TAIPEI, Taiwan, August 6th, 2020 –The leading global motherboard, graphics card and mini PC manufacturer, ASRock, proudly announces the all-new DeskMini H470 and DeskMini X300.
The Power of 10! - DeskMini H470
ASRock DeskMini H470 adopts the Intel® H470 chipset to support Intel® 10th Gen 65W LGA1200 processors and dual-channel DDR4-2933 memory. Relying on advanced power design, it supports exclusive BFB (Base Frequency Boost) Technology to allow users to bump non-K processors speed to enhance system performance.
DeskMini H470 not only features USB Alternate Mode Type-C, providing 4K resolution DisplayPort signal, up to 60-watt power delivery, and 5Gbps data transfer through one cable. Also, it supports USB 3.2 Gen2 Type-A & Type-C in the front panel to offer rapid connection. It brings Ultra M.2, dual SATA 6Gb storages, and M.2 Wi-Fi slot. For superior user experience, DeskMini H470 supports 3 video outputs simultaneously via DisplayPort, Type-C DP, HDMI, and D-Sub.
Unlocked Power – DeskMini X300
All-new DeskMini X300 not only supports AMD latest Ryzen 4000 series APU, but also allows users to adjust CPU/GPU core clock, and tuning voltage to excavate APU potential power. DeskMini X300 supports 8 Cores Ryzen 7 APU and dual-Channel DDR4-3200+MHz (OC) memory, which leads to outstanding computing power and 3D performance.
DeskMini X300 is equipped with two Ultra M.2 (2280) slots for PCIe Gen3 high-speed SSDs and two 2.5" SATA 6Gbps interface for RAID function. Moreover, the DeskMini X300 is able to connect three display outputs simultaneously, which greatly improves the user experiences. It also supports USB 3.1 Gen1 Type-C and M.2 Wi-Fi module, and various accessories within 1.9 Liter compact size.
For more information please visit:
https://www.asrock.com/nettop/Intel/DeskMini H470 Series/index.asp
https://www.asrock.com/nettop/AMD/DeskMini X300 Series/index.asp
