ATI Catalyst 8.6 Proprietary Linux Display Driver
- Ersteller cruger
Neben dem monatlich veröffentlichten Windows Catalyst Treiber-Update (<a href="http://www.planet3dnow.de/cgi-bin/newspub/viewnews.cgi?category=2&id=1213817555">wir berichteten</a>) hat AMD auch aktualisierte Linux-Treiber zum Download bereitgestellt.
<blockquote cite="http://ati.amd.com/support/drivers/linux/linux-radeon.html"><b><i>New Features</i></b><br><br><i>This release of the Catalyst™ Linux software driver introduces UYVY and YUY2 pixel format support. This support provides interleaved stream support for video playback applications such as TVTime and MythTV.</i><br><br><b><i>Resolved Issues</i></b><br><br><i>The following section provide a brief description of resolved issues with the latest version of the ATI Catalyst™ Linux software suite. These include:</i><ul><li><i>Enemy Territory: Quake Wars: Playing the demo on a system running X no longer results in corruption being noticed. Further details can be found in topic number 737-35208</i></li><li><i>Maya 2008: An incorrect colormap is no longer displayed for texture selector on systems running X. Further details can be found in topic number 737-35207</i></li><li><i>Quake 3 Arena (demo): Segmentation faults no longer occur when attempting to play the game. Further details can be found in topic number 737-35206</i></li><li><i>Quake3: Corruption is no longer noticed when changing the display resolution when the game is running. Further details can be found in topic number 737-35209</i></li><li><i>SECAM, NTSC or PAL signal changes when using aticonfig or Catalyst Control Center and now gets applied to the TV display output. Further details can be found in topic number 737-34297</i></li><li><i>Running X server without a window manager no longer results in the X server flashing green for a moment, going black, and the computer becoming unresponsive. Further details can be found in topic number 737-34299</i></li><li><i>Corruption is no longer noticed when connecting a DFP display device to a system running X after setting the TV mode to 1080i. Further details can be found in topic number 737-34301</i></li><li><i>Clock Gating is now supported and enable under the Linux operating system. Further details can be found in topic number 737-35191</i></li><li><i>The desktop background color is no longer displayed incorrectly when using xcommgr. Further details can be found in topic number 737-35192</i></li><li><i>Using the wrong delimiter in aticonfig --set-dispattrib=<disp>,<attr>, <value> no longer results in a segmentation fault. Further details can be found in topic number 737-35194</i></li><li><i>Audio out is now functioning after the installation of the ATI graphics drivers for Ubuntu 7.10. Further details can be found in topic number 737-35196</i></li><li><i>Bandwidth corruption is no longer noticed when setting the desktop resolution to 2048x1536 on systems containing an ATI Radeon HD 3200 series of product. Further details can be found in topic number 737-33499</i></li><li><i>Playing a video clip using mplayer with the Xv extension enabled no longer results in an error indicating that Xv could not find a free Xv port. Further details can be found in topic number 737-35198</i></li><li><i>Corruption is no longer noticed when enabling Big Desktop on systems containing an ATI FireGL X1 series of product and running X. Further details can be found in topic number 737-35199</i></li><li><i>Running the X server generations test no longer results in the operating system failing to respond or a Kernel panic to occur after first server generation on SuSE 10.3 64 bit. Further details can be found in topic number 737-35200</i></li><li><i>Attempting to resize a 2D application window no longer results in poor performance being noticed when composing is enabled. Further details can be found in topic number 737-35201</i></li><li><i>Screen flicker is no longer noticed after running amdcccle in X. Further details can be found in topic number 737-35202</i></li><li><i>Corruption is no longer noticed when connecting a DFP display device to a system running X after setting the TV mode to 1080i. Further details can be found in topic number 737-35203</i></li><li><i>Glxgears corruption is no longer noticed in big desktop mode. Further details can be found in topic number 737-35204</i></li><li><i>Starting glxgears and/or fgl_glxgears no longer results in the gears failing to render on SuSE 10.2 x86_64. Further details can be found in topic number 737-35205</i></li><li><i>FGL_GLXGEARS or GLXGEARS: X no longer fails to respond when launching either of the applications. Further details can be found in topic number 737-35210</i></li></ul></blockquote>
<b>Download:</b><ul><li><a href="http://ati.amd.com/support/drivers/linux/linux-radeon.html" target="b">ATI Catalyst 8.6 Proprietary Linux x86 Display Driver</a></li><li><a href="http://ati.amd.com/support/drivers/linux64/linux64-radeon.html" target="b">ATI Catalyst 8.6 Proprietary Linux x86_64 Display Driver</a></li></ul>
Danke an <a href="http://www.planet3dnow.de/vbulletin/member.php?u=3405">NemesisTN</a> für den Hinweis!
flybyray
Also erstmal vorweg. Die Treiber 8.6 gibt es schon seit mindestens 2 Tagen.
Denn ich habe genau diesen Treiber bereits auf meinem Linux Rechner laufen.
Ich habe eine Asus EAH3650 SILENT Graka und bin gerade mal wieder aus meinem Desktop rausgeflogen ohne irgendwo mal eine Meldung zu sehen warum.
Jedenfalls ist mir der Desktop abgeschmirrt und ich bin auf eine scharze Konsole tty7 mit blinkendem Cursor gelandet. Der Mauszeiger war ulkiger weise auf dem Bildschirm weiß eingefroren (bewegte sich also nicht mehr). Irgendwie seltsam wegen diesem blinkendem Cursor.
Naja muss mir noch mal genau die Xserver logs anschaun.
Was ich kurz zuvor gemacht habe (das 2. mal mit absturz zur folge aber leider nicht reproduzierbar) einen Tab im Mozilla Firefox gewechselt.
NemesisTN
- Nürnberg
- Samsung ATIV7
- Core i7 3770
- Asus P8Z77-M
- AC Cuplex Kryos Delrin
- 8 GB G-Skill DDR3 1600
- Nvidia Geforce GTX670
- Eizo 24"
- Samsung SSD 830 128GB (System)
- 2x Samsung 1TB im RAID0 (Games), 1x Samsung 1TB (Daten)
- nix
- X-Fi XtremeMusic =)
- Silverstone Fortress FT02
- beQuiet 450W
- D: Win8.1 Pro 64bit, SteamOS, N: Win8.1 64bit
- GraKa mit AC Aquagrafx GTX670 gekühlt =)
Versuch mal Powerplay abzustellen.
Das hilft bei meinem Notebook.
Ich bekomm unter sowohl unter Windoof als auch Linux Freezes mit grisseligem Bildschirm, das sieht aus, als ob irgendwas überhitzt, was aber nicht sein kann, weil ohne Powerplay hab ich die Abstürze nicht!
//Edit:
Erste Frage gelöscht, da PEBKAC...
//Edit:
mibo
- Hannover
- Lenovo T450s
- Ryzen 5800X3D
- ASUS B550M-PLUS
- Noctua NH-U12P
- 2x16GB DDR4 ECC
- AMD 6700XT
- HP X27i
- Samsung 860EVO, 960EVO, WD 850X
- DVD-Brenner :-)
- BQ Dark Power 12 750W
Ich habe den auf nem P45 Board (ASUS P5Q-E) mit ATI 3850 nicht zum laufen gekriegt. Da ist Suse11 64Bit drauf. Mit DFI DK P35 Board lief es noch...
(Der X-Server hängt nach dem Starten das ganze System auf
Fruchtnektar
mj
- Austin, TX
- 2,4kg schwer
- eckig... glaub ich
- quadratisch, praktisch, gut
- kühler?
- ja
- auch
- viel bunt
- ist drin
- ist auch drin (irgendwo)
- tut manchmal tuuut
- mit aufkleber!
- nunu!
openSUSE 11 (x86_64) hat mir der Treiber zerschossen, nach Installation ging weder KDM noch X11 und auch Deinstallation des Treibers über das fglrx-uninstall.sh Skript hat nichts daran geändert - der Installer hat diverse Dateien verändert ohne mich darüber zu informieren.
mibo
- Hannover
- Lenovo T450s
- Ryzen 5800X3D
- ASUS B550M-PLUS
- Noctua NH-U12P
- 2x16GB DDR4 ECC
- AMD 6700XT
- HP X27i
- DVD-Brenner :-)
Bei mir scheint das Problem mit dem P45 Chipsatz zusammen zu hängen.
Unter Suse 10.3 64Bit crasht der ATI-Treiber auch das System
NemesisTN
- Nürnberg
- Samsung ATIV7
- Core i7 3770
- Asus P8Z77-M
- Eizo 24"
- nix
- beQuiet 450W
Hmm, bei mir mit Hardy 64 funktioniert alles einwandfrei, einfach über den alten drüber installiert...
flybyray
Also ich habe kein Notebook. Ich habe auch nirgend wo etwas von Powerplay gelesen.Versuch mal Powerplay abzustellen.
ASUS M3A32-MVP Delux (Mainboard)
ASUS EAH3650 SILENT (Grafikarte)
OS: Ubuntu Hardy 8.04 x86_64
Treiber habe ich mittels Frontend installiert
#gksudo ./ati-driver-installer-8-6-x86.x86_64.run
Hat alles geklappt und läuft auch super. Wie gesagt nur ab und an vorallem beim Firefox crasht der XServer irgendwie völlig weg.
NemesisTN
- Nürnberg
- Samsung ATIV7
- Core i7 3770
- Asus P8Z77-M
- Eizo 24"
- nix
- beQuiet 450W
Stürzt dann nur der X-Server ab oder geht garnichts mehr?
Sprich, kannst du ne Konsole aufmachen?
Powerplay sollte ne 3000er eigentlich auch unter Linux unterstützen?
Fruchtnektar
Das scheint so zu sein. In meinem Screenshot oben stehen andere Taktraten als normal:
311MHz Speicher
669MHz Chip
statt
(Quelle Geizhals.at)Chiptakt: 670MHz, Speichertakt: 830MHz
Scheint somit nur den Spiecher runter zu takten.
NemesisTN
- Nürnberg
- Samsung ATIV7
- Core i7 3770
- Asus P8Z77-M
- Eizo 24"
- nix
- beQuiet 450W
Hmm, in den Voreinstellungen kannst du Powerplay nicht deaktivieren?
Oder gabs dafür extra einen Abschnitt? (kann grad nicht neu starten um selbst nachzugucken)
Das wär ja doof, wie gesagt, sobald ich das Powerplay deaktivier lüppt die Graka einwandfrei.
Allerdings hab ich die Abstürze auch unter Win XP mit aktiviertem Powerplay...
Fruchtnektar
NemesisTN
- Nürnberg
- Samsung ATIV7
- Core i7 3770
- Asus P8Z77-M
- Eizo 24"
- nix
- beQuiet 450W
Hmm, das ist echt doof, scheint so, als ob Powerplay für die 3000er im Linux-Treiber nicht unterstützt wird.
Dann kannst du wirklich nur auf den nächsten Treiber warten...
Hast du die Abstürze auch unter Windows?
flybyray
Naja das ist ganz unterschiedlich. Manchmal geht gar nichts mehr (nur Neustart kalt/ACPI geht auch nicht).
Letztens wars aber so dass ich eben zur tty7 Konsole mit blinkendem cursor kam und dort dann ein eingefrorener Mauszeiger zu sehen war. Ich konnte dann ohne weiteres zu anderen ttys (Konsolen) wechseln.
Frage:
Was machen eigentlich die zwei unterschiedliche Module fglrx in den Kernel-Modul libs?
Code:
$ find /lib/modules/`uname -r`/ | grep fglrx
/lib/modules/2.6.24-19-generic/updates/dkms/fglrx.ko (2984776 Bytes)
/lib/modules/2.6.24-19-generic/volatile/fglrx.ko (3191611 Bytes)
Laut fglrx-install.log ist das Modul in update/dkms das neu installiert. Aber für X haben vermutlich diese Kernel-Module nicht viel zu sagen oder?
Naja muss mir mal ansehen was es da noch unter /etc/ati/ einzustellen gibt. Evtl. mal den ganzen atievents service abschalten oder so.
NemesisTN
- Nürnberg
- Samsung ATIV7
- Core i7 3770
- Asus P8Z77-M
- Eizo 24"
- nix
- beQuiet 450W
Ok, ich nehm alles zurück...
Meine X1800 kotzt auch ab.
Nach der Installation bekomm ich nach dem Anmelden einen weißen Bildschirm und das wars dann...
Derselbe Treiber fnzt aufm Notebook mit der HD2600 aber einwandfrei.
Ich mach aufm Desktop mal Hardy 32 drauf.
Mal sehn, ob das was bringt.
