Probleme mit Platte
SpitfireXP
19.11.2003
1.816
14
  • Spinhenge ESL
Hallo Leute...
Ich habe schon die Suchfunktion bemüht, aber bin zu keiner Lösung gekommen....
Irgendwie funzt die nicht mehr so schön wie früher....
Also...
Mein Problem besteht darin, das ich meine S-ATA-Platte nicht mehr mounten kann....
Wenn ich das versuche, friert mir das ganze Sys ein...
Darum habe ich mir gedacht, läßt fsck mal drüberlaufen...
Aber der bricht mir immer ab...
Code:
Athlon3200:/home/spitfire # fsck.reiserfs --rebuild-tree -S /dev/hda1
reiserfsck 3.6.13 (2003 www.namesys.com)
** Do not  run  the  program  with  --rebuild-tree  unless **
** something is broken and MAKE A BACKUP  before using it. **
** If you have bad sectors on a drive  it is usually a bad **
** idea to continue using it. Then you probably should get **
** a working hard drive, copy the file system from the bad **
** drive  to the good one -- dd_rescue is  a good tool for **
** that -- and only then run this program.                 **
** If you are using the latest reiserfsprogs and  it fails **
** please  email bug reports to reiserfs-list@namesys.com, **
** providing  as  much  information  as  possible --  your **
** hardware,  kernel,  patches,  settings,  all reiserfsck **
** messages  (including version),  the reiserfsck logfile, **
** check  the  syslog file  for  any  related information. **
** If you would like advice on using this program, support **
** is available  for $25 at  www.namesys.com/support.html. **
Will rebuild the filesystem (/dev/hda1) tree
Will put log info to 'stdout'
Do you want to run this program?[N/Yes] (note need to type Yes if you do):Yes
* Warning: The dma on your hard drive is turned off. *
* This may really slow down the fsck process.        *
Replaying journal..
Reiserfs journal '/dev/hda1' in blocks [18..8211]: 0 transactions replayed
reiserfsck --rebuild-tree started at Tue May 10 21:59:50 2005
Pass 0:
####### Pass 0 #######
The whole partition (49781408 blocks) is to be scanned
Skipping 9730 blocks (super block, journal, bitmaps) 49771678 blocks will be read
0%                                                      left 49770230, 482 /sec
The problem has occurred looks like a hardware problem. If you have
bad blocks, we advise you to get a new hard drive, because once you
get one bad block  that the disk  drive internals  cannot hide from
your sight,the chances of getting more are generally said to become
much higher  (precise statistics are unknown to us), and  this disk
drive is probably not expensive enough  for you to you to risk your
time and  data on it.  If you don't want to follow that follow that
advice then  if you have just a few bad blocks,  try writing to the
bad blocks  and see if the drive remaps  the bad blocks (that means
it takes a block  it has  in reserve  and allocates  it for use for
of that block number).  If it cannot remap the block,  use badblock
option (-B) with  reiserfs utils to handle this block correctly.
bread: Cannot read the block (9665): (Input/output error).
Abgebrochen
Ich habe schon alle möglichen optionen durchgeführt...
Hat noch jemand einen tipp für mich?
SpitfireXP schrieb:
Hallo Leute...
Code:
Steht doch alles da. Deine Platte hat defekte Sektoren. Verusch das Problem nach dem Text da oben zu beheben, falls das nicht klappt mach einen LowLevel Format.
Gruß,
Evil
Gruß,
Evil
Also ich kann das nirgendswo rauslesen. If ist bei mir immer noch eine Bedingung. Dass verschiedene Sektoren nicht gelesen werden können, kann alles mögliche als Fehlerursache haben, angefangen bei defekten Sektoren über kaputte Controller bis hin zu Treiberproblemen (bei ACPI). Mit dem Programm badblocks kann man das evtl. weiter untersuchen, und versuchen die Fehlerursache einzugrenzen. Sinnvoll ist hier meistens auch der Inhalt vom syslog, in dem Bereich, wo auf die Sektoren zugegriffen wird.
Gruß,
Evil
Du bist wohl auch einer der sorte, die alles mit einem Vorschlaghammer richten, oder?
LowLevel Format.....
Da sind daten drauf....
Die brauche ich noch...
Edit:// Kann mir mal einer sagen, wie das mit der option -B gehen soll?
Ich bekomme da immer fehler....
Sprich, ich tippe da was falsches...
Gibt es keine Software, mit der man die platte wieder zum laufen bewegt?
kannst du nicht mit ner KNoppix CD oder irgendeiner anderen Live CD darauf zugreifen ???
Dann könntest du die daten wenigstens noch sichern oder so ???
cybered
eben nicht...
Ich habe da wohl ein paar badblocks auf der platte...
Ich habe da auch schon eine liste mit den Blöcken...
Wenn ich nun die Platte mounten könnte, so, das die Badblocks nicht beachtet werden, könnte ich alle daten, die heile sind retten...
Aber soweit komme ich garnicht erst...
Danke..
Werde ich gleich mal testen...
Ich hatte eine extra platte als backup...
Aber die habe ich zwei tage vorher mit den Daten eines Freundes bespielt...
Habe die daten von seiner defekten platte rüberkopiert...
Und darum habe ich jetzt kein Backup mehr...
Ich könnte mir sowas von in den Ars** beißen...Da denkt man mal, das das wohl eine Woche ohne platte gut geht, und dann sowas....
