WinRAR 3.60 Beta 7
cruger
Senior Moderator
Teammitglied
25.05.2002
29.381
1.577
  • QMC Race
  • BOINC Pentathlon 2014
Nachdem Anfang April die erste Beta der nächsten WinRAR Version 3.60 veröffentlicht wurde, ist nun seit kurzem die mittlerweile siebte Beta-Version verfügbar.
Mit der Version 3.60 bietet WinRAR erstmals eine Unterstützung für Dual-Core CPUs wie z.B. AMDs Athlon 64 X2.
<blockquote><b><u>WinRAR - What's new in the latest version</u></b><br><br><b>Version 3.60 beta 7</b><ul><li>Stack overflow vulnerability has been corrected in WinRAR module processing LZH archives. We thank Ryan Smith, www.hustlelabs.com, for reporting this problem.</li></ul><b>Version 3.60 beta 6</b><ul><li>Switch -ad did not work in GUI winrar.exe.</li><li>When repairing several archives, console RAR did not handle 'No' choice of overwrite archive request properly. It aborted the operation instead of skipping the current archive.</li></ul><b>Version 3.60 beta 5</b><ul><li>GUI winrar.exe ignored -mt switch and always used "Multithreading" option from "Settings" dialog. Fixed now.</li><li>Correction in -ilog switch. In some situation the current date was not written to rar.log file.</li></ul><b>Version 3.60 beta 4</b><ul><li>Recovery speed improved when repairing heavily damaged archives using the recovery record.</li><li>If volume size field contained a value exceeding 4 GB, it was changed to wrong value after switching to any other page of archiving dialog and returning back to "General" page.</li><li>Update ('u') command did not work properly with some high ASCII names in beta 3.</li></ul><b>Version 3.60 beta 3</b><ul><li>Previous beta version could create duplicate copies of same file when updating an archived file with high ASCII characters in file name.</li><li>SFX module crashed if single string length in "License" or "Text" block exceeded 4096 characters.</li></ul><b>Version 3.60 beta 2</b><ul><li>Improved Unicode support in the folder tree panel.</li><li>Fixed a bug with incorrect font in the volume size list in Japanese Windows 98.</li></ul><b>Version 3.60 beta 1</b><ul><li>Multithreaded version of RAR compression algorithm improves the compression speed on computers with several CPU, dual core CPU and processors with hyperthreading technology. Multithreading is enabled by default, but you can disable it in "General" part of "Settings" dialog. In the command line mode you can control multithreading with -mt switch.</li><li>WinRAR can display the folder tree panel allowing to navigate in disk and archive folders. Use "Options/Folder tree" submenu to enable the folder tree. It can be configured separately in file and archive management modes.Folder tree replaces "Browse for folder" command previously available in "File" menu and uses its Ctrl+T keyboard shortcut.</li><li>Now WinRAR "Rename" command also works with ZIP archives. Previous versions could rename files only in RAR archives.</li><li>Added decompression of LZH archives created with "-lh7-" algorithm.</li><li>New "Remove duplicate folders from extraction path" option in "Settings/Compression" dialog.If this option is on and you unpack an archive which root folder has no files and only one 'somename' folder and if destination folder is new or empty and also ends with '/somename', WinRAR will exclude one 'somename' from resulting 'somename/somename' path.</li><li>New "Define volume sizes..." button in "Settings/Compression". This button activates "Define volume sizes" dialog. Here you can customize the list of predefined volume sizes associated with "Split to volumes, bytes" field in archiving dialog.</li><li>Speed of RAR general compression increased for some data types. Depending on data type and size the gain may achieve 5 - 15%.</li><li>New "Rename automatically" option in the extraction dialog and command line -or switch to rename extracted files automatically if file with the same name already exists. You can also enable the auto-renaming mode directly from the overwrite confirmation prompt with "Rename All" button.Renamed files will get names like 'filename(N).txt', where 'filename.txt' is the original file name and 'N' is a number.</li><li>"Set modification time" option in "Advanced" part of extraction dialog is accessible also for ZIP archives. Previously it could be changed only for RAR archives.</li><li>"Multithreading" option added to "Benchmark and hardware test" command, so you can compare performance of usual and multithreaded versions of RAR compression algorithm.</li><li>New 'ch' (change archive parameters) command line mode command. Its purpose is to apply switches like -av, -tl and -cl to archive.</li><li>New 'cv' command line mode command. It provides the command line interface to WinRAR "Convert archives" command. It is supported only by winrar.exe, not by rar.exe.</li><li>New command line -sl and -sm switches to set size limits of processing files.</li><li>New command line -fcu[file] switch allows to read archive comments from Unicode files. It also modifies behavior of "cw" command, setting the comment output format to Unicode.</li><li>7Z added to list of formats stored without compression when using -ms switch without a parameter.</li><li>Switch -e[+] is now supported by most of command line operations including extracting and deleting files. Previously it was supported by only archiving command.</li><li>It is allowed to use environment variables in archive name in archiving dialog, in destination path in extraction dialog, in folder names on "Compression" and "Paths" pages in WinRAR settings. For example, you can enter '%temp%' in "Folder for temporary files" field.</li></ul></blockquote>
<b>Download:</b><ul><li><img src="/images/englisch.gif" border="1" height="10" width="15"> <a href="http://www.planet3dnow.de/cgi-bin/file/get.pl?20060715221529">WinRAR 3.60 beta 7 - Trial Version [Windows]</a></li></ul>
<b>Links zum Thema:</b><ul><li><a href="http://www.rarlabs.com/rarnew.htm" target="b">WinRAR Changelog</a></li></ul>
Danke SPINA für den Hinweis!
"oh, ne neue beta ... geil ... geil! gleich ma saugen und testen" oder wie?
Nö, wozu?!.....Um noch ne zehntel Sekunde schneller entpacken zu können.... Ja! Das lohnt! ;D
Richtig! --> huRi^kh4ne
.... ein Grund könnte sein: Du hast zuviel Geld und möchtest dir unbedingt eine Lizenz kaufen müssen...! Soll Leute geben die auf sowas stehen! *suspect*
Naja WinRAR hat nun einmal den Vorteil Multi Volume Zip,RAR Dateien zu entpacken. Das ist mir mit 7Zip noch nicht gelungen. Ich selber habe mir den PowerArchiver2006 gegönnt. Mit dem ich auch sehr zufrieden bin.
Mfg
Marcel
Also Multi-Volume-RAR-Dateien ließen sich bei mir bisher mit 7-Zip immer entpacken. Multi-Volume-Zips hatte ich noch keine.
<blockquote>
<b>WinRAR <br>
Version 3.60 beta 7<br>
Version 3.60 beta 5<br>
Version 3.60 beta 4<br>
Version 3.60 beta 3<br>
Version 3.60 beta 2<br>
Version 3.60 beta 1<br></blockquote>
Neue (noch geheime) Nachricht: Dies ist ein Rekordversuch! Rarlabs versucht damit, einen Eintrag im Guinness Buch der Rekorde für die meisten Betaversionen zu bekommen :D
Ich bin ganz angetan von WinRAR und besitze auch eine Lizenz für diese Shareware. Der einzige Kritikpunkt meinerseits ist nur, dass WinRAR nicht mit ZIP Archiven zurechtkommt, die eine neuere Verschlüsselung als die klassische WinZIP 2.0 Verschlüsselung nutzen. So lassen sich passwordgeschütze ZIP Files mit einer erweiterten 128 Bit oder 256 Bit AES Verschlüsselung nicht mit WinRAR öffnen, obwohl WinRAR wenigstens den Inhalt des Archives anzeigen kann.
Neben WinRAR nutze ich noch die ZipGenius Suite: http://www.zipgenius.it/eng/index.php
