Quake 3 Pr. 1.30 Finale erschienen!!
- Ersteller HELLRAISER
HELLRAISER
Endlich ist das Finale Pr. 1.30 zu Quake 3 Arena :Hier die Fixes und Änderungen im Detail:
- /in_mouse command - The cvar in_mouse can be used to set the "feel" of the sensitivity back to previous versions of Quake III.
- New id Created Pro maps - is has made some modifications to some of the more popular maps that shipped with Quake III including "The Camp Grounds", "Lost World", "The Proving Grounds", and "Vertical Vengeance".
- New Network Code - There is a new compression system built into the network code of the latest point release.
- New Cheating Counter Measures - Quite a bit of new code added to make it much more difficult to cheat and hack the game.
- New Protocol Change - The changes made to improve network code and prevent cheating will make this and future version of Quake 3 and Team Arena incompatible with older versions.
F- ixed sound bug (with Graeme hints) -- this crashed some mods
- Made sure Sys_Printf doesn't get into an endless loop if logfile is on
- Fixed qconsole.log issues, +set logfile 1 +set fs_debug 1 was crashing (any OS)
- Fixed logfile 1 / ttycon 1 issue, didn't exit properly (same endless looping) Also fixes an issue reported by q3f team
- Changed rcon commands from Com_DPrintf to Com_Printf so that they show up in the console (with IP information)
- Fixed autodownload toggle in Quake III UI
Besonders der neue Netcode dürfte interessant werden und auch die neuen Maps werden sicher wieder etwas Salz in die tägliche Gaming-Suppe streuen.
ftp://ingame.gcpro.de/planetquake/patches/q3pointrelease_130.exe^
ftp://ftp.idsoftware.com/idstuff/quake3/win32/q3pointrelease_130.exe
Gast03032021
heißt das nicht Nirvana
HELLRAISER
Dann sind die Sever wohl voll ausgelastet gell.....
Habe selbst gerade dort gezogen.
HELLRAISER
ansonsten www.planetquake.de
[quote author=[OC-Tweaks]E@rthkiller link=board=SonstigeSoftware&num=1001673461&start=0#2 date=09/28/01 um 14:20:59]
[/quote]
Hast bestimmt zuviel Mucke von Nirvana gehört!?
mr-online
- SETI@Home SIMAP
- SETI@Home
- PIII-S 1266,
- Acer Extensa 5220
- Power II-3 400MHz 4M L3
- 44P-170
- Standart
- 512MB ECC 208pin
- GXT130P 8MB
- Putty Shell
- 2x 9GB U160 System + 36 GB SCA Daten
- IBM 24x
- RS/6000 44P-170 Standfloor
- 390 Watt A-PFC
- Fedora Core 5 PPC 64bit
- Schwarz, Kantig, Laut und echte 64 Bit !!!
Der .de link geht.
der andere .com ist daten müll.
mr-online
- SETI@Home SIMAP
- SETI@Home
- PIII-S 1266,
- Acer Extensa 5220
- 44P-170
- Standart
- 512MB ECC 208pin
- GXT130P 8MB
- Putty Shell
- IBM 24x
- 390 Watt A-PFC
Hätte mal einer dazu Schreiben sollen das es sich hir um 26,7MB handelt
Gast03032021
[quote author=Bibo link=board=SonstigeSoftware&num=1001673461&start=0#6 date=09/28/01 um 22:55:57]
[/quote]
kann gut sein
[quote author=The One link=board=SonstigeSoftware&num=1001673461&start=0#10 date=09/29/01 um 10:30:53]
sollte noch wer links brauchen
http://www.filemirrors.com/ => q3pointrelease_130.exe
eingeben, fertig, sauge grad mit 35kb/s von ftp.clanbase.com
the one
[/quote]
Ich sauge grad von dem oberen ftp server mit 91 kb/s
HELLRAISER
Das coole am 1.30 ist das endlich wieder die Severauflistung wunderbar funzzt. Und nicht wie vorher 2048 Sever found und dann 20Minuten warten bis alle ctf Sever aufgelistet sind, wovon dann 8 oder 9 aufgelistet werden. Der 1.17 fuzzte genau so gut.
Hellraiser
Hellraiser
