Quick CPU
Download Quick CPU 4.0.1.0
pipin
Administrator
Teammitglied
16.10.2000
24.486
9.834
East Fishkill, Minga, Xanten
  • SIMAP Race
  • QMC Race
  • RCN Russia
  • Spinhenge ESL
  • Docking@Home
  • BOINC Pentathlon 2019
  • SETI@Home Intel-Race II
  • THOR Challenge 2020
  • BOINC Pentathlon 2021
  • BOINC Pentathlon 2023
pipin aktualisierte Quick CPU mit einem neuen Updateeintrag:
Quick CPU 3.3.5.0
Some of the features are CPU dependent and wont be available in your version of the CPU.
  • Fixed memory leak issue introduced in 3.3.4.0
  • Added preliminary support for Intel Jasper Lake
  • Added preliminary support for AMD Ryzen Cezanne
  • Added support for Intel Tiger Lake-H version
  • Added changes to error reporting dialog
Lese den Rest der Aktualisierung...
pipin hat Quick CPU mit einem neuen Updateeintrag aktualisiert:
Quick CPU 3.5.0.0
Release date: Apr 21, 2021
Highlights
Below are the highlights for version 3.5.0.0
  • Added Memory Cleanup feature to system tray menu.
  • Added TDP info for supported AMD Ryzen CPU's.
  • Added TDP L1 info for supported AMD Ryzen CPU's.
  • Added TDP L2 info for supported AMD Ryzen CPU's.
  • Added TjMax info for supported...
Lies den Rest der Aktualisierung…
Quick CPU 3.5.1.0
Release date: June 2, 2021
Highlights
Below are the highlights for version 3.5.1.0
  • Added Memory Cleanup feature to system tray notification dialog.
  • Added support for AMD Ryzen APU's 5700G, 5600G, 5300G
  • Added new functionality for Advanced CPU Settings for Intel CPU's...
Quick CPU 3.6.0.0
Quick CPU Release notes for version - 3.6.0.0​
Release date: July 19, 2021
Highlights
Below are the highlights for version 3.6.0.0
  • Added new top chart to the main application form to display load distribution for each CPU core.
  • Added new side application chart to the main application form to display CPU Temperature...
Quick CPU 3.6.1.0
Release date: July 23, 2021
Highlights
Below are the highlights for version 3.6.1.0
Current release 3.6.1.0 is a hotfix release that's addressing a bug that was introduced in application version 3.5.1.0, the fix for this bug was excluded from the 3.6.0.0 release by mistake. Please see release details below.
  • Fixed bug introduced in...
Quick CPU 4.0.0.0
Release date: Sept 22, 2021
Highlights
Below are the highlights for version 4.0.0.0
  • Introduced Dockable panels
    1. Added the ability to Show, Hide and Dock panels (use panel window controls or use Panel menu)
    2. Added the ability to detach one or all the panels and make them floatable (use panel window controls or use Panel menu)...
