Core Temp 0.99.2
pipin
Administrator
Teammitglied
16.10.2000
24.371
9.696
East Fishkill, Minga, Xanten
  • SIMAP Race
  • QMC Race
  • RCN Russia
  • Spinhenge ESL
  • Docking@Home
  • BOINC Pentathlon 2019
  • SETI@Home Intel-Race II
  • THOR Challenge 2020
  • BOINC Pentathlon 2021
  • BOINC Pentathlon 2023
Core Temp ist ein kleines kompaktes Programm zur Beobachtung von CPU Temperaturen. In der neuen Version werden erstmals auch 45nm Prozessoren von AMD unterstützt.
Alle Änderungen:
<blockquote>- Fix: Start with Windows option was broken in 0.99.1.
- Fix: Default color for the second system tray icon is invisible with WinXP blue theme.
- Fix: Save screenshot function would create a corrupted BMP in some viewing software.
- Fix: Nehalem does not report VID like earlier CPUs. VID field now disabled for Nehalem.
- Fix: Incorrect 65nm Turion X2 code name detection.
- Fix: Potential bug of improper K10 and up recognition.
- Fix: Enabling distance to Tj.Max with "Highest temp." for system tray would show the largest distance to Tj.Max instead of smallest.
- Fix: Vendor ID and Device ID values were reversed in the register dump file.
- Fix: 3/4 temperatures logged for Phenom X3/X4 instead of 1.
- Add: Support for Core Temp plugins. (Still in beta phase and not in GUI yet).
- Add: Full support for AMD's Puma platform CPUs (in previous version reffered to as Griffin).
- Add: Initial support for 45nm AMD processors.
- Add: Update K8 and K10 recognition code to support all currently known CPUs.
- Add: Default TDP detection for Nehalem.
- Add: On the fly CPU speed detection.
- Add: Close to system tray option.
- Change: Log file is now produced in CSV format - easily import your logs into Excel.
- Change: Logging interval is now in Seconds instead of miliseconds.
- Change: Default logging interval is now 10 seconds.
- Change: Logging is now off by default.</blockquote>
<b>Download:</b> <a href="http://www.alcpu.com/CoreTemp/CoreTemp.zip" target="b">Core Temp 0.99.2</a>
<b>Links zum Thema</b>:
<ul><li><a href="http://www.alcpu.com/CoreTemp/supportlist.html" target="b">Unterstützte Prozessoren</a></li><li><a href="http://www.alcpu.com/CoreTemp/" target="b">Core Temp Homepage</a></li>
</ul>
E6850
p5k (neustes BIOS + Chipsatztreiber)
Hmmm ein wenig unglaubwürdig.
T-Junk temp bei 100°C ??
