Award BIOS upgrade procedures
Download the new BIOS ROM file and upgrade utility - AWDFLASH.EXE, from our Web site or FTP site.
(Of course, you can use our new BIOS flash technology as Flasher . This function did availabled for our new boards.)
PS1. : Each BIOS and AWDFLASH file are compressed.
PS2. : Execute these files, then the BIOS and Flash Utility would de-compress themselves under Windows environment.
Turn the machine on and boot into DOS mode without CONFIG.SYS and AUTOEXEC.BAT.
Execute this commend as below under DOS prompt:
AWDFLASH.EXE xxxxxxxx.bin Or
AWDFLASH.EXE xxxxxxxx.pro Or
AWDFLASH.EXE xxxxxxxx.grd
PS1. :The extend file name did depend on which type ROM file (BIN or PRO or GRD) download by yourself.
User will get an prompt message: "Do You Want To Save BIOS (Y/N)?". Press "N" if you do not want to save the old Bios ROM to file.
User will get another prompt message: "Are you sure to program ?". Press "Y" for upgrading.
Reset the system while you have completed upgrade.
Press "Delete" to enter CMOS setup menu. User may select "LOAD SETUP DEFAULTS" and press "Y" to confirm.
User may select "SAVE & EXIT" to reboot the system.
