Download AMD Radeon Software Adrenalin Edition 18.9.1 Beta verfügbar.
- Ersteller eratte
User-News
Von eratte
Hinweis: Diese "User-News" wurde nicht von der Planet 3DNow! Redaktion veröffentlicht, sondern vom oben genannten Leser, der persönlich für den hier veröffentlichten Inhalt haftet.Release Notes & Download
Filename z.B.: Win10-64Bit-Radeon-Software-Adrenalin-Edition-18.9.1-Sept12.exe
Radeon Software Adrenalin Edition 18.9.1 Highlights
Support For
Shadow of the Tomb Raider™
Star Control®: Origins
Fixed Issues
Radeon FreeSync may fail to enable when playing Monster Hunter™: World.
Radeon Settings may sometimes not appear in the right-click context menu on Windows® desktop after Radeon Software installation.
AMD Link may fail to connect on Android Pie devices due to authentication failures.
Radeon Settings may sometimes popup an error message due to Driver and Radeon Settings version mismatch.
Cursor or system lag may be observed on some system configurations when two or more displays are connected and one display is powered off.
Some DirectX®12 gaming applications may experience instability while recording with Radeon ReLive on system configurations using Radeon R9 290 and Radeon R9 390 series graphics products.
Known Issues
Some AMD Ryzen™ Desktop Processors with Radeon™ Vega Graphics system configurations may experience a black screen during installation downgrade to a previous Radeon Software version. A recommended workaround is to perform a clean install during Radeon Software installation.
Radeon RX Vega Series graphics products may experience elevated memory clocks during system idle.
System configurations with 16+ CPU cores may experience a random system reboot during installation when upgrading Radeon Software from a version older than RSAE 18.8.1. A clean installation is recommended when performing this Radeon Software upgrade.
Package Contents
The Radeon Software Adrenalin Edition 18.9.1 installation package contains the following:
Radeon Software Adrenalin Edition 18.9.1 Driver Version 18.30.17.01 (Windows Driver Store Version 24.20.13017.1009)
Radeon Product Compatibility
Radeon Software Adrenalin Edition 18.9.1 is compatible with the following AMD Radeon products.
Note: AMD Radeon™ R9 Fury, Radeon™ Pro Duo, Radeon™ RX 400 Series, Radeon™ RX 500 Series and Radeon™ RX Vega Series graphics are only supported by Radeon Software Adrenalin Edition on Windows 7/10 64-bit.
Radeon Desktop Product Family Compatibility
Radeon RX Vega Series Graphics
Radeon™ RX 500 Series Graphics
Radeon™ RX 400 Series Graphics
AMD Radeon™ Pro Duo
AMD Radeon™ R7 300 Series Graphics
AMD Radeon™ R7 200 Series Graphics
AMD Radeon™ R9 Fury Series Graphics
AMD Radeon™ R5 300 Series Graphics
AMD Radeon™ R9 Nano Series Graphics
AMD Radeon™ R5 200 Series Graphics
AMD Radeon™ R9 300 Series Graphics
AMD Radeon™ HD 8500 - HD 8900 Series Graphics
AMD Radeon™ R9 200 Series Graphics
AMD Radeon™ HD 7700 - HD 7900 Series Graphics
AMD Ryzen™ Desktop Processors with Radeon™ Vega Graphics Compatibility
Ryzen Desktop Processors with Radeon Vega Graphics are only supported by AMD Radeon Software Adrenalin Edition on Windows® 10 64-bit.
AMD Ryzen 5 2400G
AMD Ryzen 3 2200G
Mobility Radeon™ Family Compatibility
Radeon Software Adrenalin Edition 18.9.1 is a notebook reference graphics driver with limited support for system vendor specific features.
Radeon Mobility Product Family Compatibility
AMD Radeon™ R9 M300 Series Graphics
AMD Radeon™ R7 M200 Series Graphics
AMD Radeon™ R7 M300 Series Graphics
AMD Radeon™ R5 M200 Series Graphics
AMD Radeon™ R5 M300 Series Graphics
AMD Radeon™ HD 8500M - HD 8900M Series Graphics
AMD Radeon™ R9 M200 Series Graphics
AMD Radeon™ HD 7700M - HD 7900M Series Graphics
AMD APU Product Family Compatibility
AMD APU products are only supported by AMD Radeon Software Adrenalin Edition on Windows® 7 (32 & 64-bit) and Windows® 10 (32 & 64-bit).
Desktop
AMD A-Series APUs with Radeon™ R4, R5, R6, or R7 Graphics
AMD Pro A-Series APUs with Radeon™ R5 or R7 Graphics
AMD Athlon™ Series APUs with Radeon™ R3 Graphics
AMD Sempron™ Series APUs with Radeon™ R3 Graphics
Mobile
AMD A-Series APUs with Radeon™ R3, R4, R5, R6, R7, or R8 Graphics
AMD Pro A-Series APUs with Radeon™ R5, R6, or R7 Graphics
AMD FX-Series APUs with Radeon™ R7 Graphics
AMD E-Series APUs with Radeon™ R2 Graphics
AMD Radeon™ HD 8180 - HD 8400 Series Graphics
Compatible Operating Systems
Radeon Software Adrenalin Edition 18.9.1 is designed to support the following Microsoft® Windows® platforms. Operating System support may vary depending on your specific AMD Radeon product.
Windows® 10 (32 & 64-bit version)
Windows 7 (32 & 64-bit version with SP1 or higher)
Das volle "Programm" wird unterstützt und
soll behoben sein. Frohes testen.
Support For
Fixed Issues
Known Issues
Package Contents
AMD Radeon™ Pro Duo
AMD Ryzen 5 2400G
AMD Ryzen 3 2200G
Desktop
Mobile
psychocyberdisc
- Mystery Lake
- OMEN by HP Laptop 16-c0xxx
- 230 Watt
▼50 Mbit/s
▲25 Mbit/s
Taugen die Treiber denn eigentlich auch für die Vega-GPUs der mobilen Ryzen-Prozessoren? Diese wurden in der Aufzählung bisher noch kein einziges Mal erwähnt.
Unbekannter Krieger
- 4x4 GiB Hynix DDR3-1866 ECC
- TSST SH-222AL
- Win8.x x64, Win7 x64
Das ist eine hervorragende und -stechende Frage. Über eine Antwort würde ich mich enorm freuen.
psychocyberdisc
- Mystery Lake
- 230 Watt
▼50 Mbit/s
▲25 Mbit/s
Ja, oder? Weshalb verliert AMD seit Monaten kein Wort über die aktuellen APUs für mobile Geräte?
Finster.
Finster.
Habe ich noch keine Infos zu gelesen, ggf werden die Treiber nur über den Gerätehersteller angeboten.
Krümel
- Schleswig-Holstein
- Rosetta, WCG, Einstein
- POEM *schnüff* R.I.P.
- AMD Ryzen R9 7900x3D
- Asus TUF B650-M Plus WiFi
- Noctua NH-U12S
- AMD RX 6700XT
- LG BR
- Onboardsound
- Fractal Design Define R4
- Win 10 / Pop!_OS
▼1000
In der Beschreibung steht zwar, dass der Treiber auch für die R5-Serie geeignet sein soll, ist er aber nicht wirklich.
Nach der Installation kann man nur noch 4:3 Seitenverhältnisse auswählen.
Der letzte Treiber der die (uralt) R5-Serie voll unterstützt scheint der erste Crimson-Beta zu sein.
psychocyberdisc
- Mystery Lake
- 230 Watt
▼50 Mbit/s
▲25 Mbit/s
Krümel,
möglicherweise bist du auf dem völlig falschen Dampfer?
Mit R5 ist keineswegs die Radeon HD 5000 (Evergreen) aus dem Jahr 2009 gemeint. Der letzte offizielle Treiber für diese Reihe ist der Catalyst 15.7.1 von Anfang August 2015. Dessen Installationspakete sind im Oktober 2017 übrigens zum wiederholten Male erneuert worden.
Der letzte inoffizielle Treiber ist in der Tat der Radeon Software Crimson Edition 16.2.1 vom 1. März 2016. Auch dessen Installationspakete sind später ausgetauscht worden, nämlich im September 2017.
https://www.amd.com/en/support/graphics/amd-radeon-hd/ati-radeon-hd-5000-series/ati-radeon-hd-5870
Seit ein paar Jahren bezeichnet AMD die Grafikeinheiten der APUs bspw. als AMD Radeon R2, AMD Radeon R4 oder AMD Radeon R8. In der APU meines Notebooks steckt eine AMD Radeon R7.
https://en.wikipedia.org/wiki/List_of_AMD_accelerated_processing_unit_microprocessors
Seit etwa 2,5 Jahren werden nur noch diese Produkte unterstützt:
Radeon R7 240 bis Radeon R9 295X2,
Radeon R5 240 (OEM),
Radeon HD 8570 bis Radeon HD 8970,
Radeon HD 8xxxM,
Radeon HD 7730 bis Radeon HD 7990,
Radeon HD 7730M bis Radeon HD 7970M
und neuer
Krümel
- Noctua NH-U12S
- AMD RX 6700XT
- LG BR
- Onboardsound
- Win 10 / Pop!_OS
▼1000
Ich meine diesse Radeon R5 230. Caicos PRO - Radeon R5 230 "TeraScale"
Und in den Release Notes steht:
AMD Radeon™ Pro Duo
Daher nam ich an, dass der neue auch für meine "alte" gilt (die es immer noch zu kaufen gibt, neu).
AMD Radeon™ Pro Duo
psychocyberdisc
- Mystery Lake
- 230 Watt
▼50 Mbit/s
▲25 Mbit/s
Gut, die Radeon R5 230 kam zwar erst im Frühjahr 2014 auf den Markt, allerdings stammt der noch in 40 nm produzierte Chip aus dem Jahr 2010. Im Prinzip ist das eine polierte Radeon HD 5450.
Demnach kommen als Treiber nur der klassische Catalyst 15.7.1 (mit Catalyst Control Center) oder der Radeon Software Crimson Edition 16.2.1 (mit Radeon Settings) infrage.
Radeon R5 235X (OEM),
Radeon R5 235 (OEM),
Radeon R5 230,
Radeon R5 230 (OEM),
Radeon R5 220 (OEM),
Radeon HD 8xxxD,
Radeon HD 8xxxG,
Radeon HD 8350 bis Radeon HD 84x0,
Radeon HD 7xxxD,
Radeon HD 7xxxG,
Radeon HD 7350 bis Radeon HD 7670,
Radeon HD 7430M bis Radeon HD 7690M XT,
Radeon HD 6xxxD,
Radeon HD 6xxxG,
Radeon HD 6xxx,
Radeon HD 6xxxM,
Radeon HD 5xxx,
Radeon HD 5xxxM
Es gibt btw Gerüchte das es bald keine neuen 32 Bit Treiber mehr gibt - wenn nur Sicherheitsupdates.
Unbekannter Krieger
- TSST SH-222AL
@psychocyberdisc
Wie es an anderer/anderen Stelle hier im Forum verlinkt wurde, werden für die mobilen Vega-iGPUs die Pakete 18.7.1
https://h30434.www3.hp.com/t5/Noteb...en-Crashes/m-p/6773350/highlight/true#M248805 (diverse Wortmeldungen ab dort)
sowie 18.8.1 empfohlen.
https://www.youtube.com/watch?v=FFuosuPKDNA
Falls nötig, kann man versuchen, sich auf derartige (ähnliche) Weise an der INF zu schaffen zu machen:
https://www.reddit.com/r/Amd/commen...0_vega_8_with_adrenalin_1811_drivers/dtjlorz/
skelletor
- Dresden
- einheimische Projekte
- Ryzen 7 5800X3D
- MSI X570-A Pro
- beQuiet DarkRock TF
- AMD Radeon 6900XT
- 1x 4TB WesternDigital Red
- Pioneer BluRay Brenner
- noname
- Seasonic X650 (80+ Gold)
- Swiftpoint Z
- Windows 10 Home 64bit
juhuuuu kein Cursor Lag mehr Danke fürs hervorheben - werde ich heute Abend gleich mal testen.
gruß,
skell.
Edit: Kann bestätigen: Kein Gehakel mehr mit der Maus! Halleluja, hat ja lang gedauert...
gruß,
skell.
psychocyberdisc
- Mystery Lake
- 230 Watt
▼50 Mbit/s
▲25 Mbit/s
Der Treiber ist aktualisiert worden.
https://www.amd.com/en/support/apu/...a12-apu-for-laptops/7th-gen-amd-pro-a12-9800b
