Probleme mit Platte
- Ersteller SpitfireXP
SpitfireXP
- HP Proobook 4730s
- Intel i5-2450M
- HP 167C
- 8GB
- Intel HD Graphics 3000 + HD7400M
- 2x Terra 24" Wide FullHD
- Samsunf Pro 840 512GB
- 1x DVD-RW (Combo)
- Logitech Z3 Soundsystem / USB Dockingstation
Hallo Leute...
Ich habe schon die Suchfunktion bemüht, aber bin zu keiner Lösung gekommen....
Irgendwie funzt die nicht mehr so schön wie früher....
Also...
Mein Problem besteht darin, das ich meine S-ATA-Platte nicht mehr mounten kann....
Wenn ich das versuche, friert mir das ganze Sys ein...
Darum habe ich mir gedacht, läßt fsck mal drüberlaufen...
Aber der bricht mir immer ab...
Ich habe schon alle möglichen optionen durchgeführt...
Hat noch jemand einen tipp für mich?
Also...
Code:
Athlon3200:/home/spitfire # fsck.reiserfs --rebuild-tree -S /dev/hda1
reiserfsck 3.6.13 (2003 www.namesys.com)
** Do not run the program with --rebuild-tree unless **
** something is broken and MAKE A BACKUP before using it. **
** If you have bad sectors on a drive it is usually a bad **
** idea to continue using it. Then you probably should get **
** a working hard drive, copy the file system from the bad **
** drive to the good one -- dd_rescue is a good tool for **
** that -- and only then run this program. **
** If you are using the latest reiserfsprogs and it fails **
** please email bug reports to reiserfs-list@namesys.com, **
** providing as much information as possible -- your **
** hardware, kernel, patches, settings, all reiserfsck **
** messages (including version), the reiserfsck logfile, **
** check the syslog file for any related information. **
** If you would like advice on using this program, support **
** is available for $25 at www.namesys.com/support.html. **
Will rebuild the filesystem (/dev/hda1) tree
Will put log info to 'stdout'
Do you want to run this program?[N/Yes] (note need to type Yes if you do):Yes
* Warning: The dma on your hard drive is turned off. *
* This may really slow down the fsck process. *
Replaying journal..
Reiserfs journal '/dev/hda1' in blocks [18..8211]: 0 transactions replayed
reiserfsck --rebuild-tree started at Tue May 10 21:59:50 2005
Pass 0:
####### Pass 0 #######
The whole partition (49781408 blocks) is to be scanned
Skipping 9730 blocks (super block, journal, bitmaps) 49771678 blocks will be read
0% left 49770230, 482 /sec
The problem has occurred looks like a hardware problem. If you have
bad blocks, we advise you to get a new hard drive, because once you
get one bad block that the disk drive internals cannot hide from
your sight,the chances of getting more are generally said to become
much higher (precise statistics are unknown to us), and this disk
drive is probably not expensive enough for you to you to risk your
time and data on it. If you don't want to follow that follow that
advice then if you have just a few bad blocks, try writing to the
bad blocks and see if the drive remaps the bad blocks (that means
it takes a block it has in reserve and allocates it for use for
of that block number). If it cannot remap the block, use badblock
option (-B) with reiserfs utils to handle this block correctly.
bread: Cannot read the block (9665): (Input/output error).
Abgebrochen
Evil E-Lex
SpitfireXP schrieb:Hallo Leute...
Code:The problem has occurred looks like a hardware problem. If you have bad blocks, we advise you to get a new hard drive, because once you get one bad block that the disk drive internals cannot hide from your sight,the chances of getting more are generally said to become much higher (precise statistics are unknown to us), and this disk drive is probably not expensive enough for you to you to risk your time and data on it. If you don't want to follow that follow that advice then if you have just a few bad blocks, try writing to the bad blocks and see if the drive remaps the bad blocks (that means it takes a block it has in reserve and allocates it for use for of that block number). If it cannot remap the block, use badblock option (-B) with reiserfs utils to handle this block correctly. bread: Cannot read the block (9665): (Input/output error).
Steht doch alles da. Deine Platte hat defekte Sektoren. Verusch das Problem nach dem Text da oben zu beheben, falls das nicht klappt mach einen LowLevel Format.
Gruß,
Evil
PuckPoltergeist
Evil E-Lex schrieb:Steht doch alles da. Deine Platte hat defekte Sektoren. Verusch das Problem nach dem Text da oben zu beheben, falls das nicht klappt mach einen LowLevel Format.
Gruß,
Evil
Also ich kann das nirgendswo rauslesen. If ist bei mir immer noch eine Bedingung. Dass verschiedene Sektoren nicht gelesen werden können, kann alles mögliche als Fehlerursache haben, angefangen bei defekten Sektoren über kaputte Controller bis hin zu Treiberproblemen (bei ACPI). Mit dem Programm badblocks kann man das evtl. weiter untersuchen, und versuchen die Fehlerursache einzugrenzen. Sinnvoll ist hier meistens auch der Inhalt vom syslog, in dem Bereich, wo auf die Sektoren zugegriffen wird.
SpitfireXP
- HP Proobook 4730s
- Intel i5-2450M
- HP 167C
- 8GB
- 1x DVD-RW (Combo)
Gruß,
Evil
Du bist wohl auch einer der sorte, die alles mit einem Vorschlaghammer richten, oder?
LowLevel Format.....
Da sind daten drauf....
Die brauche ich noch...
Edit:// Kann mir mal einer sagen, wie das mit der option -B gehen soll?
Ich bekomme da immer fehler....
Sprich, ich tippe da was falsches...
SpitfireXP
- HP Proobook 4730s
- Intel i5-2450M
- HP 167C
- 8GB
- 1x DVD-RW (Combo)
Gibt es keine Software, mit der man die platte wieder zum laufen bewegt?
Cybered
- Unimatrix-Zero
- Spin;Seti;QMC
- SETI
- Athlon 64 X2 3800+
kannst du nicht mit ner KNoppix CD oder irgendeiner anderen Live CD darauf zugreifen
Dann könntest du die daten wenigstens noch sichern oder so
cybered
cybered
SpitfireXP
- HP Proobook 4730s
- Intel i5-2450M
- HP 167C
- 8GB
- 1x DVD-RW (Combo)
eben nicht...
Ich habe da wohl ein paar badblocks auf der platte...
Ich habe da auch schon eine liste mit den Blöcken...
Wenn ich nun die Platte mounten könnte, so, das die Badblocks nicht beachtet werden, könnte ich alle daten, die heile sind retten...
Aber soweit komme ich garnicht erst...
pzgren
http://www.namesys.com/bad-block-handling.html
Jetzt weißt du auch, warum man immer eine gute backup Lösung parat haben sollte.
Grüße,
Marcus
Grüße,
Marcus
SpitfireXP
- HP Proobook 4730s
- Intel i5-2450M
- HP 167C
- 8GB
- 1x DVD-RW (Combo)
Danke..
Werde ich gleich mal testen...
Ich hatte eine extra platte als backup...
Aber die habe ich zwei tage vorher mit den Daten eines Freundes bespielt...
Habe die daten von seiner defekten platte rüberkopiert...
Und darum habe ich jetzt kein Backup mehr...
Ich könnte mir sowas von in den Ars** beißen...Da denkt man mal, das das wohl eine Woche ohne platte gut geht, und dann sowas....
