AOpen stellt A600A Super Tower vor
- Ersteller Nero24
AOpen hat heute sein neues High-End Gehäuse namens A600A Super Tower vorgestellt, ein schwarzes Aluminiumgehäuse als Gegenstück zur bewährten H600 Serie. Hier die Featureliste:<ul><i><b>Model name: A600A.</b>
· Color: black mirror-coating on aluminum, with metallic gray plexi-glass.
· Board Size: ATX/microATX/Full AT.
· Drive Bays: 4x 5.25" bays and 8x 3.5" bays (2 external and 6 internal).
· Power Supply: 350W 12cm silent power supply with UL/CSA/CE/VDE/S/D/N/FI/FCC/DoC certification.
· Ventilation: Intel-defined air guide with one 12cm color fan pre-installed (recommended for Pentium 4 3.06GHz systems or above), and one additional optional slot for 8cm fan for further ventilation enhancement.
· Dimensions: 49.1cm (Depth) x 20.0cm (Width) x 45.0cm (Height).
· Front connection: front 2x USB 2.0 access, audio and 6 pin firewire (IEEE 1394).
· Additional features: thumb-screws for side plate, screwless mechanism for optical, FDD and HDD drives.
· Fully CE-compliant with major safety & electronic measures approved.</i></ul>Ein Foto des A600A Super Tower sowie die komplette Pressemitteilung gibt's <a href="http://www.planet3dnow.de/vbulletin/showthread.php3?s=&postid=918724#post918724">hier</a>. Die unverbindliche Preisempfehlung von AOpen lautet 159,00 EUR...
Pressemitteilung:
AOpen launches the A600A Super Tower,
the black aluminum counterpart of the award-winning H600 series
In answer to the popular demands for aluminum tower cases from its worldwide customers, AOpen Computer GmbH announced the A600A, the newest aluminum super tower, is now being shipped to AOpen distribution channels across Europe.
A600A is the second aluminum case AOpen has launched, but the first in the super tower market. It's one of the top choices for users who need an aluminum case for expandability, flexibility, performance and modding capabilities.
Following AOpen's tradition in excellence, this new series incorporates features from the latest technologies on the mechanical design. A600A is an ATX/microATX/Full AT super tower, bearing AOpen's signature for the guarantee of the quality we are committed to. It features an ample supply of drive bays; excellent ventilation with additional fan possible; screwless functions for optical, FDD and HDD drives; a powerful 350W ultra low noise switching power supply; and front access for 2x USB 2.0, audio and 6-pin firewire (IEEE-1394) connections. In addition, A600A also integrates the latest Intel-defined air guide for a 38-degrees system so that users would not need to worry about the system overheating. Combined with our silent power supply, it is the best solution when you're looking for a high-performance and low-noise system.
Furthermore, great efforts have been devoted to aesthetical aspects as well. It is the first chassis to which the "mirror coating" method was applied. The Mirror Coating method gives the chassis a shining surface similar to a car coating. To emphasize this feature, we decided to launch our first aluminum case in black instead of the natural silver color of aluminum, which makes the A600A a truly unique experience: a black aluminum case with mirror coating.
<a href="http://www.planet3dnow.de/cgi-bin/newspub/viewnews.cgi?category=1&id=1051614845">Zurück zur Newsmeldung</a>...
Ronin[XiC]
die füsse passen so nicht richtig ins bild, sehen aus wie riesesn clown schuhe ... an sich ganz nett
meiner meinung nach, sieht das eher nachm mini tower als nachm SUPER tower aus ;(
Passen da etwa wirklich AT Boards rein? Und dann auch noch Fullsize? (Die Fullsize Boards haben über dem Keyboard Anschluss nochmal 5 Pci Slots)
[P3D] Stoneweapon
Na ja. Wenn er billig ist, warum nicht.
Sieht für ein Alugehäuse recht gewöhnlich aus. Hätte auch als 59,- EUR incl. NT Tower durchgehen können.
Dafür bleibt mehr Spielraum bzw. Bedarf für Casemodding.
Wer dem Battlefield Squad der Players beitreten will, bitte hier melden.
Meine Kiste bei Nethands http://players.planet3dnow.de
OmaKuschel
- Lenovo X300
- Core 2 Duo E7200 (8,5*400MHz)
- Gigabyte EP-P45-DS3R
- Alpenföhn Groß Clockner @ Scythe Slipstream 120mm 800rpm
- 2x 2GB G.Skill DDR2-1000
- Gigabyte ATI 4850 512MB @ Arctic Cooling Accelero S1 Rev.2 @ Scythe Slipstream 120mm 800rpm
- Videoseven D24W33
- Samsung F1 750GB 32MB @ Cooltek Disk Silencer
- LG GH20NS15
- Onboard ALC889A
- Sharkoon Rebel 9 Economy schwarz
- beQuiet 450W Straight Power
- Windows Vista Prof. x64 & Ubuntu 9.04 x64
- Multi-Cardreader , 2x Scythe Slipstream 120mm 800rpm Front , 1x Scythe Slipstream 120mm 800rpm Front
und was kostet der spass ungefähr?
Ghanja
CN_Laertes
- ThinkPad x370
- AMD Ryzen 9 3950
- Asus Prime X370-Pro AMD X370 So.AM4
- Enermax Liquid III
- 32GB G.Skill Trident Z silber/rot DDR4-3200 DIMM CL14 Dual Kit
- 6GB Gigabyte GeForce GTX 1060 G1 Gaming 6G 2x
- 2x DELL 2515 1920x1080
- 500GB Samsung 960 Evo M.2 2280 NVMe PCIe
- 4 TB Seagate BarraCuda SATA 6Gb/s
- onbord
- Fractal Design Define R5 Blackout Edition gedämmt
- Seasonic PCGH-550
- Win 10 Pro
Sieht meiner Meinung nach, doch gut aus, wenn man von 160 (T)euro und 350 Wat(t) absieht...
Grenzdebil
kenne den 600 ohne Alu und "Airguide". Ist ein feines gut, durchdachtes Gehäuse. Das beste daran wird das Netzteil sein, ist dieses unhörbare mit 120er Lüfter drin, wo an der Netzteilrückseite nur Öffnungen sind, selbst aber kein Lüfter.
ich finde es ganz schick, aber wirkt nicht so hochwertig wie Lian-Lis oder Coolermaster. Wäre man interessant es getested zu sehen bzgl. Vibtrationen und so.
habe ich das richtig gelesen? 1x 120er luefter und 1x 80er luefter? und festplatten werden mit einem der ventilatoren gekuehlt? wenn dem so ist stoert mich der preis nicht, weil ich habe mir extra schwarze laufwerke bestellt *freu*
cooler master ja, aber lian li siet doch schäbig aus...
