Die Version 2.21 des Tweaking-Programms für ATI- und NVIDIA-Grafikkarten ist erschienen und bietet zahlreiche Verbesserungen. RivaTuner bietet Zugriff auf zahlreiche nicht über den GeForce- bzw. Catalyst-Treiber erreichbare Einstellungsmöglichkeiten.
Die aktuelle Version unterstützt die aktuellen Treiber der beiden Hersteller bis zum ForceWare GeForce 180.84 und AMD ATI Catalyst 8.12.
<b>Version 2.21</b>
<blockquote><b>Minor bugfixes:</b>
<blockquote>* FOURCC INTZ and RAWZ formats are no longer forcibly disabled on GeForce 6 and newer display adapters when closing the 'Textures' tab in Direct3D tweaks dialog. Please take a note that these formats are required for proper GTA IV functionality, so if you experience problems with missing textures in this game on NVIDIA GeForce 6 and newer display adapters then please try to open the 'Textures' tab and press the 'Defaults' button.
* Fixed 'Restore after suspended mode' option in low-level fan control tab, corrupted in the previous release due to multi-GPU related core changes. </blockquote>
<b>What's new:</b>
<blockquote> * Updated databases for Detonator and ForceWare drivers. Added databases for ForceWare 180.60, 180.70 and 180.84.
* Added Catalyst 8.12 driver family detection.
* Added 'Enable FOURCC INTZ surfaces' and 'Enable FOURCC RAWZ surfaces' options to the 'Textures' tab of the Direct3D tweaks dialog.
* 'Restore after suspended mode' option in low-level fan control tab is multi-GPU oriented now. Now the option affects all display adapters in the system instead of currently selected display adapter only.
* 'Allow separate 2D/3D clock frequency adjustment' option is no longer provided when enabling driver-level hardware overclocking. The option is now hidden to reduce the amount of false bugreports posted by the beginners trying to disable 2D/3D clock frequncy then claiming that the hardware stays at extremely low boot clocks. Power users can still control this option via AllowMaxPerf registry entry.
* Extended list of detectable supported FOURCC formats in 'IDirect3D9 HAL adapter formats' diagnostic report category.</blockquote></blockquote>
<b>Download:</b> <a href="http://downloads.guru3d.com/RivaTuner-v2.21-download-163.html">RivaTuner 2.21</a>
<b>Link zum Thema:</b>
<ul><li><a href="http://www.guru3d.com/index.php?page=rivatuner" target="b">RivaTuner Homepage</a></li></ul>
