FahMon 2.3.3
TiKu
Administrator
Teammitglied
16.11.2001
21.706
1.322
München
  • SIMAP Race
  • QMC Race
  • Spinhenge ESL
  • Docking@Home
  • BOINC Pentathlon 2021
Nach längerer Pause wurde heute eine neue Version von FahMon veröffentlicht. Mit dem Programm lässt sich <a href="http://dc.planet3dnow.de/wiki/index.php?title=Portal:Folding%40Home" target="_blank">Folding@Home</a> überwachen.
Auch wenn die geringe Änderung der Versionsangabe anderes vermuten lässt, wurden viele Änderungen vorgenommen und der Versionsumfang erweitert.
<strong>Changelog 2.3.2b zu 2.3.3:</strong><ul><li>General<ul><li style="font-size: smaller;">Added new cores support.</li><li style="font-size: smaller;">Made "Last 3 Frames" the default PPD/ETA calculation method.</li><li style="font-size: smaller;">Added multiple new data columns.</li><li style="font-size: smaller;">Made client management more intuitive by adding a "Clients" menu.</li><li style="font-size: smaller;">Made main window menus more intuitive.</li><li style="font-size: smaller;">Added ability to remove the "WU Info" panel from view.</li><li style="font-size: smaller;">Updated queue structure to qd FR 069</li><li style="font-size: smaller;">Add ability to select custom web output templates.</li><li style="font-size: smaller;">Altered About Dialog text.</li><li style="font-size: smaller;">Added custom variables to web output templates.</li><li style="font-size: smaller;">Fixed GPUv2 always reporting PPD as "inaccurate."</li><li style="font-size: smaller;">Updated folding support forum link in "Web" menu (thanks to Mark Gerber).</li><li style="font-size: smaller;">Fixed div by zero error that affected GPU2 clients (thanks to John Daiker).</li><li style="font-size: smaller;">Fixed quick refresh crash bug (thanks to John Daiker).</li><li style="font-size: smaller;">Fixed file manager bug with paths containing spaces (thanks to John Daiker).</li><li style="font-size: smaller;">Fixed team number and username refresh issue (thanks to John Daiker).</li><li style="font-size: smaller;">Changed client list style and removed "zebra" background colour scheme.</li><li style="font-size: smaller;">Issue time no longer used as download time.</li><li style="font-size: smaller;">Added ability to disable clients.</li><li style="font-size: smaller;">Improved sorting algorithm.</li><li style="font-size: smaller;">Added client pause detection.</li><li style="font-size: smaller;">Added support for truncating usernames in the web output.</li></ul></li><li>Windows<ul><li style="font-size: smaller;">Fixed cosmetic issue with work/current.xyz using / instead of \.</li><li style="font-size: smaller;">Migrated configuration folder to %APPDATA% to improve behaviour in Vista.</li><li style="font-size: smaller;">Updated installer to add entry to add/remove programs.</li><li style="font-size: smaller;">Fixed some minor installer issues.</li><li style="font-size: smaller;">Now built against wxWidgets 2.8.9.</li></ul></li><li>Linux<ul><li style="font-size: smaller;">Fixed an issue with latest GCC and inline functions (thanks to KB3LWJ).</li><li style="font-size: smaller;">Fixed compiler warnings about deprecated conversions (thanks to John Daiker).</li><li style="font-size: smaller;">Added configure test to check for ANSI wxWidgets and warn if found.</li></ul></il></ul>
Leider hat es die deutsche Übersetzung nicht in die finale Version geschafft. Eine manuelle Einbindung ist durch die folgenden Schritte möglich:
<ol><li>Übersetzungsdateien herunterladen: <a href="http://trac.fahmon.net/attachment/ticket/176/de_DE_r346.zip?format=raw" target="_blank">de_DE_r346.zip</a></li><li>Inhalt der ZIP-Datei in das Unterverzeichnis <span style="font-family: Courier New;">lang\de_DE\</span> des FahMon-Installationsverzeichnisses entpacken.</li><li><span style="font-family: Courier New;">de_DE.mo</span> nach <span style="font-family: Courier New;">fahmon.mo</span> umbenennen (ggf. die bisherige <span style="font-family: Courier New;">fahmon.mo</span> vorher löschen).</li><li>FahMon neu starten.</li></ol>
<strong>Download:</strong><ul><li><a href="http://fahmon.net/download.html" target="_blank">FahMon 2.3.3</a></li></ul>
<strong>Links zum Thema:</strong><ul><li><a href="http://fahmon.net/" target="_blank">FahMon</a></li></ul>
Danke an Gerby19 für den Hinweis!
