Download AMD Radeon Software Crimson ReLive Edition 17.11.1 WHQL verfügbar.
- Ersteller eratte
User-News
Von eratte
Hinweis: Diese "User-News" wurde nicht von der Planet 3DNow! Redaktion veröffentlicht, sondern vom oben genannten Leser, der persönlich für den hier veröffentlichten Inhalt haftet.Release Notes & Download
Filename z.B.: whql-win10-64bit-radeon-software-crimson-relive-17.11.1-nov10.exe
Radeon Software Crimson ReLive Edition 17.11.1 Highlights
Support For
Call of Duty®: WWII
Up to 5% faster performance on Radeon™ RX Vega64 (8GB) graphics than with Radeon Software Crimson ReLive Edition 17.10.3 at 2560x1440. (1)
AMD XConnect™ Technology
Now supported on Radeon RX Vega56 series graphics products for select eGPU enclosures.
Fixed Issues
Radeon Software may intermittently cause an application crash on limited numbers of DirectX®11 or OpenGL applications on their first run.
Some gaming or productivity applications may experience a random hang or application crash when performing task switching.
Radeon WattMan reset and restore factory default options may not reset graphics or memory clocks.
Oculus™ Dash may experience a random application hang.
Bezel compensation in mixed mode Eyefinity cannot be applied.
Radeon Settings may experience overlapping text or corruption in the Multi GPU profiles page.
Tom Clancy's Ghost Recon®: Wildlands may experience minor corruption with Anisotropic Filtering (AF) enabled.
Middle-earth™: Shadow of War™ may experience ghosting or distortion in gameplay on Multi GPU enabled system configurations.
AMD XConnect™ Technology products may not be detected/enabled on reconnection if previously disconnected during system sleep
A limited number of system devices such as printers may be removed during Radeon Software uninstallation.
Known Issues
Some desktop productivity apps may experience latency when dragging or moving windows.
Tom Clancy's Rainbow Six® Siege may experience an application hang when breaching walls with grenades or explosives.
Rise of the Tomb Raider™ may experience an intermittent application hang during gameplay.
A random system hang may be experienced after extended periods of use on system configurations using 12 GPU’s for compute workloads.
The GPU Workload feature may cause a system hang when switching to Compute while AMD CrossFire is enabled. A workaround is to disable AMD CrossFire before switching the toggle to Compute workloads.
Resizing the Radeon Settings window may cause the user interface to stutter or exhibit corruption temporarily.
Unstable Radeon WattMan profiles may not be restored to default after a system hang.
OverWatch™ may experience a random or intermittent hang on some system configurations. Disabling Radeon ReLive as a temporary workaround may resolve the issue.
Footnotes
Testing conducted by AMD Performance Labs as of November 1st, 2017 on the 8GB Radeon RX Vega64, on a test system comprising of Intel i7 7700X CPU (4.2 GHz), 16GB DDR4-3000 Mhz system memory, and Windows 10 x64 using the game Call of Duty®: WWII on the highest game presets. PC manufacturers may vary configurations, yielding different results. At 2560x1440, the Radeon RX Vega64 scored 120.6 FPS with Radeon Software 17.10.3 whereas the Radeon RX Vega64 scored 129.6 FPS with Radeon Software 17.11.1. Performance may vary based on use of latest drivers.(1)
Package Contents
The Radeon Software Crimson ReLive Edition 17.11.1 installation package contains the following:
Radeon Software Crimson ReLive Edition 17.11.1 Driver Version 17.40.1031 (Windows Driver Store Version 23.20.788.1
Radeon Product Compatibility
Radeon Software Crimson ReLive Edition 17.11.1 is compatible with the following AMD Radeon products.
Note: AMD Radeon™ R9 Fury, Radeon™ Pro Duo and Radeon™ RX 400 Series are only supported by Radeon Software Crimson ReLive Edition on Windows 7/10 64-bit. AMD Radeon™ RX 500 Series graphics are only supported by Radeon Software Crimson ReLive Edition on Windows 7/10 64-bit.
Radeon Desktop Product Family Compatibility
Radeon RX Vega Series Graphics
Radeon™ RX 400 Series Graphics
Radeon™ RX 500 Series Graphics
AMD Radeon™ Pro Duo
AMD Radeon™ R7 300 Series Graphics
AMD Radeon™ R7 200 Series Graphics
AMD Radeon™ R9 Fury Series Graphics
AMD Radeon™ R5 300 Series Graphics
AMD Radeon™ R9 Nano Series Graphics
AMD Radeon™ R5 200 Series Graphics
AMD Radeon™ R9 300 Series Graphics
AMD Radeon™ R9 200 Series Graphics
AMD Radeon™ HD 7700 - HD 7900 Series Graphics
AMD Radeon™ HD 8500 - HD 8900 Series Graphics
Mobility Radeon™ Family Compatibility
Radeon Software Crimson ReLive Edition 17.11.1 is a notebook reference graphics driver with limited support for system vendor specific features.
Radeon Mobility Product Family Compatibility
AMD Radeon™ R9 M300 Series Graphics
AMD Radeon™ R7 M200 Series Graphics
AMD Radeon™ R7 M300 Series Graphics
AMD Radeon™ R5 M200 Series Graphics
AMD Radeon™ R5 M300 Series Graphics
AMD Radeon™ R9 M200 Series Graphics
AMD Radeon™ HD 7700M - HD 7900M Series Graphics
AMD Radeon™ HD 8500M - HD 8900M Series Graphics
AMD APU Product Family Compatibility
AMD APU products are only supported by AMD Radeon Software Crimson ReLive Edition on Windows® 7 (32 & 64-bit) and Windows® 10 (32 & 64-bit).
AMD A-Series APUs with Radeon™ R4, R5, R6, or R7 Graphics
AMD A-Series APUs with Radeon™ R3, R4, R5, R6, R7, or R8 Graphics
AMD Pro A-Series APUs with Radeon™ R5 or R7 Graphics
AMD Pro A-Series APUs with Radeon™ R5, R6, or R7 Graphics
AMD Athlon™ Series APUs with Radeon™ R3 Graphics
AMD FX-Series APUs with Radeon™ R7 Graphics
AMD Sempron™ Series APUs with Radeon™ R3 Graphics
AMD E-Series APUs with Radeon™ R2 Graphics
AMD Radeon™ HD 8180 - HD 8400 Series Graphics
Compatible Operating Systems
Radeon Software Crimson ReLive Edition 17.11.1 is designed to support the following Microsoft® Windows® platforms. Operating System support may vary depending on your specific AMD Radeon product.
Windows® 10 (32 & 64-bit version)
Windows 7 (32 & 64-bit version with SP1 or higher)
Hurra mit APU Unterstützung.
Support For
Call of Duty®: WWII
Fixed Issues
Known Issues
Footnotes
Package Contents
AMD Radeon™ Pro Duo
E555user
gefühlt jeden Tag ein neues Treiber-Release von RTG. Ich warte mal ab und installiere nur wenn ein akutes Problem behoben würde... Ich bin gespannt was mit dem nächsten Major Release an neuen Funktionen hinzukommen soll...
Ja die Windowstreiber fliegen tief im Moment, aber nicht nur bei AMD. Liegt auch an den erschienen Spielen. Wer keine Probleme hat und keins er neuen Spiele kann das ja in Ruhe aussitzen. Für APU Besitzer ist das aber endlich ein neuer Treiber für Windows 7 und 10 (abseits des Betatreibers für 1709).
War noch gar nicht aufgefallen, der Brother HL-1250 Netzwerkdrucker war weg beim 2. Rechner. Hatte beim Update auf 17.10.3 Neuinstallation ausgewählt.
Schattenreich
- Landkreis Osterholz
- Haupt PC
- 32GB@6000MHz CL32
- AMD hybrid
- Philips 4k
- Segate 2TB Backus
- bluray ext
- Schneider
- BQ Pure Power 650 Watt
- Cherry DW 3000
- Cherry DW 3000
- Firefox immer aktuell
- ▼50 M/bs ▲10 M/bs
@BloodAngle
Was genau fehlt dir denn, ich sehe auf den ersten Blick kein Problem, mangels Vergleich wie es bei dir aussehen soll.
Bei mir sieht es mit 17.10.3beta so aus: http://abload.de/img/bf1_2017_11_05_13_09_fousb.jpg
Schattenreich
- Haupt PC
- 32GB@6000MHz CL32
- AMD hybrid
- Philips 4k
- Segate 2TB Backus
- bluray ext
- Schneider
- Cherry DW 3000
- Cherry DW 3000
- ▼50 M/bs ▲10 M/bs
ok, das sieht schon "kaputter" aus als die Bilder davor, die wirkten eher Steril.
Sind deine in Game Einstellungen alle Korrekt?
Wenn ja evt. mal mit dem DDU die Treiber Reste entfernen lassen. (Wegen Shader Cache Ordner)
Windows 1703 oder 1709 ? (RedStone 2 & 3)
Schattenreich
- Haupt PC
- 32GB@6000MHz CL32
- AMD hybrid
- Philips 4k
- Segate 2TB Backus
- bluray ext
- Schneider
- Cherry DW 3000
- Cherry DW 3000
- ▼50 M/bs ▲10 M/bs
habe Windows neu Installiert und dann die Version 17.10 - 17.11 durch probiert das selbe ergebenes der Treiber von Juli leüft
1. Windows 10 mit 64Bit?habe Windows neu Installiert und dann die Version 17.10 - 17.11 durch probiert das selbe ergebenes der Treiber von Juli leüft
2. Alle updates installiert
3. Spiele neu installiert? (DirectX, .net und redistri aktuell ?)
Schattenreich
- Haupt PC
- 32GB@6000MHz CL32
- AMD hybrid
- Philips 4k
- Segate 2TB Backus
- bluray ext
- Schneider
- Cherry DW 3000
- Cherry DW 3000
- ▼50 M/bs ▲10 M/bs
1 win10 64 bit das aktuellste
2 ja habe ich
3 ja habe ich
2 ja habe ich
3 ja habe ich
1. ok
2. Welche Build Version genau?
3. inGame Einstellung "VRAM Begrenzung" an?
Schattenreich
- Haupt PC
- 32GB@6000MHz CL32
- AMD hybrid
- Philips 4k
- Segate 2TB Backus
- bluray ext
- Schneider
- Cherry DW 3000
- Cherry DW 3000
- ▼50 M/bs ▲10 M/bs
2: Steige da nicht mehr durch aber das neuste was jetzt raus Kamm und mit der alten Version war das selbe Problem.
3: VRAM Begrenzung ist an
4: vsync on oder off bringt keine Besserung
Rotzlöffel
- Brandenburg
- Acer Swift 3 Ryzen 5 2500U, Lenovo Ideapad 5
- AMD Ryzen 7 5800X3D
- MSI MPG X570 Gaming Plus
- EKL Alpenföhn Ben Nevis Advanced
- G.Skill RipJaws V F4-3200C14D-16GVR@3200 14-14-14-28-42 4x8GB
- MSI RX 6800 undervolted
- AOC AG322QCX
- Samsung 850 EVO 500GB SATA, Crucial MX500 2TB SATA, Lexar NM790 4TB PCIe
- Hitachi Deskstar 7K3000 2TB
- onboard Realtek
- Blue Thunder :o
- Thermaltake ToughPower Grand RGB Gold Sync Edition 650W omg
- lenovo
- Logitech MX518
- Windows 10 64-Bit
- ▼100 MBit ▲40 MBit
Wenn deine Karte immernoch gemodded (inklusive Übertaktung) ist, liegts vielleicht daran? (480->580) ?
Schattenreich
- Haupt PC
- 32GB@6000MHz CL32
- AMD hybrid
- Philips 4k
- Segate 2TB Backus
- bluray ext
- Schneider
- Cherry DW 3000
- Cherry DW 3000
- ▼50 M/bs ▲10 M/bs
metro beide teile bei steam leüft bf1942 bf 3 bf 4 titanfal1-2 dedadspache 1-3 leüft
ja ist eine von rx 470 zu rx 570
2. Rechtsklick auf das Start-Symbol und dort "System" im drop-down auswählen "Info":2: Steige da nicht mehr durch aber das neuste was jetzt raus Kamm und mit der alten Version war das selbe Problem.
3. Mach es mal aus, hast doch mindestens 4GByte?
4. ok
5. DDU schon mal probiert?
Schattenreich
- Haupt PC
- 32GB@6000MHz CL32
- AMD hybrid
- Philips 4k
- Segate 2TB Backus
- bluray ext
- Schneider
- Cherry DW 3000
- Cherry DW 3000
- ▼50 M/bs ▲10 M/bs
2: 1709 davor 1703
3: OK ja habe 8GB RAM verbaut zu zeit
5: Nein werde ich gleich testen
2: Aha, das könnte ein Unterschied machen was die Treiber Version angeht. Radeon Einstellungen -> System -> Software (Versionen)2: 1709 davor 1703
3: ist bei mir auch an, geht nicht über 2800MByte VRAM hinaus: http://abload.de/img/bf1_2017_11_05_16_01_josac.jpg
5. Geb bescheid wenn du Unterstützung brauchst
6. Wenn die Taktrate beim 570 Bios höher ist, nimm sie auch mal auf 470 Level herunter mit Wattmann oder MSI AB.
PC_^_^
Hallo
@Blutengel
Die fehlerhafte Darstellung von Umgebungsobjekten habe ich gestern erstmalig auch bemerkt. Bei mir betrifft es zur Zeit nur die Map
Festung von FAW. Auf der Karte wurden in der Umgebung vom Checkpoint D (Conquest) bei einigen Steinen nur der Rand gezeichnet
und der eigentliche Körper war durchsichtig man konnte direkt durchsehen. Auf andere Karten einschließlich der DLC´s habe ich noch
keine derartigen Veränderung wahrgenommen. Ob der Fehler sich wiederholt wenn die Karte neu geladen wird den Umstand werde ich
heute mal überprüfen. Radeon Software Crimson 17.10.1 (Beta) ist im Einsatz.
@Blutengel
Wer hat den den Start Bildschirm verbrochen?
http://abload.de/img/bf1_2017_11_05_15_37_svj4k.jpg
Gleich mal Melden:
http://abload.de/img/bf1_2017_11_05_12_51_34kvz.jpg
Auf dem Pferd oder als Taube, ganz schön was los auf dem Feld.
Schattenreich
- Haupt PC
- 32GB@6000MHz CL32
- AMD hybrid
- Philips 4k
- Segate 2TB Backus
- bluray ext
- Schneider
- Cherry DW 3000
- Cherry DW 3000
- ▼50 M/bs ▲10 M/bs
Hallo
@Blutengel
wie gesagt ich habe es auf allen Karten kein fussboden oder heüser
Treiber via Windows deaktiviert und DDU drüber laufen lassen Test weiße GPU Beschränkung Aus und tackt raten der GPU um 100MHZ gesengt das ergebenes
bracht leider nichts
Mein Kumpel Im ts sagte zu mir schalte mal den 2 Monitor im Treiber ab
das scheint zu klappen
PC_^_^
Hi
Ich habe die Karte Festung von FAW nochmal angespielt diesmal ohne Umgebungsfehler. Um die Situation zu verschärfen mit etwas höherem GPU Takt
von 1100 Mhz mit einer Fury Grafikkarte. Der Fehler gestern war scheinbar Zufall. Ganz ausschließen lässt sich so ein Effekt aber nicht
zumindest wenn nicht gleich die ganze untere Hälfte der Karte fehlt wie bei dir im Bild . Die dual Monitorkonfiguration könnte evtl. zu Fehlern
führen das kann stimmen. Eine dual Monitorkonfiguration ist bei mir auch im Betrieb. Im Spiel ist der zweite Monitor aber meist aus. Was Spiele
beftrifft nutze ich den zweiten Monior nur im Nachgang zum auslesen der Systemressourcen. In den Battlefield 1 Optionen gibt es unter den
Grafikeinstellung die Möglichkeit Randlos anzuwählen welche den Hauptmonitor vom zweiten Monitor entkoppelt. Sofern du keine Anzeigegruppe
mit AMD-Eyefinity erstellt hast müsster der zweite Monitor unter normalen Einstellungen auf schwarz schalten sobald der Hauptmonitor in den
Vollbildmodus wechselt.
Schattenreich
- Haupt PC
- 32GB@6000MHz CL32
- AMD hybrid
- Philips 4k
- Segate 2TB Backus
- bluray ext
- Schneider
- Cherry DW 3000
- Cherry DW 3000
- ▼50 M/bs ▲10 M/bs
ok teste auch mal wie gesagt bei BF4 Gib keine Probleme mit dual Monitor.
wie gesagt leüft es auch mit dem letzten offiziell whql Treiber 17.2.
PC_^_^
@Blutengel
Im Bild ist die Option Randlos markiert welche den zweiten Monitor freigeben sollte.
Mit der Radeon Software Crimson 17.7.2 WHQL bist du sicher zur Zeit am besten unterwegs denn die Tests nach
Vorgaben von Microsoft oder durch Microsoft selbst zur WHQL Zertifizierung decken solche fatalen Fehler auf und
es muss nachgebessert werden bis der Treiber einen bestimmten Maßstab erreicht. Die Version 17.10.1 Beta ist
bei mir weitgehend ohne Inkonsistenzen wenn der GPU / Memory Takt nicht zu hohe Werte annimmt.
Die GPU´s sind meist schon sehr gut optimiert und die Taktraten anheben macht teilweise nur bei Benchmarks Sinn für etwas mehr Punkte .
Ein Frame-Target zu setzen oder z.B. das Anti-Aliasing mal zu wechseln kann da schon für eine bessere Performance sorgen.
Anhang anzeigen 36382 Anhang anzeigen 36383 Anhang anzeigen 36384
Evt. musst du Eyefinity neu Einrichten in den Radeon Einstellungen.Mein Kumpel Im ts sagte zu mir schalte mal den 2 Monitor im Treiber ab
[/url]
Die inGame Einstellungen sowie die Radeon Einstellungen sind sich da nicht immer einig.
Unterschiedliche Auflösungen sind noch ok, wenn die Hz Synchron laufen.
Eyefinity hat bei mir nur Monitor schwächen gezeigt, der TV lieferte immer ein Top Bild auch bei der Moment Aufnahme.
psychocyberdisc
- Mystery Lake
- OMEN by HP Laptop 16-c0xxx
- 230 Watt
▼50 Mbit/s
▲25 Mbit/s
Seit Tagen kann man bei AMD keine Treiber mehr herunterladen: "Sorry, something went wrong."
Ist das bei anderen auch so?
