Omega Treiber v2.6.87 für ATI-Karten
cruger
Senior Moderator
Teammitglied
25.05.2002
29.389
1.579
  • QMC Race
  • BOINC Pentathlon 2014
Der Entwickler der populären <a href="http://omegadrivers.net" target="b">OmegaDriver</a> hat mit der Version 2.6.87 einen neuen Treiber für ATI-Grafikkarten veröffentlicht, der auf dem aktuellen offiziellen ATI CATALYST 5.12 Treiberpaket basiert (<a href="http://www.planet3dnow.de/cgi-bin/newspub/viewnews.cgi?category=2&id=1134079670">wir berichteten</a>), aber auf das .NET basierte CATALYST Control Center (CCC*) verzichtet. Statt dessen gehört eine angepasste Version der <a href="http://www.radeon2.ru/atitray/" target="b">ATI Tray Tools</a> zum Lieferumfang der OmegaDriver.
<sup>*) CCC = CATALYST Control Center; Erläuterung siehe <a href="http://www.planet3dnow.de/cgi-bin/newspub/viewnews.cgi?category=2&id=1094139055">hier</a>.</sup>
<b><u><font size="2">Changelog: What's New in Omega Drivers?</font></u></b>
<font size="2">v2.6.87</font>
<font size="1">[*] Based on the Catalyst 5.12 Official drivers.
[+] Added support for 2560x1600 and 1600x1024 resolutions.
<b>Known Issues:</b>
1) Some of the settings for both D3D & OGL will not be synchronized between ATT and the normal ATI CP, you must only use one of them to make changes, the best option is to use ATT since the ATI CP does not support changes to AI and in order to use the advanced D3D/OGL features. Changes made in ATT will work on games and such but the changes will not be reflected in the normal ATI CP since ATI stores the registry values that the CP reads separate from the actual values in the registry.
2) If ATT refuses to run because your card is "Not Supported", edit the "atitray.ini" located in the Omega Drivers&ATT installation folder and change "opt_disable_ovr=0" to "opt_disable_ovr=1", this will disable Overclocking, but the rest of ATT can be used normally.
<b>Important Info:</b>
Since these drivers include a non-standard version of ATT, I would recommend that if you have any previous version of ATT installed, please uninstall it before installing these drivers, not doing so may cause unknown problems.</font>
<b>Download:</b> <a href="http://omegadrivers.net/ati/win2k_xp.php" target="b">Omega Treiber für ATI-Karten v2.6.87 Win2k/XP (21.4 MB)</a>
Da der offizielle ATI 5.12 irgendwie nicht installiert wurde auf meinem Notebook, hab ich wieder mal zum OmegaTreiber gegriffen.
Bisher funktioniert alles, wie es soll.
MDG
jep, bei mir hats auch gut geklappt.
BF2 läuft z.B. ohne probleme ;D
