Allg. [Vorstellung] foobar2000 v2.2 Preview 2024-05-17 wurde veröffentlicht
- Ersteller Jimi
Jimi
- Hamburg
- Klöterkasten
- AMD Ryzen 7 5700X
- MSI B550-A Pro
- ENDORFY Fortis 5
- G.Skill RipJaws V schwarz DIMM Kit 32GB, DDR4-3600, CL18-22-22-42
- Palit GeForce GTX 1650 KalmX (passiv)
- AOC Q3277PQU, 32" @ 2560x1440
- Western Digital WD_BLACK SN850 500GB, M.2, Kühlkörper & Lexar NM790 4TB, M.2
- Hitachi-LG Data Storage GP57EB40 schwarz, USB 2.0
- MOTU M2 & Topping L30
- NZXT H7 Flow Black @ 6x ENDORFY Fluctus 140 PWM @ ~600 rpm
- Seasonic Focus GX 550W
- Logitech K310
- Sharkoon FireGlider
- Windows 10 Home x64 @ WinReducer
- Fluid Audio F5 Speaker & Fluid Audio DS 5 Stands, Hifiman Arya Stealth, Sennheiser HD 560S
- ▼275 ▲55
foobar2000 0.9.5.2 beta 2 wurde veröffentlicht.
Download foobar2000 0.9.5.2 beta 2
lg
Issues fixed in 0.9.5.2 beta 2:
- Bug: On Windows XP machines, attempting to open fullscreen visualisation on a non-primary monitor creates an invisible visualisation window.
- Bug: Incorrectly grouped albums and possible crashes when using ReplayGain / Scan Selection as Albums (by tags) command.
lg
Jimi
- Hamburg
- Klöterkasten
- AMD Ryzen 7 5700X
- MSI B550-A Pro
- ENDORFY Fortis 5
- Logitech K310
- ▼275 ▲55
foobar2000 0.9.5.2 Final wurde veröffentlicht.
Download
lg
Changelog:
- New array of built-in visualisations.
- Cleaned up freedb component user interface.
- Ability to auto-resize playlist columns to match playlist view size.
- Improved ID3v2 specification compliance.
- Converter: Improved handling of very long tracks.
- Support for displaying cover art extracted from WMA files.
Download
lg
Jimi
- Hamburg
- Klöterkasten
- AMD Ryzen 7 5700X
- MSI B550-A Pro
- ENDORFY Fortis 5
- Logitech K310
- ▼275 ▲55
hi,
foobar2000 v0.9.5.3 beta 1 wurde veröffentlicht.
Download foobar2000 v0.9.5.3 beta 1
lg
Changelog:
- New: Startup notification when some of loaded components are known not to cooperate correctly with this version of foobar2000.
- New: “Library Viewer Selection” playlist, compatible with Album List and Media Library Search.
- New title formatting functions: $stripprefix(), $swapprefix(), $year(), $month(), $day_of_month(), $date(), $time().
- New extensions to the search query syntax.
- Album List: faster refresh when using the built-in search box.
- ReplayGain scanner: applying ReplayGain to MP3 data no longer chokes on noncompliant ID3v2 tags with false MPEG sync words.
- ReplayGain scanner: new services allowing third-party components to perform ReplayGain analysis.
- No longer compatible with components using metadb_display_hook API.
- Changed component DLL loading logic - only “components” subdirectory along with its subdirectories is processed if it exists.
lg
Jimi
- Hamburg
- Klöterkasten
- AMD Ryzen 7 5700X
- MSI B550-A Pro
- ENDORFY Fortis 5
- Logitech K310
- ▼275 ▲55
foobar2000 v0.9.5.3 beta 2 wurde veröffentlicht.
Download foobar2000 v0.9.5.3 beta 2
lg
Changelog:
- New: Startup notification when a component is known not to cooperate correctly with this version of foobar2000.
- (New in beta 2) Playback queue index is now displayed in the “Playing” column of Default UI / Playlist View; it can be also accessed using %queue_index% .
lg
Jimi
- Hamburg
- Klöterkasten
- AMD Ryzen 7 5700X
- MSI B550-A Pro
- ENDORFY Fortis 5
- Logitech K310
- ▼275 ▲55
foobar2000 v0.9.5.3 Final wurde veröffentlicht.
Download foobar2000 v0.9.5.3 Final
lg
Changelog:
- Bug: Incorrect behaviors when Media Library folder paths include semicolon characters
- Bug: incorrect handling of additional parameters in $stripprefix()/$swapprefix() title formatting functions
lg
gast0815
Bin nun von Winamp auf Foobar umgestiegen!
Welchen Style empfiehlt ihr? Das mit den Tabs, sprich Default Playlist und Library Playlist ist mal genial.
Vorallem startet er schön schnell und ist nicht so überladen wie Winamp.
Goodbye Winamp.
Goodbye Winamp.
suppenzorro
- 7 Weltmeere
- SETI@Home, Poem@Home
- SETI@Home
- Athlon 64 X2 4800+, Athlon 64 X2 4600+, Core2Duo T8300 / NVS140M
- HP Elitebook 8540w
- Intel Core i7 M620
- 8 GByte
- Quadro FX1800M
- 15'6 1920x1080
- Intel X-25M G2
- Win7 x64
Jimi
- Hamburg
- Klöterkasten
- AMD Ryzen 7 5700X
- MSI B550-A Pro
- ENDORFY Fortis 5
- Logitech K310
- ▼275 ▲55
@rob2k:
wenn du nicht das "default user interface" nutzen möchtest dann guck mal hier: Foobar2000 @ DeviantART
lg
lg
gast0815
Wie bekomme ich Foobar in die Taskbar minimiert? Wo muss ich das Häckchen in den Einstellungen setzen?
Irgendwie hab ich grad Tomaten auf den Augen.
- München
- World Community Grid
- Folding@Home
- be quiet! Shadow Rock 3
- LG 27UL850-W, 27"
- Logitech G613 Lightspeed
- Logitech M510
- Ubuntu Linux 22.04
- Vivaldi
▼100 MBit
▲40 MBit
Einmal fragen reicht.
Display/Default User Interface/Minimize to notification area
Jimi
- Hamburg
- Klöterkasten
- AMD Ryzen 7 5700X
- MSI B550-A Pro
- ENDORFY Fortis 5
- Logitech K310
- ▼275 ▲55
foobar2000 v0.9.5.4 Beta 2 wurde veröffentlicht.
lg
Changelog:
- Ability to view/edit queries used to create autoplaylists.
- Media Library Search: queries using “SORT BY” create always-sorted autoplaylists by default.
- File format handling updates:
- Security updates to Vorbis, Speex, FLAC and WavPack libraries.
- Fixed a rare Ogg seeking accuracy bug.
- Improved MP4 parser security.- Converter improvements:
- No longer aborts the entire operation when one of queued tracks can't be processed.
- Optional status log popup after conversion.- Album List: ability to select multiple items at once by holding shift or control keys.
- New built-in DSPs: Crossfader, Skip Silence.
lg
gast0815
Gibt es ein gutes Lyrics-Plugin für Foobar2000, sowas wie Leo's Lyrics für Winamp?
Jimi
- Hamburg
- Klöterkasten
- AMD Ryzen 7 5700X
- MSI B550-A Pro
- ENDORFY Fortis 5
- Logitech K310
- ▼275 ▲55
hi,
es gibt einmal das LyricsDB (foo_lyricsdb)-plugin:
und dann das Lyrics panel (foo_uie_lyrics)-plugin:
lg
- nur für die lyrics-suche gedacht - keine darstellung.
- möglichkeit zum uploaden von erstellten lyrics in die lyric-datenbank.
- keine "timestamped lyrics" möglich - nur einfacher text (gespeichert im %LYRICS%-tag).
- grosse datenbank - gute trefferquote bei der suche.
- ein einfaches columns UI panel um lyrics darzustellen.
- "timestamped lyrics" sind mit diesem plugin möglich (suche und darstellung).
- die trefferquote bei der lyric-suche ist nicht ganz so gross wie die des lyricDB-plugins.
lg
Jimi
- Hamburg
- Klöterkasten
- AMD Ryzen 7 5700X
- MSI B550-A Pro
- ENDORFY Fortis 5
- Logitech K310
- ▼275 ▲55
foobar2000 v0.9.5.4 Beta 3 wurde veröffentlicht.
Download foobar2000 0.9.5.4 Beta 3
Issues fixed in 0.9.5.4 Beta 3:
- Bug: Incorrect focus after switching tabs.
- Bug: Nonsense in track list when trying to play/rip audio CDs over certain USB IDE adapters.
- Bug: Incorrect decoding of certain low-bitrate MP3 files.
Jimi
- Hamburg
- Klöterkasten
- AMD Ryzen 7 5700X
- MSI B550-A Pro
- ENDORFY Fortis 5
- Logitech K310
- ▼275 ▲55
foobar2000 0.9.5.4 Final wurde veröffentlicht.
Download foobar2000 0.9.5.4 Final
Issues fixed in 0.9.5.4 Final:
- Bug: Invalid data written by the Fix VBR MP3 Header command
Changelog:
Jimi
- Hamburg
- Klöterkasten
- AMD Ryzen 7 5700X
- MSI B550-A Pro
- ENDORFY Fortis 5
- Logitech K310
- ▼275 ▲55
foobar2000 0.9.5.5 wurde veröffentlicht.
lg
Issues fixed in 0.9.5.5:
- Display bugs when context menu command names include the & character.
- Incorrect handling of the @ character in HTTP login username.
- Incorrect handling of 99-track audio CDs.
- Crashes when using the Crossfader DSP.
- Autoplaylist status not preserved when copying/pasting playlists in Playlist Manager.
Download foobar2000 0.9.5.5Changelog:
- Bugs fixed:
- Fixed handling of the & character in context menu command names.
- Fixed handling of audio CDs with 99 tracks.
- Workarounds for issues with decoding some of ADPCM WAV files.
- Copying/pasting autoplaylists in Playlist Manager now preserves the autoplaylist status.
- Fixed handling of the @ character in HTTP AUTH username.
- Fixed crashes related to using the Crossfader DSP.
- AAC decoder fixes.
lg
Denyo!dP!
- OB in NRW
- Lenovo T510
- Intel® Core™ i5-4670K
- ASRock Z87M Extreme4
- Thermalright HR-02 Macho Rev.A (BW)
- 8GB G.Skill Ares DDR3-1600 DIMM CL9 Dual Kit
- MSI Radeon RX6600 MECH 2x 8GB
- LG W2452TX 24"
- 1 x Samsung SSD 240 GB 840 Basic
- 1 x 2TB Seagate Barracuda ST2000DM001
- Samsung DVD Brenner
- Lancool K7 Black
- be quiet! Straight Power E8 480 Watt
- Windows 7 Home Premium 64-bit
- Magnat Vector 203 @ Yamaha RX-V 457, Kopfhörere: Superlux HD 681
Ich hab mal eine Frage zu Foobar. Wenn ich ein Lied mit einem bestimmten Titel und/oder Interpreten suche, greift Foobar nur auf die MP3Tags zu, oder sucht es auch einfach im Dateinamen Viele meiner MP3s besitzen nämlich keine bzw. nur schlechte MP3 Tags.
CU Denyo!
CU Denyo!
gast0815
hi,
lg
Was bringt eine Lyrics Tool ohne Darstellung? Oder versteh ich da was anderes drunter?
Hab jetzt mal das zweite ausprobiert. Die Sprachdatei in den components Ordner kompiert und die .lrc in den Hauptordner. Doch ich kann das nirgends auswählen.
Jimi
- Hamburg
- Klöterkasten
- AMD Ryzen 7 5700X
- MSI B550-A Pro
- ENDORFY Fortis 5
- Logitech K310
- ▼275 ▲55
hi,
welches interface benutzt du denn? benutzt du die standard-suche (media-search)? es kann auch in den dateinamen gesucht werden.
das erste (ohne darstellung) ist halt nur für den lyrics-import gedacht. es bietet zudem ja auch die möglichkeit lyrics auf den server zu laden.
die "Hotel California.lrc"-datei brauchst du gar nicht. das ist eigentlich nur ne beispiel-lyrics-datei. wenn du die "foo_uie_lyrics.dll" in den components-ordner kopiert hast musst du anschliessend in foobar erstmal das panel zur darstellung in dein layout integrieren... MOMENT - erstmal SEHR wichtig: welches interface benutzt du? das teil funktioniert nur mit columns UI, bzw. auch mit dem DUI, aber dann mit nem kleinen trick.
Denyo!dP!
- OB in NRW
- Lenovo T510
- LG W2452TX 24"
- Lancool K7 Black
Benutze Foobar noch gar nicht Bin von MediaMonkey recht begeistert, nur finde ich da die Suche recht kompliziert. Deshalb meine Frage. Wenn Foobar nach Dateinamen suchen kann, werde ich es mal ausporbieren. Danke!
gast0815
Standard-Interface (Album List + Properties Tabbed).
Jimi
- Hamburg
- Klöterkasten
- AMD Ryzen 7 5700X
- MSI B550-A Pro
- ENDORFY Fortis 5
- Logitech K310
- ▼275 ▲55
es gibt für das default user interface das plugin foo_dockable_panels. damit kann panels in sein layout "andocken". eben auch panel, die nicht für das DUI gedacht sind. allerdings ist das eher eine bescheidene lösung, wie ich finde.
nocht nicht allzulange gibt es für das DUI das Text Display (foo_textdisplay),-plugin. damit kann man alle möglichen informationen darstellen - unter anderem eben nun auch die lyrics.
Jimi
- Hamburg
- Klöterkasten
- AMD Ryzen 7 5700X
- MSI B550-A Pro
- ENDORFY Fortis 5
- Logitech K310
- ▼275 ▲55
hi,
foobar2000 0.9.5.6 wurde veröffentlicht.
Download foobar2000 0.9.5.6
lg
Changelog:
- Fixed a major bug in Speex decoding, introduced with one of previous udpates.
- Updated Speex libraries to 1.2 RC.
- Added correct handling of multichannel WMA content.
- Various other minor/cosmetic fixes.
lg
Ich finde auch dass das Programm sehr schlank und gut erweiterbar ist ...
Der einzige Haken ist meiner Meinung nach, dass es keine "Suchfunktion bzw. Liste" der Radiostreams wie im aktuellen WinAmp gibt - Mit dieser Methode habe ich mich schon sehr gut angefreundet und will sie nicht missen ... Wenn foobar2000 das auch könnte, würde ich evtl. umsteigen
- 7K
