Display adapter ATI Radeon Graphics Processor (0x5652)
Core Name M26
SubVendor Unknown 144D
SubDevice C018
BUS 1
Device 0
Function 0
Base Address 0 D0000008
Base Address 1 00003001
Base Address 2 C0100000
Base Address 3 00000000
Bus Type PCI Express
SMARTGART Installed No
Driver Version 07.11
Release Version 8.432-071101a-054435C-ATI
QuadBuffer Stereo Support No
Catalyst Registry Path
System\CurrentControlSet\Control\Video\{3572AD55-06C6-446B-B6C5-2FA2AEB78B1A}\0000
______________________________
Clock Information
BIOS VPU 350,00
Current VPU 351,00
BIOS MEM 330,00
Current MEM 330,75
Overdrive
Supported No
Radeon PCI configuration space
00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
00 02 10 52 56 07 01 10 00 00 00 00 03 08 00 00 00
10 08 00 00 D0 01 30 00 00 00 00 10 C0 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 4D 14 18 C0
30 00 00 00 00 50 00 00 00 00 00 00 00 10 01 00 00
40 00 00 00 00 00 00 00 00 00 00 00 00 4D 14 18 C0
50 01 58 02 06 00 00 00 00 10 80 01 00 A0 04 2C 01
60 10 09 00 00 01 AD 00 00 40 00 01 11 00 00 00 00
70 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
80 05 00 80 00 00 00 00 00 00 00 00 00 00 00 00 00
90 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Hardware Information ASIC (Software) Method
Family 59
Emulated Revision 3
Gfx Engine ID 3
VRam Bit Width 128
Installed memory 128
Hardware Information Direct hardware access
Installed memory 128 Mb
Memory Type GDDR3
Memory Width 128 bit
Active Rendering Pipelines 8
Radeon Registers
RADEON_BIOS_0_SCRATCH 02040000
RADEON_BIOS_1_SCRATCH 0100C000
RADEON_X_MPLL_REF_FB_DIV 00343104
RADEON_XCLK_CNTL 00807FFA
RADEON_MCLK_CNTL 00031212
GB_TILE_CONFIG 00010017
MC_TIMING_CNTL 69444222
MC_SDRAM_MODE_REG 10230000
Video BIOS Information
Version 009.010.001.011
Part Number BR12895/rel9.10.1.11/CL186018
Date 2005/05/04 14:36
Vram Type DDR1
Controller Configurations
Controller 0
Active Connections:
-LCD Panel (Laptop) (0) 1400x1050x60
Controller 1
Active Connections:
No Active Connections
Displays supported by adapter
0 (1) Monitor (CRT1)
1 (2) Component Video Output
2 (4) LCD Panel (Laptop)
3 (8) TV
4 (16) Digital Flat Panel
EnumDisplays
Display Type 0, Extended Type 1 , Max Resolution 1600x1200
Display Type 4, Extended Type 0 , Max Resolution 720x480
Display Type 2, Extended Type 0 , Max Resolution 1400x1050
Display Type 1, Extended Type 7 , Max Resolution 1024x768
Display Type 3, Extended Type 1 , Max Resolution 0x0
Loaded Displays
Display 1 index 4
Display 2 index 61440
TV Index 8
Multi VPU State
ulActiveAdapters 1
ulAvailableAdapters 0
ulCurrentAdapter 0
ulDongleCapabilities 0
ulDongleConnection -1
ulDongleDisplayIndex 0
ulPrimaryIndex 0
ulMVPUMaxFBSize 0
ulMVPUMaxPipes 0
ulMVPUMaxVisFBSize 0
ulMVPUState 1
State Bits
NOINTERCONNECT
Multi VPU Caps
No additional information
