Für alle Planet3DNow!-Leser, die die Sektion <a href="http://www.planet3dnow.de/vbulletin/forumdisplay.php?s=&daysprune=&f=130" target="b">User-News</a> nicht verfolgen hier noch einmal der Hinweis:
Das freie Datenträgerverschlüsselungs-Programm TrueCrypt wurde am 21. Oktober in der Version 6.3 veröffentlicht. Mit dem Programm lassen sich Festplatten bzw. Teile davon und Wechseldatenträger verschlüsseln. Neuerungen sind u.a. der volle Support für Windows 7 und Mac OS X 10.6 (Snow Leopard).
Das Programm steht für Windows ab Windows 2000, Mac OS X ab 10.4, Linux und als Source zur Verfügung.
<b>Changelog:</b>
<blockquote><i>New features:<ul><li>Full support for Windows 7.</li>
<li>Full support for Mac OS X 10.6 Snow Leopard.</li>
<li>The ability to configure selected volumes as 'system favorite volumes'. This is useful, for example, when you have volumes that need to be mounted before system and application services start and before users start logging on. It is also useful when there are network-shared folders located on a TrueCrypt volume and you need to ensure that the network shares will be restored by the system each time it is restarted. For more information, see the chapter 'Main Program Window', section 'Program Menu', subsection 'Volumes -> Save Currently Mounted Volumes as System Favorites' in the documentation. (Windows)</li></ul>Improvements and bug fixes:<ul><li>'Favorite' volumes residing within partitions or dynamic volumes will no longer be affected by changes in disk device numbers, which may occur, e.g., when a drive is removed or added. Note: If you use a favorite volume list saved by TrueCrypt 6.2a or earlier and you want to take advantage of this improvement, you need to resave the list using TrueCrypt 6.3. (Windows)</li>
<li>Many other minor improvements and bug fixes. (Windows, Mac OS X, and Linux)</li></i></blockquote>
<b>Download:</b><ul><li><a href="http://www.truecrypt.org/downloads" target="b">TrueCrypt 6.3</a></li></ul>
<b>Links zum Thema:</b>
<ul><li><a href="http://www.truecrypt.org" target="b">Offizielle Internetpräsenz</a></li><li><a href="http://de.wikipedia.org/wiki/Freie_Software" target="b">Was ist Freie Software?</a></li></ul>
Vielen Dank an <a href="http://www.planet3dnow.de/vbulletin/member.php?u=22533">Rabe</a> für den <a href="http://www.planet3dnow.de/vbulletin/showthread.php?t=370308">Hinweis!</a>
