Version 3101 Beta Version 2020/12/25 20.38 MBytes
ROG CROSSHAIR VIII HERO BIOS 3101
Improved system compatibility
Updated AGESA code to ComboV2PI 1190
Updated graphical firmware
Improved RAID function
Improved system performance
Before running the USB BIOS Flashback tool, please rename the BIOS file (C8H.CAP) using BIOSRenamer.
ROG CROSSHAIR VIII DARK HERO BIOS 3101
Before running the USB BIOS Flashback tool, please rename the BIOS file (C8DH.CAP) using BIOSRenamer.
ROG CROSSHAIR VIII HERO (WI-FI) BIOS 3101
Before running the USB BIOS Flashback tool, please rename the BIOS file (C8HW.CAP) using BIOSRenamer.
Version 3101 Beta Version 2020/12/25 20.31 MBytes
ROG CROSSHAIR VIII FORMULA BIOS 3101
Before running the USB BIOS Flashback tool, please rename the BIOS file (C8F.CAP) using BIOSRenamer.
Das habe ich so mal irgendwo gelesen, dass es die nicht mehr braucht, weil ein einzelner CCD nicht mehr auf 2x4 unterteilt ist.die Ryzen Energiesparpläne werden bei den Chipsatztreibern nicht mehr mit installiert bei Ryzen 5xxx - Windows Energiesparpläne reichen hier wohl.
Shamino schrieb:
3101 is taken down because Some Matisse CPU 3300X that are with a certain CCX disabled can't power on with AGESA ComboV2 1190
and will be replaced a another bios that fixes this bug.
Version 3102 Beta Version 2021/01/06 20.38 MBytes
ROG CROSSHAIR VIII HERO BIOS 3102
Update AMD AM4 AGESA V2 PI 1.1.9.0.
Improve ReSize Bar function
Improve RAID function
Improve system performance and compatibility
ROG CROSSHAIR VIII DARK HERO BIOS 3102
ROG CROSSHAIR VIII HERO(WI-FI) BIOS 3102
Version 3102 Beta Version 2021/01/06 20.31 MBytes
ROG CROSSHAIR VIII FORMULA BIOS 3102
Version 3202 Beta Version 2021/01/14 20.4 MBytes
ROG CROSSHAIR VIII HERO BIOS 3202
1. Update AMD AM4 AGESA V2 PI 1.2.0.0
2. This Beta BIOS can only be reversed by BIOS Flashback.
Before running the BIOS Flashback tool, please rename the BIOS file (C8H.CAP) using BIOSRenamer
ROG CROSSHAIR VIII DARK HERO BIOS 3202
Before running the BIOS Flashback tool, please rename the BIOS file (C8DH.CAP) using BIOSRenamer
ROG CROSSHAIR VIII HERO(WI-FI) BIOS 3202
Before running the BIOS Flashback tool, please rename the BIOS file (C8HW.CAP) using BIOSRenamer
Version 3202 Beta Version 2021/01/14 20.33 MBytes
ROG CROSSHAIR VIII FORMULA BIOS 3202
Before running the BIOS Flashback tool, please rename the BIOS file (C8F.CAP) using BIOSRenamer
