Download AMD Radeon Software Crimson Edition 16.4.2 Hotfix (WHQL) verfügbar.
- Ersteller eratte
User-News
Von eratte
Hinweis: Diese "User-News" wurde nicht von der Planet 3DNow! Redaktion veröffentlicht, sondern vom oben genannten Leser, der persönlich für den hier veröffentlichten Inhalt haftet.AMD Radeon Software Crimson Edition 16.4.2
Download und komplette Release Notes
APU Besitzer sollten die Sektion Product Compatibility vorher lesen.
Treiber Biuld: 16.15.2401
Radeon Software Crimson Edition is AMD's revolutionary new graphics software that delivers redesigned functionality, supercharged graphics performance, remarkable new features, and innovation that redefines the overall user experience. Every Radeon Software release strives to deliver new features, better performance and stability improvements.
Radeon Software Crimson Edition 16.4.2 Highlights
Updated or New Crossfire Profiles available for:
Elite Dangerous™
Need for Speed™
AMD Xconnect™ technology: This driver provides full support for Thunderbolt™ 3 eGFX enclosures configured with Radeon™ R9 Fury, Nano or 300 Series GPUs. This driver also provides plug'n'play simplicity, plus an integrated management interface for such devices.(1)
Resolved Issues
The Division™ may experience flickering in AMD Crossfire™ technology mode.
DOTA2™ toggling between borderless fullscreen and exclusive fullscreen can sometimes cause flickering or corruption when in AMD Crossfire™ technology mode.
Some DirectX® 9 applications cannot disable AMD Crossfire™ technology mode through Radeon Settings.
GPU clocks on some products may remain in high states after recovering from an application crash.
A small subset of AMD Radeon™ R9 380 users may be experiencing slower than expected fan speeds.
Power efficiency toggle in Radeon Settings is showing up for some unsupported products.
The check for software updates feature in Radeon Settings may not find the latest available update.
Some games may fail to show up in Radeon Settings gaming tab.
The Radeon Settings option may sometimes disappear as a shortcut from the right-click context menu on desktop after a software upgrade.
Steam®VR Performance Test may experience flickering in AMD Crossfire™ technology mode.
Stuttering or corruption observed while playing Fallout 4™ on some graphics products in AMD Crossfire™ technology mode.
Corruption in Hitman™ when using AMD Crossfire™ technology mode.
Stuttering or freezing in some loading scenes while playing Hitman™ using AMD Crossfire™ technology mode.
Negative scaling seen on Hitman™ when using AMD Crossfire™ technology mode.
Known Issues
A few game titles may fail to launch or crash if the AMD Gaming Evolved overlay is enabled. A temporary workaround is to disable the AMD Gaming Evolved "In Game Overlay".
HDMI™ Scaling options may not be available in Radeon Settings on some system configurations or some applications may ignore the HDMI™ Scaling options setting.
The option to enable/disable AMD Crossfire™ technology logo may be missing on some system configurations from the Gaming, Global Options tab in Radeon Settings.
The Witcher® 3: Wild Hunt inventory and character pages may exhibit flickering in AMD Crossfire™ technology mode.
Radeon Settings game manager does not display icons for Origin Games.
AMD Radeon Pro Duo users may experience a system crash or hang after resuming from sleep or hibernate.
Compatible Operating Systems
AMD Radeon Software Crimson Edition 16.4.2 Driver is designed to support the following Microsoft® Windows® platforms:
Windows® 10 (32 & 64-bit version)
Windows 8.1 (32 & 64-bit version)
Windows 7 (32 & 64-bit version with SP1 or higher)
Elite Dangerous™
Need for Speed™
Resolved Issues
Known Issues
Psychodelik
- Intel Core i7-3770 K
- Gigabyte GA-Z77X-UD5H
- top-blow Kühler inkl. 2 x 140 mm Lüfter
- G-skill 2 x 8 GB RAM
- Sapphire R9-390 NITRO with backplate, 8GB RAM
- HP ZR2440w
- Samsung SSD 830 Series
- Samsung HD240 UI
- LG Blue-Ray Brenner, LG DVD Brenner
- Creative Sound Blaster ZxR
- Enermax 750 Watt Netzteil inkl. Kabelmanagement
- Microsoft Windows 10 Pro x64 Edition
- Firefox, Vivaldi
Ich habe gestern über eure Partner Seite "computerbase.de" diesen non-whql Treiber installiert. Danach selbstverständlich den Rechner neu gestartet.
Die integrierte Update Funktion sagt mir, das es ein WHQL 16.3.2 Treiber vorhanden ist und das ich diesen herunter laden kann !
Der non-whql Treiber ist 16.4.2 und der WHQL Treiber ist 16.3.2 !
Sollte ich den non-whql Treiber drauf lassen (der funktioniert bei mir einwandfrei) oder doch zur niedrig nummerierten WHQL 16.3.2 wechseln ?
Wie schon geschrieben wenn alles passt einfach drauf lassen und Meldung ignorieren.
Unbekannter Krieger
- 4x4 GiB Hynix DDR3-1866 ECC
- TSST SH-222AL
- Win8.x x64, Win7 x64
Die integrierte Suche interessiert sich nur für WHQL-Treiber, darum diese Meldung.Psychodelik schrieb:diesen non-whql Treiber installiert. Danach selbstverständlich den Rechner neu gestartet.
Die integrierte Update Funktion sagt mir, das es ein WHQL [...] Treiber vorhanden ist und das ich diesen herunter laden kann !
Wenn der neueste Treiber überhaupt einwandfrei funktioniert, wieso sollte man da wechseln?Sollte ich den non-whql Treiber drauf lassen (der funktioniert bei mir einwandfrei)
SPINA
- AMD Ryzen 7 3700X
- ASUS PRIME X370-PRO
- AMD Wraith Prism
- LG Electronics 27UD58P-B
- HL Data Storage BH16NS55
- Lian Li PC-7NB
- Seasonic PRIME Gold 650W
- Debian 12.x (x86-64)
- ASUS TPM-M R2.0
Das stimmt so nicht ganz, wenn man es von der Warte der Radeon Software 16.3.2 aus betrachtet.Die integrierte Suche interessiert sich nur für WHQL-Treiber, darum diese Meldung.
CNext blendet dort unter Windows 8.1 und 10 eine Benachrichtung mit folgendem Titel ein:
Öffnet man CNext und klickt auf "Neue Aktualisierung" neben dem Achtungschild, dann wird dem Nutzer der "16.4.2 (Beta)" als neu angeboten.Neue Software-Aktualisierung ist verfügbar
Und die Radeon Software 16.4.2 (Beta) ist kein WHQL Treiber, wie man schon am Dateinamen erkennt:
/drivers/beta/non-whql-64bit-radeon-software-crimson-16.4.2-win10-win8.1-win7-apr20.exe
Kann ich bestätigen, habe den 16.3.2 WHQL installiert und erst wurde immer der 16.4.1 vermeldet und jetzt der 16.4.2 - da muss AMD noch mal nachbessern das man es einstellen kann (z.B: nur WHQL und keine BETA/Hotfix angezeigt zu bekommen) und das man ausschalten kann.
Unbekannter Krieger
- TSST SH-222AL
Verstehe ich es recht: Hat man 16.3.2 installiert, wird einem 16.4.x vorgeschlagen.
Hat man 16.4.x installiert, wird einem 16.3.2 vorgeschlagen.
Oder wie meintet ihr das?
Ja genau.
psychocyberdisc
- Mystery Lake
- OMEN by HP Laptop 16-c0xxx
- 230 Watt
▼50 Mbit/s
▲25 Mbit/s
Ob dieser Treiber die Carrizo-Unterstützung wieder an Bord hat?
Nein
when are you going to update carrizo drivers ( as in the A10 8700p) (AMD Forum)
amdmatt
No we are not dropping support, we have temporarily removed it whilst we address a bug found in QA.
maikrosoft
- germany
- AMD Ryzen 7 7800x 3d
- ASUS ROG STRIX B650-A Gaming
- Thermalright Peerless Assassin 120 SE ARGB white
- 2 x 16 GB Corsair Vengeance 5600MHz CL 36
- ASUS GeForce RTX 4060 Ti OC white
- LG UltraGear 27GP850-B
- Samsung 970 EVO Plus 2TB, Western Digital SN550, Crucial MX500 1TB m.2, Silicon Power Ace A55 1TB
- Soundblaster AE-5 PLUS - DT-990pro
- BeQuiet Silentbase 802
- Seasonic Core GM 650W
- Sharkoon SGK 60
- Gigabyte M3
- Windows 11 pro x64 / Manjaro
- AUKEY Large mousepad gaming xxl
Heute ist der Beta 16.4.2 mit WHQL Zertifikat erschienen und der 16.4.2 Chipsatztreiber.
Sehe da kein WHQL, gibt nur nun 6 Treiberpakete (je Windows 7, 8.1, 10 in 32 oder 64 Bit).
psychocyberdisc
- Mystery Lake
- 230 Watt
▼50 Mbit/s
▲25 Mbit/s
Ich lese überall "Crimson Edition 16.4.2 Hotfix".
maikrosoft
- germany
- Sharkoon SGK 60
- Gigabyte M3
Nun eine Webseite kann da viel dran schreiben das würde ich nicht als sichere Aussage annehmen, Treiber lade ich auch lieber bei AMD und nVidia.
Es stimmt aber das AMD den Treiber nicht nur heimlich erneuert hat er hat auch ein WHQL abbekommen.
Auf APU Rechner installiert:
Alter Filename:
Neuer Filename z.B.:
radeon-crimson-16.4.2-win10-64bit.exe oder radeon-crimson-16.4.2-with-dotnet45-win7-64bit.exe usw
Post 1 passt weiterhin auch der Downloadlink.
So steht er jetzt Original bei AMD z.B.:
http://support.amd.com/en-us/download/desktop?os=Windows+10+-+64
Alter Filename:
Hallo zusammen,
welcher ist denn der richtige Treiber für eine AMD APU A8-5545M (Richland APU) mit intergrieter HD8510G unter Win 10 64-Bit.
Gibts hierfür überhaupt einen Crimson-Treiber oder bleibt es bei der letzten Catalyst-Version 15.7 ?
Und wenn wir schon mal dabei sind.
Im Mini-PC ist eine Realtek RTL8723AE Wlan 802.11n PCI-E Karte verbaut. Ich habe seit dem Update auf Win 10 dauernd Verbindungsabbrüche (alle 3-5 Minuten).
Finde auch nirgends einen Win 10 64-Bit Treiber für die Wlan-Karte. Gibt es einen Allround-Treiber oder alternativen Treiber?
Danke schon mal für eure Hilfe.
HAL9001
HAL9001
Einfach auf die AMD Seite gehen und Auto Detect machen oder APU manuell angeben:
http://support.amd.com/en-us/download/desktop/legacy?product=legacy3&os=Windows 10 - 64
Catalyst 15.7 oder Crimson 16.2.1 Beta
psychocyberdisc
- Mystery Lake
- 230 Watt
▼50 Mbit/s
▲25 Mbit/s
Bei Realtek selbst wirst du nur in Sachen Audio und Ethernet fündig, daher solltest du mal hier schauen:
http://www.station-drivers.com/index.php?option=com_remository&Itemid=353&func=select&id=17&lang=en
