hat das was zu bedeuten? (projekt 2609)
- Ersteller trick
trick
- Lenovo ThinkPad X61
- Phenom II X4 940 Black Edition
- ASUS M3A78-T
- boxed
- 2 * 2048 DDR2-800 ECC Kingston
- onboard Radeon HD3300 / bei Bedarf GF8800GTS 512
- 20" nec 20wgx²
- 64er Solidata K5 SSD (Linux), 74er WD Raptor (Win 7)
- Benq DW1640
- Audigy2 ZS
- Lian Li PC-V600A
- Enermax Pro 82+ 425W
- Arch Linux amd64, ganz selten (zocken) Windows 7 Pro x64
moin moin!
gerade hat mein f@h-client ne fertige 2605 abgeliefert und sich nachschub geholt. aufgefallen ist mir ein "rejecting checkpoint" ganz zu anfang. habs unten markiert. hat das was besonderes zu bedeuten? hatte das noch nie.
tia
trick
edit:
oder hats was mit der vorherigen wu zu tun? eine der cores scheint nicht 0, sondern 18 als returncode ausgespuckt zu haben
Code:
[21:56:12] - Preparing to get new work unit...
[21:56:12] + Attempting to get work packet
[21:56:12] - Connecting to assignment server
[21:56:13] - Successful: assigned to (171.64.65.56).
[21:56:13] + News From Folding@Home: Welcome to Folding@Home
[21:56:13] Loaded queue successfully.
[21:57:45] + Closed connections
[21:57:45]
[21:57:45] + Processing work unit
[21:57:45] Core required: FahCore_a1.exe
[21:57:45] Core found.
[21:57:45] Working on Unit 06 [April 23 21:57:45]
[21:57:45] + Working ...
[21:57:45]
[21:57:45] *------------------------------*
[21:57:45] Folding@Home Gromacs SMP Core
[21:57:45] Version 1.73 (November 27, 2006)
[21:57:45]
[21:57:45] Preparing to commence simulation
[21:57:45] - Ensuring status. Please wait- Created dyn
[21:57:45] - Files status OK
[21:57:46] - Expanded 4014162 -> 21620008 (decompressed 538.5 percent)
[21:57:46] - Starting from initial work packet
[21:57:46]
[21:57:46] Project: 2609 (Run 1, Clone 47, Gen 3)
[21:57:46]
[21:57:46] Assembly optimizations on if available.
[21:57:46] Entering M.D.
[21:58:03] .5 percent)
[21:58:04] - Starting from initial work packet
[21:58:04]
[21:58:04] Project: 2609 (Run 1, Clone 47, Gen 3)
[21:58:04]
[21:58:04] Entering M.D.
NNODES=4, MYRANK=1, HOSTNAME=desktop
NNODES=4, MYRANK=3, HOSTNAME=desktop
NNODES=4, MYRANK=2, HOSTNAME=desktop
NNODES=4, MYRANK=0, HOSTNAME=desktop
NODEID=1 argc=15
NODEID=2 argc=15
NODEID=3 argc=15
NODEID=0 argc=15
Written by David van der Spoel, Erik Lindahl, Berk Hess, and others.
Copyright (c) 1991-2000, University of Groningen, The Netherlands.
Copyright (c) 2001-2004, The GROMACS development team,
check out http://www.gromacs.org for more information.
This inclusion of Gromacs code in the Folding@Home Core is under
a special license (see http://folding.stanford.edu/gromacs.html)
specially granted to Stanford by the copyright holders. If you
are interested in using Gromacs, visit www.gromacs.org where
you can download a free version of Gromacs under
the terms of the GNU General Public License (GPL) as published
by the Free Software Foundation; either version 2 of the License,
or (at your option) any later version.
[21:58:11] Rejecting checkpoint [COLOR="Red"]<-- das hier meine ich[/COLOR]
starting mdrun 'Protein'
500000 steps, 15000.0 ps.
[21:58:12] Protein: Protein
[21:58:12] Writing local files
[21:58:14] Extra SSE boost OK.
[21:58:14] Writing local files
[21:58:14] Completed 0 out of 500000 steps (0 percent)
tia
trick
edit:
Code:
[21:41:13] Past main M.D. loop
[21:41:13] Will end MPI now
[21:42:13]
[21:42:13] Finished Work Unit:
[21:42:13] - Reading up to 3714144 from "work/wudata_05.arc": Read 3714144
[21:42:13] - Reading up to 1762336 from "work/wudata_05.xtc": Read 1762336
[21:42:13] goefile size: 0
[21:42:13] logfile size: 16912
[21:42:13] Leaving Run
[21:42:14] - Writing 5497792 bytes of core data to disk...
[21:42:14] ... Done.
[21:42:20] - Shutting down core
[21:42:20]
[21:42:20] Folding@home Core Shutdown: FINISHED_UNIT
[0]0:Return code = 100
[0]1:Return code = 0, signaled with Quit
[0]2:Return code = 0, signaled with Quit
[0]3:Return code = 0, signaled with Quit
[21:42:32] CoreStatus = 64 (100)
[21:42:32] Sending work to server
[21:42:32] + Attempting to send results
[21:52:01] + Results successfully sent
[21:52:01] Thank you for your contribution to Folding@Home.
[21:52:01] + Number of Units Completed: 15
[0]0:Return code = 0, signaled with Quit
[0]1:Return code = 18
trick
- ASUS M3A78-T
- boxed
- 20" nec 20wgx²
- Benq DW1640
- Audigy2 ZS
- Lian Li PC-V600A
die aktuelle ist ne 2609, davor hatte ich ne 2605, die inzwischen auch schon gutgeschrieben wurde.bislang sind keine weiteren probleme aufgetreten. so gesehen scheint inzwischen wieder alles i.o. zu sein. der schreck war aber anfangs nicht gerade unerheblich
