nForce 500 Series Treiber 9.34 Beta
- Ersteller cruger
Parallel zur <a href="http://www.planet3dnow.de/cgi-bin/newspub/viewnews.cgi?category=1&id=1148389240">offiziellen Vorstellung</a> der nForce 500 Serie für AMDs neue <a href="http://www.planet3dnow.de/cgi-bin/newspub/viewnews.cgi?category=1&id=1148358949">AM2-Plattform</a> hat NVIDIA mit der Version 9.34 Beta ein passendes Treiberpaket für die neuen Chipsätze veröffentlicht.
<blockquote><b>Release Notes:</b><ul><li>Beta release of driver package for nForce 590 SLI, nForce 570 SLI, nForce 570 Ultra, nForce 550 motherboards.</li><li>WHQL candidate</li></ul><b>Installation Notes:</b><ul><li>Uninstall any existing nForce networking drivers prior to installing this package.</li><li>Windows XP users must install Service Pack 1, at a minimum, prior to attempting to install this package. Failure to do so will result in the inability to support USB 2.0.</li><li>Installation of DirectX 9.0 or higher is required in order to use NVMixer.</li></ul><b>User Guides</b>
<a href="http://download.nvidia.com/Windows/nforce/9.34/NVMediaShield_UGv5.pdf" target="b">MediaShield</a>
<a href="http://download.nvidia.com/Windows/nforce/9.34/NVNetworking_UG.pdf" target="b">Networking</a>
<b>Windows XP/2000 Driver Versions:</b><ul><li>Ethernet Driver (v60.15)</li><li>Network Management Tools (v60.16)</li><li>SMBus Driver (v4.52) "WHQL"</li><li>Installer (v5.08)</li><li>WinXP IDE SataRAID Driver (v6.67) "WHQL"</li><li>WinXP IDE SataIDE Driver (v6.67) "WHQL"</li><li>WinXP RAIDTOOL Application (v6.69) RAIDTOOL application version 5.52</li></ul></blockquote>
<b>Download:</b><ul><li><a href="http://www.planet3dnow.de/cgi-bin/file/get.pl?20060523180140">nForce 500 Series Treiber 9.34 Beta [Windows 2000/XP] (28,1 MB) - Mirror 1</a></li><li><a href="http://www.planet3dnow.de/cgi-bin/file/get.pl?20060523180141">nForce 500 Series Treiber 9.34 Beta [Windows 2000/XP] (28,1 MB) - Mirror 2</a></li><li><a href="http://www.planet3dnow.de/cgi-bin/file/get.pl?20060523180142">nForce 500 Series Treiber 9.34 Beta [Windows 2000/XP] (28,1 MB) - Mirror 3</a></li><li><a href="http://www.planet3dnow.de/cgi-bin/file/get.pl?20060523180143">nForce 500 Series Treiber 9.34 Beta [Windows 2000/XP] (28,1 MB) - Mirror 4</a></li>
<li><a href="http://www.planet3dnow.de/cgi-bin/file/get.pl?20060523180144">nForce 500 Series Treiber 9.34 Beta [Windows XP x64] (28,9 MB) - Mirror 1</a></li><li><a href="http://www.planet3dnow.de/cgi-bin/file/get.pl?20060523180145">nForce 500 Series Treiber 9.34 Beta [Windows XP x64] (28,9 MB) - Mirror 2</a></li><li><a href="http://www.planet3dnow.de/cgi-bin/file/get.pl?20060523180146">nForce 500 Series Treiber 9.34 Beta [Windows XP x64] (28,9 MB) - Mirror 3</a></li><li><a href="http://www.planet3dnow.de/cgi-bin/file/get.pl?20060523180147">nForce 500 Series Treiber 9.34 Beta [Windows XP x64] (28,9 MB) - Mirror 4</a></li></ul>
gast0972
Irgendwie peil' ich das nicht. Nach außen hin trägt der Treiber die Version 9.34 BETA, während er sich nach dem Entpacken als 6.69 outet...
Terminatrix
- Hamburg
Hast du schon ein AM2 Board?
gast0972
Nö. Wozu? Bin neugierig. Außerdem lassen die sich auch auf 'nem nForce 2 installieren *g* Gerade ausprobiert ^^;Hast du schon ein AM2 Board?
Gast07032022
Funtzt das denn auch normal auf nem nforce2?
Edit: Es funtzt, nur fürn nf2 gibs anscheinend kein verbsesserungen mehr
gast0972
Laut entsprechenden .inf Treiberinformationen, ja. Aber auch nur ein- oder zwei Treiber aus dem Package.Funtzt das denn auch normal auf nem nforce2?
EiRoGGe
- Leipzig
- IBM Thinkpad T60
- Intel Core i7-2600K @ 4x 4000MHz @ 1,144V
- ASUS P8Z68-V, Sockel 1155
- Thermalright HR-02 Macho (semi-passiv)
- 4x Kingston 4GB DDR3-1333 CL9
- Intel HD 3000
- ASUS PA246Q, 1920x1200
- Crucial m4 128GB, 2x Hitachi Z5K320 320GB
- Pioneer DVR-212BK
- Realtek HD
- Fractal Define R3
- HuntKey Jumper 300G @ Enermax T.B.Silence @ 5V
- Windows 7 Professional x64
Denkt dran, dass hier nicht alle Treiber für NF2 etc. drin sind, die benötigt werden.
Bei einem Update sollte das natürlich kein Problem sein
gast0972
Ganz genau. Eine Neuinstallation ist NICHT ratsam mit diesen Treibern. Ich würde sie sowieso gänzlich meiden... wäre da nur nicht die Neugierde...
Debaser
Worauf bist Du neugierig? Entweder es läuft, dann ist alles wie vorher, oder es läuft nicht, dann hast Du evtl. ein Problem am Hals.Ganz genau. Eine Neuinstallation ist NICHT ratsam mit diesen Treibern. Ich würde sie sowieso gänzlich meiden... wäre da nur nicht die Neugierde...
Also ich wüßte, was zu tun ist - never change a running system. Wie auch immer das Ergebnis ausfällt, es ist entweder so wie jetzt oder schlechter. Ist es wirklich wert, das herauszufinden?
gast0972
Definitiv: JA
Nun, eine Begründung bin ich Dir ja schuldig geblieben:
3 Treiber interessieren mich primär:
1. Der IDE-Treiber (ein Update wäre nicht übel)
2. S-ATA RAID Treiber (ein wenig mehr Performance ist nie schlecht)
3. Ethernet Treiber (hier wäre etwas mehr Stabilität wünschenswert)
Deshalb teste ich. Nachher ist mein nForce 430 an der Reihe @ Test ^^
Definitiv: JA
ja gib mal feedback. wie gesagt, hab die 9.16er drauf und funzt ganz gut. vll sind im neueren 9.34er auch für das nf4 die treiber aktualisiert worden.
gast0972
Darf ein armer, bis 24:00h arbeitender Mensch, auch erstmal nach Hause kommen...ja gib mal feedback. wie gesagt, hab die 9.16er drauf und funzt ganz gut. vll sind im neueren 9.34er auch für das nf4 die treiber aktualisiert worden.
Ich werd' mir nachher mit der neuen ForceWare ein Paket zusammenbasteln und dann mal schauen. Dürfte ein paar Tage dauern, bis ich Feedback gebe (nach 5 Minuten kann ich keine Aussage @ Performance / Stabilität treffen).
arm ist ok, aber arbeiten......nur nen scherz.
ich geh ins bett, muss morgen arbeiten. *g* =)
gast0972
So, habe nun getestet.
Mainboard: ASUS A8N-VM CSM (nForce 430+GeForce 6150)
GraKa: GeForce 7600 GT
In dieses Paket habe ich auch die neue 90er ForceWare gepackt (einfach Unterordner namens Display erstellen).
Tja... die neue ForceWare scheint die GeForce 6150 nicht zu mögen; sobald der Treiber für diese installiert wurde, führt der PC unweigerlich einen Reset durch.
Egal wie man testet: 6150 + ForceWare 9x.xx mögen sich nicht.
Sei's drum... auf die ForceWare verzichtet und nur dieses Paket auf mein nForce 430 installiert. SMBus und Ethernet Treiber wurden anstandlos installiert; der NVIDIA IDE-SW Treiber quittierte jedoch mit einer Fehlermeldung.
Mein Fazit: Weder die neue ForceWare, noch der neue nForce Treiber sind für das integrierte Mainboard nForce 430 + GeForce 6150 geeignet; vielleicht betrifft es aber auch nur das ASUS A8N-VM CSM.
hmm, najo...ich hab nen herkömmliches nf4 und werde den treiber einfach mal saugen und bei der nächsten installation ggf. berücksichtigen.
gast0972
Wie geschrieben: Ethernet und SMBus müssten sich ohne Weiteres installieren lassen. Der IDE-Treiber will nicht recht.hmm, najo...ich hab nen herkömmliches nf4 und werde den treiber einfach mal saugen und bei der nächsten installation ggf. berücksichtigen.
Paß' bitte auf, wenn Du ein RAID-0/1 nutzen solltest! Mache vorher unbedingt ein BackUp Deiner wichtigsten Dateien !!!
ok danke, RAID is aber nicht mehr bei mir drinn. ^^
Gangowilli
- Nähe Freiburg
- E4300 @2,47GHz
- Gigabyte 965 DS3P
- Boxed nicht hörbar
- 2GB Corsair PC5400 CL4
- Asus 1950Pro
- 19" CRT Philips
keine Soundtreiber dabei? ich such für NForce2 wegen massivem Soundproblem bei DTM3 noch neue Treiber, aber scheint so als währ der 4.62 der neuste... und der is anfang 2005
gast0972
AFAIK ist dort der Realtek ALC650 verbaut, oder? Dann halte Dich also bitte an www.realtek.com.tw und suche dort nach ALC650
Es wird Dir ein Link für Downloads angezeigt.
