Neue Version für die freie Brennsoftware CDBurnerXP.
Runterladen: CDBurnerXP v4.3.1 2101
Changelog:
* Added support for .NET Framework 4.0
* Added -speed option to command line version
* New replace dialog (with option "replace changed files only")
*Command line version now behaves in a more useful way: -folder[\targetFolder]:sourcePath will add all contents within sourcePath into targetFolder, instead of adding the source folder as a sub directory
*Fixed an IOException in the language selection dialog
* Fixed FormatExcpetions when using Arabic translations
*Fixed: Burning ISO images close to the max. size fails with error message
