Allg. [Vorstellung] foobar2000 v2.2 Preview 2024-05-01 wurde veröffentlicht
- Ersteller Jimi
Jimi
- Hamburg
- Klöterkasten
- AMD Ryzen 7 5700X
- MSI B550-A Pro
- ENDORFY Fortis 5
- G.Skill RipJaws V schwarz DIMM Kit 32GB, DDR4-3600, CL18-22-22-42
- Palit GeForce GTX 1650 KalmX (passiv)
- AOC Q3277PQU, 32" @ 2560x1440
- Western Digital WD_BLACK SN850 500GB, M.2, Kühlkörper & Lexar NM790 4TB, M.2
- Hitachi-LG Data Storage GP57EB40 schwarz, USB 2.0
- MOTU M2 & Topping L30
- NZXT H7 Flow Black @ 6x ENDORFY Fluctus 140 PWM @ ~600 rpm
- Seasonic Focus GX 550W
- Logitech K310
- Sharkoon FireGlider
- Windows 10 Home x64 @ WinReducer
- Fluid Audio F5 Speaker & Fluid Audio DS 5 Stands, Hifiman Arya Stealth, Sennheiser HD 560S
- ▼275 ▲55
foobar2000 1.3.19 Final wurde veröffentlicht.
Download foobar2000 1.3.19 Final
This is another no-new-features bug-fixes-only update of the 1.3 series.
Changelog v1.3.19:
This is a maintenance update, contains only bug fixes backported from 1.4 series.
- Made possible to load our own M3U8 files again. Sigh.
- Worked around certain Ogg files playing incorrectly.
Jimi
- Hamburg
- Klöterkasten
- AMD Ryzen 7 5700X
- MSI B550-A Pro
- ENDORFY Fortis 5
- Logitech K310
- ▼275 ▲55
foobar2000 1.4 beta 20 wurde veröffentlicht.
Download foobar2000 1.4 beta 20
Changelog v1.4:
- Added preferences page to adjust priority order of installed decoders.
- Greatly improved DSP manager dialog.
- Default User Interface improvements:
- New toolbar items for switching output modes, ReplayGain modes and DSP presets.
- Improved status bar: added optional display of selected track count.
- Reworked Preferences pages; improved options for minimize & close behaviors.- Converter improvements:
- Keeping incomplete/problematic output files is now optional; they're deleted by default.
- New and improved overwrite prompt dialog.
- FDK AAC is now among the default presets.- ReplayGain scanner improvements:
- Greatly improved “Apply Gain to File Content” feature, with multi threading and more supported formats.
- Added command to manually manipulate Opus header gain field for both .opus and Matroska.
- New Preferences pages.- Playlist & Media Library search use a new text-matching algorithm similar to Unicode Asymmetric Search.
- Cosmetic tweaks; prettier buttons attached to editboxes in various dialogs.
- Cleaned up Opus header gain manipulation, reported value no longer offseted by 5 dB, made header gain respected when embedded in Matroska container.
- Amended Matroska tagging, certain rare files that would fail to update before are now taggable.
- Matroska support improvements, improved seeking performance on files without seektables.
- Made possible to choose between alternate audio streams in MP4 and Matroska files.
- Implemented WebM internet stream playback.
- Compiled using dynamic VC runtime, raising the limit of how many component DLLs can be loaded.
- Made Album List remember expanded nodes.
- Raised track count limit for cue sheets from 99 to 999.
- Integration with Windows 10 Universal Volume Control.
- Playback controls in taskbar on Windows 7 and newer.
- Configuration saving now uses transacted NTFS if available.
- Changed the way playlists and media library data are stored to minimize the amount of rewriting on each app shutdown.
- Merged networking features from foobar2000 mobile:
- FTP/FTPES/FTPS reader!
- Refreshed HTTP/HTTPS reader; added the ability to read remote folder listings.- Improved handling of various file formats over HTTP, AIFF and Musepack in particular.
- More robust M3U/M3U8/PLS playlist handling; shows a warning when trying to save a M3U/PLS file that may not be readable correctly due to international characters.
- New file format icons.
- Improved media library search performance.
- Made various playlist and search result sorting operations use multiple CPU cores.
- All communication with foobar2000 website (troubleshooter, crash reporting, update checks) is now encrypted.
- Refreshed File Operations preset management, now stored in a plain text files instead and possible to import/export/edit.
- Work around for DirectSound audio stutters with Windows 10 1803 (beta 19).
Jimi
- Hamburg
- Klöterkasten
- AMD Ryzen 7 5700X
- MSI B550-A Pro
- ENDORFY Fortis 5
- Logitech K310
- ▼275 ▲55
foobar2000 1.4 beta 21 wurde veröffentlicht.
Download foobar2000 1.4 beta 21
This is the last beta, and the last moment to report any outstanding issues. Version 1.4 stable will be out early next week.
foobar2000 v1.4 beta 21 release notes
Changelog v1.4:
Jimi
- Hamburg
- Klöterkasten
- AMD Ryzen 7 5700X
- MSI B550-A Pro
- ENDORFY Fortis 5
- Logitech K310
- ▼275 ▲55
foobar2000 1.3.20 Final wurde veröffentlicht.
Download foobar2000 1.3.20 Final
foobar2000 1.4 Final wurde veröffentlicht.
Download foobar2000 1.4 Final
Changelog v1.3.20:
- Reverted the much criticized CONTENT GROUP vs GROUPING remapping for FLAC/Vorbis.
- GROUPING field name is now used for ID3v2 TIT1, M4A ©grp, etc.
Changelog v1.4:
- Fix implemented for splitter lock bug.
- Workaround implemented for HTTPS issues on Windows XP.
Unbekannter Krieger
- 4x4 GiB Hynix DDR3-1866 ECC
- TSST SH-222AL
- Win8.x x64, Win7 x64
Danke für die Bekanntmachung!
Ich hatte ein paar 1.3.x-Versionen ausprobiert und war jeweils schockiert, dass das angeblich großartige foobar2000 mit nahezu keiner meiner Ogg-Vorbis-Audiodateien zurechtkam, die der gute alte Winamp lite (jüngste Version mit oder ohne Patch) problemlos wiedergibt.
Nummer 1.3.19 gab ich wiederum eine Chance. Diese Version hatte ja explizit eine Ogg-Vorbis-Reparatur (und eine für Abspiellisten) erhalten. Tatsächlich lassen sich mit der Ausgabe die (aller)meisten meiner OGGs abspielen. Einige werden weiterhin als defekt zurückgewiesen.
Was mich nun noch wundert, ist, dass im Random-Modus kein Sprung zurück zum vorigen Titel möglich ist, nicht mal ersatzweise zur nächsthöheren Zeile in der Liste. (Winamp setzt auf shuffling und kann es dort.) Zu guter Letzt benötigt das Programm massiv länger für das Laden einer knapp 3000 Einträge fassenden Abspielliste.
Fazit: Ich weiß foobar2000 sehr zu schätzen und würdigen. Während ich ihm, seinen Nutzern und mir die größten Entwicklungsfortschritte wünsche, muss ich konstatieren, dass es aus meiner Sicht bis Mitte 2018 Winamp (Stand Ende 2013) nicht erkennbar überflügelt oder gar nicht erst eingeholt hat. Auf Skins kann ich verzichten, andere GUI-Einschränkungen (ggü. Winamp) sind akzeptabel, die oft behauptete bessere/beste Klangqualität foobars vermag ich sinnlich nicht zu (er)fassen/begreifen. Die Dateikompatibiliät, Bedienung und Ladezeiten sollten jedoch passen, da verorte ich Verbesserungsbedarf. Seine Suchfunktion gefällt mir sehr; die in Winamp lite habe ich bis heute nicht gefunden – wobei das nur seltene Aufwallen von Interesse daran erwähnt sei.
Nachtrag: Die Suchfunktion von Winamp heißt in deutschen Versionen "Springe zu Titel" und ist per J-Taste blitzschnell aufrufbar. Wo die Unterschiede zum (im Installer separat geführten) "Erweiterten Springe zu Titel" liegen, kann ich bloß spekulieren.
Gespannt bin ich, ob zuerst foobar2000, WACUP (WinAmp Community Update Project) oder das propagierte künftige Winamp (unter dem aktuellen Eigentümer) einen höheren Stand erreichen wird als Winamp 5.666. Meine Befürchtung ist, man wird auf absehbare Zeit nirgends einen erklimmen.
- München
- World Community Grid
- Folding@Home
- be quiet! Shadow Rock 3
- LG 27UL850-W, 27"
- Logitech G613 Lightspeed
- Logitech M510
- Ubuntu Linux 22.04
- Vivaldi
▼100 MBit
▲40 MBit
Ich habe "Order" auf "Shuffle (Tracks)" stehen und kann problemlos vorwärts und rückwärts gehen.Was mich nun noch wundert, ist, dass im Random-Modus kein Sprung zurück zum vorigen Titel möglich ist, nicht mal ersatzweise zur nächsthöheren Zeile in der Liste. (Winamp setzt auf shuffling und kann es dort.) Zu guter Letzt benötigt das Programm massiv länger für das Laden einer knapp 3000 Einträge fassenden Abspielliste.
- Je nach Gusto
- AMD Ryzen 9 5900X
- ASRock B550
- 2x 16 GB DDR4 3200
- GeForce GTX 1650
- 27 Zoll Acer + 24 Zoll DELL
- Samsung 980 Pro 256 GB
- diverse
- Fractal Design R5
- Logitech Cordless Desktop
- Logitech G502
- Firefox, Vivaldi
- ▼250 MBit ▲40 MBit
Funktioniert bei mir auch ohne Probleme.
Unbekannter Krieger
- TSST SH-222AL
In den beiden oberen Shuffle-Modi ist der Rücksprung möglich. (Im dritten scheint immer der nächsthöhere Listeneintrag aufgerufen zu werden, wobei ich die Ordnerstruktur nicht im Blick hatte.) Ich ging davon aus, dass man im avantgardistischen foobar2000 eine Lösung für den Sprung zurück im Random-Modus implementiert hätte, denn jenen bevorzuge ich.
Eine simple Umsetzung dürfte im sequentiellen Speichern der Listennummer des zuletzt erfolgreich gestarteten Audios liegen. Im Falle einer anschließenden Änderung der derzeitigen Titelliste könnte man
a) Subtraktionen und Additionen auf die gespeicherte Listennummer anwenden, um sie an die Änderung anzupassen,
b) einfach intern die überholte Nummerierung (bis zum Programmneustart oder Speichern der Liste als Datei) beibehalten, dabei etwaige neue Einträge ignorieren oder fortsetzend nummerieren,
c) schlicht die gespeicherte Listennummer verwerfen.
Nachtrag: Da vergaß ich glatt, das eigens angefertigte Bildschirmfoto hochzuladen.
https://up.picr.de/33355494ln.jpg
- München
- Folding@Home
- LG 27UL850-W, 27"
- Logitech M510
- Vivaldi
▼100 MBit
▲40 MBit
Warum nimmst du nicht Shuffle? Oben hattest du ja noch geschrieben, dass WinAmp im Grunde auch einen Shuffle-Modus nutze und kein echtes Random.
Jimi
- Hamburg
- Klöterkasten
- AMD Ryzen 7 5700X
- MSI B550-A Pro
- ENDORFY Fortis 5
- Logitech K310
- ▼275 ▲55
foobar2000 1.4.1 beta 1 wurde veröffentlicht.
Download foobar2000 1.4.1 beta 1
foobar2000 mobile for iOS beta testing program is now open for everyone.
You can sign up to become a beta tester here.
Changelog v1.4.1:
- Better error message when trying to open M4A file renamed to .aac.
- Added %video_codec% info for Matroska and MP4 files.
- Added support for PCM audio in MP4 container.
- Made mouse wheel work in playlist view during a drag&drop operation.
- Improved handling of classical music metadata for iTunes M4A files.
- Added %bitspersample_extra% info to tell between int32/float32 PCM files.
- Added support for ID3v2 iTunes Grouping field.
- Converter: advanced-preferences option to encode to temp folder and move encoded-and-tagged files to the intended destination.
- Made tag update operations not fail when another application has the file open for reading.
- Corrected wrong bitrate shown for FLAC in Matroska container.
- Corrected labels for F13-F24 keyboard shortcuts.
- Fixed bugs with ReplayGain Scanner's automatic resampling of high sample rate content.
- Bumped maximum allowed sample rate to deal with DSD1024 content.
- Made Media Library respect 'include hidden files & folders' setting in Advanced Preferences.
- Converter with “don't reset DSP between tracks” now respects DSP-reported latency for proper handling of gapless albums.
- PPHS resampler bug fixes (inaccurate reported latency, crashing with extreme sample rates).
- Fixed ReplayGain scan results showing zero peaks on near-silent 24-bit files.
- New and improved buffering scheme for improved network streaming performance (ported from foobar2000 mobile).
- Internet radio handling regressions from 1.4 fixed; added an Advanced Preferences setting for ShoutCast metadata codepage.
- Fixed component auto update on Windows XP (1.4 regression).
- Added an Advanced Preferences option to toggle asymmetric search, reverting search behaviors to 1.3 style.
- Added title formatting fields for showing track/album peaks as decibel values.
- Improved status feedback from batch attach album art tool.
- Pressing “next” past the end of playlist now restarts the playlist even without “repeat” mode.
- Made Converter “copy other files” feature respect parent folder (..\pattern) references.
- Added EXTM3U info writing (enabled via advanced preferences).
- Added 5.1 and 7.1 upmix DSPs.
Jimi
- Hamburg
- Klöterkasten
- AMD Ryzen 7 5700X
- MSI B550-A Pro
- ENDORFY Fortis 5
- Logitech K310
- ▼275 ▲55
foobar2000 1.4.1 beta 2 wurde veröffentlicht.
Download foobar2000 1.4.2 beta 2
Changelog v1.4.1:
- (beta 2) Deleting the currently playing files no longer shows error popups (1.4 regression).
- (beta 2) Fixed repaint glitches in media library search edit box.
Unbekannter Krieger
- TSST SH-222AL
Sofern es hier nicht unerwünscht ist, ergänze ich den Themenbereich etwas:
1. Am 28.09.2018 erschien die jüngste geschlossene Beta von WACUP: https://getwacup.com/
2. https://www.au-ja.de/aktuell-news-1-Lebenszeichen%3A_Winamp_5.8.3660_Beta
Jimi
- Hamburg
- Klöterkasten
- AMD Ryzen 7 5700X
- MSI B550-A Pro
- ENDORFY Fortis 5
- Logitech K310
- ▼275 ▲55
@Unbekannter Krieger: Also mich stört es jetzt nicht. Aber vielleicht wäre ein eigener Thread dazu übersichtlicher.
foobar2000 1.4.1 beta 3 wurde veröffentlicht.
Download foobar2000 1.4.2 beta 3
Changelog v1.4.1:
- (beta 3) Updated Opus decoder to latest libopus 1.3.
- (beta 3) Fixed a bug causing poor Default UI playlist performance with tens of thousands of item.
- (beta 3) Fixed incompatibility with certain HTTP servers causing music files to fail to play from those servers.
- (beta 3) Internet radio regression fixes.
- (beta 3) Made DSP presets in the toolbar sorted.
Jimi
- Hamburg
- Klöterkasten
- AMD Ryzen 7 5700X
- MSI B550-A Pro
- ENDORFY Fortis 5
- Logitech K310
- ▼275 ▲55
foobar2000 1.4.1 beta 5 wurde veröffentlicht.
Download foobar2000 1.4.2 beta 5
The infamous disappearing-window bug with Windows 10 1809 has been worked around. Sadly other Windows 10 1809 issues (font substitution) still persist.
foobar2000 v1.4.1 beta 5 release notes
Changelog v1.4.1:
- (beta 5) Worked around the disappearing window bug of Windows 10 1809.
- (beta 5) Made technical info properly shown for various Ogg based internet radios (Vorbis, Opus, FLAC).
Jimi
- Hamburg
- Klöterkasten
- AMD Ryzen 7 5700X
- MSI B550-A Pro
- ENDORFY Fortis 5
- Logitech K310
- ▼275 ▲55
foobar2000 1.4.1 beta 6 wurde veröffentlicht.
Download foobar2000 1.4.2 beta 6
Changelog v1.4.1:
- (beta 6) Fixed 1.4 regression causing incorrect detection of Internet Explorer proxy server settings.
- (beta 6) Fixed 1.4 regression causing some tag updates to fail with 'access denied' when another app is accessing the files.
- (beta 6) Fixed various 175% text size rendering glitches.
- (beta 6) Fixed odd behaviors while installing regular foobar2000 alongside MS Store foobar2000.
- (beta 6) Fixed ReplayGain scanner preferences page glitches.
Jimi
- Hamburg
- Klöterkasten
- AMD Ryzen 7 5700X
- MSI B550-A Pro
- ENDORFY Fortis 5
- Logitech K310
- ▼275 ▲55
foobar2000 1.4.1 Final wurde veröffentlicht.
Download foobar2000 1.4.1 Final
Changelog v1.4.1:
- Worked around the disappearing window bug of Windows 10 1809.
- Converter updates:
- Advanced-preferences option to encode to temp folder and move encoded-and-tagged files to the intended destination.
- “Don't reset DSP between tracks” now respects DSP-reported latency for proper handling of gapless albums.
- Made Converter “copy other files” feature respect parent folder (..\pattern) references.- Better error message when trying to open M4A file renamed to .aac.
- Deleting the currently playing files no longer shows error popups (1.4 regression).
- Fixed repaint glitches in media library search edit box.
- Updated Opus decoder to latest libopus 1.3.
- Fixed a bug causing poor Default UI playlist performance with tens of thousands of item.
- Fixed incompatibility with certain HTTP servers causing music files to fail to play from those servers.
- Internet radio regression fixes.
- Made DSP presets in the toolbar sorted.
- Made technical info properly shown for various Ogg based internet radios (Vorbis, Opus, FLAC).
- Fixed 1.4 regression causing incorrect detection of Internet Explorer proxy server settings.
- Fixed 1.4 regression causing some tag updates to fail with 'access denied' when another app is accessing the files.
- Fixed various 175% text size rendering glitches.
- Fixed odd behaviors while installing regular foobar2000 alongside MS Store foobar2000.
- Fixed ReplayGain scanner preferences page glitches.
Unbekannter Krieger
- TSST SH-222AL
Für die wenigen Meldungen alle paar Monate lohnt ein eigener Themenstrang nicht.
Am 13.11.2018 erschien die jüngste geschlossene Beta von WACUP, 0.9.9.2940: https://getwacup.com/changelog/beta_0_9_9_2940.html
Die Übersicht über die einzelnen Changelogs aller Beta-Versionen befindet sich hier: https://getwacup.com/changelog/
Nachtrag: Die Entwicklung scheint angezogen zu haben, denn nur einen Monat später sind wir schon 3 Builds weiter: https://getwacup.com/changelog/beta_0_9_9_3100.html
Jimi
- Hamburg
- Klöterkasten
- AMD Ryzen 7 5700X
- MSI B550-A Pro
- ENDORFY Fortis 5
- Logitech K310
- ▼275 ▲55
foobar2000 1.4.2 beta 1 wurde veröffentlicht.
Download foobar2000 1.4.2 beta 1
This is a maintenanace update focused on addressing known bugs.
A major update with new features is being worked on separately.
Changelog v1.4.2:
- Added new iTunes ID3 classical fields.
- Improved playlist behaviors when deleting the now playing file.
- ReplayGain apply-gain-and-prevent-clipping no longer presumes 1.0 peak when peak is unknown.
- Fixed occasional errors when saving configuration.
- Converter: Improved behavior when output file names repeat.
- Fixed HTTP client bugs (internet radio, network shares).
- Made MP4 files with missing duration info playable.
- Windows 10 Universal Volume Control integration disabled by default due to bugs. This should address “multimedia keys don't work” issues.
- Je nach Gusto
- AMD Ryzen 9 5900X
- ASRock B550
- GeForce GTX 1650
- diverse
- Fractal Design R5
- Logitech G502
- Firefox, Vivaldi
Danke.
Irgendwie war ich noch bei 1.3.16.
Unbekannter Krieger
- TSST SH-222AL
Dann empfehle ich einen baldigen Umstieg. Für Ogg-Vorbis-Nutzer jedenfalls waren die fehlerhaften foobar2000-Versionen vor 1.3.19 eine Zumutung.
Das wurde anschließend überboten, immerhin benötigten die nächsten 3 Builds praktisch nur einen halben Monat: https://getwacup.com/changelog/beta_1_0_0_3174.htmlUnbekannter Krieger schrieb:Nachtrag: Die Entwicklung scheint angezogen zu haben, denn nur einen Monat später sind wir schon 3 Builds weiter: https://getwacup.com/changelog/beta_0_9_9_3100.html
Jimi
- Hamburg
- Klöterkasten
- AMD Ryzen 7 5700X
- MSI B550-A Pro
- ENDORFY Fortis 5
- Logitech K310
- ▼275 ▲55
foobar2000 1.4.2 beta 2 wurde veröffentlicht.
foobar2000 for Mac 2.1.27 wurde veröffentlicht.
Download foobar2000 for Mac 2.1.27
... with more incremental bug fixes.
Changelog v1.4.2:
- Fixed a bug that would cause spurious rewrites of certain configuration files [beta 2].
- Made default MP4 handler gracefully fail to decode files with no supported audio tracks - so another decoder lower on the list can handle them [beta 2].
New version of foobar2000 for Mac has been released, with seekbar and bottom playback controls.
Changelog v2.1.27:
- Playback controls pane (buttons, seekbar, playback order) at the bottom instead of toolbar
- Now possible to toggle repeat/shuffle modes
- Now-playing info and controls now accessible via Mac OS notifications
Jimi
- Hamburg
- Klöterkasten
- AMD Ryzen 7 5700X
- MSI B550-A Pro
- ENDORFY Fortis 5
- Logitech K310
- ▼275 ▲55
foobar2000 1.4.2 Final wurde veröffentlicht.
Download foobar2000 1.4.2 Final
Changelog v1.4.2:
- Worked around an “Open…” dialog lockup with lots and lots of supported file formats provided by third party components [final].
Gast17122020
Windows Defender verhindert die Ausführung der Exe. Norton Security sagt alles in Ordnung. Windows Defender ist übrigens ausgeschaltet.
morpheus
morpheus
Jimi
- Hamburg
- Klöterkasten
- AMD Ryzen 7 5700X
- MSI B550-A Pro
- ENDORFY Fortis 5
- Logitech K310
- ▼275 ▲55
da wird es sich wohl um ein "False Positive" handeln. Bei virustotal.com sieht es jedenfalls gut aus.
Ansonsten könntest Du es auch im offiziellen Support-Forum melden.
LG
LG
Jimi
- Hamburg
- Klöterkasten
- AMD Ryzen 7 5700X
- MSI B550-A Pro
- ENDORFY Fortis 5
- Logitech K310
- ▼275 ▲55
foobar2000 1.4.3 beta 1 wurde veröffentlicht.
Download foobar2000 1.4.3 beta 1
This is a maintenanace update addressing known bugs.
Changelog v1.4.3:
- Fixed disappearing metadata and playlist content corruption with certain internet radio playlists.
- Fixed high CPU usage with read-ahead options active.
- Converter: Fixed broken save-as dialog with | character in encoder names.
- Made foo_ui_std.dll & foo_input_std.dll report version number of the foobar2000 release that they came with, as some people seem to mix binaries from different releases then run into issues.
- Made possible to fall back to another decoder with WMA files that standard WMA decoder doesn't accept.
- Fixed disappearing & appearing 'version' file in library configuration folder.
- Updated FFmpeg to 3.4.5.
- 7K
