SpeedFan 4.34 veröffentlicht
- Ersteller cruger
Das Freeware-Tool SpeedFan ist in einer neuen Version 4.34 erschienen. SpeedFan ermöglicht die Überwachung diverser System-Parameter wie Lüfterdrehzahlen, Temperaturen, Spannungen oder auch das Auslesen von <a href="http://de.wikipedia.org/wiki/Self-Monitoring%2C_Analysis_and_Reporting_Technology" target="b">S.M.A.R.T. Informationen</a>. In der Hauptsache kann man mit SpeedFan aber vor allem die Drehzahlen der über ein Mainboard angeschlossenen Lüfter regeln.
Die Version 4.34 enthält folgende Änderungen:
<blockquote cite="http://www.almico.com/sfhistory.php"><ul><li><i>added full support for SiS964 SMBus</i></li><li><i>added full support for SiS966 SMBus</i></li><li><i>added full support for ULi M1575 SMBus</i></li><li><i>added full support for VIA VT8237S SMBus</i></li><li><i>added full support for VIA VT8251 SMBus</i></li><li><i>added full support for nVidia MCP61 SMBus</i></li><li><i>added full support to read internal temperatures on AMD K10 processors</i></li><li><i>added native nVidia video card (up to, but excluding 8xxx) internal temperature reporting</i></li><li><i>added full support for SMSC SCH5307</i></li><li><i>added full support for F8000 temperatures and fan speeds</i></li><li><i>added full support for SMSC EMCT03</i></li><li><i>added full support for WINBOND W83793G, including ADVANCED options</i></li><li><i>added support for Fintek F71782F hardware monitor at unusual addresses</i></li><li><i>added support for Winbond W83627DHG at unusual addresses</i></li><li><i>added support for ITE IT8726F hardware monitor at unusual addresses</i></li><li><i>added support for a new stepping of the Andigilog aSC7621</i></li><li><i>Winbond W83791D properly handles higher fan divisors for fan1, fan2 and fan3 and shows fan4 and fan5 too</i></li><li><i>added SMSC LPC47M192 FAN DIVISOR settings in CONFIGURE / ADVANCED</i></li><li><i>added full PWM support to SMSC LPC47B397, including settings in CONFIGURE / ADVANCED</i></li><li><i>CONFIGURE now allows to go as low as -60C when selecting the DESIRED and WARNING levels to let users of the RELATIVE Intel Core temperature reading properly configure SpeedFan</i></li><li><i>improved DDR2 memory module size detection</i></li><li><i>added preliminary DDR3 identification</i></li><li><i>new icon by Bengt Strom</i></li><li><i>fixed an issue where Intel Core temperatures on multi core systems reported the same temperature for all cores</i></li><li><i>improved Tjunction detection for Intel CORE temperatures (you might no longer need the temperature offset in CONFIGURE / ADVANCED)</i></li><li><i>fixed crash on several DFI motherboards</i></li><li><i>fixed the detection of older revisions of the ITE IT8705F</i></li><li><i>restored the correct clock speed after resume from hibernation</i></li><li><i>rewritten the logic of the usage of a synchronizer in the thread that reads CPU usage (this will fix the SpeedFan not exiting issue)</i></li><li><i>address $2E on DFI motherboards is no longer scanned if the motherboard model starts with LP. If you have one of these models and you know that there should be a valid chip at that address, send me a SEND REPORT (INFO tab) with some NOTES</i></li><li><i>fixed ADT7475 temperature readings when in offset 64 mode</i></li><li><i>fixed a bug when changing the type of data to be charted</i></li><li><i>mails sent by SpeedFan now properly separate headers and the body with a blank line</i></li><li><i>fixed an issue with SUN 2864 motherboard</i></li></ul></blockquote>
<b>Download:</b><ul><li><a href="http://www.almico.com/sfdownload.php" target="b">SpeedFan 4.34 [Windows]</a></li></ul>
klein van
- Raum Hessen
- Spinhenge@home
- Spinhenge
- i7-860, Q6600, Q6600, E6600, T7400, Athlon4000, i5-560M
- Lenovo R60
- Intel i7-860
- GA-P55A-UD6
- Noctua P12 mit 2x120/35
- 2x2GB DDR3 1600 OCZ
- ATI HD6850
- 19 TFT
- 1xWDC15 als System; 2x500er Samsung
- GGC-H20L, LG GSA-H55N
- Chieftec Mesh LCX-01BL-BL-B, blau
- Enermax 485W Noisetaker (EG495AX-VE(W)-SFMA)
- Windows7 Ultimate 64 bit
- IE8, FireFox3.6xx
Danke, endlich mal wieder eine Finale
cpushreder
- Hannover
- QuadCore Intel Core 2 Quad Q6600, 3510 MHz (9 x 390)
- Gigabyte GA-P35-DS3R
- EK Waterblock Plexi
- 2x G Skill F2-6400CL5-2GBPQ
- ATI Radeon HD 5770 (1024 MB) (Asus CuCore)
- Medion 23.6 Tft Akoya P55005 | Samsung SyncMaster 940NW [19" WS LCD]
- 2x SAMSUNG HD103SI (1TB) 2x SAMSUNG HD103SJ (1TB)
- HL-DT-ST DVD-RAM GH22NS30; TSSTcorp DVD-ROM SH-D163B
- Creative X-fi Titanium
- NZXT Whisper
- Nitrox 500w
- WIN7 x64
- Firefox V3.6
na das ist ja mal ne lange liste er changes. ich hoffe das es das hält was diesmal versprochen wird.
speedfan ist eines der programme die bei mir selten ihren dienst so verrichteten wie gefordert, aber dennoch immer wohlwollend beachtet und immer wieder angetestet wurden.
Denyo!dP!
- OB in NRW
- Lenovo T510
- Intel® Core™ i5-4670K
- ASRock Z87M Extreme4
- Thermalright HR-02 Macho Rev.A (BW)
- 8GB G.Skill Ares DDR3-1600 DIMM CL9 Dual Kit
- MSI Radeon RX6600 MECH 2x 8GB
- LG W2452TX 24"
- 1 x Samsung SSD 240 GB 840 Basic
- 1 x 2TB Seagate Barracuda ST2000DM001
- Samsung DVD Brenner
- Lancool K7 Black
- be quiet! Straight Power E8 480 Watt
- Windows 7 Home Premium 64-bit
- Magnat Vector 203 @ Yamaha RX-V 457, Kopfhörere: Superlux HD 681
Hat jemand Speedfan mit nem Gigabyte GA-Ma770-DS3 am laufen? Klappt bei mir nämlich nicht wirklich. Speedfan zeigt zwar Drehzahlen und Temps an, aber regeln kann ich nix
Coolsys
- Schweiz
- Immer Projekt des Monats oder Race
- Xeon Quad Yorkfield X3350 @8x425=3400MHz; AMD Turion(tm) 64 X2 Mobile Technology TL-56
- Asus Z53T mit Turion X2 64 2x1,8GHz, 2GB Ram, Geforce 7600Go, Vista Home Premium
- Athlon 64 3200+ So754
- Gigabyte K8NS Pro
- Zalman CNPS 7000CU
- 2x1024MB G.Skill DDR500
- Sapphire Radeon X800 XL AGP
- Acer AL1715msd DVI 1280x1024
- Samsung Sp1604N, Samsung SP1614C
- Plextor DVD Rom, Samsung SW224B, LG4163B
- Soundblaster Audigy 2
- Lian-LI PC7 SE
- Be Quiet 420W
- Windows XP SP2
- Dieses System ist mein letztes AMD System bevor das Intel-System kam. Daten dazu auf Nethands.
Ich krieg damit in regelmäßigem Abstand nen Grafikfehler zu sehen, der auch sofort wieder verschwindet. Recht "doof".
yahlov
- AM2 X2 5000+ BE
- Asus M2A-VM HDMI
- Alphacool NexXxos X2+
- 4x 1GB
- ATI x1250 @64MB
- Philips TFT 20"
- WD Raptor 150GB, 2x Samsung F1 RAID-1
- Pioneer Slot-In
- YY-Cube B0221
- Corsair VX450
- tweaked XP SP3
- Firefox 3.0
- Wak » Aquaduct 360XT MK2
Speedfan ist meiner Meinung nach eines der besten Tools zum regeln der Lüfter und zum auslesen der Temperatur.
Das es hin und wieder bei einigen Chipsätzen Probleme gibt oder es gar nicht funktioniert ist leider nicht wirklich zu ändern. Für das, dass es Freeware ist, kann man darüber hinweg sehen. Bei neuen Boards heisst es eben fleißig Reports an ihn senden.
Peter1984
- Mainfranken
- Asus Eee PC 901
- AMD Phenom II X4 940 @ ~3,5 Ghz
- Gigabyte GA-MA790GP-DS4H
- Arctic Cooling Freezer Xtreme mit Scythe S-Flex 1900 Lüfter
- 4 GB RAM (2x2 GB) PC 1066
- Gigabyte Radeon HD5850 1024 MB
- Samsung 245B, 24", 1920*1200
- 2x500 GB S-ATA WD AAKS RAID 1
- BR-LW LG
- Realtek HD Audio
- Enermax Vostok weiß
- Enermax 380W
- Windows 7 Pro 64 Bit
- Firefox 3.6
Das gleiche beim MA78GM-S2H...
McBain
- Hsinchu Taiwan
- Schenker Compact 15 (2017)
- AMD RyZen 9 3950X
- ASRock 570X Creator
- Noctua C14S
- G.Skill Trident Z Neo DIMM Kit 32GB, DDR4-3600, CL16-19-19-39
- Apple Cinema Display 27"
- Plextor PX-1TM8PeG 1024GB M.2 (PCIe), WD Blue 2TB M.2(SATA)
- 2x Seagate ST2000VX000 @Raid1
- Apple Power Mac G5 Mod
- Corsair AX1200i
klappt super mit dem MA78GM-S2H, mußt dir nur die 90° CPU Phantom Temperatur ausblenden lassen!
siehe hier: http://www.computerbase.de/forum/attachment.php?attachmentid=94305&d=1208153259
und hier das gesamte Thema: http://www.computerbase.de/forum/showthread.php?t=406564
Habe version 4.34 jetzt noch nicht ausprobiert, wird aber bald nachgeholt.
Peter1984
- Mainfranken
- Asus Eee PC 901
- BR-LW LG
- Realtek HD Audio
- Enermax 380W
- Firefox 3.6
Ah okay, in den erweiterten Optionen muss PWM-Mode auf Software-Controlled gestellt werden, dann läufts!
Denyo!dP!
- OB in NRW
- Lenovo T510
- LG W2452TX 24"
- Lancool K7 Black
Wo haste denn das jetzt eingestellt? Im Bios oder irgendwo in SpeedFan
Peter1984
- Mainfranken
- Asus Eee PC 901
- BR-LW LG
- Realtek HD Audio
- Enermax 380W
- Firefox 3.6
Im Speedfan, unter "advanced". Geht astrein!
Denyo!dP!
- OB in NRW
- Lenovo T510
- LG W2452TX 24"
- Lancool K7 Black
So einfach kann es sein Jetzt scheint Speedfan auch mit dem GA-MA770-DS3 zu funktionieren.
Danke Dir!
Danke Dir!
Neue beta Version von Speedfan.
http://www.almico.com/sfbetaprogram.php
Da gibts jetzt auch nen neuen Part im beta Stadium. Die Übersichtlichkeit sollte sich dort noch verbessern.
KIDH
- Pogotopia
- Folding@Home
- Abit AV8 3rd Eye
- Thermaltake Silent Boost K8
- GeForce 6800 GT
- DVD-ROM / DVD-Brenner
- Creative Audigy
- noname
- Enermax Liberty 400W Dual
- Win98SE / WinXP SP3
Ich würde es ja mal klasse finden, wenn man so viele Temps wie man will im Tray anzeigen lassen könnte und nicht nur eine ausgewählte...so im Stil von MBM halt.
cpushreder
- Hannover
- NZXT Whisper
- Nitrox 500w
- WIN7 x64
- Firefox V3.6
dann schreib almico (alfredo) an und hoff das er es implementiert.
