Winamp 5.34 veröffentlicht
- Ersteller cruger
Die Entwickler von Nullsoft haben eine neue Version 5.34 des Media-Players Winamp zum Download bereitgestellt.
<blockquote><i><b>Whats new:</b></i><ul><li><i>New: IPv6 support</i></li><li><i>Improved: Made installer delete in_mp3pro :/</i></li><li><i>Improved: Embedded IE pages now run in a separate thread</i></li><li><i>Improved: General speed and performance optimizations</i></li><li><i>Improved: Various Media Library resize flicker fixes</i></li><li><i>Improved: GDI+ video rendering for Windows Vista</i></li><li><i>Improved: IPC_CONVERTFILE now uses api_decodefile (for ripping & transcoding)</i></li><li><i>Improved: [in_wave] Added ATF support for %bitrate%</i></li><li><i>Improved: [gen_ff] Better handling of invalid XML during skin load</i></li><li><i>Improved: [gen_jumpex] JTFE Unicode support</i></li><li><i>Improved: [ml_local] Composer / Album view (in Edit View, Filters tab)</i></li><li><i>Improved: [ml_local] Unicode drag&drop and send-to support</i></li><li><i>Improved: [ml_local] Added option for using Artist as Album Artist</i></li><li><i>Improved: [ml_local] Updated 'Field names' in Smart View query documentation</i></li><li><i>Improved: [ml_pmp] PMP Unicode support</i></li><li><i>Fixed: ? in the taskbar & system tray with Unicode titles (note that many third party plugins will cause this to revert back to ?)</i></li><li><i>Fixed: CD Burning on Windows Vista</i></li><li><i>Fixed: Classic skin scrollbar overlap display glitch with 'smooth resize' enabled</i></li><li><i>Fixed: Crash on exit with docked playlist toolbar (ml_local/ml_playlists bug)</i></li><li><i>Fixed: DirectDraw video rendering (non-overlay mode) constant redraw/flicker</i></li><li><i>Fixed: Folder locking bug after using Open Files/Folder dialog</i></li><li><i>Fixed: Installation of Sonic Engine on systems with other Sonic/Roxio products</i></li><li><i>Fixed: Installer resets cwd= to the install dir</i></li><li><i>Fixed: Redraw bug when moving external windows over Pledit</i></li><li><i>Fixed: Tab orders in Preferences</i></li><li><i>Fixed: Various media library accessibility/focus issues</i></li><li><i>Fixed: Video crash when using WinKey+L</i></li><li><i>Fixed: [enc_lame] Better output samplerate selection for transcoding</i></li><li><i>Fixed: [enc_wav] WAVs missing first 11 samples</i></li><li><i>Fixed: [gen_ff] Tooltips appear on primary monitor only</i></li><li><i>Fixed: [gen_jumpex] Stability issues and key reported plugin bugs</i></li><li><i>Fixed: [gen_ml] Keyboard focus issue</i></li><li><i>Fixed: [gen_ml] Node alignment bug</i></li><li><i>Fixed: [in_cdda] Long artist/albumartist CD Info bug</i></li><li><i>Fixed: [in_cdda] Crash on Winamp exit after playing Audio CD</i></li><li><i>Fixed: [in_cdda] CDDB crash-on-close bug</i></li><li><i>Fixed: [in_cdda] CD-Text adds to end of cddb fields instead of clearing first</i></li><li><i>Fixed: [in_dshow] Potential crash on corrupt/malformed media files</i></li><li><i>Fixed: [in_dshow] Crash scanning ml folders containing videos on a network drive</i></li><li><i>Fixed: [in_mod] .s3m and .it memory corruption bug</i></li><li><i>Fixed: [in_mp3] Memory leak when retrieving info for .aac files</i></li><li><i>Fixed: [in_mp3] .aac / out_wave playback glitches</i></li><li><i>Fixed: [in_vorbis] Album tag removed when using ml 'edit selected items'</i></li><li><i>Fixed: [in_wm] Crash when trying to burn WMA files</i></li><li><i>Fixed: [libsndfile] matlab (.mat) memory corruption bug</i></li><li><i>Fixed: [ml_local] Composer tag not saving with 'Edit Info'</i></li><li><i>Fixed: [ml_local] Total size not showing up in local media views</i></li><li><i>Fixed: [ml_local] Possible duplicate entries on upgrades after rescanning folders</i></li><li><i>Fixed: [ml_local] (No Album Artist) & (No Publisher) sometimes displays no results</i></li><li><i>Fixed: [ml_local] Sorting Album pane by Year</i></li><li><i>Fixed: [ml_local] isempty/isnotempty for querying empty/populated fields</i></li><li><i>Fixed: [ml_local] Search broken in simple views (Win2k-specific)</i></li><li><i>Fixed: [ml_playlists] Drag+Drop playlists to pmp devices broken</i></li><li><i>Fixed: [ml_pmp] Crash when deleting a group of songs containing non-sequential duplicates</i></li><li><i>Fixed: [ml_pmp] "haven't" typo in prefs :-D</i></li><li><i>Fixed: [ml_rg] ReplayGain analysis failing on mono mp3's</i></li><li><i>Fixed: [ml_rg] Now skips over DRM WMA files instead of applying -24601 dB gain</i></li><li><i>Fixed: [ml_transcode] Now prevents same source and destination filename</i></li><li><i>Fixed: [ml_wire] Crash when encountering certain non-xml feeds</i></li><li><i>Fixed: [pmp_ipod] Incompatibility with iTunes 7.1</i></li><li><i>Fixed: [pmp_p4s] Launching Winamp on device insertion not working</i></li><li><i>Fixed: [pmp_p4s] No longer creates .alb files on devices that don't support it</i></li><li><i>Updated: in_vorbis to libvorbis 1.1.2 and libogg 1.1.3</i></li><li><i>Updated: in_flac 2.0 (based on FLAC 1.1.4)</i></li><li><i>Updated: MusicIP Mix (formerly Predixis MusicMagic) v1.1</i></li><li><i>Updated: Sonic Ripping/Burning Engine v3.6.36.500</i></li><li><i>Updated: [gen_jumpex] Jump To File Extra v0.99.1a</i></li></ul></blockquote>
<b>Download:</b><ul><li><img src="/images/englisch.gif" border="1" height="10" width="15"> <a href="http://www.planet3dnow.de/cgi-bin/file/get.pl?20070423221349">Winamp 5.34 Full (6,4 MB)</a></li><li><img src="/images/englisch.gif" border="1" height="10" width="15"> <a href="http://www.planet3dnow.de/cgi-bin/file/get.pl?20070423221350">Winamp 5.34 Pro (6,2 MB)</a></li><li><img src="/images/englisch.gif" border="1" height="10" width="15"> <a href="http://www.planet3dnow.de/cgi-bin/file/get.pl?20070423221351">Winamp 5.34 lite (1,4 MB)</a></li></ul>
<b>Links zum Thema:</b><ul><li><a href="http://www.winamp.com/player/version_history.php" target="b">Winamp Versions History</a></li></ul>
Kommando
- Laptop: Clevo P751ZM (15,6")
- Intel® Core™ i5 4690K @ 4 GHz @ 1 V
- 2x8 GB Hyper X Impact @ 2200-10-11-11-1T
- nVidia GeForce GTX 970M 6 GB @ 1238/3130 MHz
- Dell 2709W (27", 1920x1200)
- Samsung SSD 830 (512 GB)
- 230W
- Windows 10 Professional (64 bit)
- Razer Orochi
Immer wieder interessant was bei einem vermeintlich einfachen Programm, das eine solche lange Zeit auf dem Markt ist noch alles gefixt werden muss. Ist ja ne ordentliche Liste...
sieht so aus.Die Version ohne eMusic ist nun definitiv tot oder seh ich das falsch?
allerdings sollte es nun imho kein problem sein, bei der installation vor emusic den haken wegzuklicken
psychocyberdisc
- Mystery Lake
- OMEN by HP Laptop 16-c0xxx
- 230 Watt
▼50 Mbit/s
▲25 Mbit/s
Sie ist nicht tot. Einfach immer die Pro-Version herunterladen. Ohne Registrierung und ohne Eingabe eines Produktschlüssels verhält sie sich dann wie die Full-Version - aber ohne den eMusic-Müll.
Neben der Pro-Version kommt auch die Lite-Version ohne den eMusic-Müll aus. Allerdings ist der Funktionsumfang der Lite-Version wohl vielen Nutzern zu gering.
Daher sollte man in diesem Fall auf oben beschriebene Weise die Pro-Version nutzen.
