Download Pidgin 2.7.0
- Ersteller KIDH
KIDH
- Pogotopia
- Folding@Home
- Abit AV8 3rd Eye
- Thermaltake Silent Boost K8
- GeForce 6800 GT
- DVD-ROM / DVD-Brenner
- Creative Audigy
- noname
- Enermax Liberty 400W Dual
- Win98SE / WinXP SP3
Der freie Multiprotokoll-Messenger Pidgin wurde in der Version 2.7.0 veröffentlicht. Das Programm unterstützt grundsätzlich die Chat-Protokolle von AIM, ICQ, Google Talk, Jabber/XMPP, MSN Messenger, Yahoo!, Bonjour, Gadu-Gadu, IRC, Novell GroupWise Messenger, QQ, Lotus Sametime, SILC, SIMPLE, MySpaceIM, und Zephyr - weitere stehen über Plugins zur Verfügung. Aktuell werden 70 Sprachen unterstützt.
Pidgin läuft unter Windows ab Windows 2000, Mac OS X ab 10.4 und Linux.
<b>Changelog:</b>
<ul><li>version 2.7.0 (05/12/2010):<blockquote><b>General</b><ul>
<li>Changed GTK+ minimum version requirement to 2.10.0.</li><li>Changed GLib minimum version requirement to 2.12.0.</li><li>Using the --disable-nls argument to configure now works properly. You will no longer be forced to have intltool to configure and build.</li><li>Fix two related crashes in the GnuTLS and NSS plugins when they suffer internal errors immediately upon attempting to establish an SSL connection.</li><li>Fix NSS to work when reinitialized after being used. (Thanks to Ludovico Cavedon for the testcase)</li><li>Added support for PURPLE_GNUTLS_PRIORITIES environment variable. This can be used to specify GnuTLS priorities on a per-host basis. The format is "host=priority;host2=priority;...". The default priority can be overridden by using "*" as the host. See the GnuTLS manual for documentation on the format of the priority strings.</li><li>Fix autoconf detection of Python. (Brad Smith)</li><li>Fix a crash when a Windows proxy (from IE) does not have a port. (Marten Klencke)</li></ul>
<b>Pidgin</b><ul>
<li>Moved the "Debugging Information" section of the About box to a "Build Information" dialog accessible on the Help menu.</li><li>Moved the Developer and Crazy Patch Writer information from the About box to a "Developer Information" dialog accessible on the Help menu.</li><li>Moved the Translator information from the About box to a "Translator Information" dialog accessible on the Help menu.</li><li>Use G!tkStatusIcon for the docklet, providing better integration in notification area.</li><li>Added UI for sending attentions (buzz, nudge) on supporting protocols.</li><li>Make the search dialog unobtrusive in the conversation window (by making it look and behave like the search dialog in Firefox)</li><li>The Recent Log Activity sort method for the Buddy List now distinguishes between no activity and a small amount of activity in the distant past. (Greg McNew)</li><li>Added a menu set mood globally for all mood-supporting accounts (currently XMPP and ICQ).</li><li>Default binding of Ctrl+Shift+v to 'Paste as Plain Text' in conversation windows. This can be changed in .gtkrc-2.0. For example, Ctrl+v can be bound to 'Paste as Plain Text' by default.</li><li>Plugins can now handle markup in buddy names by attaching to the "drawing-buddy" signal. (Daniele Ricci, Andrea Piccinelli)</li><li>Be more accommodating when scaling down large images for use as buddy icons.</li><li>The 'Message Timestamp Formats' plugin allows changing the timestamp format from the timestamps' context menu in conversation log.</li><li>The 'Message Timestamp Formats' plugin allows forcing 12-hour timestamps. (Jonathan Maltz)</li><li>Fix pastes from Chrome (rich-text pastes and probably URLs having garbage appended to them).</li><li>Show file transfer thumbnails for images on supporting protocols (currently only supported on MSN).</li></ul>
<b>Bonjour</b><ul>
<li>Added support for IPv6. (Thanks to T_X for testing)</li></ul>
<b>Gadu-Gadu</b><ul>
<li>Updated our bundled libgadu to 1.9.0-rc2 (many thanks to Krzysztof Klinikowski for the work and testing put in here!)</li><li>Minimum requirement for external libgadu is now also 1.9.0-rc2.</li></ul>
<b>AIM and ICQ</b><ul>
<li>X-Status (Custom ICQ status icon) support. Since most of the icons available reflect moods, this is labeled "Set Mood" on the Accounts->ICQ Account menu. (Andrew Ivanov, Tomáš Kebert, Yuriy Yevgrafov, and trac users bob007, salieff, and nops)</li><li>Allow setting and displaying icons between 1x1 and 100x100 pixels for ICQ. Previously only icons between 48x48 and 52x64 were allowed.</li><li>When using the clientLogin authentication method, prompt for a password on reconnect when "Remember Password" is not checked and authentication fails due to an incorrect password. (This is the same behavior as the legacy authentication method)</li><li>Support sending and receiving HTML-formatted messages for ICQ.</li><li>Use the proper URL for "View web profile" link for ICQ buddies. (Alexander Nartov)</li></ul>
<b>MSN</b><ul>
<li>Support for version 9 of the MSN protocol has been removed. This version is no longer supported on the servers.</li><li>Support file transfer thumbnails (previews) for images.</li><li>Fix CVE-2010-1624 (custom emoticon remote crash).</li></ul>
<b>XMPP</b><ul>
<li>Direct messages to a specific resource only upon receipt of a message with content (as opposed to a typing notification, etc). (Thanks to rjoly for testing)</li><li>Present a better error message when authentication fails while trying to connect to Facebook. (David Reiss, Facebook)</li><li>When sending data using in-band-bytestreams, interpret the block-size attribute as the size of the BASE64-encoded representation of the data.</li><li>Validate the hash on incoming BoB data objects (for custom smileys etc.), cache based per JID when the CID is not a valid hash (as specified by the BoB XEP).</li><li>Send whitespace keepalives if we haven't sent data in a while (2 minutes). This fixes an issue with Openfire disconnecting a libpurple-baesd client that has just been quiet for about 6 minutes.</li><li>Only support Google Talk's JID Domain Discovery extension (allowing a user to log in with "@gmail.com" or "@googlemail.com" interchangeably) for those two domains. This change was made due to interoperability issues with some BOSH Connection Managers and namespaced attributes.</li></ul>
<b>Yahoo/Yahoo JAPAN</b><ul>
<li>Attempt to better handle transparent proxies interfering with HTTP-based login.</li><li>Fix handling of P2P packets, thus fixing the loss of some messages.</li><li>Retrieve the pager server address from Yahoo!'s servers directly.</li><li>Removed the "Pager server" account option, as it is no longer needed.</li><li>The authentication code is now less order-sensitive with the components of the server's response.</li><li>The authentication process now acts more like the official client.</li></ul>
<b>Finch</b><ul>
<li>New action 'history-search', with default binding ctrl+r, to search the entered string in the input history.</li></ul></blockquote></li></ul>
<b>Download:</b><ul><li><a href="http://www.planet3dnow.de/cgi-bin/file/get.cgi?20100513202042">Pidgin 2.7.0 [Windows]</a></li><li><a href="http://www.planet3dnow.de/cgi-bin/file/get.cgi?20100513202043">Pidgin 2.7.0 [Source]</a></li></ul>
<b>Links zum Thema:</b>
<ul><li><a href="http://www.pidgin.im" target="b">Offizielle Internetpräsenz</a></li><li><a href="http://de.wikipedia.org/wiki/Freie_Software" target="b">Was ist Freie Software?</a></li><li><a href="http://www.planet3dnow.de/cgi-bin/newspub/viewnews.cgi?id=1272659466">Miranda IM 0.8.22</a></li><li><a href="http://www.planet3dnow.de/cgi-bin/newspub/viewnews.cgi?id=1266154318">Trillian Astra 4.1.0.24</a></li></ul>
Vielen Dank auch an <a href="http://www.planet3dnow.de/vbulletin/member.php?u=524">Der_Kanzler</a> für den Hinweis.
<b>Changelog:</b>
<b>Pidgin</b><ul>
<b>Bonjour</b><ul>
<b>MSN</b><ul>
<b>XMPP</b><ul>
<b>Finch</b><ul>
LostHero
- Osnabrück
- Medion Akoya P6630
- Intel Core i7 3770k (3,5Ghz)
- ASUS P8Z77-V Deluxe
- Prolimatech Genesis
- 2x8GB Corsair Vengeance (1866 Mhz @1,5V mit 9-10-9-27-2)
- Gigabyte NVIDIA Geforce GTX 680 (2GB)
- 27" ASUS VG278-X 120 Hz 3D Monitor
- SSD1: Samsung 840 Pro Series (512GB), SSD2: Intel X25 Postville (160GB), HDD1: 3TB, HDD2: 3TB
- LG BH10LS (Blue-Ray Combo Brenner)
- Creative X-Fi Titanium HD
- BitFenix ShinobiXL Big-Tower (gedämmt)
- Enermax Modu87+ (600 Watt)
- Windows 7 Professional SP1 (64 Bit)
- Puh zu viel...
bin ich der einzige bei dem eine bestimmte ICQ nummer einfach nich löschbar/umbenennbar/verschiebbar ist?
ich versuche seit wochen einen bestimmten ICQ Kontakt zu löschen aber sobald ich pidgin neu starte, ist der kontakt wieder da -.-.
das selbe passiert wenn ich den kontakt umbenenne oder in eine andere gruppe schiebe. pidgin neustarten und alles wieder wie vorher (betrifft nur den einen kontakt! nicht alle).
das problem besteht mit der neuen version leider immer noch.
Nutze w7 64bit...
Nutze w7 64bit...
NemesisTN
- Nürnberg
- Samsung ATIV7
- Core i7 3770
- Asus P8Z77-M
- AC Cuplex Kryos Delrin
- 8 GB G-Skill DDR3 1600
- Nvidia Geforce GTX670
- Eizo 24"
- Samsung SSD 830 128GB (System)
- 2x Samsung 1TB im RAID0 (Games), 1x Samsung 1TB (Daten)
- nix
- X-Fi XtremeMusic =)
- Silverstone Fortress FT02
- beQuiet 450W
- D: Win8.1 Pro 64bit, SteamOS, N: Win8.1 64bit
- GraKa mit AC Aquagrafx GTX670 gekühlt =)
Ich würde aus anderen Gründen erstmal auf die 2.7.1 warten:
Pidgin Encryption funktioniert nicht mehr. (!)
Und Messages vom ICQ-Client kommen als unformatiertes HTML an *AAAAAAARGH*
Downgegraded habe ich aber vor allem wegen der nicht mehr existenten Verschlüsselung.
Txxxxs
- Intel Core i5-3570 (3,40 GHz)
- Intel Desktop Board DZ77BH-55K
- Noctua NH-U12P + NF-P12 PWM
- Crucial Ballistix Sport VLP 2x 8 GB PC3-12800 (BLS2C8G3D1609ES2LX0CEU)
- GIGABYTE AMD Radeon HD 7870 (GV-R787OC-2GD)
- iiyama ProLite XB2483HSU
- Samsung 830 512 GB (MZ-7PC512D/EU)
- Pioneer BDR-208DBK
- Onboard (Realtek ALC898)
- Antec Performance One P182
- Seasonic X-650
- Microsoft Windows 8.1 Pro (64-Bit)
- Cherry eVolution STREAM XT Corded MultiMedia Keyboard, Logitech G9x Laser Mouse
Die OTR-Erweiterung arbeitet bisher problemlos.Pidgin Encryption funktioniert nicht mehr.
Weißt du, welche Version derjenige nutzt? Offenbar hat man das Problem mit ICQ-6.5-Nutzern, zumindest laut Ticket-System und eigener Feststellung, denn Nachrichten von ICQ-7.x-Nutzern kommen bisher ohne HTML-Code an bzw. werden ohne solchen dargestellt. Vielleicht sollte der Chat-Partner mal sein Programm aktualisieren - spätestens wenn der Anbieter wieder ältere Versionen aussperrt, wird er keine Wahl mehr haben.Und Messages vom ICQ-Client kommen als unformatiertes HTML an *AAAAAAARGH*
Ein Problem für viele wird auch das nicht mehr funktionierende Blinken bei neuen Nachrichten sein - aber das wurde bereits behoben und kommt mit Version 2.7.1: http://developer.pidgin.im/ticket/11842
NemesisTN
- Nürnberg
- Samsung ATIV7
- Core i7 3770
- Asus P8Z77-M
- Eizo 24"
- nix
- beQuiet 450W
Ich glaube er nutzt den ICQ 6.5.
Aber es kann doch nicht sein, dass ich alle Kontakte notfalls darauf hinweisen soll, dass sie updaten sollen?
(Manche wissen garnicht wie das geht, bzw. können das garnicht, weil sie eingeschränkte Nutzerkonten haben.)
Oh, das Nichtblinken hab ich ganz vergessen. Das ist auch ziemlich bescheiden.
Alles in allem ein Release, welches (ohne Grund?) mit der heißen Nadel gestickt wurde.
Gast17102016
Pidgin 2.7.1 mit dem Bugfix für das Problem mit den nicht blinkenden Nachrichten ist raus:
http://developer.pidgin.im/wiki/ChangeLog
NemesisTN
- Nürnberg
- Samsung ATIV7
- Core i7 3770
- Asus P8Z77-M
- Eizo 24"
- nix
- beQuiet 450W
Tscha, Pidgin Encryption 3.0 lüppt immernoch nicht...
