Download AMD Radeon Software Crimson ReLive Edition 17.9.3 WHQL verfügbar.
- Ersteller eratte
User-News
Von eratte
Hinweis: Diese "User-News" wurde nicht von der Planet 3DNow! Redaktion veröffentlicht, sondern vom oben genannten Leser, der persönlich für den hier veröffentlichten Inhalt haftet.Release Notes & Download
Radeon Software Crimson ReLive Edition 17.9.3 Highlights
Support For
Total War: WARHAMMER™ II
Radeon Chill profile added
Multi GPU support enabled
Forza™ Motorsport 7
Fixed Issues
The drop-down option to enable Enhanced Sync may be missing in Radeon Settings on Radeon RX Vega Series Graphics Products.
ReLive may cause higher idle clocks on the secondary Radeon RX Vega Series Graphics Product in a multi-GPU configuration on certain AMD Ryzen based systems.
Negative scaling in F1™ 2017 may be observed on Radeon RX 580 Series Graphics products in multi-GPU system configurations.
Known Issues
Unstable Radeon WattMan profiles may not be restored to default after a system hang. A workaround is to launch Radeon WattMan after reboot and restore settings to default.
Wattman may fail to apply user adjusted voltage values on certain configurations.
Radeon Settings may not populate game profiles after Radeon Software's initial install.
Overwatch™ may experience a random or intermittent hang on some system configurations.
GPU Scaling may fail to work on some DirectX®11 applications.
Secondary displays may show corruption or green screen when the display/system enters sleep or hibernate with content playing.
Bezel compensation in mixed mode Eyefinity cannot be applied.
When recording with Radeon ReLive on Radeon RX Vega Series graphics products GPU usage and clocks may remain in high states.
Package Contents
The Radeon Software Crimson ReLive Edition 17.9.3 installation package contains the following:
Radeon Software Crimson ReLive Edition 17.9.3 Driver Version 17.30.1091.1011 (Windows Driver Store Version 22.19.677.256)
Radeon Product Compatibility
Radeon Software Crimson ReLive Edition 17.9.3 is compatible with the following AMD Radeon products.
Note: AMD Radeon™ R9 Fury, Radeon™ Pro Duo, Radeon™ RX 400 Series, AMD Radeon™ RX 500 Series and Radeon RX Vega Series Graphics are only supported by Radeon Software Crimson ReLive Edition on Windows 7/10 64-bit.
Radeon Desktop Product Family Compatibility
Radeon™ RX 500 Series Graphics
Radeon™ RX 400 Series Graphics
AMD Radeon™ Pro Duo
AMD Radeon™ R7 300 Series Graphics
AMD Radeon™ R7 200 Series Graphics
AMD Radeon™ R9 Fury Series Graphics
AMD Radeon™ R5 300 Series Graphics
AMD Radeon™ R9 Nano Series Graphics
AMD Radeon™ R5 200 Series Graphics
AMD Radeon™ R9 300 Series Graphics
AMD Radeon™ R9 200 Series Graphics
AMD Radeon™ HD 7700 - HD 7900 Series Graphics
AMD Radeon™ HD 8500 - HD 8900 Series Graphics
Mobility Radeon™ Family Compatibility
Radeon Software Crimson ReLive Edition 17.9.3 is a notebook reference graphics driver with limited support for system vendor specific features.
Radeon Mobility Product Family Compatibility
AMD Radeon™ R9 M300 Series Graphics
AMD Radeon™ R7 M200 Series Graphics
AMD Radeon™ R7 M300 Series Graphics
AMD Radeon™ R5 M200 Series Graphics
AMD Radeon™ R5 M300 Series Graphics
AMD Radeon™ R9 M200 Series Graphics
AMD Radeon™ HD 7700M - HD 7900M Series Graphics
AMD Radeon™ HD 8500M - HD 8900M Series Graphics
Compatible Operating Systems
Radeon Software Crimson ReLive Edition 17.9.3 is designed to support the following Microsoft® Windows® platforms. Operating System support may vary depending on your specific AMD Radeon product.
Windows® 10 (32 & 64-bit version)
Windows 7 (32 & 64-bit version with SP1 or higher)
Support For
Forza™ Motorsport 7
Fixed Issues
Known Issues
Package Contents
AMD Radeon™ Pro Duo
Hat schon jemand mit einer Vega erfolgreich mGPU fahren können?
z.B. mit Rise of the Tomb Raider und DirectX_12: http://abload.de/img/rottr_2017_10_01_09_1taju8.jpg
Bei mir läuft Crossfire mit dem Treiber immer noch, auch mit openGL: https://abload.de/img/crimsonrelive_1793_fuy8y52.jpg
Das dürfte für die DX12 Version von Tomb Raider doch ohnehin egal sein da der multi GPU Part nichts mit Crossfire zu tuen hat.
Ja das stimmt, mir ging es jetzt eher darum, dass "legacy" nicht bedeutet, es gibt kein Crossfire mehr.Das dürfte für die DX12 Version von Tomb Raider doch ohnehin egal sein da der multi GPU Part nichts mit Crossfire zu tuen hat.
Daher auch Furmark mit OpenGL welches ebenfalls den legacy mode nutzt.
P.S. Hitmann(tm) kann auch mGPU:
http://abload.de/img/hitman_47_setmykvk.jpg
http://abload.de/img/hitman_2017_10_02_18_nsjyl.jpg
Heimliches Treiber Update:
whql-radeon-software-crimson-relive-17.9.3-win10-64bit-oct2.exe
psychocyberdisc
- Mystery Lake
- OMEN by HP Laptop 16-c0xxx
- 230 Watt
▼50 Mbit/s
▲25 Mbit/s
Die Nutzer von APUs gucken wieder mal in die Röhre.
http://support.amd.com/en-us/download/apu?os=Windows 10 - 64
Ja sehr stiefmütterlich - wie auch der eingestellte Windows 8.x Support.
psychocyberdisc
- Mystery Lake
- 230 Watt
▼50 Mbit/s
▲25 Mbit/s
Absolut. Ich wollte zu Beginn des Jahres von Windows 10 zurück zu Windows 8.1 wechseln, weil letzteres spätestens seit April 2014 (Veröffentlichung von Windows 8.1 Update 1) ein gutes Betriebssystem war (und ist). AMD belässt es jedoch beim Crimson ReLive Edition 16.12.2 und hat das erst im April kommuniziert. Da ich in den kommenden Monaten auch mal ein paar aktuelle, jedoch grafisch nicht ganz so anspruchsvolle Spiele auf meinem Notebook ausprobieren möchte, kommt ein 10 Monate alter Grafiktreiber nicht in Betracht.
Überhaupt ließ der Zeitraum für Software-Unterstützung in jüngerer Vergangenheit für einzelne Produkte arg zu wünschen übrig: Die Richland-APUs (Sommer 2013) waren gerade einmal 2 Jahre auf dem Markt, als mit dem Catalyst 15.7.1 der letzte passende Treiber für deren Grafikeinheiten kam.
Mit dem Trend - ist ja nicht nur bei AMD so - Support für ältere Windowsversionen fallen zu lassen kann man sich aus Kundensicht nur ärgern.
Radeon RX Vega: Anisotrope Filterung mit aktueller Radeon Software fehlerhaft (PC Gameshardware)
Tja, blöd gelaufen bei mir!
Hab den 3DCenter Filter Tester getestet, als ich am LOD Bias Regler herumgespielt habe ging der PC auf einmal aus (-3.x war der letzte Wert denn ich noch sah vom LOD Bias)
Letzten Endes fand ich heraus, das Nr 364 nicht mehr erkannt wird vom System und der Beep Ton für die GPU kommt wenn sie allein im System steckt.
Die zweite Karte Nr 451 funktioniert noch in beiden PCI-E Steckplätzen.
Habe ja gehofft, dass nur die Video Einheit tot ist, da die Lüfter noch laufen.
Kann natürlich Zufall sein mit dem 3DCenter Filter Tester.
Ich muss sie mal durchmessen bei Gelegenheit, evt ist nur eine Sicherung auf dem PCB durch.
€dit: Hab vorsichtshalber den 17.9.3 Beta mit DDU entfernt und den 17.9.3 whql neu aufgesetzt.
Ohne Crossfire fehlt schon was: http://abload.de/img/crimsonrelive_1793oct2ksks.jpg
Nicht nur FPS, die Single GPU stottert regelmäßig.
€dit: Wasserstandsmeldung: Vermeintliche Sicherung ausgelötet und eine Löt-Brücke erstellt -> brachte nichts.
Gebrauchte R9 280x bestellt...
"Beileid" zur Karte. Titel auf WHQL geändert.
Thx, in ehren halten!"Beileid" zur Karte. Titel auf WHQL geändert.
Die R9 geht auf 850MHz zurück, mal sehen was sie im Vergleich zur R7970 DD 925MHz bringt... (Crossfire?)
Ich könnte dir nur eine HD7970 3GB Ref bieten.
Tripple-Crossfire?Ich könnte dir nur eine HD7970 3GB Ref bieten.
Edit:
Leider nicht viel Zeit zum Testen, bei dem schönen Wetter.
Sieht soweit gut aus, musste den 17.9.3 oct2 nicht neu installieren, trotz UEFI und Boost bei der R9 280X.
Furmark: http://abload.de/img/furmark_r9-280r7970_cv6un6.jpg
AvP Frametimes: http://abload.de/img/avp_d3d11_benchmark_2lnuml.jpg
Trotz Asynchronem GPU und VRAM Takt gute Frametimes.
