Download SpeedFan 4.41
- Ersteller Dr@
Dr@
- Baden-Württemberg
- Collatz Conjecture
- Zacate E-350 APU
- E35M1-I DELUXE
- DVD-Brenner
- Firefox 13
<div class="newsfloatleft"><a href="http://www.almico.com/speedfan.php"><img src="http://www.planet3dnow.de/photoplog/images/54308/1_SpeedFan.png" border="1" alt="SpeedFan"></a></div>Das kostenlose Hardware-Überwachungsprogramm SpeedFan ist in der Verion 4.41 erschienen. Mit dem Programm lassen sich Temperatursensoren (CPU, GPU, HDD usw.), S.M.A.R.T.-Werte, Lüfterdrehzahlen und Spannungen auslesen. Teilweise lassen sich auch Lüfterdrehzahlen und Taktraten manuell einstellen.
<p style="clear:left">
Speedfan läuft unter Windows ab Windows 98.
<b>Changelog:</b><blockquote><i>- added full support for Intel 5 Series/3400 Series SMBus
- added full support for Intel QST 2.x
- added full support for fan control for Intel QST
- added full support for Fintek F71889F
- added full support for Fintek F71889ED
- added full support for SB8x0 SMBus
- added full support for Nuvoton W83677HG-I
- added full support for Nuvoton W83667HG-B
- added SB7xx/8xx PM2 fan speed readings and fan control
- added full support for MCP98242
- added full support for CAT34TS02
- added support for ITE IT8721F
- added support for USB hard disk enclosures with Cypress chipset
- added W83791D advanced settings for PWM MODEs
- improved ADT7490 PWM MODE advanced settings
- added ADVANCED options for Fintek F75387 PWM MODEs
- fixed Fintek F75387F PWM setting
- enabled SMBus on Intel ICH9-M, if needed
- added detection of LIS331DL
- added Intel QST 2.x advanced option to revert back to AUTO fan control
- upon resume from suspend only those fans that are automatically variated are initially set to 100%
- identified more CPUs
- Intel Atom Series 300 Tjmax set to 90C
- HECI support works only on Windows 2000 and later
- AMCC/3ware support works only on Windows 2000 and later
- added more names for SMART attributes
- added a new option to CONFIGURE / OPTIONS to disable SMART Summary Error Log on program start (this can dramatically improve SpeedFan startup time)
- the UI is now updated whenever new SMART data is read from the selected hard disk
- now, in CONFIGURE / EVENTS, when you press UPDATE to change some event, the editing fields are automatically cleared and the OK button is automatically enabled
- restored access to SMART attributes on AdvSmart, Areca and AMCC/3ware connected drives in Event configuration window
- events can now react to FITNESS and PERFORMANCE values of SMART hard disks
- added NOADVSMARTSCAN command line switch
- the first line of the email sent by an EVENT now has been changed to include the Machine Name</i></blockquote></p>
<b>Download:</b>
<ul><li><a href="http://www.planet3dnow.de/cgi-bin/file/get.cgi?20100725213157">SpeedFan 4.41 [Setup] - Lokaler Mirror</a></li></ul>
<b>Links zum Thema:</b>
<ul><li><a href="http://www.almico.com/speedfan.php" target="b">Offizielle Internetpräsenz</a></li>
<li><a href="http://www.planet3dnow.de/cgi-bin/newspub/viewnews.cgi?category=2&id=1279305364" target="b">System Information for Windows (SIW) 2010 build 0714</a></li><li><a href="http://www.planet3dnow.de/cgi-bin/newspub/viewnews.cgi?category=2&id=1278960578" target="b">NVIDIA Inspector Tool 1.90</a></li><li><a href="http://www.planet3dnow.de/cgi-bin/newspub/viewnews.cgi?category=2&id=1278700437" target="b">CPUID CPU-Z 1.55</a></li><li><a href="http://www.planet3dnow.de/cgi-bin/newspub/viewnews.cgi?category=2&id=1278520795" target="b">Core Temp 0.99.7.3</a></li><li><a href="http://www.planet3dnow.de/cgi-bin/newspub/viewnews.cgi?category=2&id=1277990516" target="b">GPU-Z 0.4.4</a></li></ul>
<b>Download:</b>
thunderbuster
- Poem , collatz
- derzeit poem
- xp 1800, xp 2400,x2 4400,x2 4200, pentium m baninas 1300 ,3650
- Acer Travelmate 800
- Centrino 1300
- Acer Gedigens
- Heatpipe/ aktiv
- 1,25GB
- mobility radeon 9000
- 15zoll 1400/1050
- Firefox 2.0
nutze es immernoch gerne
Dalai
- Meiningen, Thüringen
- ASUS Prime X370-A
- Samsung 850 Evo 250 GB
- Lian Li PC-8NB Midi-Tower
Bin mal gespannt, wann SpeedFan endlich in der Lage ist, mehrere Temperaturen im Tray anzuzeigen (analog zu MBM) und nicht nur eine. Wird wohl nichts mehr in diesem Leben... Dennoch verwende ich es, wenn auch in erster Linie, weil MBM leider tot ist.
MfG Dalai
MfG Dalai
Dalai
- ASUS Prime X370-A
Ich nicht. Zumal es im XP den "schönen" Bug gibt, dass Tooltips hinter der Taskleiste verschwinden - sehr hilfreich, nicht nur in diesem Fall. Aber ich möchte es ja auch nur als Option, d.h. wer's nicht will/braucht, muss es nicht nutzen.Finds eigentlich ausreichend dass man bei Maus over dann alle Temps sieht.
MfG Dalai
