Download AMD Radeon Software Adrenalin Edition 18.10.1 Beta verfügbar.
- Ersteller eratte
User-News
Von eratte
Hinweis: Diese "User-News" wurde nicht von der Planet 3DNow! Redaktion veröffentlicht, sondern vom oben genannten Leser, der persönlich für den hier veröffentlichten Inhalt haftet.Release Notes & Download
Filename Alt z.B.: Win10-64Bit-Radeon-Software-Adrenalin-Edition-18.10.1-Oct10.exe
Filename Neu z.B.: win10-64bit-radeon-software-adrenalin-edition-18.10.1-oct15.exe
Filename noch Neuer z.B. win10-64bit-radeon-software-adrenalin-edition-18.10.1-oct18.exe
Keine 32bit Treiber mehr wie es aussieht.
Radeon Software Adrenalin Edition 18.10.1 Highlights
Support For
Windows® 10 October 2018 Update
Call of Duty®: Black Ops 4
Up to 5% faster performance in Call of Duty: Black Ops 4 using Radeon™ Software Adrenalin Edition 18.10.1 on the Radeon™ RX Vega 64 (8GB) graphics card than with Radeon™ Software Adrenalin Edition 18.9.3 at 1920x1080 (1080p).RS-258
Up to 6% faster performance in Call of Duty: Black Ops 4 using Radeon™ Software Adrenalin Edition 18.10.1 on the Radeon™ RX 580 (8GB) graphics card than with Radeon™ Software Adrenalin Edition 18.9.3 at 1920x1080 (1080p).RS-259
Fixed Issues
HDMI™ Audio Drivers may sometimes not upgrade during Radeon Software installation.
Fortnite™ may experience lighting corruption when effects quality is set to High or Epic.
System configurations with 16+ CPU cores may experience a random system reboot during installation when upgrading Radeon Software from a version older than RSAE 18.8.1.
Sea of Thieves™ may experience flickering textures in multi GPU system configurations.
Known Issues
When using Radeon Overlay on system configurations with the latest Windows®10 October 2018 Update some users may experience intermittent instability or game crashes.
Microsoft® Office applications may experience lag or stutter when dragging applications.
Radeon RX Vega Series graphics products may experience elevated memory clocks during system idle.
Added Vulkan™ Extension Support
VK_KHR_shader_atomic_int64
This extension advertises the SPIR-V Int64Atomics capability for Vulkan, which allows a shader to contain 64-bit atomic operations on signed and unsigned integers.
VK_KHR_driver_properties
This extension provides a new physical device query which allows retrieving information about the driver implementation, allowing applications to determine which physical device corresponds to which particular vendor’s driver, and which conformance test suite version the driver implementation is compliant with.
SPV_GOOGLE_decorate_string
This extension provides two new instructions to decorate a variable or a struct member with a string.
SPV_GOOGLE_hlsl_functionality1
This extension provides two new decorations to extend HLSL functionality: HlslCounterBuffer and HlslSemantic.
Footnotes
Testing conducted by AMD Performance Labs as of October 9th, 2018 on the 8GB Radeon™ RX 580, on a test system comprising of Intel i7 7700K CPU (4.2 GHz), 16GB DDR4-3000 Mhz system memory, and Windows 10 x64. PC manufacturers may vary configurations, yielding different results. With very high preset settings on Call of Duty: Black Ops 4, the Radeon™ RX 580 scored with Radeon™ software Adrenalin Edition 18.10.1 scored 107.4 FPS whereas the Radeon™ RX 580 scored 100.9 FPS with Radeon Software Adrenalin Edition 18.9.3. Comparing software versions, Radeon Software Adrenalin Edition 18.10.1 has 6% faster performance in Call of Duty: Black Ops 4. Performance may vary based on use of latest drivers. RS-259
Testing conducted by AMD Performance Labs as of October 9th, 2018 on the 8GB Radeon™ RX Vega 64, on a test system comprising of Intel i7 7700K CPU (4.2 GHz), 16GB DDR4-3000 Mhz system memory, and Windows 10 x64. PC manufacturers may vary configurations, yielding different results. With very high preset settings on Call of Duty: Black Ops 4, the Radeon™ RX Vega 64 scored with Radeon™ software Adrenalin Edition 18.10.1 scored 162.8 FPS whereas the Radeon™ RX Vega 64 scored 155.3 FPS with Radeon Software Adrenalin Edition 18.9.3. Comparing software versions, Radeon Software Adrenalin Edition 18.10.1 has 5% faster performance in Call of Duty: Black Ops 4. Performance may vary based on use of latest drivers. RS-258
Package Contents
The Radeon Software Adrenalin Edition 18.10.1 installation package contains the following:
Radeon Software Adrenalin Edition 18.10.1 Driver Version 18.40.03.01 (Windows Driver Store Version 24.20.14003.1010)
Radeon Product Compatibility
Radeon Software Adrenalin Edition 18.10.1 is compatible with the following AMD Radeon products.
Radeon Desktop Product Family Compatibility
Radeon RX Vega Series Graphics
Radeon™ RX 500 / Radeon 500X Series Graphics
Radeon™ RX 400 Series Graphics
AMD Radeon™ Pro Duo
AMD Radeon™ R7 300 Series Graphics
AMD Radeon™ R7 200 Series Graphics
AMD Radeon™ R9 Fury Series Graphics
AMD Radeon™ R5 300 Series Graphics
AMD Radeon™ R9 Nano Series Graphics
AMD Radeon™ R5 200 Series Graphics
AMD Radeon™ R9 300 Series Graphics
AMD Radeon™ R9 200 Series Graphics
AMD Radeon™ HD 7700 - HD 7900 Series Graphics
AMD Radeon™ HD 8500 - HD 8900 Series Graphics
AMD Ryzen™ Desktop Processors with Radeon™ Vega Graphics Compatibility
Ryzen Desktop Processors with Radeon Vega Graphics are only supported by AMD Radeon Software Adrenalin Edition on Windows® 10 64-bit.
AMD Ryzen™ / Athlon™ Desktop Processors with Radeon™ Vega Graphics Compatibility
AMD Ryzen 5 2400G
AMD Ryzen 5 2400GE
AMD Ryzen 3 2200G
AMD Ryzen 3 2200GE
AMD Ryzen 5 PRO 2400G
AMD Ryzen 3 PRO 2200G
AMD Ryzen 5 PRO 2400GE
AMD Ryzen 3 PRO 2200GE
AMD Ryzen 3 PRO 2100GE
AMD Athlon 200GE
AMD Athlon PRO 200GE
Mobility Radeon™ Family Compatibility
Radeon Software Adrenalin Edition 18.10.1 is a notebook reference graphics driver with limited support for system vendor specific features.
Radeon Mobility Product Family Compatibility
AMD Radeon™ R9 M300 Series Graphics
AMD Radeon™ R7 M200 Series Graphics
AMD Radeon™ R7 M300 Series Graphics
AMD Radeon™ R5 M200 Series Graphics
AMD Radeon™ R5 M300 Series Graphics
AMD Radeon™ R9 M200 Series Graphics
AMD Radeon™ HD 7700M - HD 7900M Series Graphics
AMD Radeon™ HD 8500M - HD 8900M Series Graphics
AMD APU Product Family Compatibility
Desktop
AMD A-Series APUs with Radeon™ R4, R5, R6, or R7 Graphics
AMD Pro A-Series APUs with Radeon™ R5 or R7 Graphics
AMD Athlon™ Series APUs with Radeon™ R3 Graphics
AMD Sempron™ Series APUs with Radeon™ R3 Graphics
Mobile
AMD A-Series APUs with Radeon™ R3, R4, R5, R6, R7, or R8 Graphics
AMD Pro A-Series APUs with Radeon™ R5, R6, or R7 Graphics
AMD FX-Series APUs with Radeon™ R7 Graphics
AMD E-Series APUs with Radeon™ R2 Graphics
AMD Radeon™ HD 8180 - HD 8400 Series Graphics
Compatible Operating Systems
Radeon Software Adrenalin Edition 18.10.1 is designed to support the following Microsoft® Windows® platforms. Operating System support may vary depending on your specific AMD Radeon product.
Windows® 10 64-bit version
Windows 7 64-bit version with SP1 or higher
Support For
Fixed Issues
Known Issues
Footnotes
Package Contents
AMD Radeon™ Pro Duo
AMD Ryzen 5 2400G
AMD Ryzen 5 2400GE
AMD Ryzen 3 2200G
AMD Ryzen 3 2200GE
AMD Athlon 200GE
Desktop
Mobile
psychocyberdisc
- Mystery Lake
- ASUS ROG Zephyrus G14 (GA402RJ-L8116X) // 14 Zoll
- Details zu meinem Laptop
- AMD Ryzen 7 6800HS (Rembrandt, 3200 MHz, bis zu 4700 MHz, 4 MB L2-Cache, 16 MB L3-Cache)
- ASUS GA402RJ (BIOS 319)
- 8 GB verlötet sowie 1 × Samsung M425R4GA3BB0-CQK (insges. 40 GB, DDR5-4800)
- AMD Radeon 680M (RDNA 2), AMD Radeon RX 6700S (Navi 23, bis zu 105 Watt mittels AMD SmartShift)
- 2560 × 1600 Bildpunkte, 500 cd/m², 120 Hz // HP EliteDisplay E273q (1FH52AA#ABB)
- Samsung SSD 990 PRO (2 TB, Firmware 8B2QJXD7) // Samsung Portable SSD T7 (2 TB)
- ASUS ROG Zephyrus G14 (2022) mit AniMe Matrix
- 240 Watt
- Razer BlackWidow V4 Pro (RZ03-04682100-R3G1)
- Microsoft Windows 11 Pro (Windows 11 2025 Update / Version 25H2)
- Microsoft Edge mit uBlock Origin Lite
- HP USB-C Dock G5 (5TW10AA#ABB), beyerdynamic MMX 300 Manufaktur, FRITZ! FRITZ!Box 6690 Cable
▼100 Mbit/s
▲50 Mbit/s
Die Dateien wurden wieder ausgetauscht.
win7-64bit-radeon-software-adrenalin-edition-18.10.1-oct15.exe
- Ryzen R9 9950X3D
Danke auch in Post 1 angepasst.
psychocyberdisc
- Mystery Lake
- 240 Watt
▼100 Mbit/s
▲50 Mbit/s
win7-64bit-radeon-software-adrenalin-edition-18.10.1-oct18.exe
- Ryzen R9 9950X3D
Nerv
PS.: also AMD nicht du
SPINA
- AMD Ryzen 7 5700X3D (100-100001503)
- ASUS ProArt B550-Creator
- AMD Wraith Prism
- Sapphire Pulse Radeon RX 7600 8GB (11324-01-20G)
- LG Electronics 27UD58P-B
- Western Digital SN850X (WDS400T2XHE)
- HL Data Storage BH16NS55
- Lian Li PC-7NB
- Seasonic PRIME Gold 650W
- Debian 12.x (x86-64) Xfce
- ASUS TPM-SPI (Nuvoton NPCT750A)
Die Radeon Software 18.10.1 bereitet bei mir Schwierigkeiten beim Aufwachen aus dem ACPI S3:
Es wird kein Bild ausgegeben und in einigen Fällen folgt darauf ein (nicht sichtbarer) BSOD mit der ID 0x8000400000000002. Mit der Radeon Software 18.9.3 war dieses Verhalten nicht zu beobachten, aber es besteht halt immer die Gefahr, dass es unerwünschte Begleiterscheinungen gibt, wenn man non-WHQL Treiber ausprobiert.
- Question
- Question
- Question
- Question
