1.6.9 beta 3 wurde veröffentlicht.
Changelog v1.6.9:
  • Visual consistency fixes in Preferences, mainly affecting Windows 7 in classic mode. (beta 3)
Download foobar2000 1.6.9 beta 3
foobar2000 1.6.9 Final wurde veröffentlicht.
Changelog v1.6.9:
Download foobar2000 1.6.9 Final
foobar2000 1.5.9 Final (old) wurde veröffentlicht.
Changelog v1.5.9:
  • Bug fix update with latest fixes from 1.6 series.
Changelog v1.5.8:
  • Backported Matroska tagging code from 1.6 series, many bugs fixed.
  • Converter: Fixed some warning prompts not being possible to permanently disable.
Download foobar2000 1.5.9 Final (old)
foobar2000 1.6.10 beta 1 wurde veröffentlicht.
Changelog v1.6.10:
  • Fixed stuck now playing album art with many single tracks in one folder.
  • Workaround for certain radio serving .pls that 302-redirects to audio/mpeg stream.
  • Playlist Search: Don't reload view / drop selection if search refresh changed nothing.
  • Properly focus newly spawned UI Element popup - Library Search etc is now focused if invoked via global hotkey.
  • Implemented #EXT-X-PROGRAM-DATE-TIME for HLS internet radio.
Download foobar2000 1.6.10 beta 1
foobar2000 1.6.10 beta 2 wurde veröffentlicht.
Changelog v1.6.10:
Download foobar2000 1.6.10 beta 2
foobar2000 1.3 für Android wurde veröffentlicht.
Changelog v1.3:
  • Rewritten Android filesystem integration.
  • Added support for playing DTS and AC3 files.
  • Improved playlist manipulation features.
  • Media Library can now index folders shared with rclone over HTTP.
  • Internet radio compatibility fixes.
  • Options to toggle what's shown on the main screen, under Advanced.
  • New "internet radio" page where you can input and play your radio station URLs.
  • TuneFUSION pairing fixes, previously paired instances are no longer remembered indefinitely and falsely discovered when trying to pair a new one.
Download foobar2000 1.3 für Android
foobar2000 1.3 für iOS wurde veröffentlicht.
Changelog v1.3:
Download foobar2000 1.3 für iOS
