12.06.2019 21:00:07 | | Starting BOINC client version 7.8.3 for windows_x86_64
12.06.2019 21:00:07 | | log flags: file_xfer, sched_ops, task
12.06.2019 21:00:07 | | Libraries: libcurl/7.47.1 OpenSSL/1.0.2g zlib/1.2.8
12.06.2019 21:00:07 | | Data directory: C:\ProgramData\BOINC
12.06.2019 21:00:07 | | Running under account Vishera
12.06.2019 21:00:08 | | OpenCL: AMD/ATI GPU 0: AMD Radeon R9 200 Series (driver version 2766.5, device version OpenCL 1.2 AMD-APP (2766.5), 3072MB, 3072MB available, 4096 GFLOPS peak)
12.06.2019 21:00:08 | | OpenCL: AMD/ATI GPU 1: AMD Radeon R9 200 Series (driver version 2766.5, device version OpenCL 1.2 AMD-APP (2766.5), 3072MB, 3072MB available, 4096 GFLOPS peak)
12.06.2019 21:00:08 | Asteroids@home | Found app_info.xml; using anonymous platform
12.06.2019 21:00:08 | | Host name: Vishera-PC
12.06.2019 21:00:08 | | Processor: 8 AuthenticAMD AMD FX(tm)-8350 Eight-Core Processor [Family 21 Model 2 Stepping 0]
12.06.2019 21:00:08 | | Processor features: fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush mmx fxsr sse sse2 htt pni ssse3 fma cx16 sse4_1 sse4_2 popcnt aes f16c syscall nx lm avx svm sse4a osvw ibs xop skinit wdt fma4 tce tbm topx page1gb rdtscp bmi1
12.06.2019 21:00:08 | | OS: Microsoft Windows 10: Professional x64 Edition, (10.00.18362.00)
12.06.2019 21:00:08 | | Memory: 31.90 GB physical, 40.90 GB virtual
12.06.2019 21:00:08 | | Disk: 949.07 GB total, 723.99 GB free
12.06.2019 21:00:08 | | Local time is UTC +2 hours
12.06.2019 21:00:08 | | VirtualBox version: 5.1.26
12.06.2019 21:00:08 | Einstein@Home | Found app_config.xml
12.06.2019 21:00:08 | Milkyway@Home | Found app_config.xml
12.06.2019 21:00:08 | | Config: use all coprocessors
12.06.2019 21:00:08 | | Eine neue Version von BOINC ist verfügbar (7.14.2). <a href=https://boinc.berkeley.edu/download.php>Herunterladen</a>
12.06.2019 21:00:08 | Asteroids@home | URL
http://asteroidsathome.net/boinc/; Computer ID 21394; resource share 100
12.06.2019 21:00:08 | collatz | URL
https://boinc.thesonntags.com/collatz/; Computer ID 806824; resource share 100
12.06.2019 21:00:08 | Cosmology@Home | URL
http://www.cosmologyathome.org/; Computer ID 389394; resource share 100
12.06.2019 21:00:08 | Einstein@Home | URL
http://einstein.phys.uwm.edu/; Computer ID 12450009; resource share 100
12.06.2019 21:00:08 | Milkyway@Home | URL
http://milkyway.cs.rpi.edu/milkyway/; Computer ID 707922; resource share 100
12.06.2019 21:00:08 | Poem@Home | URL
http://boinc.fzk.de/poem/; Computer ID 1837968; resource share 100
12.06.2019 21:00:08 | pogs | URL
http://pogs.theskynet.org/pogs/; Computer ID 750594; resource share 100
12.06.2019 21:00:08 | PrimeGrid | URL
http://www.primegrid.com/; Computer ID 930611; resource share 100
12.06.2019 21:00:08 | SETI@home | URL
http://setiathome.berkeley.edu/; Computer ID 7068553; resource share 100
12.06.2019 21:00:08 | Asteroids@home | General prefs: from Asteroids@home (last modified 14-May-2018 21:28:16)
12.06.2019 21:00:08 | Asteroids@home | Computer location: school
12.06.2019 21:00:08 | | General prefs: using separate prefs for school
12.06.2019 21:00:08 | | Reading preferences override file
12.06.2019 21:00:08 | | Preferences:
12.06.2019 21:00:08 | | max memory usage when active: 24496.42 MB
12.06.2019 21:00:08 | | max memory usage when idle: 29395.70 MB
12.06.2019 21:00:08 | | max disk usage: 723.54 GB
12.06.2019 21:00:08 | | suspend work if non-BOINC CPU load exceeds 90%
12.06.2019 21:00:08 | | (to change preferences, visit a project web site or select Preferences in the Manager)
12.06.2019 21:00:08 | Einstein@Home | Task LATeah1049ZB_164.0_0_0.0_1149855_1 is 11.87 days overdue; you may not get credit for it. Consider aborting it.
12.06.2019 21:00:08 | Einstein@Home | Task LATeah1049ZB_164.0_0_0.0_4814712_0 is 11.87 days overdue; you may not get credit for it. Consider aborting it.
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_25261_HIP20901_0098.30923.818.22.45.159.vlar_2; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_26261_HIP20357_0101.1959.409.22.45.72.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_26261_HIP20357_0101.1959.409.22.45.73.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_24231_HIP20491_0095.2550.0.22.45.248.vlar_0; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_24231_HIP20491_0095.4008.818.22.45.150.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_24925_HIP20215_0097.4065.0.21.44.6.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_24231_HIP20491_0095.4008.818.22.45.137.vlar_0; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_24231_HIP20491_0095.1928.818.21.44.65.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_25595_HIP20290_0099.2011.409.22.45.70.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_24925_HIP20215_0097.4065.0.21.44.10.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_24231_HIP20491_0095.2550.409.22.45.9.vlar_0; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_24925_HIP20215_0097.4065.0.21.44.1.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_24231_HIP20491_0095.4008.818.22.45.134.vlar_0; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_24231_HIP20491_0095.4044.0.21.44.13.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_25595_HIP20290_0099.2011.409.22.45.75.vlar_0; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_24231_HIP20491_0095.1928.818.21.44.70.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_26261_HIP20357_0101.1959.409.22.45.76.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_25595_HIP20290_0099.2011.409.22.45.76.vlar_0; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_24231_HIP20491_0095.1928.818.21.44.71.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_25595_HIP20290_0099.2011.409.22.45.71.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_24231_HIP20491_0095.1928.818.21.44.57.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_24231_HIP20491_0095.4044.0.21.44.7.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_24231_HIP20491_0095.2550.0.22.45.225.vlar_0; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_24231_HIP20491_0095.2550.409.22.45.2.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_24231_HIP20491_0095.1928.818.21.44.67.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_24231_HIP20491_0095.1928.818.21.44.55.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_24231_HIP20491_0095.4008.818.22.45.147.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_25595_HIP20290_0099.2011.409.22.45.65.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_27281_HIP20917_0104.1939.409.21.44.63.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_24231_HIP20491_0095.4008.818.22.45.146.vlar_0; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_24231_HIP20491_0095.2550.0.22.45.247.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_27281_HIP20917_0104.1939.409.21.44.83.vlar_0; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_24925_HIP20215_0097.4065.0.21.44.14.vlar_0; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_24231_HIP20491_0095.1928.818.21.44.46.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_24231_HIP20491_0095.1928.818.21.44.73.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_26261_HIP20357_0101.1959.409.22.45.85.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_24231_HIP20491_0095.4044.0.21.44.9.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_27281_HIP20917_0104.1939.409.21.44.69.vlar_0; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_26261_HIP20357_0101.1959.409.22.45.75.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_24231_HIP20491_0095.4044.0.21.44.11.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_24231_HIP20491_0095.4008.818.22.45.154.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_26261_HIP20357_0101.1959.409.22.45.70.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_24231_HIP20491_0095.4044.0.21.44.8.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_24231_HIP20491_0095.2550.0.22.45.252.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_23898_HIP20842_0094.3551.818.21.44.20.vlar_2; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_24231_HIP20491_0095.2550.409.22.45.11.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_26261_HIP20357_0101.1959.409.22.45.71.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_24231_HIP20491_0095.1928.818.21.44.77.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_26261_HIP20357_0101.1959.409.22.45.65.vlar_0; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_26261_HIP20357_0101.1959.409.22.45.81.vlar_0; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_24231_HIP20491_0095.4008.818.22.45.153.vlar_0; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_24231_HIP20491_0095.1928.818.21.44.74.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_25595_HIP20290_0099.2011.409.22.45.55.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_24231_HIP20491_0095.4044.0.21.44.2.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_24231_HIP20491_0095.4008.818.22.45.148.vlar_0; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_24925_HIP20215_0097.4065.0.21.44.9.vlar_0; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_24231_HIP20491_0095.4008.818.22.45.156.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_24231_HIP20491_0095.4008.818.22.45.129.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_26261_HIP20357_0101.1959.409.22.45.57.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_24231_HIP20491_0095.2550.0.22.45.235.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_24231_HIP20491_0095.1928.818.21.44.82.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_24231_HIP20491_0095.4008.818.22.45.159.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_24231_HIP20491_0095.2550.409.22.45.1.vlar_0; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_25595_HIP20290_0099.2011.409.22.45.67.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_27281_HIP20917_0104.1939.409.21.44.51.vlar_0; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_26261_HIP20357_0101.1959.409.22.45.51.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_24231_HIP20491_0095.4008.818.22.45.123.vlar_0; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_24231_HIP20491_0095.4008.818.22.45.151.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_24231_HIP20491_0095.1928.818.21.44.64.vlar_0; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_26261_HIP20357_0101.1959.409.22.45.42.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_24925_HIP20215_0097.4065.0.21.44.7.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_24925_HIP20215_0097.4065.0.21.44.3.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_26261_HIP20357_0101.1959.409.22.45.55.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_24231_HIP20491_0095.4008.818.22.45.161.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_26261_HIP20357_0101.1959.409.22.45.66.vlar_0; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_25595_HIP20290_0099.2011.409.22.45.29.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_24925_HIP20215_0097.4065.0.21.44.11.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_24231_HIP20491_0095.2550.0.22.45.249.vlar_0; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_24231_HIP20491_0095.1928.818.21.44.76.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_24231_HIP20491_0095.2550.0.22.45.254.vlar_0; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_25595_HIP20290_0099.2011.409.22.45.66.vlar_0; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_24925_HIP20215_0097.4065.0.21.44.15.vlar_0; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_23898_HIP20842_0094.3551.818.21.44.35.vlar_2; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_27281_HIP20917_0104.1939.409.21.44.46.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_26261_HIP20357_0101.1959.409.22.45.77.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_27281_HIP20917_0104.1939.409.21.44.90.vlar_0; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_27281_HIP20917_0104.1939.409.21.44.89.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_26261_HIP20357_0101.1959.409.22.45.74.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_24231_HIP20491_0095.4008.818.22.45.160.vlar_0; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_24231_HIP20491_0095.2550.0.22.45.238.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_24231_HIP20491_0095.1928.818.21.44.80.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_25595_HIP20290_0099.2011.409.22.45.61.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_24231_HIP20491_0095.1928.818.21.44.69.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_24231_HIP20491_0095.4044.0.21.44.10.vlar_0; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_24231_HIP20491_0095.2550.409.22.45.5.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_27281_HIP20917_0104.1939.409.21.44.87.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_24925_HIP20215_0097.4065.0.21.44.2.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_24231_HIP20491_0095.2550.0.22.45.255.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_25595_HIP20290_0099.2011.409.22.45.26.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_24925_HIP20215_0097.4065.0.21.44.13.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_24925_HIP20215_0097.4065.0.21.44.17.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_24231_HIP20491_0095.1928.818.21.44.79.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_26261_HIP20357_0101.1959.409.22.45.83.vlar_0; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_26261_HIP20357_0101.1959.409.22.45.78.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_24231_HIP20491_0095.4008.818.22.45.145.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_26261_HIP20357_0101.1959.409.22.45.89.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_24925_HIP20215_0097.4065.0.21.44.0.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_25595_HIP20290_0099.2011.409.22.45.77.vlar_0; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_24231_HIP20491_0095.2550.409.22.45.3.vlar_0; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_24925_HIP20215_0097.4065.0.21.44.4.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_26261_HIP20357_0101.1959.409.22.45.91.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_24231_HIP20491_0095.1928.818.21.44.81.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_25595_HIP20290_0099.2011.409.22.45.74.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_24231_HIP20491_0095.4044.0.21.44.6.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_24231_HIP20491_0095.1928.818.21.44.78.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_27281_HIP20917_0104.1939.409.21.44.77.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_25595_HIP20290_0099.2011.409.22.45.49.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_25595_HIP20290_0099.2011.409.22.45.64.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_24231_HIP20491_0095.4008.818.22.45.163.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_25595_HIP20290_0099.2011.409.22.45.69.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_24231_HIP20491_0095.2550.409.22.45.6.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_25595_HIP20290_0099.2011.409.22.45.45.vlar_0; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_24231_HIP20491_0095.4044.0.21.44.5.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_24231_HIP20491_0095.2550.0.22.45.243.vlar_0; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_24231_HIP20491_0095.1928.818.21.44.68.vlar_0; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_24231_HIP20491_0095.1928.818.21.44.32.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_26261_HIP20357_0101.1959.409.22.45.43.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_24231_HIP20491_0095.1928.818.21.44.75.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_24231_HIP20491_0095.4008.818.22.45.122.vlar_0; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_24925_HIP20215_0097.4065.0.21.44.5.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_27281_HIP20917_0104.1939.409.21.44.91.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_26261_HIP20357_0101.1959.409.22.45.84.vlar_0; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_24231_HIP20491_0095.4008.818.22.45.155.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_24231_HIP20491_0095.4044.0.21.44.12.vlar_0; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_24231_HIP20491_0095.4044.0.21.44.3.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_25595_HIP20290_0099.2011.409.22.45.63.vlar_0; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_27281_HIP20917_0104.1939.409.21.44.94.vlar_0; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_27281_HIP20917_0104.1939.409.21.44.85.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_25595_HIP20290_0099.2011.409.22.45.32.vlar_0; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_23569_HIP20270_0093.3541.818.22.45.230.vlar_2; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_24925_HIP20215_0097.4065.0.21.44.12.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_24231_HIP20491_0095.4044.0.21.44.15.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_24231_HIP20491_0095.4008.818.22.45.124.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_24231_HIP20491_0095.2550.409.22.45.4.vlar_0; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_25595_HIP20290_0099.2011.409.22.45.56.vlar_0; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_24231_HIP20491_0095.4008.818.22.45.152.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_24231_HIP20491_0095.2550.0.22.45.207.vlar_0; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_24231_HIP20491_0095.4044.0.21.44.4.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_25595_HIP20290_0099.2011.409.22.45.53.vlar_0; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_26261_HIP20357_0101.1959.409.22.45.37.vlar_0; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_27281_HIP20917_0104.1939.409.21.44.57.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_25595_HIP20290_0099.2011.409.22.45.72.vlar_0; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_24925_HIP20215_0097.5527.818.22.45.20.vlar_0; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_24231_HIP20491_0095.5629.0.21.44.229.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_26949_HIP20491_0103.6106.0.21.44.22.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_26261_HIP20357_0101.6081.818.21.44.12.vlar_0; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_25930_HIP20901_0100.5549.409.22.45.109.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_26949_HIP20491_0103.6106.0.21.44.16.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_26617_HIP20917_0102.5618.0.21.44.219.vlar_0; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_26617_HIP20917_0102.5618.0.21.44.231.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_25261_HIP20901_0098.5646.0.22.45.202.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_25930_HIP20901_0100.5549.409.22.45.112.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_27281_HIP20917_0104.5597.409.22.45.23.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_26617_HIP20917_0102.5618.0.21.44.222.vlar_0; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_24231_HIP20491_0095.6116.0.21.44.19.vlar_0; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_26261_HIP20357_0101.6081.818.21.44.15.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_24231_HIP20491_0095.6091.818.22.45.17.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_24231_HIP20491_0095.5656.0.22.45.208.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_24231_HIP20491_0095.6116.0.21.44.18.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_24231_HIP20491_0095.5607.409.22.45.21.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_24231_HIP20491_0095.5561.409.21.44.113.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_26617_HIP20917_0102.5618.0.21.44.226.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_25261_HIP20901_0098.5646.0.22.45.200.vlar_0; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_25261_HIP20901_0098.5646.0.22.45.204.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_24231_HIP20491_0095.5561.409.21.44.114.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_26949_HIP20491_0103.6106.0.21.44.11.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_24231_HIP20491_0095.5561.409.21.44.115.vlar_0; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_25261_HIP20901_0098.5646.0.22.45.199.vlar_0; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_24925_HIP20215_0097.5527.818.22.45.24.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_25930_HIP20901_0100.5549.409.22.45.111.vlar_0; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_25930_HIP20901_0100.5549.409.22.45.114.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_26949_HIP20491_0103.6106.0.21.44.12.vlar_0; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_26261_HIP20357_0101.6081.818.21.44.22.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_24231_HIP20491_0095.5561.409.21.44.117.vlar_0; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_24231_HIP20491_0095.6091.818.22.45.18.vlar_0; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_24231_HIP20491_0095.5629.0.21.44.236.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_24231_HIP20491_0095.5561.409.21.44.50.vlar_0; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_24231_HIP20491_0095.5629.0.21.44.233.vlar_0; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_26617_HIP20917_0102.5618.0.21.44.221.vlar_0; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_25595_HIP20290_0099.6070.818.21.44.22.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_25261_HIP20901_0098.5646.0.22.45.190.vlar_0; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_24231_HIP20491_0095.6091.818.22.45.16.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | SETI@home | Aborting task blc22_2bit_guppi_58406_26261_HIP20357_0101.6081.818.21.44.19.vlar_1; not started and deadline has passed
12.06.2019 21:00:08 | Cosmology@Home | Aborting task camb_boinc2docker_9050_1557779677.370550_0; not started and deadline has passed
12.06.2019 21:00:08 | Cosmology@Home | Aborting task camb_boinc2docker_8797_1557779670.204530_0; not started and deadline has passed
12.06.2019 21:00:08 | Cosmology@Home | Aborting task camb_boinc2docker_8760_1557779668.905493_0; not started and deadline has passed
12.06.2019 21:00:08 | Cosmology@Home | Aborting task camb_boinc2docker_8902_1557779672.794822_0; not started and deadline has passed
12.06.2019 21:00:08 | Cosmology@Home | Aborting task camb_boinc2docker_8536_1557779659.278182_0; not started and deadline has passed
12.06.2019 21:00:08 | Cosmology@Home | Aborting task camb_boinc2docker_7912_1557779641.615510_0; not started and deadline has passed
12.06.2019 21:00:08 | Cosmology@Home | Aborting task camb_boinc2docker_8973_1557779674.756473_0; not started and deadline has passed
12.06.2019 21:00:08 | Cosmology@Home | Aborting task camb_boinc2docker_8920_1557779673.446611_0; not started and deadline has passed
12.06.2019 21:00:08 | Cosmology@Home | Aborting task camb_boinc2docker_8394_1557779654.989344_0; not started and deadline has passed
12.06.2019 21:00:08 | Cosmology@Home | Aborting task camb_boinc2docker_8059_1557779645.970424_0; not started and deadline has passed
12.06.2019 21:00:08 | Cosmology@Home | Aborting task wu_051319_200033_0_0_0; not started and deadline has passed
12.06.2019 21:00:08 | Cosmology@Home | Aborting task camb_boinc2docker_8189_1557779649.814828_0; not started and deadline has passed
12.06.2019 21:00:08 | Cosmology@Home | Aborting task camb_boinc2docker_8429_1557779656.244632_0; not started and deadline has passed
12.06.2019 21:00:08 | Cosmology@Home | Aborting task camb_boinc2docker_8815_1557779670.851712_0; not started and deadline has passed
12.06.2019 21:00:08 | Cosmology@Home | Aborting task wu_051319_200028_2_0_0; not started and deadline has passed
12.06.2019 21:00:08 | Cosmology@Home | Aborting task camb_boinc2docker_8487_1557779657.493741_0; not started and deadline has passed
12.06.2019 21:00:08 | Cosmology@Home | Aborting task camb_boinc2docker_8211_1557779650.472407_0; not started and deadline has passed
12.06.2019 21:00:08 | Cosmology@Home | Aborting task camb_boinc2docker_8735_1557779668.215700_0; not started and deadline has passed
12.06.2019 21:00:08 | Cosmology@Home | Aborting task wu_051319_200039_0_0_0; not started and deadline has passed
12.06.2019 21:00:08 | Cosmology@Home | Aborting task camb_boinc2docker_8504_1557779658.099976_0; not started and deadline has passed
12.06.2019 21:00:08 | Cosmology@Home | Aborting task camb_boinc2docker_8410_1557779655.610342_0; not started and deadline has passed
12.06.2019 21:00:08 | Cosmology@Home | Aborting task camb_boinc2docker_8120_1557779647.875708_0; not started and deadline has passed
12.06.2019 21:00:08 | Cosmology@Home | Aborting task camb_boinc2docker_7975_1557779643.540007_0; not started and deadline has passed
12.06.2019 21:00:08 | Cosmology@Home | Aborting task wu_051319_200018_0_0_0; not started and deadline has passed
12.06.2019 21:00:08 | Cosmology@Home | Aborting task camb_boinc2docker_9008_1557779676.077861_0; not started and deadline has passed
12.06.2019 21:00:08 | Cosmology@Home | Aborting task camb_boinc2docker_8287_1557779651.115324_0; not started and deadline has passed
12.06.2019 21:00:08 | Cosmology@Home | Aborting task camb_boinc2docker_9027_1557779676.735254_0; not started and deadline has passed
12.06.2019 21:00:08 | Cosmology@Home | Aborting task camb_boinc2docker_8629_1557779661.096186_0; not started and deadline has passed
12.06.2019 21:00:08 | Cosmology@Home | Aborting task camb_boinc2docker_8990_1557779675.418238_0; not started and deadline has passed
12.06.2019 21:00:08 | Cosmology@Home | Aborting task camb_boinc2docker_8099_1557779647.262862_0; not started and deadline has passed
12.06.2019 21:00:08 | Cosmology@Home | Aborting task camb_boinc2docker_8081_1557779646.616974_0; not started and deadline has passed
12.06.2019 21:00:08 | Cosmology@Home | Aborting task camb_boinc2docker_8865_1557779671.495667_0; not started and deadline has passed
12.06.2019 21:00:08 | Cosmology@Home | Aborting task camb_boinc2docker_8338_1557779653.069394_0; not started and deadline has passed
12.06.2019 21:00:08 | Cosmology@Home | Aborting task camb_boinc2docker_9068_1557779678.024854_0; not started and deadline has passed
12.06.2019 21:00:08 | Cosmology@Home | Aborting task camb_boinc2docker_8322_1557779652.431210_0; not started and deadline has passed
12.06.2019 21:00:08 | Cosmology@Home | Aborting task camb_boinc2docker_8939_1557779674.099522_0; not started and deadline has passed
12.06.2019 21:00:08 | Cosmology@Home | Aborting task camb_boinc2docker_8375_1557779654.340146_0; not started and deadline has passed
12.06.2019 21:00:08 | Cosmology@Home | Aborting task wu_051319_200028_1_0_0; not started and deadline has passed
12.06.2019 21:00:08 | Einstein@Home | Aborting task LATeah1049ZB_164.0_0_0.0_632828_1; not started and deadline has passed
12.06.2019 21:00:08 | Einstein@Home | Aborting task LATeah1049ZB_164.0_0_0.0_1896853_1; not started and deadline has passed
12.06.2019 21:00:08 | Einstein@Home | Aborting task LATeah1049ZB_164.0_0_0.0_7287308_1; not started and deadline has passed
12.06.2019 21:00:08 | Einstein@Home | Aborting task LATeah1049ZB_164.0_0_0.0_7285677_1; not started and deadline has passed
12.06.2019 21:00:08 | Einstein@Home | Aborting task LATeah1049ZB_164.0_0_0.0_11302830_1; not started and deadline has passed
12.06.2019 21:00:08 | Einstein@Home | Aborting task LATeah1049ZB_164.0_0_0.0_10479175_1; not started and deadline has passed
12.06.2019 21:00:08 | Einstein@Home | Aborting task LATeah1049ZB_164.0_0_0.0_8637776_1; not started and deadline has passed
12.06.2019 21:00:08 | Einstein@Home | Aborting task LATeah1049ZB_164.0_0_0.0_7161721_1; not started and deadline has passed
12.06.2019 21:00:08 | Einstein@Home | Aborting task LATeah1049ZB_164.0_0_0.0_11299568_1; not started and deadline has passed
12.06.2019 21:00:08 | Einstein@Home | Aborting task LATeah1049ZB_164.0_0_0.0_7145411_1; not started and deadline has passed
12.06.2019 21:00:08 | Einstein@Home | Aborting task LATeah1049ZB_164.0_0_0.0_10484068_1; not started and deadline has passed
12.06.2019 21:00:08 | Einstein@Home | Aborting task LATeah1049ZB_164.0_0_0.0_7156828_1; not started and deadline has passed
12.06.2019 21:00:08 | Einstein@Home | Aborting task LATeah1049ZB_164.0_0_0.0_7063861_1; not started and deadline has passed
12.06.2019 21:00:08 | Einstein@Home | Aborting task LATeah1049ZB_164.0_0_0.0_10482437_1; not started and deadline has passed
12.06.2019 21:00:08 | Einstein@Home | Aborting task LATeah1049ZB_164.0_0_0.0_11291413_1; not started and deadline has passed
12.06.2019 21:00:08 | Einstein@Home | Aborting task LATeah1049ZB_164.0_0_0.0_7060599_1; not started and deadline has passed
12.06.2019 21:00:08 | Einstein@Home | Aborting task LATeah1049ZB_164.0_0_0.0_11301199_1; not started and deadline has passed
12.06.2019 21:00:08 | Einstein@Home | Aborting task LATeah1049ZB_164.0_0_0.0_8574167_1; not started and deadline has passed
12.06.2019 21:00:08 | Einstein@Home | Aborting task LATeah1049ZB_164.0_0_0.0_15450463_1; not started and deadline has passed
12.06.2019 21:00:08 | Einstein@Home | Aborting task LATeah1049ZB_164.0_0_0.0_15111215_1; not started and deadline has passed
12.06.2019 21:00:08 | Einstein@Home | Aborting task LATeah1049ZB_164.0_0_0.0_15310197_1; not started and deadline has passed
12.06.2019 21:00:08 | Einstein@Home | Aborting task LATeah1049ZB_164.0_0_0.0_15473297_1; not started and deadline has passed
12.06.2019 21:00:08 | Einstein@Home | Aborting task LATeah1049ZB_164.0_0_0.0_17657206_1; not started and deadline has passed
12.06.2019 21:00:08 | Einstein@Home | Aborting task LATeah1049ZB_164.0_0_0.0_15434153_1; not started and deadline has passed
12.06.2019 21:00:08 | Einstein@Home | Aborting task LATeah1049ZB_164.0_0_0.0_15489607_0; not started and deadline has passed
12.06.2019 21:00:08 | Einstein@Home | Aborting task LATeah1049ZB_164.0_0_0.0_15308566_1; not started and deadline has passed
12.06.2019 21:00:08 | Einstein@Home | Aborting task LATeah1049ZB_164.0_0_0.0_15107953_1; not started and deadline has passed
12.06.2019 21:00:08 | Einstein@Home | Aborting task LATeah1049ZB_164.0_0_0.0_17658837_1; not started and deadline has passed
12.06.2019 21:00:08 | Einstein@Home | Aborting task LATeah1049ZB_164.0_0_0.0_15114477_1; not started and deadline has passed
12.06.2019 21:00:08 | Einstein@Home | Aborting task LATeah1049ZB_164.0_0_0.0_15474928_1; not started and deadline has passed
12.06.2019 21:00:08 | Einstein@Home | Aborting task LATeah1049ZB_164.0_0_0.0_15112846_1; not started and deadline has passed
12.06.2019 21:00:08 | Einstein@Home | Aborting task LATeah1049ZB_164.0_0_0.0_15109584_1; not started and deadline has passed
12.06.2019 21:00:08 | Einstein@Home | Aborting task LATeah1049ZB_164.0_0_0.0_20615840_1; not started and deadline has passed
12.06.2019 21:00:08 | Einstein@Home | Aborting task LATeah1049ZB_164.0_0_0.0_24908632_0; not started and deadline has passed
12.06.2019 21:00:08 | Einstein@Home | Aborting task LATeah1049ZB_164.0_0_0.0_20659877_0; not started and deadline has passed
12.06.2019 21:00:08 | Einstein@Home | Aborting task LATeah1049ZB_164.0_0_0.0_24902108_0; not started and deadline has passed
12.06.2019 21:00:08 | Einstein@Home | Aborting task LATeah1049ZB_164.0_0_0.0_24903739_0; not started and deadline has passed
12.06.2019 21:00:08 | Einstein@Home | Aborting task LATeah1049ZB_164.0_0_0.0_24910263_0; not started and deadline has passed
12.06.2019 21:00:08 | Einstein@Home | Aborting task LATeah1049ZB_164.0_0_0.0_20591375_0; not started and deadline has passed
12.06.2019 21:00:08 | Einstein@Home | Aborting task LATeah1049ZB_164.0_0_0.0_24913525_0; not started and deadline has passed
12.06.2019 21:00:08 | Einstein@Home | Aborting task LATeah1049ZB_164.0_0_0.0_20658246_1; not started and deadline has passed
12.06.2019 21:00:08 | Einstein@Home | Aborting task LATeah1049ZB_164.0_0_0.0_20593006_0; not started and deadline has passed
12.06.2019 21:00:08 | Einstein@Home | Aborting task LATeah1049ZB_164.0_0_0.0_24907001_0; not started and deadline has passed
12.06.2019 21:00:08 | Einstein@Home | Aborting task LATeah1049ZB_164.0_0_0.0_20589744_0; not started and deadline has passed
12.06.2019 21:00:08 | Einstein@Home | Aborting task LATeah1049ZB_164.0_0_0.0_24905370_0; not started and deadline has passed
12.06.2019 21:00:08 | Einstein@Home | Aborting task LATeah1049ZB_164.0_0_0.0_24911894_0; not started and deadline has passed
12.06.2019 21:00:08 | Einstein@Home | Aborting task LATeah1049ZB_164.0_0_0.0_23440732_1; not started and deadline has passed
12.06.2019 21:00:08 | Einstein@Home | Aborting task LATeah1049ZB_164.0_0_0.0_23424422_1; not started and deadline has passed
12.06.2019 21:00:08 | Einstein@Home | Aborting task LATeah1049ZB_164.0_0_0.0_23448887_0; not started and deadline has passed
12.06.2019 21:00:08 | Einstein@Home | Aborting task LATeah1049ZB_164.0_0_0.0_23435839_0; not started and deadline has passed
12.06.2019 21:00:08 | Einstein@Home | Aborting task LATeah1049ZB_164.0_0_0.0_23437470_0; not started and deadline has passed
12.06.2019 21:00:08 | Einstein@Home | Aborting task LATeah1049ZB_164.0_0_0.0_23443994_0; not started and deadline has passed
12.06.2019 21:00:08 | Einstein@Home | Aborting task LATeah1049ZB_164.0_0_0.0_23447256_0; not started and deadline has passed
12.06.2019 21:00:08 | Einstein@Home | Aborting task LATeah1049ZB_164.0_0_0.0_23445625_0; not started and deadline has passed
12.06.2019 21:00:08 | Einstein@Home | Aborting task LATeah1049ZB_164.0_0_0.0_23427684_0; not started and deadline has passed
12.06.2019 21:00:08 | Einstein@Home | Aborting task LATeah1049ZB_164.0_0_0.0_23432577_1; not started and deadline has passed
12.06.2019 21:00:08 | Einstein@Home | Aborting task LATeah1049ZB_164.0_0_0.0_23439101_0; not started and deadline has passed
12.06.2019 21:00:08 | Einstein@Home | Aborting task LATeah1049ZB_164.0_0_0.0_23434208_0; not started and deadline has passed
12.06.2019 21:00:08 | Einstein@Home | Aborting task LATeah1049ZB_164.0_0_0.0_23442363_0; not started and deadline has passed
12.06.2019 21:00:08 | Einstein@Home | Aborting task LATeah1049ZB_164.0_0_0.0_23426053_0; not started and deadline has passed
12.06.2019 21:00:08 | Einstein@Home | Aborting task LATeah1049ZB_164.0_0_0.0_29894599_1; not started and deadline has passed
12.06.2019 21:00:08 | Einstein@Home | Aborting task LATeah1049ZB_164.0_0_0.0_26151454_0; not started and deadline has passed
12.06.2019 21:00:08 | Einstein@Home | Aborting task LATeah1049ZB_164.0_0_0.0_26182443_1; not started and deadline has passed
12.06.2019 21:00:08 | Einstein@Home | Aborting task LATeah1049ZB_164.0_0_0.0_30372482_1; not started and deadline has passed
12.06.2019 21:00:08 | Einstein@Home | Aborting task LATeah1049ZB_164.0_0_0.0_27749834_0; not started and deadline has passed
12.06.2019 21:00:08 | Einstein@Home | Aborting task LATeah1049ZB_164.0_0_0.0_26128620_1; not started and deadline has passed
12.06.2019 21:00:08 | Einstein@Home | Aborting task LATeah1049ZB_164.0_0_0.0_29879920_0; not started and deadline has passed
12.06.2019 21:00:08 | Einstein@Home | Aborting task LATeah1049ZB_164.0_0_0.0_27751465_0; not started and deadline has passed
12.06.2019 21:00:08 | Einstein@Home | Aborting task LATeah1049ZB_164.0_0_0.0_27748203_0; not started and deadline has passed
12.06.2019 21:00:08 | Einstein@Home | Aborting task LATeah1049ZB_164.0_0_0.0_26188967_1; not started and deadline has passed
12.06.2019 21:00:08 | Einstein@Home | Aborting task LATeah1049ZB_164.0_0_0.0_30374113_1; not started and deadline has passed
12.06.2019 21:00:08 | Einstein@Home | Aborting task LATeah1049ZB_164.0_0_0.0_30370851_1; not started and deadline has passed
12.06.2019 21:00:08 | Einstein@Home | Aborting task LATeah1049ZB_164.0_0_0.0_26645647_1; not started and deadline has passed
12.06.2019 21:00:10 | Einstein@Home | Sending scheduler request: To report completed tasks.
12.06.2019 21:00:10 | Einstein@Home | Reporting 83 completed tasks
12.06.2019 21:00:10 | Einstein@Home | Requesting new tasks for AMD/ATI GPU
12.06.2019 21:00:12 | Einstein@Home | Scheduler request completed: got 24 new tasks
12.06.2019 21:00:14 | Einstein@Home | Started download of hsgamma_FGRPB1G_1.22_windows_x86_64__FGRPopencl1K-ati.exe
12.06.2019 21:00:14 | Einstein@Home | Started download of LATeah1049b.dat
12.06.2019 21:00:15 | Einstein@Home | Finished download of hsgamma_FGRPB1G_1.22_windows_x86_64__FGRPopencl1K-ati.exe
12.06.2019 21:00:15 | Einstein@Home | Finished download of LATeah1049b.dat
12.06.2019 21:00:15 | Einstein@Home | Started download of templates_LATeah1049b_0196_46853737.dat
12.06.2019 21:00:15 | Einstein@Home | Started download of templates_LATeah1049b_0196_46855368.dat
12.06.2019 21:00:16 | Einstein@Home | Finished download of templates_LATeah1049b_0196_46853737.dat
12.06.2019 21:00:16 | Einstein@Home | Finished download of templates_LATeah1049b_0196_46855368.dat
12.06.2019 21:00:16 | Einstein@Home | Started download of templates_LATeah1049b_0196_46878202.dat
12.06.2019 21:00:16 | Einstein@Home | Started download of templates_LATeah1049b_0196_46879833.dat
12.06.2019 21:00:18 | Einstein@Home | Finished download of templates_LATeah1049b_0196_46878202.dat
12.06.2019 21:00:18 | Einstein@Home | Finished download of templates_LATeah1049b_0196_46879833.dat
12.06.2019 21:00:18 | Einstein@Home | Started download of templates_LATeah1049b_0196_46881464.dat
12.06.2019 21:00:18 | Einstein@Home | Started download of templates_LATeah1049b_0196_46904298.dat
12.06.2019 21:00:19 | Einstein@Home | Finished download of templates_LATeah1049b_0196_46881464.dat
12.06.2019 21:00:19 | Einstein@Home | Finished download of templates_LATeah1049b_0196_46904298.dat
12.06.2019 21:00:19 | Einstein@Home | Started download of templates_LATeah1049b_0196_46905929.dat
12.06.2019 21:00:19 | Einstein@Home | Started download of templates_LATeah1049b_0196_46909191.dat
12.06.2019 21:00:19 | Einstein@Home | project suspended by user
12.06.2019 21:00:20 | Einstein@Home | Finished download of templates_LATeah1049b_0196_46905929.dat
12.06.2019 21:00:20 | Einstein@Home | Finished download of templates_LATeah1049b_0196_46909191.dat
12.06.2019 21:00:20 | Einstein@Home | Started download of templates_LATeah1049b_0196_46912453.dat
12.06.2019 21:00:20 | Einstein@Home | Started download of templates_LATeah1049b_0196_46914084.dat
12.06.2019 21:00:20 | Einstein@Home | work fetch suspended by user
12.06.2019 21:00:21 | Einstein@Home | Finished download of templates_LATeah1049b_0196_46912453.dat
12.06.2019 21:00:21 | Einstein@Home | Finished download of templates_LATeah1049b_0196_46914084.dat
12.06.2019 21:00:21 | Einstein@Home | Started download of templates_LATeah1049b_0196_47284321.dat
12.06.2019 21:00:21 | Einstein@Home | Started download of templates_LATeah1049b_0196_46927132.dat
12.06.2019 21:00:22 | Einstein@Home | Finished download of templates_LATeah1049b_0196_47284321.dat
12.06.2019 21:00:22 | Einstein@Home | Finished download of templates_LATeah1049b_0196_46927132.dat
12.06.2019 21:00:22 | Einstein@Home | Started download of templates_LATeah1049b_0196_46933656.dat
12.06.2019 21:00:22 | Einstein@Home | Started download of templates_LATeah1049b_0196_46935287.dat
12.06.2019 21:00:23 | Einstein@Home | Finished download of templates_LATeah1049b_0196_46933656.dat
12.06.2019 21:00:23 | Einstein@Home | Finished download of templates_LATeah1049b_0196_46935287.dat
12.06.2019 21:00:23 | Einstein@Home | Started download of templates_LATeah1049b_0196_46938549.dat
12.06.2019 21:00:23 | Einstein@Home | Started download of templates_LATeah1049b_0196_46940180.dat
12.06.2019 21:00:24 | Einstein@Home | Finished download of templates_LATeah1049b_0196_46938549.dat
12.06.2019 21:00:24 | Einstein@Home | Finished download of templates_LATeah1049b_0196_46940180.dat
12.06.2019 21:00:24 | Einstein@Home | Started download of templates_LATeah1049b_0196_46941811.dat
12.06.2019 21:00:24 | Einstein@Home | Started download of templates_LATeah1049b_0196_46943442.dat
12.06.2019 21:00:24 | SETI@home | project resumed by user
12.06.2019 21:00:25 | SETI@home | update requested by user
12.06.2019 21:00:25 | Einstein@Home | Finished download of templates_LATeah1049b_0196_46941811.dat
12.06.2019 21:00:25 | Einstein@Home | Finished download of templates_LATeah1049b_0196_46943442.dat
12.06.2019 21:00:25 | Einstein@Home | Started download of templates_LATeah1049b_0196_46945073.dat
12.06.2019 21:00:25 | Einstein@Home | Started download of templates_LATeah1049b_0196_46946704.dat
12.06.2019 21:00:27 | SETI@home | Starting task blc32_2bit_guppi_58406_28625_HIP21029_0108.15642.818.21.44.155.vlar_0
12.06.2019 21:00:27 | SETI@home | Starting task blc32_2bit_guppi_58406_28625_HIP21029_0108.15642.818.21.44.235.vlar_0
12.06.2019 21:00:27 | SETI@home | work fetch resumed by user
12.06.2019 21:00:28 | Einstein@Home | Finished download of templates_LATeah1049b_0196_46945073.dat
12.06.2019 21:00:28 | Einstein@Home | Finished download of templates_LATeah1049b_0196_46946704.dat
12.06.2019 21:00:28 | Einstein@Home | Started download of templates_LATeah1049b_0196_46949966.dat
12.06.2019 21:00:28 | Einstein@Home | Started download of templates_LATeah1049b_0196_46951597.dat
12.06.2019 21:00:29 | Einstein@Home | Finished download of templates_LATeah1049b_0196_46949966.dat
12.06.2019 21:00:29 | Einstein@Home | Finished download of templates_LATeah1049b_0196_46951597.dat
12.06.2019 21:00:29 | Einstein@Home | Started download of templates_LATeah1049b_0196_46953228.dat
12.06.2019 21:00:29 | Einstein@Home | Started download of templates_LATeah1049b_0196_46956490.dat
12.06.2019 21:00:29 | SETI@home | Sending scheduler request: Requested by user.
12.06.2019 21:00:29 | SETI@home | Reporting 195 completed tasks
12.06.2019 21:00:29 | SETI@home | Requesting new tasks for AMD/ATI GPU
12.06.2019 21:00:30 | Einstein@Home | Finished download of templates_LATeah1049b_0196_46953228.dat
12.06.2019 21:00:30 | Einstein@Home | Finished download of templates_LATeah1049b_0196_46956490.dat
12.06.2019 21:00:38 | SETI@home | Scheduler request completed: got 18 new tasks
12.06.2019 21:00:40 | SETI@home | Started download of 25jn12ac.2188.480.14.41.71
12.06.2019 21:00:40 | SETI@home | Started download of blc26_2bit_guppi_58406_30334_HIP20482_0113.10874.0.22.45.31.vlar
12.06.2019 21:00:45 | SETI@home | Finished download of 25jn12ac.2188.480.14.41.71
12.06.2019 21:00:45 | SETI@home | Finished download of blc26_2bit_guppi_58406_30334_HIP20482_0113.10874.0.22.45.31.vlar
12.06.2019 21:00:45 | SETI@home | Started download of blc25_2bit_guppi_58406_28274_HIP20533_0107.10255.409.22.45.5.vlar
12.06.2019 21:00:45 | SETI@home | Started download of blc25_2bit_guppi_58406_28274_HIP20533_0107.10255.409.22.45.4.vlar
12.06.2019 21:00:49 | SETI@home | Finished download of blc25_2bit_guppi_58406_28274_HIP20533_0107.10255.409.22.45.5.vlar
12.06.2019 21:00:49 | SETI@home | Started download of blc25_2bit_guppi_58406_28274_HIP20533_0107.10255.409.22.45.2.vlar
12.06.2019 21:00:50 | SETI@home | Finished download of blc25_2bit_guppi_58406_28274_HIP20533_0107.10255.409.22.45.4.vlar
12.06.2019 21:00:50 | SETI@home | Started download of blc25_2bit_guppi_58406_26617_HIP20917_0102.10864.818.21.44.26.vlar
12.06.2019 21:00:52 | SETI@home | Finished download of blc25_2bit_guppi_58406_28274_HIP20533_0107.10255.409.22.45.2.vlar
12.06.2019 21:00:52 | SETI@home | Started download of 25jn12ac.2188.480.14.41.86
12.06.2019 21:00:54 | SETI@home | Finished download of blc25_2bit_guppi_58406_26617_HIP20917_0102.10864.818.21.44.26.vlar
12.06.2019 21:00:54 | SETI@home | Started download of 25jn12ac.2188.480.14.41.80
12.06.2019 21:00:55 | SETI@home | Finished download of 25jn12ac.2188.480.14.41.86
12.06.2019 21:00:55 | SETI@home | Started download of 25jn12ac.2188.480.14.41.74
12.06.2019 21:00:58 | SETI@home | Finished download of 25jn12ac.2188.480.14.41.80
12.06.2019 21:00:58 | SETI@home | Started download of 25jn12ac.2188.480.14.41.125
12.06.2019 21:00:59 | SETI@home | Finished download of 25jn12ac.2188.480.14.41.74
12.06.2019 21:00:59 | SETI@home | Started download of blc25_2bit_guppi_58406_26617_HIP20917_0102.10843.818.22.45.51.vlar
12.06.2019 21:01:02 | SETI@home | Finished download of 25jn12ac.2188.480.14.41.125
12.06.2019 21:01:02 | SETI@home | Started download of 25jn12ac.2188.480.14.41.103
12.06.2019 21:01:03 | SETI@home | Finished download of blc25_2bit_guppi_58406_26617_HIP20917_0102.10843.818.22.45.51.vlar
12.06.2019 21:01:03 | SETI@home | Started download of blc25_2bit_guppi_58406_26617_HIP20917_0102.10122.409.21.44.182.vlar
12.06.2019 21:01:07 | SETI@home | Finished download of blc25_2bit_guppi_58406_26617_HIP20917_0102.10122.409.21.44.182.vlar
12.06.2019 21:01:07 | SETI@home | Started download of blc25_2bit_guppi_58406_27943_HIP20917_0106.10186.409.22.45.126.vlar
12.06.2019 21:01:09 | SETI@home | Finished download of 25jn12ac.2188.480.14.41.103
12.06.2019 21:01:09 | SETI@home | Started download of 25jn12ac.2188.480.14.41.101
12.06.2019 21:01:12 | SETI@home | Finished download of blc25_2bit_guppi_58406_27943_HIP20917_0106.10186.409.22.45.126.vlar
12.06.2019 21:01:12 | SETI@home | Started download of blc25_2bit_guppi_58406_27943_HIP20917_0106.10186.409.22.45.125.vlar
12.06.2019 21:01:16 | SETI@home | Finished download of blc25_2bit_guppi_58406_27943_HIP20917_0106.10186.409.22.45.125.vlar
12.06.2019 21:01:16 | SETI@home | Started download of blc25_2bit_guppi_58406_26617_HIP20917_0102.10843.818.22.45.48.vlar
12.06.2019 21:01:18 | SETI@home | Finished download of 25jn12ac.2188.480.14.41.101
12.06.2019 21:01:18 | SETI@home | Started download of 25jn12ac.2188.480.14.41.67
12.06.2019 21:01:19 | SETI@home | Finished download of blc25_2bit_guppi_58406_26617_HIP20917_0102.10843.818.22.45.48.vlar
12.06.2019 21:01:25 | SETI@home | Finished download of 25jn12ac.2188.480.14.41.67
12.06.2019 21:05:46 | SETI@home | Sending scheduler request: To fetch work.
12.06.2019 21:05:46 | SETI@home | Requesting new tasks for AMD/ATI GPU
12.06.2019 21:05:49 | | Eine neue Version von BOINC ist verfügbar (7.14.2). <a href=https://boinc.berkeley.edu/download.php>Herunterladen</a>
12.06.2019 21:05:49 | SETI@home | Scheduler request completed: got 83 new tasks
12.06.2019 21:05:51 | SETI@home | Started download of 25jn12ac.1705.5388.13.40.80
12.06.2019 21:05:51 | SETI@home | Started download of blc25_2bit_guppi_58406_27281_HIP20917_0104.12802.818.22.45.8.vlar
12.06.2019 21:05:56 | SETI@home | Finished download of blc25_2bit_guppi_58406_27281_HIP20917_0104.12802.818.22.45.8.vlar
12.06.2019 21:05:56 | SETI@home | Started download of blc26_2bit_guppi_58406_29306_HIP21029_0110.10672.409.21.44.160.vlar
12.06.2019 21:05:57 | SETI@home | Finished download of 25jn12ac.1705.5388.13.40.80
12.06.2019 21:05:57 | SETI@home | Started download of blc25_2bit_guppi_58406_27281_HIP20917_0104.12802.818.22.45.23.vlar
12.06.2019 21:06:00 | SETI@home | Finished download of blc26_2bit_guppi_58406_29306_HIP21029_0110.10672.409.21.44.160.vlar
12.06.2019 21:06:00 | SETI@home | Started download of blc26_2bit_guppi_58406_29992_HIP21029_0112.12793.818.21.44.22.vlar
12.06.2019 21:06:03 | SETI@home | Finished download of blc25_2bit_guppi_58406_27281_HIP20917_0104.12802.818.22.45.23.vlar
12.06.2019 21:06:03 | SETI@home | Started download of blc25_2bit_guppi_58406_28274_HIP20533_0107.10255.818.22.45.117.vlar
12.06.2019 21:06:04 | SETI@home | Finished download of blc26_2bit_guppi_58406_29992_HIP21029_0112.12793.818.21.44.22.vlar
12.06.2019 21:06:04 | SETI@home | Started download of blc25_2bit_guppi_58406_26617_HIP20917_0102.12784.818.22.45.29.vlar
12.06.2019 21:06:07 | SETI@home | Finished download of blc25_2bit_guppi_58406_28274_HIP20533_0107.10255.818.22.45.117.vlar
12.06.2019 21:06:07 | SETI@home | Started download of blc26_2bit_guppi_58406_29649_HIP20369_0111.10855.409.21.44.141.vlar
12.06.2019 21:06:08 | SETI@home | Finished download of blc25_2bit_guppi_58406_26617_HIP20917_0102.12784.818.22.45.29.vlar
12.06.2019 21:06:08 | SETI@home | Started download of blc25_2bit_guppi_58406_26617_HIP20917_0102.10685.409.21.44.165.vlar
12.06.2019 21:06:11 | SETI@home | Finished download of blc26_2bit_guppi_58406_29649_HIP20369_0111.10855.409.21.44.141.vlar
12.06.2019 21:06:11 | SETI@home | Started download of blc26_2bit_guppi_58406_29992_HIP21029_0112.12793.818.21.44.23.vlar
12.06.2019 21:06:12 | SETI@home | Finished download of blc25_2bit_guppi_58406_26617_HIP20917_0102.10685.409.21.44.165.vlar
12.06.2019 21:06:12 | SETI@home | Started download of blc25_2bit_guppi_58406_27943_HIP20917_0106.12774.818.22.45.14.vlar
12.06.2019 21:06:16 | SETI@home | Finished download of blc25_2bit_guppi_58406_27943_HIP20917_0106.12774.818.22.45.14.vlar
12.06.2019 21:06:16 | SETI@home | Started download of blc25_2bit_guppi_58406_28274_HIP20533_0107.10255.818.22.45.99.vlar
12.06.2019 21:06:20 | SETI@home | Finished download of blc26_2bit_guppi_58406_29992_HIP21029_0112.12793.818.21.44.23.vlar
12.06.2019 21:06:20 | SETI@home | Finished download of blc25_2bit_guppi_58406_28274_HIP20533_0107.10255.818.22.45.99.vlar
12.06.2019 21:06:20 | SETI@home | Started download of blc25_2bit_guppi_58406_26617_HIP20917_0102.10916.409.21.44.7.vlar
12.06.2019 21:06:20 | SETI@home | Started download of blc26_2bit_guppi_58406_29306_HIP21029_0110.10672.409.21.44.175.vlar
12.06.2019 21:06:25 | SETI@home | Finished download of blc26_2bit_guppi_58406_29306_HIP21029_0110.10672.409.21.44.175.vlar
12.06.2019 21:06:25 | SETI@home | Started download of blc25_2bit_guppi_58406_27943_HIP20917_0106.12774.818.22.45.32.vlar
12.06.2019 21:06:27 | SETI@home | Finished download of blc25_2bit_guppi_58406_26617_HIP20917_0102.10916.409.21.44.7.vlar
12.06.2019 21:06:27 | SETI@home | Started download of blc26_2bit_guppi_58406_29992_HIP21029_0112.12793.818.21.44.26.vlar
12.06.2019 21:06:29 | SETI@home | Finished download of blc25_2bit_guppi_58406_27943_HIP20917_0106.12774.818.22.45.32.vlar
12.06.2019 21:06:29 | SETI@home | Started download of blc25_2bit_guppi_58406_26617_HIP20917_0102.10685.409.21.44.168.vlar
12.06.2019 21:06:31 | SETI@home | Finished download of blc26_2bit_guppi_58406_29992_HIP21029_0112.12793.818.21.44.26.vlar
12.06.2019 21:06:31 | SETI@home | Started download of blc25_2bit_guppi_58406_26617_HIP20917_0102.12784.818.22.45.33.vlar
12.06.2019 21:06:33 | SETI@home | Finished download of blc25_2bit_guppi_58406_26617_HIP20917_0102.10685.409.21.44.168.vlar
12.06.2019 21:06:33 | SETI@home | Started download of blc25_2bit_guppi_58406_27943_HIP20917_0106.12774.818.22.45.31.vlar
12.06.2019 21:06:37 | SETI@home | Finished download of blc25_2bit_guppi_58406_27943_HIP20917_0106.12774.818.22.45.31.vlar
12.06.2019 21:06:37 | SETI@home | Started download of blc25_2bit_guppi_58406_27281_HIP20917_0104.12802.818.22.45.22.vlar
12.06.2019 21:06:39 | SETI@home | Finished download of blc25_2bit_guppi_58406_26617_HIP20917_0102.12784.818.22.45.33.vlar
12.06.2019 21:06:39 | SETI@home | Started download of blc25_2bit_guppi_58406_27943_HIP20917_0106.12774.818.22.45.29.vlar
12.06.2019 21:06:42 | SETI@home | Finished download of blc25_2bit_guppi_58406_27281_HIP20917_0104.12802.818.22.45.22.vlar
12.06.2019 21:06:42 | SETI@home | Started download of blc25_2bit_guppi_58406_26617_HIP20917_0102.10929.409.22.45.1.vlar
12.06.2019 21:06:45 | SETI@home | Finished download of blc25_2bit_guppi_58406_27943_HIP20917_0106.12774.818.22.45.29.vlar
12.06.2019 21:06:45 | SETI@home | Started download of 25jn12ac.18881.15204.12.39.21
12.06.2019 21:06:46 | SETI@home | Finished download of blc25_2bit_guppi_58406_26617_HIP20917_0102.10929.409.22.45.1.vlar
12.06.2019 21:06:46 | SETI@home | Started download of blc25_2bit_guppi_58406_26617_HIP20917_0102.10929.0.22.45.249.vlar
12.06.2019 21:06:51 | SETI@home | Finished download of 25jn12ac.18881.15204.12.39.21
12.06.2019 21:06:51 | SETI@home | Finished download of blc25_2bit_guppi_58406_26617_HIP20917_0102.10929.0.22.45.249.vlar
12.06.2019 21:06:51 | SETI@home | Started download of blc25_2bit_guppi_58406_27943_HIP20917_0106.12774.818.22.45.28.vlar
12.06.2019 21:06:51 | SETI@home | Started download of blc25_2bit_guppi_58406_26617_HIP20917_0102.10929.409.22.45.4.vlar
12.06.2019 21:06:56 | SETI@home | Finished download of blc25_2bit_guppi_58406_26617_HIP20917_0102.10929.409.22.45.4.vlar
12.06.2019 21:06:56 | SETI@home | Started download of 25jn12ac.1705.5388.13.40.79
12.06.2019 21:06:58 | SETI@home | Finished download of blc25_2bit_guppi_58406_27943_HIP20917_0106.12774.818.22.45.28.vlar
12.06.2019 21:06:58 | SETI@home | Started download of blc25_2bit_guppi_58406_26617_HIP20917_0102.10685.409.21.44.137.vlar
12.06.2019 21:07:00 | SETI@home | Finished download of 25jn12ac.1705.5388.13.40.79
12.06.2019 21:07:00 | SETI@home | Started download of blc26_2bit_guppi_58406_29306_HIP21029_0110.10672.409.21.44.126.vlar
12.06.2019 21:07:02 | SETI@home | Finished download of blc25_2bit_guppi_58406_26617_HIP20917_0102.10685.409.21.44.137.vlar
12.06.2019 21:07:02 | SETI@home | Started download of blc25_2bit_guppi_58406_27281_HIP20917_0104.12802.818.22.45.9.vlar
12.06.2019 21:07:04 | SETI@home | Finished download of blc26_2bit_guppi_58406_29306_HIP21029_0110.10672.409.21.44.126.vlar
12.06.2019 21:07:04 | SETI@home | Started download of blc25_2bit_guppi_58406_26617_HIP20917_0102.10929.0.22.45.230.vlar
12.06.2019 21:07:06 | SETI@home | Finished download of blc25_2bit_guppi_58406_27281_HIP20917_0104.12802.818.22.45.9.vlar
12.06.2019 21:07:06 | SETI@home | Started download of blc25_2bit_guppi_58406_28274_HIP20533_0107.10255.818.22.45.115.vlar
12.06.2019 21:07:08 | SETI@home | Finished download of blc25_2bit_guppi_58406_26617_HIP20917_0102.10929.0.22.45.230.vlar
12.06.2019 21:07:08 | SETI@home | Started download of blc25_2bit_guppi_58406_28274_HIP20533_0107.10255.818.22.45.96.vlar
12.06.2019 21:07:11 | SETI@home | Finished download of blc25_2bit_guppi_58406_28274_HIP20533_0107.10255.818.22.45.115.vlar
12.06.2019 21:07:11 | SETI@home | Started download of blc26_2bit_guppi_58406_30334_HIP20482_0113.10874.409.22.45.134.vlar
12.06.2019 21:07:12 | SETI@home | Finished download of blc25_2bit_guppi_58406_28274_HIP20533_0107.10255.818.22.45.96.vlar
12.06.2019 21:07:12 | SETI@home | Started download of blc25_2bit_guppi_58406_26617_HIP20917_0102.12784.818.22.45.28.vlar
12.06.2019 21:07:16 | SETI@home | Finished download of blc26_2bit_guppi_58406_30334_HIP20482_0113.10874.409.22.45.134.vlar
12.06.2019 21:07:16 | SETI@home | Started download of blc26_2bit_guppi_58406_29649_HIP20369_0111.10855.409.21.44.140.vlar
12.06.2019 21:07:17 | SETI@home | Finished download of blc25_2bit_guppi_58406_26617_HIP20917_0102.12784.818.22.45.28.vlar
12.06.2019 21:07:17 | SETI@home | Started download of blc25_2bit_guppi_58406_28274_HIP20533_0107.10255.818.22.45.119.vlar
12.06.2019 21:07:22 | SETI@home | Finished download of blc26_2bit_guppi_58406_29649_HIP20369_0111.10855.409.21.44.140.vlar
12.06.2019 21:07:22 | SETI@home | Finished download of blc25_2bit_guppi_58406_28274_HIP20533_0107.10255.818.22.45.119.vlar
12.06.2019 21:07:22 | SETI@home | Started download of blc25_2bit_guppi_58406_27943_HIP20917_0106.12774.818.22.45.27.vlar
12.06.2019 21:07:22 | SETI@home | Started download of blc25_2bit_guppi_58406_27943_HIP20917_0106.12774.818.22.45.26.vlar
12.06.2019 21:07:26 | SETI@home | Finished download of blc25_2bit_guppi_58406_27943_HIP20917_0106.12774.818.22.45.27.vlar
12.06.2019 21:07:26 | SETI@home | Finished download of blc25_2bit_guppi_58406_27943_HIP20917_0106.12774.818.22.45.26.vlar
12.06.2019 21:07:26 | SETI@home | Started download of 25jn12ac.1705.5388.13.40.71
12.06.2019 21:07:26 | SETI@home | Started download of blc25_2bit_guppi_58406_26617_HIP20917_0102.10834.409.22.45.151.vlar
12.06.2019 21:07:32 | SETI@home | Finished download of blc25_2bit_guppi_58406_26617_HIP20917_0102.10834.409.22.45.151.vlar
12.06.2019 21:07:32 | SETI@home | Started download of blc25_2bit_guppi_58406_26617_HIP20917_0102.10834.409.22.45.156.vlar
12.06.2019 21:07:34 | SETI@home | Finished download of 25jn12ac.1705.5388.13.40.71
12.06.2019 21:07:34 | SETI@home | Started download of blc25_2bit_guppi_58406_26617_HIP20917_0102.10929.0.22.45.224.vlar
12.06.2019 21:07:37 | SETI@home | Finished download of blc25_2bit_guppi_58406_26617_HIP20917_0102.10834.409.22.45.156.vlar
12.06.2019 21:07:37 | SETI@home | Started download of blc26_2bit_guppi_58406_29306_HIP21029_0110.10672.409.21.44.168.vlar
12.06.2019 21:07:39 | SETI@home | Finished download of blc25_2bit_guppi_58406_26617_HIP20917_0102.10929.0.22.45.224.vlar
12.06.2019 21:07:39 | SETI@home | Started download of blc25_2bit_guppi_58406_27612_HIP20531_0105.10695.409.21.44.176.vlar
12.06.2019 21:07:41 | SETI@home | Finished download of blc26_2bit_guppi_58406_29306_HIP21029_0110.10672.409.21.44.168.vlar
12.06.2019 21:07:41 | SETI@home | Started download of blc26_2bit_guppi_58406_30334_HIP20482_0113.10874.409.22.45.137.vlar
12.06.2019 21:07:45 | SETI@home | Finished download of blc25_2bit_guppi_58406_27612_HIP20531_0105.10695.409.21.44.176.vlar
12.06.2019 21:07:45 | SETI@home | Finished download of blc26_2bit_guppi_58406_30334_HIP20482_0113.10874.409.22.45.137.vlar
12.06.2019 21:07:45 | SETI@home | Started download of blc26_2bit_guppi_58406_29992_HIP21029_0112.12793.818.21.44.5.vlar
12.06.2019 21:07:45 | SETI@home | Started download of blc26_2bit_guppi_58406_29306_HIP21029_0110.10672.409.21.44.161.vlar
12.06.2019 21:07:49 | SETI@home | Finished download of blc26_2bit_guppi_58406_29992_HIP21029_0112.12793.818.21.44.5.vlar
12.06.2019 21:07:49 | SETI@home | Finished download of blc26_2bit_guppi_58406_29306_HIP21029_0110.10672.409.21.44.161.vlar
12.06.2019 21:07:49 | SETI@home | Started download of blc25_2bit_guppi_58406_26617_HIP20917_0102.12784.818.22.45.21.vlar
12.06.2019 21:07:49 | SETI@home | Started download of blc25_2bit_guppi_58406_27612_HIP20531_0105.10695.409.21.44.163.vlar
12.06.2019 21:07:54 | SETI@home | Finished download of blc25_2bit_guppi_58406_27612_HIP20531_0105.10695.409.21.44.163.vlar
12.06.2019 21:07:54 | SETI@home | Started download of blc26_2bit_guppi_58406_29992_HIP21029_0112.12793.818.21.44.10.vlar
12.06.2019 21:07:55 | SETI@home | Finished download of blc25_2bit_guppi_58406_26617_HIP20917_0102.12784.818.22.45.21.vlar
12.06.2019 21:07:55 | SETI@home | Started download of blc25_2bit_guppi_58406_26617_HIP20917_0102.10685.409.21.44.136.vlar
12.06.2019 21:07:58 | SETI@home | Finished download of blc26_2bit_guppi_58406_29992_HIP21029_0112.12793.818.21.44.10.vlar
12.06.2019 21:07:58 | SETI@home | Started download of blc25_2bit_guppi_58406_25930_HIP20901_0100.27412.0.22.45.203.vlar
12.06.2019 21:08:01 | SETI@home | Finished download of blc25_2bit_guppi_58406_26617_HIP20917_0102.10685.409.21.44.136.vlar
12.06.2019 21:08:01 | SETI@home | Started download of blc25_2bit_guppi_58406_26617_HIP20917_0102.10929.0.22.45.238.vlar
12.06.2019 21:08:02 | SETI@home | Finished download of blc25_2bit_guppi_58406_25930_HIP20901_0100.27412.0.22.45.203.vlar
12.06.2019 21:08:02 | SETI@home | Started download of blc26_2bit_guppi_58406_30334_HIP20482_0113.10874.409.22.45.99.vlar
12.06.2019 21:08:05 | SETI@home | Finished download of blc25_2bit_guppi_58406_26617_HIP20917_0102.10929.0.22.45.238.vlar
12.06.2019 21:08:05 | SETI@home | Started download of blc25_2bit_guppi_58406_28274_HIP20533_0107.10255.818.22.45.114.vlar
12.06.2019 21:08:06 | SETI@home | Finished download of blc26_2bit_guppi_58406_30334_HIP20482_0113.10874.409.22.45.99.vlar
12.06.2019 21:08:06 | SETI@home | Started download of 25jn12ac.1705.5388.13.40.70
12.06.2019 21:08:11 | SETI@home | Finished download of blc25_2bit_guppi_58406_28274_HIP20533_0107.10255.818.22.45.114.vlar
12.06.2019 21:08:11 | SETI@home | Finished download of 25jn12ac.1705.5388.13.40.70
12.06.2019 21:08:11 | SETI@home | Started download of blc25_2bit_guppi_58406_28274_HIP20533_0107.10255.818.22.45.110.vlar
12.06.2019 21:08:11 | SETI@home | Started download of blc25_2bit_guppi_58406_27612_HIP20531_0105.10695.409.21.44.170.vlar
12.06.2019 21:08:16 | SETI@home | Finished download of blc25_2bit_guppi_58406_28274_HIP20533_0107.10255.818.22.45.110.vlar
12.06.2019 21:08:16 | SETI@home | Finished download of blc25_2bit_guppi_58406_27612_HIP20531_0105.10695.409.21.44.170.vlar
12.06.2019 21:08:16 | SETI@home | Started download of 25jn12ac.18881.15204.12.39.24
12.06.2019 21:08:16 | SETI@home | Started download of 25jn12ac.1705.5388.13.40.75
12.06.2019 21:08:25 | SETI@home | Finished download of 25jn12ac.1705.5388.13.40.75
12.06.2019 21:08:25 | SETI@home | Started download of blc25_2bit_guppi_58406_26617_HIP20917_0102.10929.409.22.45.0.vlar
12.06.2019 21:08:27 | SETI@home | Finished download of 25jn12ac.18881.15204.12.39.24
12.06.2019 21:08:27 | SETI@home | Started download of blc25_2bit_guppi_58406_26617_HIP20917_0102.10834.409.22.45.147.vlar
12.06.2019 21:08:29 | SETI@home | Finished download of blc25_2bit_guppi_58406_26617_HIP20917_0102.10929.409.22.45.0.vlar
12.06.2019 21:08:29 | SETI@home | Started download of blc25_2bit_guppi_58406_26617_HIP20917_0102.10916.409.21.44.12.vlar
12.06.2019 21:08:34 | SETI@home | Finished download of blc25_2bit_guppi_58406_26617_HIP20917_0102.10916.409.21.44.12.vlar
12.06.2019 21:08:34 | SETI@home | Started download of 25jn12ac.18881.15204.12.39.34
12.06.2019 21:08:37 | SETI@home | Finished download of blc25_2bit_guppi_58406_26617_HIP20917_0102.10834.409.22.45.147.vlar
12.06.2019 21:08:37 | SETI@home | Started download of blc25_2bit_guppi_58406_27281_HIP20917_0104.12802.818.22.45.21.vlar
12.06.2019 21:08:39 | SETI@home | Finished download of 25jn12ac.18881.15204.12.39.34
12.06.2019 21:08:39 | SETI@home | Started download of blc26_2bit_guppi_58406_29992_HIP21029_0112.12793.818.21.44.24.vlar
12.06.2019 21:08:41 | SETI@home | Finished download of blc25_2bit_guppi_58406_27281_HIP20917_0104.12802.818.22.45.21.vlar
12.06.2019 21:08:41 | SETI@home | Started download of blc25_2bit_guppi_58406_26617_HIP20917_0102.10929.409.22.45.2.vlar
12.06.2019 21:08:43 | SETI@home | Finished download of blc26_2bit_guppi_58406_29992_HIP21029_0112.12793.818.21.44.24.vlar
12.06.2019 21:08:43 | SETI@home | Started download of blc25_2bit_guppi_58406_26617_HIP20917_0102.10834.409.22.45.150.vlar
12.06.2019 21:08:45 | SETI@home | Finished download of blc25_2bit_guppi_58406_26617_HIP20917_0102.10929.409.22.45.2.vlar
12.06.2019 21:08:45 | SETI@home | Started download of 25jn12ac.1705.5388.13.40.76
12.06.2019 21:08:47 | SETI@home | Finished download of blc25_2bit_guppi_58406_26617_HIP20917_0102.10834.409.22.45.150.vlar
12.06.2019 21:08:47 | SETI@home | Started download of blc26_2bit_guppi_58406_30334_HIP20482_0113.10874.409.22.45.139.vlar
12.06.2019 21:08:49 | SETI@home | Finished download of 25jn12ac.1705.5388.13.40.76
12.06.2019 21:08:49 | SETI@home | Started download of blc25_2bit_guppi_58406_26617_HIP20917_0102.12784.818.22.45.26.vlar
12.06.2019 21:08:53 | SETI@home | Finished download of blc26_2bit_guppi_58406_30334_HIP20482_0113.10874.409.22.45.139.vlar
12.06.2019 21:08:53 | SETI@home | Finished download of blc25_2bit_guppi_58406_26617_HIP20917_0102.12784.818.22.45.26.vlar
12.06.2019 21:08:53 | SETI@home | Started download of blc26_2bit_guppi_58406_30334_HIP20482_0113.10874.409.22.45.138.vlar
12.06.2019 21:08:53 | SETI@home | Started download of blc26_2bit_guppi_58406_29992_HIP21029_0112.12793.818.21.44.17.vlar
12.06.2019 21:08:57 | SETI@home | Finished download of blc26_2bit_guppi_58406_29992_HIP21029_0112.12793.818.21.44.17.vlar
12.06.2019 21:08:57 | SETI@home | Started download of 25jn12ac.18881.15204.12.39.12
12.06.2019 21:08:58 | SETI@home | Finished download of blc26_2bit_guppi_58406_30334_HIP20482_0113.10874.409.22.45.138.vlar
12.06.2019 21:08:58 | SETI@home | Started download of blc26_2bit_guppi_58406_29649_HIP20369_0111.10855.409.21.44.135.vlar
12.06.2019 21:09:01 | SETI@home | Finished download of 25jn12ac.18881.15204.12.39.12
12.06.2019 21:09:01 | SETI@home | Started download of blc25_2bit_guppi_58406_27943_HIP20917_0106.12774.818.22.45.22.vlar
12.06.2019 21:09:04 | SETI@home | Finished download of blc26_2bit_guppi_58406_29649_HIP20369_0111.10855.409.21.44.135.vlar
12.06.2019 21:09:04 | SETI@home | Started download of blc25_2bit_guppi_58406_26617_HIP20917_0102.10834.409.22.45.159.vlar
12.06.2019 21:09:05 | SETI@home | Finished download of blc25_2bit_guppi_58406_27943_HIP20917_0106.12774.818.22.45.22.vlar
12.06.2019 21:09:05 | SETI@home | Started download of blc26_2bit_guppi_58406_29306_HIP21029_0110.10672.409.21.44.163.vlar
12.06.2019 21:09:08 | SETI@home | Finished download of blc25_2bit_guppi_58406_26617_HIP20917_0102.10834.409.22.45.159.vlar
12.06.2019 21:09:08 | SETI@home | Started download of blc25_2bit_guppi_58406_27612_HIP20531_0105.10695.409.21.44.141.vlar
12.06.2019 21:09:09 | SETI@home | Finished download of blc26_2bit_guppi_58406_29306_HIP21029_0110.10672.409.21.44.163.vlar
12.06.2019 21:09:09 | SETI@home | Started download of blc25_2bit_guppi_58406_28274_HIP20533_0107.10255.818.22.45.81.vlar
12.06.2019 21:09:12 | SETI@home | Finished download of blc25_2bit_guppi_58406_27612_HIP20531_0105.10695.409.21.44.141.vlar
12.06.2019 21:09:12 | SETI@home | Started download of blc25_2bit_guppi_58406_27943_HIP20917_0106.12774.818.22.45.9.vlar
12.06.2019 21:09:13 | SETI@home | Finished download of blc25_2bit_guppi_58406_28274_HIP20533_0107.10255.818.22.45.81.vlar
12.06.2019 21:09:13 | SETI@home | Started download of blc25_2bit_guppi_58406_28274_HIP20533_0107.10255.818.22.45.80.vlar
12.06.2019 21:09:16 | SETI@home | Finished download of blc25_2bit_guppi_58406_27943_HIP20917_0106.12774.818.22.45.9.vlar
12.06.2019 21:09:17 | SETI@home | Finished download of blc25_2bit_guppi_58406_28274_HIP20533_0107.10255.818.22.45.80.vlar
12.06.2019 21:10:34 | SETI@home | Computation for task blc32_2bit_guppi_58406_28625_HIP21029_0108.15642.818.21.44.155.vlar_0 finished
12.06.2019 21:10:34 | SETI@home | Starting task 30ap19aa.15963.476.16.43.164_0
12.06.2019 21:10:36 | SETI@home | Started upload of blc32_2bit_guppi_58406_28625_HIP21029_0108.15642.818.21.44.155.vlar_0_r890912093_0
12.06.2019 21:10:40 | SETI@home | Finished upload of blc32_2bit_guppi_58406_28625_HIP21029_0108.15642.818.21.44.155.vlar_0_r890912093_0
12.06.2019 21:11:15 | SETI@home | Computation for task blc32_2bit_guppi_58406_28625_HIP21029_0108.15642.818.21.44.235.vlar_0 finished
12.06.2019 21:11:15 | SETI@home | Starting task blc32_2bit_guppi_58406_28625_HIP21029_0108.15642.818.21.44.135.vlar_1
12.06.2019 21:11:17 | SETI@home | Started upload of blc32_2bit_guppi_58406_28625_HIP21029_0108.15642.818.21.44.235.vlar_0_r1582007669_0
12.06.2019 21:11:20 | SETI@home | Finished upload of blc32_2bit_guppi_58406_28625_HIP21029_0108.15642.818.21.44.235.vlar_0_r1582007669_0
