GPU-Z 0.2.0
pipin
Administrator
Teammitglied
16.10.2000
24.371
9.696
East Fishkill, Minga, Xanten
  • SIMAP Race
  • QMC Race
  • RCN Russia
  • Spinhenge ESL
  • Docking@Home
  • BOINC Pentathlon 2019
  • SETI@Home Intel-Race II
  • THOR Challenge 2020
  • BOINC Pentathlon 2021
  • BOINC Pentathlon 2023
Den Stellenwert, den das System-Informationstool <a href="http://www.planet3dnow.de/cgi-bin/newspub/viewnews.cgi?category=2&id=1199656424">CPU-Z</a> im CPU-Bereich inne hat, will das ähnlich angelegte GPU-Z von <a href="http://www.techpowerup.com/gpuz/" target="b">techPowerUp</a> bei Grafikkarten einnehmen. GPU-Z liefert technische Informationen zu Grafikkarten, beschränkt sich derzeit aber vor allem auf Produkte von AMD/ATI und NVIDIA und einige IGP-Chipsätze (u.a. von Intel).
<blockquote cite="http://www.techpowerup.com/gpuz/"><b><i>Main Features</i></b><ul><li><i>Support NVIDIA and ATI cards</i></li><li><i>Displays adapter, GPU and display information</i></li><li><i>Displays overclock, default clocks and 3D clocks (if available)</i></li><li><i>Validation of results</i></li><li><i>No installation required</i></li><li><i>Support for Windows 2000 / XP / Vista (both 32 and 64 bit versions are supported)</i></li><li><i>BETA SOFTWARE - please test and post feedback in the <a href="http://forums.techpowerup.com/forumdisplay.php?f=53" target="b">forums</a></i></li><li><i>.. and yes, the author of CPU-Z has granted us permission to use a name similar to his product. Thanks Franck.</i></li></ul></blockquote>
<blockquote cite="http://www.techpowerup.com/downloads/1058/TechPowerUp_GPU-Z_v0.2.0.html"><b><i>Revision History 0.2</i></b><ul><li>Added support for S3 graphics cards</li><li>Added screenshot upload feature (press F5 or click the camera icon)</li><li>Added NVIDIA GT200 detection</li><li>Updated RV770 detection</li><li>Vista64 is now listed as "Vista64" in the driver version readout</li><li>On Vista64, CrossFire status will be marked as "Unknown" until fix is found</li><li>Added dump to XML. Use command line parameter -dump gpuz.xml</li><li>More robust NVIDIA clock detection</li><li>Fixed G73 fillrate calculation</li><li>Added die size for RV350</li><li>Fixed R680 clock readings</li><li>Fixed R600 ROM reading code</li><li>Fixed sensors not refreshing properly sometimes</li><li>When unknown architecture detected, NVIDIA logo won't be shown anymore</li><li>Fixed random UNICODE characters on some architectures in upload progress</li></ul></blockquote>
<b>Download:</b><ul><li><a href="http://www.techpowerup.com/downloads/1058/TechPowerUp_GPU-Z_v0.2.0.html" target="b">GPU-Z Version 0.2.0</a></li></ul><b>Hinweis:</b><ul><li><a href="http://de.wikipedia.org/wiki/Entwicklungsstadium_%28Software%29#Beta-Version" target="b">Was ist eine Beta-Version</a></li></ul><b>Links zum Thema:</b><ul><li><a href="http://www.techpowerup.com/downloads/1058/TechPowerUp_GPU-Z_v0.2.0.html" target="b">Changelog</a></li></ul>
Vielen Dank an <a href="http://www.planet3dnow.de/vbulletin/member.php?u=41217">KIDH</a> für den Hinweis!
