Foxit Reader 2.3 Build 2825
- Ersteller cruger
Der PDF-Betrachter Foxit Reader, eine Alternative zu dem weit verbreiteten Adobe Reader, ist in der Version 2.3 mit der Buildnummer 2825 erschienen und bietet zahlreiche neue Features.
<blockquote cite="http://www.foxitsoftware.com/pdf/reader_2/whatsnew23.htm"><i><b>What's new in Version 2.3?</b><br><br>The following is a list of exciting improvements introduced in Foxit Reader 2.3.</i><br><br><b><i>New features:</i></b><ul><li><i><b>Bookmark Design:</b> Makes it possible to have your own bookmarks. Users can create, edit, or delete bookmarks in a PDF file if the security settings allow.</i></li><li><i><b>Multi-tab Browsing:</b> Enables users to open multiple files in a single instance.You can choose to view PDFs in a multi-tab window or multiple instances by setting documents layout from the Preferences dialog.</i></li><li><i><b>Multimedia Player Support:</b> Supports many media formats including audio and video. Read multimedia ebooks with Foxit Reader 2.3.</i></li><li><i><b>Callout and Text box Tool:</b> Creates comments in a callout text box or a box. You can also define their appearance as other commenting tools.</i></li><li><i><b>Commenting Text Tool:</b> Enables users to add most types of text edits by right-clicking on the selected text, including highlight, strikeout, underline, squiggly and replacement. You can also use the Commenting Text Tool to add bookmarks for PDF files.</i></li><li><i><b>Rulers and Guides:</b> Provides horizontal and vertical ruler guides to help users align and position objects on the page. Right-clicking on the ruler enables you to change the unit of measurement.</i></li><li><i><b>Magnifier:</b> Magnifies areas of the PDF files easily as you work on Foxit Reader.</i></li><li><i><b>Automatic Scrolling:</b> Allows users to view documents without using mouse actions or keystrokes.</i></li><li><i><b>OCG Support:</b> Enables the user to view related content stored in a variable number of separate layers.</i></li><li><i><b>FDF Related:</b> Opens FDF files directly with Foxit Reader without any import implementations.</i></li></ul><b><i>Enhanced features:</i></b><ul><li><i><b>Optimized Rendering:</b>Supports progressive rendering and significantly reduces the response time from the user interface events.</i></li><li><i><b>Improved Link Tools:</b>Allows users to add actions to links, such as go to a page view, open or execute a file, open a web link, etc.</i></li><li><i><b>Improved Snapshot:</b>Enables users to print the selected area in Foxit Reader by simply selecting the Print option from the context menu.</i></li><li><i><b>Search Enhancement:</b>Allows users to float, move and resize the Full Foxit Search box.</i></li><li><i><b>Better Annotation control:</b>Groups drawing markups to help users operate objects collectively, and allows users to move annotations through pages.</i></li><li><i><b>Font Information:</b>Lists the fonts and the font types used in the original document in the Properties dialog.</i></li><li><i><b>Updated Command Line:</b>Allows users to open password protected PDF documents with a simple command prompt.</i></li><li><i><b>Streamlined UI:</b>A completely redesigned UI with a new look and feel makes Foxit Reader more intuitive than ever before.</i></li><li><i>Many bug fixes.</i></li></ul></blockquote>
<b>Download:</b><ul><li><a href="http://www.planet3dnow.de/cgi-bin/file/get.pl?20080425153252">Foxit Reader 2.3 Build 2825 [Windows Installer]</a></li><li><a href="http://www.planet3dnow.de/cgi-bin/file/get.pl?20080425153253">Foxit Reader 2.3 Build 2825 [Windows ZIP-Version]</a></li></ul>Die neue Version kann man demnächst auch über die intergrierte Update-Funktion des Foxit Reader beziehen.
<b>Update:</b> Inzwischen haben die Foxit-Entwickler die Build Version 2822 durch die Nummer 2825 ersetzt. Die neue Version beseitigt eine vor kurzem bekannt gewordene <a href="http://www.heise.de/security/Schwachstelle-in-Foxit-PDF-Reader-Update--/news/meldung/106946" target="b">Sicherheitlücke</a> im Foxit Reader.
<b>Links zum Thema:</b><ul><li><a href="http://www.foxitsoftware.com/pdf/reader_2/whatsnew23.htm" target="b">What's new in Version 2.3?</a></li></ul>
Vielen Dank an <a href="http://www.planet3dnow.de/vbulletin/member.php?u=41217">KIDH</a> für den Hinweis!
Tenchi Muyo 26
Super Programm und schön schlank dabei!
Habe auch noch nie Probs beim PDF drucken gehabt *daumenhoch*
SpaceMan
- Schweiz
- i7 2600k
- ASUS P8P67
- Noctua NH-U12P SE2 / 2x Noctua NF-P12 Gehäuselüfter
- 4x4GB Corsair Vengeance, DDR3-1600
- ASUS HD6950 2GB @6970 + Scythe Setsugen 2
- 27" Acer S273HL @1080p
- OCZ SSD Vertex 2 240GB
- Lian Li PC-8NB Midi-Tower
- Antec TP-650
- Windows 7 x64
- Logitech MX Revolution, Logitech Wireless Solar Keyboard K750
jo, perfekt und sauschnell.
benutze auch nix anderes mehr für PDFs!
Die Downloadserver lahmen aber grad extrem... sind wohl viele am saugen
Christian433
Bin neulich auch vom Adobe Reader auf den Foxit Reader umgestiegen, hab es keine Sekunde bereut. Im Gegenteil, ich hätte früher umsteigen sollen...
Leider ist die aktuelle Sicherheitslücke bislang noch nicht geschlossen.
Bis dahin kann man z.B. den Sumatra PDF Viewer verwenden.
Bond.007
- Berlin
- Dell XPS M1330 mit Win7
- Xeon E5-2696 v4 --> 22Cores!!
- Asrock X99 WS
- Corsair Hydro Series H110 mit 2x Noctua NF-A14 PWM
- 32GB Crucial DDR4-2133
- Palit GeForce GTX 1650 KalmX Passiv
- Eizo EV2455-BK
- Samsung SSD 980 PRO 2TB; 2x Samsung 870 Evo 4TB
- 3x LG UHD BluRay
- OnBoardSound
- Lian Li PC-B25FB Blue Ring + 3x120er S2 Noiseblocker Multiframe Lüfter + beQuiet Dämmset
- Sea Sonic Platinum Series Fanless 400W
- Win 10 Pro
- Idle: 55W und max: 195W, sehr sparsam und wahnsinnig schnell.
Tut mir leid, aber dieser ist nicht mal ansatzweise eine Alternative für mich.....und wer weiß wieviele Sicherheitslücken dieser hat
gruffi
- vorhanden
- AMD Ryzen 5 1600
- MSI B350M PRO-VDH
- Wraith Spire
- 2x 8 GB DDR4-2400 CL16
- XFX Radeon R7 260X
- LG W2361
- Crucial CT250BX100SSD1
- Toshiba DT01ACA200
- LG Blu-Ray-Brenner BH16NS40
- Realtek HD Audio
- Sharkoon MA-I1000
- be quiet! Pure Power 9 350W
- https://valid.x86.fr/mb4f0j
Foxit ist zwar recht schlank, mich konnte das Programm aber nicht wirklich überzeugen. Mal abgesehen von einigen Darstellungsfehlern, war mir die Suchfunktionalität immer zu primitiv. Nutze daher den PDF-XChange PDF Viewer momentan. Ist zwar nicht ganz so schlank, aber immer noch deutlich schlanker als Adobe. Und gefällt mir auch sonst einfach besser.
SpaceMan
- Schweiz
- i7 2600k
- ASUS P8P67
- Antec TP-650
- Windows 7 x64
was ist denn zu primitiv?
habe bis jetzt immer alle suchbegriffe gefunden
SPINA
- AMD Ryzen 7 3700X
- ASUS PRIME X370-PRO
- AMD Wraith Prism
- LG Electronics 27UD58P-B
- HL Data Storage BH16NS55
- Lian Li PC-7NB
- Seasonic PRIME Gold 650W
- Debian 12.x (x86-64)
- ASUS TPM-M R2.0
Tardiv
- AMD Athlon X2 5400+ (Brisbane) AM2
- Gigabyte GA-MA78GM-S2H
- EKL Großclockner
- 2x Samsung 2GB DDR2 6400
- Eizo L 568
- Samsung HD250HJ
- Asus DRW-2014S1T, Toshiba SD-M1712
- Casetek CS-1026b
- Enermax PRO82+ 385W
- Windows XP
- http://ftp.mozilla.org/pub/mozilla.org/seamonkey/nightly/latest-comm-central-trunk/
- Pfft.
Wenn der Foxit Reader Probleme mit einem PDF hat, weiche ich immer auf GSview aus. Eine sehr nützliche Ghostscript Erweiterung.
Übrigens kann GSview auch geschützte PDF ausdrucken. Die Oberfläche wirkt allerdings etwas altmodisch.
Oha. GSView verwende ich auch recht regelmäßig. Daher hatte ich es noch gar nicht bemerkt, dass es offenbar auch *.pdfs gibt, die sich z.B. mit dem Acrobat Reader nicht drucken lassen sollen.
Das wirft dann natürlich Bedenken hinsichtlich der Zulässigkeit der Verwendung von GSView in Deutschland im Hinblick auf § 95a UrhG auf.
mmoses
- Bembeltown
- Lenovo Thinkpad Edge T450
- AMD Ryzen5 - 1600
- MSI B350 PC MATE
- Original Bex Kühler
- Asus Radeon R7 250X
- 27" iiyama ProLite B2783QSU
- Samsung SSD 840PRO 256GB
- WD WD20EZRZ 2 TB
- 64-Bit Linux Mint 19.2
- Frickelfuchs/opera
Der PDF-Betrachter Foxit Reader, eine Alternative zu dem weit verbreiteten Adobe Reader, ist in der Version 2.3 mit der Buildnummer 2822 erschienen und bietet zahlreiche neue Features.
Dank der unglaublichen Fettsucht des Adobe originals inzwischen ein definitives MUST !
zumindest wenn man irgendwann auch mal zum Schaffen kommen will....
Mmoe
- München
- World Community Grid
- Folding@Home
- be quiet! Shadow Rock 3
- LG 27UL850-W, 27"
- Logitech G613 Lightspeed
- Logitech M510
- Ubuntu Linux 22.04
- Vivaldi
▼100 MBit
▲40 MBit
Inzwischen gibt es Build 2825, in welchem die angesprochene Sicherheitslücke gefixt ist.
Tardiv
- EKL Großclockner
- Eizo L 568
- Samsung HD250HJ
- Casetek CS-1026b
- Windows XP
- Pfft.
Leider ist die aktuelle Sicherheitslücke bislang noch nicht geschlossen. (...)
So, in dem jetzt erhältlichen 2.3 Build 2825 wurde nach Angaben der Entwickler auch die von heise gemeldete Sicherheitslücke geschlossen.
Opteron
Jupp, also Bitte an @P3D: Bitte die Links in der Ursprungsmeldung fixenSo, in dem jetzt erhältlichen 2.3 Build 2825 wurde nach Angaben der Entwickler auch die von heise gemeldete Sicherheitslücke geschlossen.
ciao
Alex
gruffi
- vorhanden
- AMD Ryzen 5 1600
- MSI B350M PRO-VDH
- Wraith Spire
- LG W2361
- Realtek HD Audio
- Sharkoon MA-I1000
ZB hat mir immer die Komplettsuche gefehlt. Du gibst also einen Begriff ein, sämtliche Fundorte werden dann aufgelistet und lassen sich bequem abrufen.was ist denn zu primitiv?
gast0815
Das ging ja fix!
Habe Foxit auch eine Zeitlang benutzt, deutlich besser als der Acrobat-Reader-Müll
Mittlerweise bin ich aber zum (ebenfalls kostenlosen!) Pdf-Xchange Viewer gewechselt, der noch mehr Features hat
http://www.docu-track.com/home/prod_user/PDF-XChange_Tools/pdfx_viewer/
wazzup
nutze immer noch die 1.3, hab da noch keine nachteile bemerkt, nur die datei ist etwas kleiner und vor allem exe only. Hatte nie probleme damit, keine darstellungsfehler, nichts. Den adobe schrott kann man sich spätestens seit Version 6 nicht mehr antun...
