ASUS ROG Crosshair X670E Gene/Hero/Extreme & ProArt X670E-Creator WIFI (AM5 Mainboard mit X670E Chipsatz, DDR5, PCIe 5.0)
- Ersteller eratte
1101 ist nun kein BETA mehr, links sind die Selben und change.log ebenso.
Post 1 angepasst.
Post 1 angepasst.
ROG CROSSHAIR/STRIX/PROART X670E Series Beta Bios 1202 (safedisk@overclock.net)
Weiterhin AGESA 1.0.0.6 - auch für Strix und ProArt.
1) Update EC FW 0236
2) Improve System Performance.
Und schon gibt es 1202 auch offiziell bei ASUS:
ROG-CROSSHAIR-X670E-GENE-ASUS-1202.zip
ROG-CROSSHAIR-X670E-HERO-ASUS-1202.zip
ROG-CROSSHAIR-X670E-EXTREME-ASUS-1202.zip
Man achte auf die neuen CPU Beschreibungen
ROG CROSSHAIR X670E GENE BIOS 1202 Version 1202 9.42 MB 2023/04/21
1.Update AGESA version to ComboAM5PI 1.0.0.6
2.TPM 2.0 security update
3.Recommended for optimum performance with AMD Ryzen™ 7000X7D series processors
Before running the USB BIOS Flashback tool, please rename the BIOS file (CX670EG.CAP) using BIOSRenamer.
ROG CROSSHAIR X670E HERO BIOS 1202 Version 1202 9.43 MB 2023/04/21
3.Recommended for optimum performance with AMD Ryzen™ 7000X6D series processors
Before running the USB BIOS Flashback tool, please rename the BIOS file (CX670EH.CAP) using BIOSRenamer.
ROG CROSSHAIR X670E EXTREME BIOS 1202 Version 1202 9.54 MB 2023/04/21
3.Recommended for optimum performance with AMD Ryzen™ 7000X8D series processors
Before running the USB BIOS Flashback tool, please rename the BIOS file (CX670EE.CAP) using BIOSRenamer.
Möglichst das neuste BIOS (1302 oder höher) verwenden, gerade mir X3D CPU:
Doch mehr Fälle: Zu hohe Spannungen für Ryzen-7000-Prozessoren (HardwareLUXX)
The EFI updates posted on Friday contain some dedicated thermal monitoring mechanisms we've implemented to help protect the boards and CPUs. We removed older BIOSes for that reason and also because manual core control was available on previous builds. We're also working with AMD on defining new rules for AMD Expo and SoC voltage. We'll issue new updates for that ASAP.
- Rajinder Gill, ASUS-Mitarbeiter gegenüber der8auer
ROG-CROSSHAIR-X670E-HERO-ASUS-1302.zip
Liegt auf dem orginal Downloadserver von ASUS, auf Webseite noch nicht gelistet.
Quelle: AM5 AGESA/UEFI/BIOS Table - Ryzen SMU Table (AM5/AM4) - danach weiterhin AGESA 1.0.0.6
Info dazu was ich gefunden habe:
D.h. auch Besitzer von Strix, ProArt etc sollten danach Ausschau halten.
URL ausprobiert, klappt:
ROG-CROSSHAIR-X670E-EXTREME-ASUS-1302.zip
BIOS 1302 eingespielt und Einstellungen soweit hergestellt und dann mal auf die Spannungen im BIOS geschaut.
BIOS 1202 EXPO1 aktiv (2 x 16 GB DDR5 6000 CL32...)
BIOS 1302 Speicher auf AUTO (2 x 16 GB DDR5 4800 CL40...)
BIOS 1302 EXPO1 aktiv (2 x 16 GB DDR5 6000 CL32...)
Sehe da keine Änderung zwischen 1202 und 1302 bei mir mit einem 7950X
PS.: EXPO II sieht auch nicht anders aus.
"Asus hat jetzt mit der BIOS-Version 1302 für das Asus ROG Crosshair X670E Hero und andere AM5-Mainboards reagiert und begrenzt die SoC-Spannung ("VSoC") auf maximal 1,3 Volt um die CPU und das Mainboards nicht zu beschädigen."
Von der zentralen Webseite:
ROG CROSSHAIR X670E HERO BIOS 1302 Version 1302 Beta Version 9.43 MB 2023/04/25
SoC voltage for Ryzen 7000X3D series limited to a maximum of 1.30V to protect the CPU and motherboard.
Please note that this is a beta BIOS version of the motherboard which is still undergoing final testing before its official release. The UEFI, its firmware and all content found on it are provided on an “as is” and “as available” basis. ASUS does not give any warranties, whether express or limited, as to the suitability, compatibility, or usability of the UEFI, its firmware or any of its content. Except as provided in the Product warranty and to the maximum extent permitted by law, ASUS is not responsible for direct, special, incidental or consequential damages resulting from using this beta BIOS.
Das 1302 BETA ist nun auch auf der ASUS Webseite gelistet, change.log bei allen 3 identisch.
Habe nun auf 2 x 32 aufgerüstet anstatt auf 4 x16 siehe:
läuft bisher ohne Fehler. Spannungen für CPU/SOC nach laden von EXPO sind identisch zu 2 x 32GB.
Ryzen DDR5 RAM - Sammelthread
Intel habe ich hier nicht. Hoffe mit offizieller Firmware / nächstem Agesa laufen die ohne Probleme.
forum.planet3dnow.de
ASUS X670E/B650 Series NEW BIOS Update (safedisk@overclock.net)
TEST/BETA BIOS 1303 - verhindert wohl das man per Ryzen Master seinen X3D "grillt"
1) Improve System Performance - limit Ryzen master SOC upper limit to 1.3v for X3D.
ROG CROSSHAIR X670E HERO Bios 1303
ROG-CROSSHAIR-X670E-HERO-ASUS-1303.7z
drive.google.com
ROG CROSSHAIR X670E GENE Bios 1303
ROG-CROSSHAIR-X670E-GENE-ASUS-1303.7z
drive.google.com
ROG CROSSHAIR X670E EXTREME Bios 1303
ROG-CROSSHAIR-X670E-EXTREME-ASUS-1303.7z
drive.google.com
ROG STRIX X670E-A GAMING WIFI Bios 1303
ROG-STRIX-X670E-A-GAMING-WIFI-ASUS-1303.7z
drive.google.com
ROG STRIX X670E-E GAMING WIFI Bios 1303
ROG-STRIX-X670E-E-GAMING-WIFI-ASUS-1303.7z
drive.google.com
ROG STRIX X670E-F GAMING WIFI Bios 1303
ROG-STRIX-X670E-F-GAMING-WIFI-ASUS-1303.7z
drive.google.com
ROG STRIX X670E-I GAMING WIFI Bios 1413
ROG-STRIX-X670E-I-GAMING-WIFI-ASUS-1413.7z
drive.google.com
TUF GAMING X670E-PLUS Bios 1413
TUF-GAMING-X670E-PLUS-ASUS-1413.7z
drive.google.com
TUF GAMING X670E-PLUS WIFI Bios 1413
TUF-GAMING-X670E-PLUS-WIFI-ASUS-1413.7z
drive.google.com
PROART X670E CREATOR WIFI Bios 1303
ProArt-X670E-CREATOR-WIFI-ASUS-1303.7z
drive.google.com
ROG STRIX B650-A GAMING WIFI Bios 1413
ROG-STRIX-B650-A-GAMING-WIFI-ASUS-1413.7z
drive.google.com
ROG STRIX B650E-E GAMING WIFI Bios 1413
ROG-STRIX-B650E-E-GAMING-WIFI-ASUS-1413.7z
drive.google.com
ROG STRIX B650E-F GAMING WIFI Bios 1413
ROG-STRIX-B650E-F-GAMING-WIFI-ASUS-1413.7z
drive.google.com
ROG STRIX B650E-I GAMING WIFI Bios 1413
ROG-STRIX-B650E-I-GAMING-WIFI-ASUS-1413.7z
drive.google.com
TUF GAMING B650M-PLUS Bios 1413
TUF-GAMING-B650M-PLUS-ASUS-1413.7z
drive.google.com
TUF GAMING B650M-PLUS WIFI Bios 1424
TUF-GAMING-B650M-PLUS-WIFI-ASUS-1424.7z
drive.google.com
PROART B650-CREATOR Bios 1303
ProArt-B650-CREATOR-ASUS-1303.7z
drive.google.com
Schlag auf Schlag:
ROG-CROSSHAIR-X670E-GENE-ASUS-1303.zip
ROG-CROSSHAIR-X670E-HERO-ASUS-1303.zip
ROG-CROSSHAIR-X670E-EXTREME-ASUS-1303.zip
ROG CROSSHAIR X670E GENE BIOS 1303 Version 1303 9.42 MB 2023/04/27
ROG CROSSHAIR X670E HERO BIOS 1303 Version 1303 9.43 MB 2023/04/27
ROG CROSSHAIR X670E EXTREME BIOS 1303 Version 1303 9.54 MB 2023/04/27
1303 installiert, VSOC etc wird wie im change.log beschrieben wenn nur bei X3D begrenzt. Nach aktivieren EXPO wird bei mir mit dem 7950x weiterhin 1,341 angelegt (siehe auch Screenshot weiter oben). Habe das nun manuell auf 1,3 begrenzt - das läuft bisher stabil ebenso wie die neuen 64 GB RAM (CB 23 und Prime 95 und 4 Stunden zocken).
Bootdauer ist annehmbar schnell, schalte ich den 2. Rechner gleichzeitig ein ist der allerdings einiges schneller.
Dann warte wir mal auf des neue BIOS mit dem neuen AGESA. Bei all dem Theater muss ich sagen das ich ingesamt ausser den 2 Stunden mit 4 Modulen keinen Ärger mit dem Rechner hatte.
Nicht zu fassen (laut SMU Table weiterhin AGEAS 1.0.0.6):
ROG-CROSSHAIR-X670E-GENE-ASUS-1401.zip
ROG-CROSSHAIR-X670E-HERO-ASUS-1401.zip
ROG-CROSSHAIR-X670E-EXTREME-ASUS-1401.zip
Alter
ASUS X670 Series NEW Beta BIOS (AGESA 1007 BETA) (safedisk@overclock.net)
Unter Links in Post 1 aufgenommen: SMU Table (Übersicht BIOS Version mit welchem AGESA)
ROG CROSSHAIR X670E GENE BIOS 1401 Version 1401 Beta Version 9.42 MB 2023/04/28
SoC voltage for Ryzen 7000 series limited to a maximum of 1.30V to protect the CPU and motherboard.
ROG CROSSHAIR X670E HERO BIOS 1401 Version 1401 Beta Version 9.43 MB 2023/04/28
ROG CROSSHAIR X670E EXTREME BIOS 1401 Version 1401 Beta Version 9.54 MB 2023/04/28
Alter
1) Update AGESA to ComboAM5 1007 BETA
ROG CROSSHAIR X670E HERO Beta Bios 1410
ROG-CROSSHAIR-X670E-HERO-ASUS-1410.7z
ROG CROSSHAIR X670E GENE Beta Bios 1410
ROG-CROSSHAIR-X670E-GENE-ASUS-1410.7z
ROG CROSSHAIR X670E EXTREME Beta Bios 1410
ROG-CROSSHAIR-X670E-EXTREME-ASUS-1410.7z
ROG STRIX X670E-A GAMING WIFI Beta Bios 1410
ROG-STRIX-X670E-A-GAMING-WIFI-ASUS-1410.7z
ROG STRIX X670E-E GAMING WIFI Beta Bios 1410
ROG-STRIX-X670E-E-GAMING-WIFI-ASUS-1410.7z
ROG STRIX X670E-F GAMING WIFI Beta Bios 1410
ROG-STRIX-X670E-F-GAMING-WIFI-ASUS-1410.7z
ROG STRIX X670E-I GAMING WIFI Beta Bios 1601
ROG-STRIX-X670E-I-GAMING-WIFI-ASUS-1601.7z
TUF GAMING X670E-PLUS Beta Bios 1601
TUF-GAMING-X670E-PLUS-ASUS-1601.7z
TUF GAMING X670E-PLUS WIFI Beta Bios 1601
TUF-GAMING-X670E-PLUS-WIFI-ASUS-1601.7z
PROART X670E CREATOR WIFI Beta Bios 1410
ProArt-X670E-CREATOR-WIFI-ASUS-1410.7z
PRIME X670-P Beta Bios 1601
PRIME-X670-P-ASUS-1601.7z
PRIME X670-P WIFI Beta Bios 1601
PRIME-X670-P-WIFI-ASUS-1601.7z
PRIME X670E-PRO WIFI Beta Bios 1601
PRIME-X670E-PRO-WIFI-ASUS-1601.7z
So mutig das 2. BIOS an einem Tag eingespielt (das auch mal was Neues):
Speicher auf AUTO - alles wie gehabt:
Speicher mit EXPO II und VSOC knapp unter 1,3 anstatt vorher auf 1,341, CPU VDDIO Voltage habe ich auch nachher manuell gesenkt auf 1,3v
es gibt jetzt auch einen Warnhinweis nach dem BIOS Flash:
Nun auch bei ASUS auf der Webseite/Downloadserver direkt incl. Support für 24/48GB Module, Post 1 angepasst.
ROG-CROSSHAIR-X670E-GENE-ASUS-1410.zip
ROG-CROSSHAIR-X670E-HERO-ASUS-1410.zip
ROG-CROSSHAIR-X670E-EXTREME-ASUS-1410.zip
ROG CROSSHAIR X670E GENE BIOS 1410 Version 1410 Beta Version 9.45 MB 2023/05/02
"1. Update AGESA version to Combo AM5 PI 1.0.0.7.
2. Support 48/24GB high-density DDR5 memory module.
3. SoC voltage for Ryzen 7000 series limited to a maximum of 1.30V to protect the CPU and motherboard.
ROG CROSSHAIR X670E HERO BIOS 1410 Version 1410 Beta Version 9.46 MB 2023/05/02
ROG CROSSHAIR X670E EXTREME BIOS 1410 Version 1410 Beta Version 9.57 MB 2023/05/02
TESTBIOS 1412
ASUS X670 Series NEW Beta BIOS (AGESA 1007a) (safedisck@overcolckers.net)
Mit BIOS 1412 bleibt VSOC nun auf Auto bei 1,24v - wie es bei dem BIOS 0802 schon mal war wenn man EXPO geladen hat. Warum das zischen zeitlich mal so ausgeartet ist wird mal wohl nicht erfahren.
1) Update AGESA to ComboAM5 PI1007a
If the BIOS version is different, the .cmo file of the previous BIOS cannot be used (bsod problem)
so need new setting
ROG CROSSHAIR X670E HERO Beta Bios 1412
ROG-CROSSHAIR-X670E-HERO-ASUS-1412.7z
drive.google.com
ROG CROSSHAIR X670E GENE Beta Bios 1412
ROG-CROSSHAIR-X670E-GENE-ASUS-1412.7z
drive.google.com
ROG CROSSHAIR X670E EXTREME Beta Bios 1412
ROG-CROSSHAIR-X670E-EXTREME-ASUS-1412.7z
drive.google.com
ROG STRIX X670E-A GAMING WIFI Beta Bios 1412
ROG-STRIX-X670E-A-GAMING-WIFI-ASUS-1412.7z
drive.google.com
ROG STRIX X670E-E GAMING WIFI Beta Bios 1412
ROG-STRIX-X670E-E-GAMING-WIFI-ASUS-1412.7z
drive.google.com
ROG STRIX X670E-F GAMING WIFI Beta Bios 1412
ROG-STRIX-X670E-F-GAMING-WIFI-ASUS-1412.7z
drive.google.com
ROG STRIX X670E-I GAMING WIFI Beta Bios 1610
ROG-STRIX-X670E-I-GAMING-WIFI-ASUS-1610.7z
drive.google.com
TUF GAMING X670E-PLUS Beta Bios 1610
TUF-GAMING-X670E-PLUS-ASUS-1610.7z
drive.google.com
TUF GAMING X670E-PLUS WIFI Beta Bios 1610
TUF-GAMING-X670E-PLUS-WIFI-ASUS-1610.7z
drive.google.com
PROART X670E CREATOR WIFI Beta Bios 1412
ProArt-X670E-CREATOR-WIFI-ASUS-1412.7z
drive.google.com
PRIME X670-P Beta Bios 1610
PRIME-X670-P-ASUS-1610.7z
drive.google.com
PRIME X670-P WIFI Beta Bios 1610
PRIME-X670-P-WIFI-ASUS-1610.7z
drive.google.com
PRIME X670E-PRO WIFI Beta Bios 1610
PRIME-X670E-PRO-WIFI-ASUS-1610.7z
drive.google.com
Neues BIOS auf ASUS Webseite, keine BETA.
Passend zu Asus Responds to AM5 BIOS Controversy: Warranty Covers Beta Fixes, EXPO Presets (tom's Hardware)
ROG-CROSSHAIR-X670E-GENE-ASUS-1415.zip
ROG-CROSSHAIR-X670E-HERO-ASUS-1415.zip
Mit 1415 bei mir mit EXPO II mit Auto auf 1.25v - laut mit loggen von HWINFO bleibt das auch so wenn Prime 95 das System auslastet.
Da gibt es andere Aussage zu im Netz, aber die gibt es auch zum MSI Mortar B650M - da liegen mit dem neusten BETA BIOS bei mir 1.304v bei der
VSOC an mit EXPO DDR5 6000. Dazu gibt es im Netz auch niedrigere Angaben.
Muss man wohl bei der eigenen Hardwarekonfig kucken was anliegt. Und bedenken das ggf das verwendete Tool es nicht richtig ausliest.
ROG CROSSHAIR X670E GENE BIOS 1415 Version 1415 9.45 MB 2023/05/16
"1. Update AGESA version to Combo AM5 PI 1.0.0.7.a
3. Memory QVL amended to account for AMD 1.3V SoC voltage limit.
4. EXPO/XMP prompt notice removed.
Before running the USB BIOS Flashback tool, please rename the BIOS file (CX670EG.CAP) using BIOSRenamer."
ROG CROSSHAIR X670E HERO BIOS 1415 Version 1415 9.46 MB 2023/05/16
Before running the USB BIOS Flashback tool, please rename the BIOS file (CX670EH.CAP) using BIOSRenamer."
Ich habe mir mal die QVL Speicherliste vom Hero bei ASUS angeschaut, fast alle Kits mit DDR5 6400 sind aus der überarbeiteten Liste verschwunden.
Cappuandy
- Lübeck
- ROGi
- MacBook Pro
- -none
- -none
- Gskill Trident-Z5 RGB Black
- -none
- LG 27" UHD60 HDR
- 980 Pro & T500
- - none -
- - none -
- ROG Hive - ALC4050
- Fractal Design Torrent Nano
- BeQuiet SP12 1W Platinum
- Razer Cynosa
- Razer Mamba
- Firefox | Safari@iPhone
- ▼schneller ▲schnell
, ja das ist aber schade. Ist bei meinem Strix I auch weg. Zumal da die Bios Version 1616 ist, vom 16.5.Ich habe mir mal die QVL Speicherliste vom Hero bei ASUS angeschaut, fast alle Kits mit DDR5 6400 sind aus der überarbeiteten Liste verschwunden.
Bei mir ist zwar noch ein älteres Bios drauf aber nun überleg ich ob das neue drauf mache..
Sind denn die ROG RAM Presets mit 6400 auch raus ?
Ich würde ja jedem empfehlen das aktuelle BIOS mit AGESA 1.0.0.7a einzuspielen. Auch wenn man dann ggf was geringfügig zurückdrehen müsste.
Eben mal geschaut, beim HERO sind sie wohl noch da (BIOS 1415):
Das die Module aus der OVL raus sind kann auch bedeuten das ASUS das nun erst mal neu Validieren muss.
Mein Kit mit 2 x 32 GB (F5-6000J3040G32GX2-TZ5NR) ist als einziges 2. x 32 GB KIT von G.Skill noch in der OVL. Macht auch keine Zicken.
ROG CROSSHAIR/STRIX X670E Series Beta Bios 1510 (safedisk@overclock.net)
1) Update to AGESA 1007a patch A
2) Update ROG logos for visual identity
3) Improve system performance
ROG CROSSHAIR X670E HERO Beta Bios 1510
ROG-CROSSHAIR-X670E-HERO-ASUS-1510.7z
drive.google.com
ROG CROSSHAIR X670E GENE Beta Bios 1510
ROG-CROSSHAIR-X670E-GENE-ASUS-1510.7z
drive.google.com
ROG CROSSHAIR X670E EXTREME Beta Bios 1510
ROG-CROSSHAIR-X670E-EXTREME-ASUS-1510.7z
drive.google.com
ROG STRIX X670E-A GAMING WIFI Beta Bios 1510
ROG-STRIX-X670E-A-GAMING-WIFI-ASUS-1510.7z
drive.google.com
ROG STRIX X670E-E GAMING WIFI Beta Bios 1510
ROG-STRIX-X670E-E-GAMING-WIFI-ASUS-1510.7z
drive.google.com
ROG STRIX X670E-F GAMING WIFI Beta Bios 1510
ROG-STRIX-X670E-F-GAMING-WIFI-ASUS-1510.7z
drive.google.com
ROG STRIX X670E-I GAMING WIFI Beta Bios (Maybe next week)
USB_Audio_FW_Update_Tool_PID19AC_PID1A98_PID1A27_PID1A53_2023-06-26_ASUS.zip
USB Audio FW Update Tool Version - 4.09 MB 2023/07/13
ROG CROSSHAIR/STRIX X670E Series Beta Bios 1512 (savedisk@overclock.net)
1) Update to AMD ComboAM5_1007b
2) Improve system performance
*Don't use .CMO files from old bios Need new setting
ROG CROSSHAIR X670E HERO Beta Bios 1512
ROG-CROSSHAIR-X670E-HERO-ASUS-1512.7z
drive.google.com
ROG CROSSHAIR X670E GENE Beta Bios 1512
ROG-CROSSHAIR-X670E-GENE-ASUS-1512.7z
drive.google.com
ROG CROSSHAIR X670E EXTREME Beta Bios 1512
ROG-CROSSHAIR-X670E-EXTREME-ASUS-1512.7z
drive.google.com
ROG STRIX X670E-A GAMING WIFI Beta Bios 1512
ROG-STRIX-X670E-A-GAMING-WIFI-ASUS-1512.7z
drive.google.com
ROG STRIX X670E-E GAMING WIFI Beta Bios 1512
ROG-STRIX-X670E-E-GAMING-WIFI-ASUS-1512.7z
drive.google.com
ROG STRIX X670E-F GAMING WIFI Beta Bios 1512
ROG-STRIX-X670E-F-GAMING-WIFI-ASUS-1512.7z
drive.google.com
ROG STRIX X670E-I GAMING WIFI Beta Bios 8012
ROG-STRIX-X670E-I-GAMING-WIFI-ASUS-8012.7z
drive.google.com
PROART X670E-CREATOR WIFI Beta Bios 1512
ProArt-X670E-CREATOR-WIFI-ASUS-1512.7z
drive.google.com
See less
Gast28082023
Ich habe ein Asus ProArt X670E... gehört dieses auch in diese Gruppe oder weniger? Wenn ja, ist für mich das Beobachten eine durchaus sinnmvolle Besschäftigung. Das ProArt scheint in der User- und Forenwelt recht selten vertreten zu sein.
Die ProArt hängen dazwischen, eigene "Reihe" wie Strix oder Crosshair. Das ProArt X670E hätte ich fast gekauft aber ist dann doch das Hero geworden.
Bei den BETA Bios die savedisk veröffentlicht ist das ProArt auch meist dabei wie auch die Strix X670.
Aber auch bei Fragen zu dem ProArt oder generell kannst du gerne auch den Thread hier benutzen.
Und das nächste BETA Bios, Benutzung auf eigene Gefahr
ROG CROSSHAIR/STRIX/PROART X670E Series Beta Bios 1514 (safedisk@oversclok.net)
ROG CROSSHAIR X670E HERO BETA BIOS 1514
ROG-CROSSHAIR-X670E-HERO-ASUS-1514.7z
drive.google.com
ROG CROSSHAIR X670E GENE BETA BIOS 1514
ROG-CROSSHAIR-X670E-GENE-ASUS-1514.7z
drive.google.com
ROG CROSSHAIR X670E EXTREME BETA BIOS 1514
ROG-CROSSHAIR-X670E-EXTREME-ASUS-1514.7z
drive.google.com
ROG STRIX X670E-A GAMING WIFI BETA BIOS 1514
ROG-STRIX-X670E-A-GAMING-WIFI-ASUS-1514.7z
drive.google.com
ROG STRIX X670E-E GAMING WIFI BETA BIOS 1514
ROG-STRIX-X670E-E-GAMING-WIFI-ASUS-1514.7z
drive.google.com
ROG STRIX X670E-F GAMING WIFI BETA BIOS 1514
ROG-STRIX-X670E-F-GAMING-WIFI-ASUS-1514.7z
drive.google.com
ROG STRIX X670E-I GAMING WIFI BETA BIOS 1632
ROG-STRIX-X670E-I-GAMING-WIFI-ASUS-1632.7z
drive.google.com
PROART X670E CREATOR WIFI BETA BIOS 1514
ProArt-X670E-CREATOR-WIFI-ASUS-1514.7z
drive.google.com
Gast28082023
Ich habe mir das ProArt gekauft, weil ich eigentlich außerhalb der Herstellerspezifikation keinerlei OC betreibe. Das Board muß mit "Auto"-Einstellungen stabil laufen. Das gleiche bei der Grafikkarte. Das Hero wäre dann zu viel des Guten gewesen. Zudem hätte es mich weitere 180€ mehr gekostet. 5k reicht für eine kleine Workstation zur Software-Entwicklung unter Linux. Man kann auch mit Kanonen auf spatzen schießen. Ich setze da einen 7950x drauf, 64GB RAM und zwei PCIe 4.0 SSD mit 2 ubd 4TB. Ich hab im Bereich Kühlung in den letzten Wochen schon ein Heidengeld ausgegeben. Die WaKü besteht hauptsächlich aus EKWB Teilen. Dazu eine Distroplate von AlphaCool. Und und und. Als einziges juckt noch der Alphacool Core 1 CPU-Kühler. Der soll um einigeds besser sein als mein guter alter EKWB Velocity 1 bzw. Heatkiller IV. Letzteren habe ich momentan auf meinen 3800x geschnallt. Wenn der EKWB mit dem 7950x probleme bekommt, probiere ich mal den Heatkiller IV auf dem 7950x aus.
Wenn man übertakten wollte wäre das auch mit dem ProArt kein Problem. Auch mit dem PCIe Slot finde ich es besser gelöst als beim Hero.
Ich sehe da wenige Unterschiede. ProArt bietet halt noch 10g LAN.
Verkehrt macht man mit beiden nichts außer das sie Teuer sind.
Die Vorteile vom Hero sind unter anderem die Audioausgänge, Resetknopf am ATX Panel, Segmentanzeige - Start/Reset Button auf dem Board.
Gast28082023
Ich arbeite mit dem Rechner und er muß Geld verdienen. Da sind dann die Investitionen machmal eher nebensächlich. Man hat einen anderen Blickwinkel auf die Materie. Da zählt zunächst die 24/7 Stabilität und dire Haltbarkeit weitaus mehr. Ich hab in meinem aktuellen Rechner ein Gigabyte Aorus Master in der Version 1.0 verbaut. Und der spinnt jetzt schon einige Monate herum. Es begann mit meinem DAC/KHV am optischen Audioausgang. Dann wollte er meine 2TB Daten SSD nicht mehr. Momentan spinnt er herum und bootet beim Start mehrfach. Da rennt dann das OS schon minuten und schwups sieht man unvermittelt einen Reboot. Ich nehme an, daß ich da ein BIOS Problem habe. Mein Zweitrechner mit einem X470 Asus Hero dagegen läuft stabil. Wenn mein neuer Dicker fertig ist, rüste ich den kleinen um.
Künftig bleibe ich lieber und besser bei Asus. Ich will, wie gesagt, ein stabiles Bios zum Arbeiten. Ich mache auch (schon aufgrund meiner Firma) viel mit 3D und 3D Druck inkl. 3D Scannen. Da wird einiges an Daten berechnet.Punktwolken mit mehreren millionen Einzelelementen sind bei mir keine Seltenheit. Da muß dann vom Einscannen bis zur Druckaufbereitung alles problemlos laufen. Und derartige Erfahrungen habe ich bisher mit Asus gemacht. Die Produkte der Marke kosten zwar zumeist etwas mehr, aber sie laufen, und das interessiert mich mehr, auch stabil.
- 7K
- 66K
- 52K
- 47K
