GPU-Z,Tool zur Analyse von Grafikkarten,ist verfügbar in eine neue Version :0.4.2.
Runterladen: techPowerUp! GPU-Z 0.4.2
Änderungen:
* Fixed an issue on all NVIDIA cards that would sometimes cause them to lose fan control when GPU-Z is running. Please don't run pre-0.4.2 and 0.4.2 at the same time, this might result in incorrect readings in the 0.4.2 window.
* Fixed system crash on MSI HD 5830 TwinFrozr II
* Validation upload now uses Unicode for entered name
* Reverted memory bandwidth calculation introduced in last version. It introduces too much confusion, we will go with what all companies use in their marketing material, even though we believe it is not correct. Using power of 10 again now, 1 GB/s = 1,000,000,000 Bytes per Second.
