• In dieser Sektion des Forums werden Pressemitteilungen der Hersteller 1:1 veröffentlicht. Planet 3DNow! übernimmt weder für die Richtigkeit der Angaben noch für die Art der Formulierung jedwede Verantwortung. Oft sind Pressemitteilungen mit typischen Marketing-Floskeln wie "einer der bedeutendsten Herstellern von XY" versetzt. Diese Aussagen sind subjektiv und geben nicht notwendigerweise die Meinung der auf Planet 3DNow! schreibenden Autoren wieder.
PR Ryzen Embedded R2000 Series with Optimized Performance and Power Efficiency for Industrial, Machine Vision, IoT and Thin-Client Solutions
Press Release - englischsprachige Pressemitteilung
Pressemitteilung
<h3 class="spr-ir-news-article-title">New Ryzen Embedded R-Series system-on-chips provide up to 2X more cores, enhanced Radeon graphics, Windows 11 support, and versatile, multi-display configurability</h3>
NUREMBURG, Germany, June 21, 2022 (GLOBE NEWSWIRE) — (Embedded World 2022) AMD (NASDAQ: AMD) today announced the Ryzen™ Embedded R2000 Series, second-generation mid-range system-on-chip (SoC) processors optimized for a wide range of industrial and robotics systems, machine vision, IoT and thin-client equipment. Ryzen Embedded R2000 Series doubles the core count<sup>1</sup> and delivers a significant performance uplift compared to the prior generation, with the new R2515 model exhibiting up to 81 percent higher CPU<sup>2</sup> and graphics<sup>3</sup> performance than the comparable R1000 series processor. Performance-per-watt efficiency is also optimized using “Zen+” core architecture with AMD Radeon™ graphics for rich and versatile multimedia capabilities. Ryzen Embedded R2000 processors can power up to four independent displays in brilliant 4K resolution.​
Embedded R2000 Series processors are scalable up to four “Zen+” CPU cores with eight threads, 2MB of L2 cache and 4MB of shared L3 cache. This gives embedded system designers great flexibility to scale performance and power efficiencies with a single processing platform.
» Pressemitteilung lesen
