ULi Integrated Driver 2.20
cruger
Senior Moderator
Teammitglied
25.05.2002
29.389
1.579
  • QMC Race
  • BOINC Pentathlon 2014
ULi Electronics hat für seine Chipsätze ein neues integriertes Treiberpaket mit der Versionsnummer 2.20 für Microsoft Windows Betriebssysteme veröffentlicht.
<i><b>This integrated driver integrates</b></i><ol><li><i>AGP driver V2.14 for Win2K/WinXP with M1563, V2.30 for WinXP/2003/x64 , V2.14Win98SE/WinME</i></li><li><i>IDE Cache Utility 1.06 for Win95 OSR2.1/Win98/Win98SE/WinME.</i></li><li><i>Mini-IDE driver 1.5.1.0 for Win2K/WinXP(WHQL).</i></li><li><i>FIR driver 1.150 for Win98(WHQL)/Win98SE(WHQL). FIR driver 1.141 for WinME(WHQL)
FIR driver 2.01 for Win2K(WHQL)/WinXP(WHQL).</i></li><li><i>Audio M5451 WDM driver 5.12.01.5260 for Win98SE/WinME(WHQL)/Win2K(WHQL)/WinXP(WHQL).</i></li><li><i>Audio M5455 WDM driver 5.12.01.7006 for Win98SE/WinME/Win2K/WinXP(WHQL), 5.12.01.7005 for x64.
Audio M5455 WDM driver for Vista(tested on Vista beta Build 5320)</i></li><li><i>Memory Stick driver 1.32.1018 for Win98SE/WinME,and 1.32.1030 for Win2000/WinXP.</i></li><li><i>SD/MMC driver 1.10.1018 for Win98SE/WinME,and 1.10.1040 for Win2000/WinXP.</i></li><li><i>LAN driver 3.50 for Win98/Win98SE/WinME/Win2K(WHQL)/2003/WinXP(WHQL)/x64(WHQL).
LAN driver 3.51 for Vista(tested on Vista beta Build 5320)</i></li><li><i>USB 1.1 controller 1.03 for Win95 OSR2.1.</i></li><li><i>M7101 Patch 1.01 for Win95.</i></li><li><i>IRQ Miniport driver 0.1 for Windows95</i></li><li><i>USB 2.0 controller 1.76 for Win98SE/WinME/Win2K/2003/WinXP.</i></li><li><i>M5228 v 5.0.2.8 driver for NT4/98se/Me/2000/XP/2003/x64</i></li><li><i>M5281 v 5.0.2.8 driver for NT4/98se/Me v 5.0.2.9 for 2000/XP/2003/x64/Vista(tested on Vista beta Build 5320)</i></li><li><i>M5287 v 6.2.0.9 driver for 2000(WHQL)/2003/XP(WHQL)/x64(WHQL)/Vista(tested on Vista beta Build 5320)</i></li><li><i>M5288 v 6.2.1.8 driver for 2000(WHQL)/2003(WHQL)/XP(WHQL)/x64(WHQL)/Vista(tested on Vista beta Build 5320)</i></li><li><i>M5289 v 5.0.3.0 driver for NT4/98se/Me/2000(WHQL)/XP(WHQL)/2003/x64(WHQL)/Vista(tested on Vista beta Build 5320)</i></li><li><i>M5461 v 5.0.1.0 (MS Inbox/function) driver for 2000_sp4 /XP/2003</i></li></ol>
Gegenüber dem letzten Treiberpaket in der Version 2.13 hat sich folgendes geändert
<i><b>Change List v2.20</b></i><ol><li><i>Update setup package to support Vista(tested on Vista beta Build 5320)</i></li><li><i>Update ULi M5288 v6.2.1.8 driver support for 2000/XP/2003/x64/Vista(tested on Vista beta Build 5320)</i></li><li><i>Update ULi Lan driver v3.51 driver for Vista(tested on Vista beta Build 5320).</i></li></ol>
<b>Download:</b><ul><li><a href="http://www.planet3dnow.de/cgi-bin/file/get.pl?20060324124825">ULi Integrated Driver 2.20 [Windows] (9,9 MB)</a></li><li><a href="http://www.planet3dnow.de/cgi-bin/file/get.pl?20060324125855">ULi Integrated Driver 2.20 [Windows] (9,9 MB) - Mirror</a></li></ul>
<b>Links zum Thema:</b><ul><li><a href="http://www.planet3dnow.de/cgi-bin/newspub/viewnews.cgi?category=1&id=1140561833">NVIDIA beendet Akquisition von ULi Electronics</a></li><li><a href="http://www.planet3dnow.de/cgi-bin/newspub/viewnews.cgi?category=1&id=1134556370">NVIDIA übernimmt ULi für 52 Mio. Dollar</a></li></ul>
Irgendwie klappt euer Link - ftp://www.uli.com.tw/driver/Integrated220.rar - nicht.
Der hier geht grad:
ftp://ftp.uli.com.tw/driver/Integrated220.rar.
Langsam, aber er geht.
thx, muss ein fehler beim erstellen des links gewesen sein. habs korrigiert, aber inzwischen taucht sporadisch eine login-aufforderung bei uli ftp-server auf. :]
der link geht auch, nur scheint der server überlastet zu sein, so dass es teilweise keine verbindung gibt. ich hab jetzt mal beide links genommen.
Hats jemand schon drauf und kann was dazu sagen?
Also unter der Vista Beta 2 stürzt der Installer leider ab. Wodurch sich die Treiber fürs LAN und Audio nicht installieren lassen. :/
Beide Links gehen bei mir nicht. Beim ersten wird nach LogIn Daten gefragt.
Schade, bräuchte dringend die Treiber für Vista Beta2 64Bit. Theoretisch müssten das die richtigen sein?
Link funzt jetzt, Treiber aber nicht... Vista 64.
Treiber entpacken und manuell installieren ?
Oder geht das bei Vista nicht mehr ?
Sowohl als auch... :(
Und manuell per Gerätemanager geht auch noch. :) ...wenn denn der Treiber gehen würde...
hat denn jetzt villt schon einer ne nützliche lösung gefunden... bei mir ist das selbe problem weil ich die 64 bit version von vista habe :( kann nicht ins i-net.
wäre dankbar wenn mir da jemand helfen könnte :)
Bei mir gehen die Treiber auch bei Vista x64 (Netzwerk nicht getestet, weil das bei mir ein Realtek chip extra aufm Board ist). Aber die anderen gehen ohne Probleme.
