Download AMD Radeon Software Adrenalin Edition 17.12.2 Beta verfügbar.
- Ersteller eratte
User-News
Von eratte
Hinweis: Diese "User-News" wurde nicht von der Planet 3DNow! Redaktion veröffentlicht, sondern vom oben genannten Leser, der persönlich für den hier veröffentlichten Inhalt haftet.Release Notes & Download
Filename z.B. Win10-64Bit-Radeon-Software-Adrenalin-Edition-17.12.2-Dec19.exe (Beta)
Radeon Software Adrenalin Edition 17.12.2 Highlights
Resolved Issues
Radeon Settings Video tab may disappear on some hybrid graphics system configurations after a reboot
AMD XConnect™ Technology enabled system configurations may experience an intermittent system hang on hot plug.
GPU Display scaling may fail to enable when desktop resolution is set very low.
Region recording in Radeon ReLive will continue to record when the region window is closed.
3x1 display configurations may experience instability during Eyefinity creation or during gaming.
Ark Survival Evolved™ may experience heavy flickering or corruption when enabling the performance metrics overlay in Windows®7.
A black screen may be experienced when running full screen games on the Samsung CF791 Radeon FreeSync enabled display.
Netflix™ playback in a browser or via UWP application may experience stutter.
Radeon Overlay performance metrics may appear and disappear intermittently during updates.
Color Temperature controls may change colors on the incorrect display when using the reset option.
Star Wars™: Battlefront II may experience graphical corruption in some areas of the game.
Known Issues
Radeon Settings may experience a hang when enabling AMD CrossFire with three or more graphics products.
Trimming videos may fail to create a thumbnail if the video contains non-English characters.
Flickering may be observed on the performance metrics overlay when Enhanced Sync is enabled on some Radeon FreeSync connected displays.
Performance Metrics Overlay may hang if enabled when cycling display power off and on.
The "Reset" function in Radeon Settings for Display, ReLive, and Video may not work as intended when using Radeon Settings in certain regional languages.
Radeon WattMan may intermittently fail to load profiles for Radeon RX Vega on the global Radeon Wattman page.
Rise of the Tomb Raider™ may experience an intermittent application hang during gameplay.
A random system hang may be experienced after extended periods of use on system configurations using 12 GPU's for compute workloads.
The GPU Workload feature may cause a system hang when switching to Compute while AMD CrossFire is enabled. A workaround is to disable AMD CrossFire before switching the toggle to Compute workloads.
Package Contents
The Radeon Software Adrenalin Edition 17.12.2 installation package contains the following:
Radeon Software Adrenalin Edition 17.12.2 Driver Version 17.50.07.01 (Windows Driver Store Version 23.20.15007.1005)
Radeon Product Compatibility
Radeon Software Adrenalin Edition 17.12.2 is compatible with the following AMD Radeon products.
Note: AMD Radeon™ R9 Fury, Radeon™ Pro Duo, Radeon™ RX 400 Series, Radeon™ RX 500 Series and Radeon™ RX Vega Series graphics are only supported by Radeon Software Adrenalin Edition on Windows 7/10 64-bit.
Radeon Desktop Product Family Compatibility
Radeon™ RX Vega Series Graphics
Radeon™ RX 500 Series Graphics
Radeon™ RX 400 Series Graphics
AMD Radeon™ Pro Duo
AMD Radeon™ R7 300 Series Graphics
AMD Radeon™ R7 200 Series Graphics
AMD Radeon™ R9 Fury Series Graphics
AMD Radeon™ R5 300 Series Graphics
AMD Radeon™ R9 Nano Series Graphics
AMD Radeon™ R5 200 Series Graphics
AMD Radeon™ R9 300 Series Graphics
AMD Radeon™ R9 200 Series Graphics
AMD Radeon™ HD 7700 - HD 7900 Series Graphics
AMD Radeon™ HD 8500 - HD 8900 Series Graphics
Mobility Radeon™ Family Compatibility
Radeon Software Adrenalin Edition 17.12.2 is a notebook reference graphics driver with limited support for system vendor specific features.
Radeon Mobility Product Family Compatibility
AMD Radeon™ R9 M300 Series Graphics
AMD Radeon™ R7 M200 Series Graphics
AMD Radeon™ R7 M300 Series Graphics
AMD Radeon™ R5 M200 Series Graphics
AMD Radeon™ R5 M300 Series Graphics
AMD Radeon™ R9 M200 Series Graphics
AMD Radeon™ HD 7700M - HD 7900M Series Graphics
AMD Radeon™ HD 8500M - HD 8900M Series Graphics
Compatible Operating Systems
Radeon Software Adrenalin Edition 17.12.2 is designed to support the following Microsoft® Windows® platforms. Operating System support may vary depending on your specific AMD Radeon product.
Windows® 10 (32 & 64-bit version)
Windows 7 (32 & 64-bit version with SP1 or higher)
Resolved Issues
Known Issues
Package Contents
AMD Radeon™ Pro Duo
ThePowerOfDream
- Düsseldorf
- Acer A315-42
- AMD TR 2990WX
- ASRock X399 Taichi
- Noctua NH-U14S TR4-SP3
- 128GB GSkill DDR4 3200
- PNY Verto GTX1050Ti
- AOC FHD ,LCPower 27" Curved
- 1TB Samsung 960Pro ; 2x Samsung 1TB 960Evo
- paar externe
- BD + DVD Brenner
- onBoard
- Corsair Obsidian 750D
- Corsair HX Series HX750
- W-10x64
- alle
- Capture Card fürs Streamen ist eine Avermedia LiveGamer HD2
Dafür das es eigendlich ja nur ein Fix sein sollte haben se aber schnell mal wieder die APUs raus genommen. Na was solls, der 17.12.1 läuft ja 1a.
maikrosoft
- germany
- AMD Ryzen 7 7800x 3d
- ASUS ROG STRIX B650-A Gaming
- Thermalright Peerless Assassin 120 SE ARGB white
- 2 x 16 GB Corsair Vengeance 5600MHz CL 36
- ASUS GeForce RTX 4060 Ti OC white
- LG UltraGear 27GP850-B
- Samsung 970 EVO Plus 2TB, Western Digital SN550, Crucial MX500 1TB m.2, Silicon Power Ace A55 1TB
- Soundblaster AE-5 PLUS - DT-990pro
- BeQuiet Silentbase 802
- Seasonic Core GM 650W
- Sharkoon SGK 60
- Gigabyte M3
- Windows 11 pro x64 / Manjaro
- AUKEY Large mousepad gaming xxl
Ich habe wieder vermehrt Probleme mit den letzten AMD Treibern.
Wenn ich zum Beispiel länger im Browser auf twitch unterwegs war oder auf amazon, sky oder wo auch immer einen Film geschaut habe und dann ein Spiel starte habe ich Ameisenfussball. Ich muss dann jedes mal den PC neu starten.
Ameisenfussball - ist so in der Art wie früher bei Röhren TVs wenn kein Empfang war.
In den meisten Beta und non-WHQL ist kein Support für die APUs vorhanden.
Unbekannter Krieger
- 4x4 GiB Hynix DDR3-1866 ECC
- TSST SH-222AL
- Win8.x x64, Win7 x64
Für Testzwecke suche ich nach neuen Versionen der
atiumdag.dll aus dem Ordnerpfad C:\Windows\SysWOW64.
Mit "neu" meine ich dabei älter als die aktuelle aus RSAE 17.12.2 und
mind. aus einer Crimson-Ausgabe, also jünger als Catalyst 15.10.
(Besonders interessieren mich Veröffentlichungen zwischen September und November 2017.)
Wer welche zu bieten hat, lade sie – nur die eine dll – bitte hoch und teile einen Link (mit mir).
Vielen Dank im Voraus!
SPINA
- AMD Ryzen 7 3700X
- ASUS PRIME X370-PRO
- AMD Wraith Prism
- LG Electronics 27UD58P-B
- HL Data Storage BH16NS55
- Lian Li PC-7NB
- Seasonic PRIME Gold 650W
- Debian 12.x (x86-64)
- ASUS TPM-M R2.0
Man sollte einen Treiber aus der Crimson Reihe vorhalten, denn der Adrenalin hat Probleme mit einigen Direct3D9 Titeln und AMD möchte daran nichts ändern.
Quelle: https://redd.it/7na5ws (mit Liste der betroffenen Spiele)This title is from 2007, so we are unlikely to devote any valuable engineering resources to this issue, which is most likely caused by outdated API modules.
Dachte ich mir das du mit dem Sturm im Wasserglas ankommst
Wer eins der wenigen betroffenen Spiele noch zockt der kann das DX9 SDK installieren, laut Userrückmeldungen reicht das.
Update per Twitter von Terry Makedon:
Happy 2018 everyone!! I am seeing some stories pop up about AMD not supporting some old games. That is absolutely not true, we are identifying the bug and working on a fix asap. C&C, Witcher, BfME, etc will be working again.
SPINA
- AMD Ryzen 7 3700X
- AMD Wraith Prism
- Lian Li PC-7NB
- ASUS TPM-M R2.0
Die Beschreibung des folgenden Fehlers ist unpräzise. Das Flackern tritt nicht im Spiel auf, sondern auf dem Windows Desktop nach dem Verlassen des Spiels.
Am Anfang dachte ich schon der VRAM meiner Radeon RX480 hätte ein Schlag weg, aber das Abmelden des Benutzers behebt das Flackern. Enhanced Sync ist übrigens eine richtig gute Erfindung von AMD. Man sieht überhaupt kein Tearing mehr, ohne die Nachteile vom herkömmlichen VSync; es ist in der Praxis beinah noch wirkungsvoller als FreeSync. Wer keinen Monitor mit FreeSync Unterstüzung sein Eigen nennt, sollte es unbedingt ausprobieren und selbst wer über FreeSync verfügt, sollte Enhanced Sync als Ergänzung oder sogar Ersatz in Betracht ziehen. Eine der besten Neuerungen der letzten Jahre.Flickering may be observed on the performance metrics overlay when Enhanced Sync is enabled on some Radeon FreeSync connected displays.
Ich muss doch zur Abwechslung auch einmal den Newsbot geben.Dachte ich mir das du mit dem Sturm im Wasserglas ankommst
Unbekannter Krieger
- TSST SH-222AL
Was die atiumdag.dll betrifft, siehe auch
http://planet3dnow.de/vbulletin/thr...a-verfuegbar?p=5184753&viewfull=1#post5184753.
